Doorstop Issues
Sun Apr 19 15:14:02 UTC 2020
Hello,
I am about to add the next couple of hundred specification items for the
RTEMS pre-qualification activity. Before I do this, I would like to
present some issues that popped up during my daily work with Doorstop.
Doorstop is a requirements management tool which was selected for the
pre-qualification activity:
https://docs.rtems.org/branches/master/eng/req-eng.html#selected-tool-doorstop
I am quite happy that Jan Sommer suggested to use this tool. I has some
pretty nice features. In particular, I think the file based organization
in YAML format forming a directed acyclic graph is really the right
thing for this project. However, it turned out that it lacks the
required flexibility.
1. Its use case is requirements management. So it has some standard
attributes useful in this domain, like derived, header, level,
normative, ref, reviewed, and text. However, I want to use it more
generally for specification items and these attributes make not always
sense. Having them in every item is just overhead and may cause confusion.
2. The links cannot have custom attributes, e.g. role, enabled-by.
3. Inside a document (directory) items are supposed to have a common
type. I would like to store at a hierarchy level also distinct
specializations.
4. The verification if the items is quite limited. We need verification
with type-based rules.
5. The UIDs in combination with the document hierarchy lead to
duplication, e.g. a/b/c/a-b-c-d.yml. You have the path (a/b/c) also in
the file name (a-b-c). You cannot have relative UIDs in links (e.g.
../parent-req) . The specification items may contain multiple
requirements, e.g. min/max attributes. There is no way to identify them.
I will probably stop using Doorstop and use a custom tooling. With
Python, this is quite easy. I already have the infrastructure for this in:
https://git.rtems.org/sebh/rtems-qual.git/
I will try this out with the new build system.
