[PATCH rtems-libbsd v2 12/14] ehci_imx: Add to build.
Christian Mauderer christian.mauderer at embedded-brains.de
Thu Apr 16 07:41:52 UTC 2020
On 16/04/2020 09:21, Vijay Kumar Banerjee wrote:
> On Thu, Apr 16, 2020 at 12:41 PM Christian Mauderer
> <christian.mauderer at embedded-brains.de
> <mailto:christian.mauderer at embedded-brains.de>> wrote:
>     Hello Vijay,
>     On 16/04/2020 09:04, Vijay Kumar Banerjee wrote:
>     > Hi Christian,
>     > I'm not able to build libbsd with this patch. I'm getting the
>     following
>     > error:
>     > ../../freebsd/sys/dev/usb/controller/ehci_imx.c:70:10: fatal error:
>     > arm/freescale/imx/imx_ccmvar.h: No such file or directory
>     >  #include <arm/freescale/imx/imx_ccmvar.h>
>     > From git blame I got to know that this file was introduced by the
>     commit
>     > from this patch.
>     > Am I missing something or is it really a bug?
>     Thanks for the report. On what BSP and which exact commit did you try to
>     build? I had no trouble building the patch set from a clean checkout
>     yesterday before committing it.
> I did a pull from the upstream master and tried the build on
> arm/beagleboneblack
> I see that the header file is not present in the freebsd/ directory
> rtems-libbsd $>find -iname imx_ccmvar.h
> ./freebsd-org/sys/arm/freescale/imx/imx_ccmvar.h
Hello Vijay,
that's quite clearly a bug that I introduced. I'll create a patch.
The imx_ccmvar.h is a file that is provided by the BSP I used for testing.
Best regards
Christian
>     > Sorry for commenting on the patch that has already been committed,
>     > please let me know of
>     > the preferred way to comment on a commit if this is not the right way.
>     No problem. That's exactly the right way to do it. If there is a bug it
>     has to be solved and everyone should know that someone is having a look
>     at it.
>     Best regards
>     Christian
>     > Best regards,
>     > Vijay
>     > On Tue, Apr 14, 2020 at 8:21 PM Christian Mauderer
>     <mailto:christian.mauderer at embedded-brains.de>>> wrote:
>     >      libbsd.py                            | 2 ++
>     >      rtemsbsd/include/bsp/nexus-devices.h | 5 +++++
>     >      2 files changed, 7 insertions(+)
>     >     diff --git a/libbsd.py b/libbsd.py
>     >     index 4f8fb4d2..ed6493b2 100644
>     >     --- a/libbsd.py
>     >     +++ b/libbsd.py
>     >     @@ -5028,6 +5028,8 @@ class imx(builder.Module):
>     >              self.addKernelSpaceSourceFiles(
>     >                      'sys/arm/freescale/imx/imx6_ccm.c',
>     >     +                'sys/arm/freescale/imx/imx6_usbphy.c',
>     >     +                'sys/dev/usb/controller/ehci_imx.c',
>     >                  mm.generator['source']()
>     >     diff --git a/rtemsbsd/include/bsp/nexus-devices.h
>     >     b/rtemsbsd/include/bsp/nexus-devices.h
>     >     index 0a210bd9..d2ceab8e 100644
>     >     --- a/rtemsbsd/include/bsp/nexus-devices.h
>     >     +++ b/rtemsbsd/include/bsp/nexus-devices.h
>     >     @@ -128,6 +128,11 @@ RTEMS_BSD_DEFINE_NEXUS_DEVICE(ofwbus, 0,
>     0, NULL);
>     >      SYSINIT_DRIVER_REFERENCE(simplebus, ofwbus);
>     >      SYSINIT_DRIVER_REFERENCE(ccm, simplebus);
>     >     +SYSINIT_DRIVER_REFERENCE(ehci, simplebus);
>     >     +SYSINIT_DRIVER_REFERENCE(usbphy, simplebus);
>     >     +SYSINIT_DRIVER_REFERENCE(usbus, ehci);
>     >     +RTEMS_BSD_DRIVER_USB;
>     >     +RTEMS_BSD_DRIVER_USB_MASS;
>     >      SYSINIT_DRIVER_REFERENCE(ffec, simplebus);
>     >      SYSINIT_DRIVER_REFERENCE(ukphy, miibus);
>     >     2.16.4
>     >     _______________________________________________
>     >     devel mailing list
>     >     devel at rtems.org <mailto:devel at rtems.org>
>     <mailto:devel at rtems.org <mailto:devel at rtems.org>>
>     >     http://lists.rtems.org/mailman/listinfo/devel
>     embedded brains GmbH
>     Herr Christian Mauderer
>     Dornierstr. 4
>     D-82178 Puchheim
>     Germany
>     email: christian.mauderer at embedded-brains.de
>     Phone: +49-89-18 94 741 - 18
>     Fax:   +49-89-18 94 741 - 08
>     PGP: Public key available on request.
>     Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
Dornierstr. 4
D-82178 Puchheim
Germany
