[PATCH v4] Tests for pthread_getcpuclockid method. Ticket:3891
Eshan dhawan
eshandhawan51 at gmail.com
Sat Apr 18 20:17:06 UTC 2020
The patch is the test for pthread_getcpuclockid.
The patch will not run since there is no support for pthread_cpuclockid in clock_gettime function
the patch compiled with no errors
It is tested against the patch https://lists.rtems.org/pipermail/devel/2020-March/058176.html
Can you all review it and check if it is logically correct?
and what changes are required for it to be pushed
-Eshan
testsuites/psxtests/Makefile.am | 9 +
testsuites/psxtests/configure.ac | 1 +
testsuites/psxtests/psxgetcpuclockid01/init.c | 161 ++++++++++++++++++
.../psxgetcpuclockid01/psxgetcpuclockid01.doc | 23 +++
.../psxgetcpuclockid01/psxgetcpuclockid01.scn | 4 +
5 files changed, 198 insertions(+)
create mode 100644 testsuites/psxtests/psxgetcpuclockid01/init.c
create mode 100644 testsuites/psxtests/psxgetcpuclockid01/psxgetcpuclockid01.doc
create mode 100644 testsuites/psxtests/psxgetcpuclockid01/psxgetcpuclockid01.scn
diff --git a/testsuites/psxtests/Makefile.am b/testsuites/psxtests/Makefile.am
index 1f9e4233ec..7924bbea5d 100755
--- a/testsuites/psxtests/Makefile.am
+++ b/testsuites/psxtests/Makefile.am
@@ -462,6 +462,15 @@ psxgetattrnp01_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psxgetattrnp01) \
$(support_includes) -I$(top_srcdir)/include
endif
+if TEST_psxgetcpuclockid01
+psx_tests += psxgetcpuclockid01
+psx_screens += psxgetcpuclockid01/psxgetcpuclockid01.scn
+psx_docs += psxgetcpuclockid01/psxgetcpuclockid01.doc
+psxgetcpuclockid01_SOURCES = psxgetcpuclockid01/init.c
+psxgetcpuclockid01_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psxgetcpuclockid01) \
+ $(support_includes)
+endif
if TEST_psxgetrusage01
psx_tests += psxgetrusage01
psx_screens += psxgetrusage01/psxgetrusage01.scn
diff --git a/testsuites/psxtests/configure.ac b/testsuites/psxtests/configure.ac
index 139787cccb..c509086abc 100644
--- a/testsuites/psxtests/configure.ac
+++ b/testsuites/psxtests/configure.ac
@@ -91,6 +91,7 @@ RTEMS_TEST_CHECK([psxfile01])
RTEMS_TEST_CHECK([psxfile02])
RTEMS_TEST_CHECK([psxfilelock01])
RTEMS_TEST_CHECK([psxgetattrnp01])
+RTEMS_TEST_CHECK([psxgetcpuclockid01])
RTEMS_TEST_CHECK([psxgetrusage01])
RTEMS_TEST_CHECK([psxglobalcon01])
RTEMS_TEST_CHECK([psxglobalcon02])
diff --git a/testsuites/psxtests/psxgetcpuclockid01/init.c b/testsuites/psxtests/psxgetcpuclockid01/init.c
new file mode 100644
index 0000000000..938ff39e71
--- /dev/null
+++ b/testsuites/psxtests/psxgetcpuclockid01/init.c
@@ -0,0 +1,161 @@
+ * @file
+ * @brief Test suite for getcpuclockid methods
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2020 Eshan Dhawan, Vaibhav Gupta
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <errno.h>
+#include <pthread.h>
+#include <stdint.h>
+#include <stdio.h>
+#include <string.h>
+#include <rtems.h>
+#include <rtems/timespec.h>
+#include <rtems/test.h>
+#include <time.h>
+#include <unistd.h>
+#include "tmacros.h"
+#include "test_support.h"
+const char rtems_test_name[] = "PSXGETCPUCLOCKID 1";
+/* Forward declaration to avoid warnings */
+void *POSIX_Init (void * argument);
+void *test_pthread(void *);
+/* test_pthread function begins */
+void *test_pthread(void *arg)
+ int i;
+ /*do something*/
+ for( i = 0; i < 200000; i++ );
+ pthread_exit(0);
+ return NULL;
+/* init test function begins */
+ TEST_BEGIN();
+ int r;
+ clockid_t cid;
+ pthread_t thread_id;
+ struct timespec start_cpu, start_wall, finish;
+ struct timespec time_passed_wall, time_passed_cpu ;
+ bool result ;
+ /* setting the timespecs to zero */
+ rtems_timespec_zero( &start_cpu );
+ rtems_timespec_zero( &start_wall );
+ rtems_timespec_zero( &finish );
+ rtems_timespec_zero( &time_passed_wall );
+ rtems_timespec_zero( &time_passed_cpu );
+ /* getting the cpu_clock_id of the thread */
+ r = pthread_getcpuclockid( pthread_self(), &cid );
+ if ( r ) {
+ printf( "pthread_getcpuclockid : %s (%d) \n", strerror(r), r );
+ rtems_test_assert( r == 0 );
+ /* getting the strat cpu time of the pthread */
+ r = clock_gettime( cid, &start_cpu );
+ if ( r ) {
+ printf( "clock_gettime : %s (%d) \n", strerror(r), r );
+ /* starting the wall time */
+ r = clock_gettime( CLOCK_MONOTONIC, &start_wall );
+ if ( r ) {
+ /* starting the loop for .5 seconds of wall time passed */
+ while (1) {
+ /* getting the wall time */
+ clock_gettime( CLOCK_MONOTONIC, &finish );
+ /* calculating the time elapsed */
+ rtems_timespec_subtract( &start_wall, &finish, &time_passed_wall );
+ if(time_passed_wall.tv_nsec >= 500000000 || time_passed_wall.tv_sec >= 0.5 ){
+ break;
+ /* getting the end cpu clock time */
+ clock_gettime( cid, &finish );
+ /* calculating the cpu time elapsed */
+ rtems_timespec_subtract( &start_cpu, &finish, &time_passed_cpu );
+ /* comparing the wall and cpu times*/
+ /* cpu time should be greater then the wall time */
+ result = rtems_timespec_less_than( &time_passed_wall, &time_passed_cpu );
+ /* checking the result */
+ if( !result )
+ printf( "CPU time elapsed is less than the wall time" );
+ rtems_test_assert( result );
+ /* creating a pthread to chech for ESRCH Exeption */
+ r= pthread_create( &thread_id, NULL, test_pthread, NULL );
+ if( r ) {
+ printf( "pthread_create : %s (%d)\n", strerror(r), r );
+ /* joinin the pthread to make the thread_id invalid */
+ r = pthread_join( thread_id, NULL );
+ if( r ) {
+ printf( "pthread_join : %s (%d)\n", strerror(r), r );
+ /* checking the ESRCH Exeption */
+ r = pthread_getcpuclockid( thread_id, &cid );
+ if( r != ESRCH ) {
+ rtems_test_assert( r == ESRCH );
+ TEST_END();
+ rtems_test_exit(0);
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
+#define CONFIGURE_MAXIMUM_POSIX_THREADS 2
+#define CONFIGURE_MAXIMUM_TASKS 1
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#define CONFIGURE_POSIX_INIT_THREAD_TABLE
+#include <rtems/confdefs.h>
diff --git a/testsuites/psxtests/psxgetcpuclockid01/psxgetcpuclockid01.doc b/testsuites/psxtests/psxgetcpuclockid01/psxgetcpuclockid01.doc
index 0000000000..ef148182d5
--- /dev/null
+++ b/testsuites/psxtests/psxgetcpuclockid01/psxgetcpuclockid01.doc
@@ -0,0 +1,23 @@
+# COPYRIGHT (c) 2020
+# On-Line Applications Research Corporation (OAR).
+# SPDX-License-Identifier: BSD-2-Clause
+This file describes the directives and concepts tested by this test set.
+test set name: psxgetcpuclockid 1
+Directives:
+ Pthread_getcpuclockid()
+Concepts:
++ This test exercises the getcpuclockid methods.
++ For pthread_getcpuclockid it created a pthread using pthread_create and
+ then finds the clockid_t of that thread then used gettime() add a pause of .5 seconds
+ and then ends the thread.
+ After the thread is ended it again tried to find the clockid_t of the thread to
+ check for ESRCH exception.
diff --git a/testsuites/psxtests/psxgetcpuclockid01/psxgetcpuclockid01.scn b/testsuites/psxtests/psxgetcpuclockid01/psxgetcpuclockid01.scn
index 0000000000..937a908fd5
--- /dev/null
+++ b/testsuites/psxtests/psxgetcpuclockid01/psxgetcpuclockid01.scn
@@ -0,0 +1,4 @@
+*** BEGIN OF TEST PSXGETCLOCKID 1 ***
+*** END OF TEST PSXGETCPUCLOCKID 1 ***
2.17.1
