[PATCHES v2] Add more i.MX6UL/ULL support
Gedare Bloom
gedare at rtems.org
Wed Apr 15 16:23:46 UTC 2020
On Wed, Apr 15, 2020 at 9:31 AM Christian Mauderer
<christian.mauderer at embedded-brains.de> wrote:
> On 15/04/2020 15:56, Gedare Bloom wrote:
> > Yes, go ahead and push them in.
> Thanks. I pushed them. But now I have a small problem: I wanted to
> update RSB to use the new versions (Chris said in another mail that it
> should be up to date that near to a release). But I noted that I have no
> idea what format is used for the hash. Currently
> rtems/config/tools/rtems-kernel-5.cfg contains the following:
> %define rtems_kernel_version 01219541289e8081054d4a57924ee169339f1eaf
> %hash sha512 rtems-kernel-%{rtems_kernel_version}.tar.bz2 \
> qJIBYkdFGRROoJlkmxRk5Ugr2IcrcWIlXH5FfuE88mecUkDDy4JBtFDXcH0YzjwyrpmlFSaaaK850nb4o89ZCA==
> That's definitively not an unprocessed output of sha512sum. Can someone
> help me?
Use rtems-source-builder/source-builder/sha512-base64
> Best regards
> Christian
> > On Wed, Apr 15, 2020 at 12:07 AM Christian Mauderer
> >> On 15/04/2020 07:06, Sebastian Huber wrote:
> >>> Hello Christian,
> >>> the patch set looks good (except maybe "[PATCH rtems-libbsd v2 09/14]
> >>> bus-dma, imx: Don't sync nocache area.").
> >> Thanks.
> >> Chris, Gedare, Joel: Would it be OK for you if I push the patches before
> >> the release?
> >> Best regards
> >> Christian
> >> embedded brains GmbH
> >> Herr Christian Mauderer
> >> Dornierstr. 4
> >> D-82178 Puchheim
> >> Germany
> >> email: christian.mauderer at embedded-brains.de
> >> Phone: +49-89-18 94 741 - 18
> >> Fax: +49-89-18 94 741 - 08
> >> PGP: Public key available on request.
> >> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
> Dornierstr. 4
> D-82178 Puchheim
> Germany
