FreeBSD 12 Failures - Py_Initialize: can't initialize sys standard streams
Joel Sherrill
joel at rtems.org
Wed Apr 15 14:04:20 UTC 2020
Hi
I see this type of failure on rtems-tools and rtems-tester. I run nohup'ed
and I suspect these happen after the connection is dropped. I see what I
think is discussion of similar issues here:
https://bugs.python.org/issue32849
I don't see this on Linux although in that issue report, it was
reproducible there.
+ cd rtems-tools-ca7b290f94a19238ed068aad229854cf67dee9b5
+ ./waf distclean configure '--prefix=/home/joel/rtems-cron-5/tools/5'
Fatal Python error: Py_Initialize: can't initialize sys standard streams
OSError: [Errno 9] Bad file descriptor
Current thread 0x00000008009e2000 (most recent call first):
Abort trap (core dumped)
shell cmd failed: /bin/sh -ex
/usr/home/joel/rtems-cron-5/rtems-source-builder/
rtems/build/rtems-tools-ca7b290f94a19238ed068aad229854cf67dee9b5-1/do-build
error: building rtems-tools-ca7b290f94a19238ed068aad229854cf67dee9b5-1
I also see this in my script that builds a bsp individually and then uses
rtems-tester:
time: command terminated abnormally
I have everything nohup'ed and redirected to files which shouldn't be a big
surprise.
--joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200415/d21756f2/attachment.html>
