[PATCH rtems-libbsd v2 12/14] ehci_imx: Add to build.
Christian Mauderer
christian.mauderer at embedded-brains.de
Thu Apr 16 08:21:44 UTC 2020
On 16/04/2020 09:41, Christian Mauderer wrote:
> On 16/04/2020 09:21, Vijay Kumar Banerjee wrote:
>> On Thu, Apr 16, 2020 at 12:41 PM Christian Mauderer
>> <christian.mauderer at embedded-brains.de
>> <mailto:christian.mauderer at embedded-brains.de>> wrote:
>> Hello Vijay,
>> On 16/04/2020 09:04, Vijay Kumar Banerjee wrote:
>> > Hi Christian,
>> > I'm not able to build libbsd with this patch. I'm getting the
>> following
>> > error:
>> > ../../freebsd/sys/dev/usb/controller/ehci_imx.c:70:10: fatal error:
>> > arm/freescale/imx/imx_ccmvar.h: No such file or directory
>> > #include <arm/freescale/imx/imx_ccmvar.h>
>> > From git blame I got to know that this file was introduced by the
>> commit
>> > from this patch.
>> > Am I missing something or is it really a bug?
>> Thanks for the report. On what BSP and which exact commit did you try to
>> build? I had no trouble building the patch set from a clean checkout
>> yesterday before committing it.
>> I did a pull from the upstream master and tried the build on
>> arm/beagleboneblack
>> I see that the header file is not present in the freebsd/ directory
>> rtems-libbsd $>find -iname imx_ccmvar.h
>> ./freebsd-org/sys/arm/freescale/imx/imx_ccmvar.h
> Hello Vijay,
> that's quite clearly a bug that I introduced. I'll create a patch.
> The imx_ccmvar.h is a file that is provided by the BSP I used for testing.
> Best regards
> Christian
I've sent a patch. Can you test it?
>> > Sorry for commenting on the patch that has already been committed,
>> > please let me know of
>> > the preferred way to comment on a commit if this is not the right way.
>> No problem. That's exactly the right way to do it. If there is a bug it
>> has to be solved and everyone should know that someone is having a look
>> at it.
>> Best regards
>> Christian
>> > Best regards,
>> > Vijay
>> > On Tue, Apr 14, 2020 at 8:21 PM Christian Mauderer
>> <mailto:christian.mauderer at embedded-brains.de>>> wrote:
>> > libbsd.py | 2 ++
>> > rtemsbsd/include/bsp/nexus-devices.h | 5 +++++
>> > 2 files changed, 7 insertions(+)
>> > diff --git a/libbsd.py b/libbsd.py
>> > index 4f8fb4d2..ed6493b2 100644
>> > --- a/libbsd.py
>> > +++ b/libbsd.py
>> > @@ -5028,6 +5028,8 @@ class imx(builder.Module):
>> > self.addKernelSpaceSourceFiles(
>> > 'sys/arm/freescale/imx/imx6_ccm.c',
>> > + 'sys/arm/freescale/imx/imx6_usbphy.c',
>> > + 'sys/dev/usb/controller/ehci_imx.c',
>> > mm.generator['source']()
>> > diff --git a/rtemsbsd/include/bsp/nexus-devices.h
>> > b/rtemsbsd/include/bsp/nexus-devices.h
>> > index 0a210bd9..d2ceab8e 100644
>> > --- a/rtemsbsd/include/bsp/nexus-devices.h
>> > +++ b/rtemsbsd/include/bsp/nexus-devices.h
>> > @@ -128,6 +128,11 @@ RTEMS_BSD_DEFINE_NEXUS_DEVICE(ofwbus, 0,
>> 0, NULL);
>> > SYSINIT_DRIVER_REFERENCE(simplebus, ofwbus);
>> > SYSINIT_DRIVER_REFERENCE(ccm, simplebus);
>> > +SYSINIT_DRIVER_REFERENCE(ehci, simplebus);
>> > +SYSINIT_DRIVER_REFERENCE(usbphy, simplebus);
>> > +SYSINIT_DRIVER_REFERENCE(usbus, ehci);
>> > +RTEMS_BSD_DRIVER_USB;
>> > +RTEMS_BSD_DRIVER_USB_MASS;
>> > SYSINIT_DRIVER_REFERENCE(ffec, simplebus);
>> > SYSINIT_DRIVER_REFERENCE(ukphy, miibus);
>> > 2.16.4
>> > _______________________________________________
>> > devel mailing list
>> > devel at rtems.org <mailto:devel at rtems.org>
>> <mailto:devel at rtems.org <mailto:devel at rtems.org>>
>> > http://lists.rtems.org/mailman/listinfo/devel
>> embedded brains GmbH
>> Herr Christian Mauderer
>> Dornierstr. 4
>> D-82178 Puchheim
>> Germany
>> email: christian.mauderer at embedded-brains.de
>> Phone: +49-89-18 94 741 - 18
>> Fax: +49-89-18 94 741 - 08
>> PGP: Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
Dornierstr. 4
D-82178 Puchheim
Germany
