[PATCHES v2] Add more i.MX6UL/ULL support
Christian Mauderer
christian.mauderer at embedded-brains.de
Wed Apr 15 15:30:33 UTC 2020
On 15/04/2020 15:56, Gedare Bloom wrote:
> Yes, go ahead and push them in.
Thanks. I pushed them. But now I have a small problem: I wanted to
update RSB to use the new versions (Chris said in another mail that it
should be up to date that near to a release). But I noted that I have no
idea what format is used for the hash. Currently
rtems/config/tools/rtems-kernel-5.cfg contains the following:
%define rtems_kernel_version 01219541289e8081054d4a57924ee169339f1eaf
%hash sha512 rtems-kernel-%{rtems_kernel_version}.tar.bz2 \
qJIBYkdFGRROoJlkmxRk5Ugr2IcrcWIlXH5FfuE88mecUkDDy4JBtFDXcH0YzjwyrpmlFSaaaK850nb4o89ZCA==
That's definitively not an unprocessed output of sha512sum. Can someone
help me?
Best regards
Christian
> On Wed, Apr 15, 2020 at 12:07 AM Christian Mauderer
> <christian.mauderer at embedded-brains.de> wrote:
>> On 15/04/2020 07:06, Sebastian Huber wrote:
>>> Hello Christian,
>>> the patch set looks good (except maybe "[PATCH rtems-libbsd v2 09/14]
>>> bus-dma, imx: Don't sync nocache area.").
>> Thanks.
>> Chris, Gedare, Joel: Would it be OK for you if I push the patches before
>> the release?
>> Best regards
>> Christian
>> embedded brains GmbH
>> Herr Christian Mauderer
>> Dornierstr. 4
>> D-82178 Puchheim
>> Germany
>> email: christian.mauderer at embedded-brains.de
>> Phone: +49-89-18 94 741 - 18
>> Fax: +49-89-18 94 741 - 08
>> PGP: Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
Dornierstr. 4
D-82178 Puchheim
Germany
