[PATCH rtems v2] bsps/arm: Fix uninitialized value in generic timer
Christian Mauderer
christian.mauderer at embedded-brains.de
Mon Apr 20 07:10:31 UTC 2020
On 17/04/2020 19:34, Gedare Bloom wrote:
> OK I would prefer to have it close a ticket on 5.1 that addresses the
> fact it was a latent bug. I'm not sure how to feel about having
> commits made prior to cutting a release, that update tickets for
> milestones after the release. I suppose it is just a minor annoyance
> to me.
I created a separate ticket, closed that ticket with the commit and
pushed it.
Best regards
Christian
> On Fri, Apr 17, 2020 at 12:35 AM Christian Mauderer
> <christian.mauderer at embedded-brains.de> wrote:
>> Hello Gedare,
>> On 16/04/2020 21:16, Gedare Bloom wrote:
>>> You can push this to 5.1, update the ticket milestone if you do.
>> Thanks. In that case I most likely should create an extra ticket. I'm
>> not sure whether Sebastian sees that one as close enough to finished to
>> be a 5.1 ticket. For me it was a fix for the feature in progress and
>> therefore I updated that ticket.
>> Best regards
>> Christian
>>> On Thu, Apr 16, 2020 at 9:27 AM Sebastian Huber
>>> <sebastian.huber at embedded-brains.de> wrote:
>>>> On 16/04/2020 15:29, Christian Mauderer wrote:
>>>>> _CPU_Counter_frequency() can be called by the rtems_counter
>>>>> initialization before arm_gt_clock_initialize() initializes the value
>>>>> used in _CPU_Counter_frequency().
>>>>> Update #3456.
>>>> Thanks, looks good.
>>>> _______________________________________________
>>>> devel mailing list
>>>> devel at rtems.org
>>>> http://lists.rtems.org/mailman/listinfo/devel
>> embedded brains GmbH
>> Herr Christian Mauderer
>> Dornierstr. 4
>> D-82178 Puchheim
>> Germany
>> email: christian.mauderer at embedded-brains.de
>> Phone: +49-89-18 94 741 - 18
>> Fax: +49-89-18 94 741 - 08
>> PGP: Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
Dornierstr. 4
D-82178 Puchheim
Germany
