FreeBSD 12 Failures - Py_Initialize: can't initialize sys standard streams
Joel Sherrill
joel at rtems.org
Fri Apr 17 16:16:34 UTC 2020
After some Google searching and talking to Chris, I modified my nohup
command that starts the script to add "</dev/null". It is still running now
and reporting results.
I don't know how to capture this info and the fact that removing gcc from
the FreeBSD 12 test machine to improve the results.
--joel
On Wed, Apr 15, 2020 at 9:04 AM Joel Sherrill <joel at rtems.org> wrote:
> Hi
> I see this type of failure on rtems-tools and rtems-tester. I run nohup'ed
> and I suspect these happen after the connection is dropped. I see what I
> think is discussion of similar issues here:
> https://bugs.python.org/issue32849
> I don't see this on Linux although in that issue report, it was
> reproducible there.
> + cd rtems-tools-ca7b290f94a19238ed068aad229854cf67dee9b5
> + ./waf distclean configure '--prefix=/home/joel/rtems-cron-5/tools/5'
> Fatal Python error: Py_Initialize: can't initialize sys standard streams
> OSError: [Errno 9] Bad file descriptor
> Current thread 0x00000008009e2000 (most recent call first):
> Abort trap (core dumped)
> shell cmd failed: /bin/sh -ex
> /usr/home/joel/rtems-cron-5/rtems-source-builder/
> rtems/build/rtems-tools-ca7b290f94a19238ed068aad229854cf67dee9b5-1/do-build
> error: building rtems-tools-ca7b290f94a19238ed068aad229854cf67dee9b5-1
> I also see this in my script that builds a bsp individually and then uses
> rtems-tester:
> time: command terminated abnormally
> I have everything nohup'ed and redirected to files which shouldn't be a
> big surprise.
> --joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200417/cff05455/attachment.html>
