[PATCH v5 0/7] [5-freebsd-12] Fix compilation for i386
Jan.Sommer at dlr.de Jan.Sommer at dlr.de
Fri Apr 17 12:01:02 UTC 2020
Thank you.
I will see, that we prepare a similar patch set for the master branch as well.
Have a nice week-end,
   Jan
> -----Original Message-----
> From: Sebastian Huber [mailto:sebastian.huber at embedded-brains.de]
> Sent: Friday, April 17, 2020 1:20 PM
> To: Sommer, Jan; devel at rtems.org
> Subject: Re: [PATCH v5 0/7] [5-freebsd-12] Fix compilation for i386
> On 17/04/2020 10:24, Jan Sommer wrote:
> > This is the  backport for the 5-freebsd-12 branch to make rtems-libbsd
> compile for i386 again:
> > - It also introduces path-mappings to waf_libbsd.py as introduced here:
> > https://lists.rtems.org/pipermail/devel/2020-February/057457.html
> > Changes compared to v4:
> > - Split up the changes in more reasonable commits
> > - header files in rtemsbsd/include/x86 are now only stubs forwarding to
> >    the correct file
> > Changes compared to v3:
> > - iflib.c: Properly deactivate usage of ifc_cpus
> > - subr_gtaskqueue.c: Deactivate BSD_ASSERT for i386 (will open a
> >    discussion for that)
> > - Could successfully run network tests (e.g. dhcpcd0x.exe on hardware)
> > Changes compared to v2:
> > - callout.h: Change the callout_reset_on macro
> > - iflib.c: Do not use different callout* macro, but use the changed one
> Thanks, I checked in v5 of the patch set with a minor modification in
> patch 7.
