[PATCH rtems v2] bsps/arm: Fix uninitialized value in generic timer
Gedare Bloom
gedare at rtems.org
Fri Apr 17 17:34:44 UTC 2020
OK I would prefer to have it close a ticket on 5.1 that addresses the
fact it was a latent bug. I'm not sure how to feel about having
commits made prior to cutting a release, that update tickets for
milestones after the release. I suppose it is just a minor annoyance
to me.
On Fri, Apr 17, 2020 at 12:35 AM Christian Mauderer
<christian.mauderer at embedded-brains.de> wrote:
> Hello Gedare,
> On 16/04/2020 21:16, Gedare Bloom wrote:
> > You can push this to 5.1, update the ticket milestone if you do.
> Thanks. In that case I most likely should create an extra ticket. I'm
> not sure whether Sebastian sees that one as close enough to finished to
> be a 5.1 ticket. For me it was a fix for the feature in progress and
> therefore I updated that ticket.
> Best regards
> Christian
> > On Thu, Apr 16, 2020 at 9:27 AM Sebastian Huber
> > <sebastian.huber at embedded-brains.de> wrote:
> >> On 16/04/2020 15:29, Christian Mauderer wrote:
> >>> _CPU_Counter_frequency() can be called by the rtems_counter
> >>> initialization before arm_gt_clock_initialize() initializes the value
> >>> used in _CPU_Counter_frequency().
> >>> Update #3456.
> >> Thanks, looks good.
> >> _______________________________________________
> >> devel mailing list
> >> devel at rtems.org
> >> http://lists.rtems.org/mailman/listinfo/devel
> embedded brains GmbH
> Herr Christian Mauderer
> Dornierstr. 4
> D-82178 Puchheim
> Germany
> email: christian.mauderer at embedded-brains.de
> Phone: +49-89-18 94 741 - 18
> Fax: +49-89-18 94 741 - 08
> PGP: Public key available on request.
