Small doubt in a build time warning of sp test of leon3
Joel Sherrill
joel at rtems.org
Sun Apr 19 17:22:02 UTC 2020
On Sun, Apr 19, 2020, 9:59 AM Richi Dubey <richidubey at gmail.com> wrote:
> Hey everyone,
> In the Covid Code-in update by Dr. Joel, he mentioned that the RTEMS could
> use some help to remove warnings from the code. In the link(
> https://ftp.rtems.org/pub/rtems/people/joel/warnings/warnings-5-20200408/warnings-all-5-20200408.txt)
> of warnings for RTEMS 5, one of the warning is:
> log/sparc-leon3.log:../../../../../../rtems/c/src/../../testsuites/sptests/sp37/init.c:172:21:
> warning: unused variable 'name' [-Wunused-variable]
> warning: 'name' defined but not used [-Wunused-const-variable=]
> On opening init.c from ~/quick-start/src/rtems/testsuites/sptests/sp37/.
> Lines 172 to 175 are:
> static const char name[] = "test";
> ISR_Level normal_interrupt_level = _ISR_Get_level();
> ISR_lock_Control initialized = ISR_LOCK_INITIALIZER( name );
> ISR_lock_Control zero_initialized;
> We can see that the name variable is being used in line 174(and later on 3
> more times, outside any conditional blocks). Why would Dr. Joel get such a
> warning then?
Does ISR_LOCK_INITIALIZER actually use the name? It possibly only uses it
when RTEMS_DEBUG is enabled. Check that.
> Thanks,
> Richi.
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200419/c1b52bf1/attachment-0001.html>
