Doorstop Issues
Mon Apr 20 05:12:54 UTC 2020
On 20/4/20 1:14 am, Sebastian Huber wrote:
> Hello,
> I am about to add the next couple of hundred specification items for the
> RTEMS pre-qualification activity. Before I do this, I would like to
> present some issues that popped up during my daily work with Doorstop.
> Doorstop is a requirements management tool which was selected for the
> pre-qualification activity:
> https://docs.rtems.org/branches/master/eng/req-eng.html#selected-tool-doorstop
> I am quite happy that Jan Sommer suggested to use this tool. I has some
> pretty nice features. In particular, I think the file based organization
> in YAML format forming a directed acyclic graph is really the right
> thing for this project. However, it turned out that it lacks the
> required flexibility.
> 1. Its use case is requirements management. So it has some standard
> attributes useful in this domain, like derived, header, level,
> normative, ref, reviewed, and text. However, I want to use it more
> generally for specification items and these attributes make not always
> sense. Having them in every item is just overhead and may cause confusion.
> 2. The links cannot have custom attributes, e.g. role, enabled-by.
> 3. Inside a document (directory) items are supposed to have a common
> type. I would like to store at a hierarchy level also distinct
> specializations.
> 4. The verification if the items is quite limited. We need verification
> with type-based rules.
> 5. The UIDs in combination with the document hierarchy lead to
> duplication, e.g. a/b/c/a-b-c-d.yml. You have the path (a/b/c) also in
> the file name (a-b-c). You cannot have relative UIDs in links (e.g.
> ../parent-req) . The specification items may contain multiple
> requirements, e.g. min/max attributes. There is no way to identify them.
> I will probably stop using Doorstop and use a custom tooling.
Have you discussed these issues with the Doorstop project?
> With
> Python, this is quite easy. I already have the infrastructure for this in:
> https://git.rtems.org/sebh/rtems-qual.git/
Why not place the tool in the rtems-tools repo? This repo exists for
this purpose.
> I will try this out with the new build system.
I suppose this is something else in the queue to review....
