[PATCHES v2] Add more i.MX6UL/ULL support
Christian Mauderer oss at c-mauderer.de
Wed Apr 15 18:45:35 UTC 2020
Hello Gedare,
On 15/04/2020 18:23, Gedare Bloom wrote:
> On Wed, Apr 15, 2020 at 9:31 AM Christian Mauderer
> <christian.mauderer at embedded-brains.de> wrote:
>> On 15/04/2020 15:56, Gedare Bloom wrote:
>>> Yes, go ahead and push them in.
>> Thanks. I pushed them. But now I have a small problem: I wanted to
>> update RSB to use the new versions (Chris said in another mail that it
>> should be up to date that near to a release). But I noted that I have no
>> idea what format is used for the hash. Currently
>> rtems/config/tools/rtems-kernel-5.cfg contains the following:
>> %define rtems_kernel_version    01219541289e8081054d4a57924ee169339f1eaf
>> %hash sha512 rtems-kernel-%{rtems_kernel_version}.tar.bz2 \
>> qJIBYkdFGRROoJlkmxRk5Ugr2IcrcWIlXH5FfuE88mecUkDDy4JBtFDXcH0YzjwyrpmlFSaaaK850nb4o89ZCA==
>> That's definitively not an unprocessed output of sha512sum. Can someone
>> help me?
> Use rtems-source-builder/source-builder/sha512-base64
Thanks for that.
I've updated the RSB to use the latest patches.
>> Best regards
>> Christian
>>> On Wed, Apr 15, 2020 at 12:07 AM Christian Mauderer
>>>> On 15/04/2020 07:06, Sebastian Huber wrote:
>>>>> Hello Christian,
>>>>> the patch set looks good (except maybe "[PATCH rtems-libbsd v2 09/14]
>>>>> bus-dma, imx: Don't sync nocache area.").
>>>> Thanks.
>>>> Chris, Gedare, Joel: Would it be OK for you if I push the patches before
>>>> the release?
>>>> Best regards
>>>> Christian
>>>> embedded brains GmbH
>>>> Herr Christian Mauderer
>>>> Dornierstr. 4
>>>> D-82178 Puchheim
>>>> Germany
>>>> email: christian.mauderer at embedded-brains.de
>>>> Phone: +49-89-18 94 741 - 18
>>>> Fax:   +49-89-18 94 741 - 08
>>>> PGP: Public key available on request.
>>>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>> Dornierstr. 4
>> D-82178 Puchheim
>> Germany
> devel mailing list
> devel at rtems.org
