Small doubt in a build time warning of sp test of leon3
Richi Dubey
richidubey at gmail.com
Wed Apr 22 13:06:31 UTC 2020
Dear Dr. Joel,
Thank you for your reply. I did a grep on the root rtems folder and I came
to know that ISR_LOCK_INITIALIZER is being used by intr.h and isrlock.h
inside leon3's include directory. It includes various macros like :
#if defined( RTEMS_SMP )
#define ISR_LOCK_INITIALIZER( _name ) \
and
#define RTEMS_INTERRUPT_LOCK_INITIALIZER( _name ) ISR_LOCK_INITIALIZER(
_name )
I couldn't find the implementation of the function ISR_LOCK_INITIALIZER( )
anywhere. Is there a isrlock.c present somewhere? I couldn't find any
helpful references for RTEMS_INTERRUPT_LOCK_INITIALIZER too. Am i missing
something?
Please let me know.
Thanks,
Richi.
On Sun, Apr 19, 2020 at 10:52 PM Joel Sherrill <joel at rtems.org> wrote:
> On Sun, Apr 19, 2020, 9:59 AM Richi Dubey <richidubey at gmail.com> wrote:
>> Hey everyone,
>> In the Covid Code-in update by Dr. Joel, he mentioned that the RTEMS
>> could use some help to remove warnings from the code. In the link(
>> https://ftp.rtems.org/pub/rtems/people/joel/warnings/warnings-5-20200408/warnings-all-5-20200408.txt)
>> of warnings for RTEMS 5, one of the warning is:
>> log/sparc-leon3.log:../../../../../../rtems/c/src/../../testsuites/sptests/sp37/init.c:172:21:
>> warning: unused variable 'name' [-Wunused-variable]
>> warning: 'name' defined but not used [-Wunused-const-variable=]
>> On opening init.c from ~/quick-start/src/rtems/testsuites/sptests/sp37/.
>> Lines 172 to 175 are:
>> static const char name[] = "test";
>> ISR_Level normal_interrupt_level = _ISR_Get_level();
>> ISR_lock_Control initialized = ISR_LOCK_INITIALIZER( name );
>> ISR_lock_Control zero_initialized;
>> We can see that the name variable is being used in line 174(and later on
>> 3 more times, outside any conditional blocks). Why would Dr. Joel get such
>> a warning then?
> Does ISR_LOCK_INITIALIZER actually use the name? It possibly only uses it
> when RTEMS_DEBUG is enabled. Check that.
>> Thanks,
>> Richi.
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200422/86ae86af/attachment.html>
