[PATCH rtems v2] bsps/arm: Fix uninitialized value in generic timer
Christian Mauderer
christian.mauderer at embedded-brains.de
Fri Apr 17 06:34:59 UTC 2020
Hello Gedare,
On 16/04/2020 21:16, Gedare Bloom wrote:
> You can push this to 5.1, update the ticket milestone if you do.
Thanks. In that case I most likely should create an extra ticket. I'm
not sure whether Sebastian sees that one as close enough to finished to
be a 5.1 ticket. For me it was a fix for the feature in progress and
therefore I updated that ticket.
Best regards
Christian
> On Thu, Apr 16, 2020 at 9:27 AM Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
>> On 16/04/2020 15:29, Christian Mauderer wrote:
>>> _CPU_Counter_frequency() can be called by the rtems_counter
>>> initialization before arm_gt_clock_initialize() initializes the value
>>> used in _CPU_Counter_frequency().
>>> Update #3456.
>> Thanks, looks good.
>> devel mailing list
>> devel at rtems.org
embedded brains GmbH
Herr Christian Mauderer
Dornierstr. 4
D-82178 Puchheim
Germany
Phone: +49-89-18 94 741 - 18
Fax: +49-89-18 94 741 - 08
PGP: Public key available on request.
