[PATCH] Test for clock_nanosleep() with CLOCK_MONOTONIC option.
Utkarsh Rai utkarsh.rai60 at gmail.com
Tue Apr 21 10:29:22 UTC 2020
Rationale for a new test-
>Although most of the test cases for this test have been taken from clockrealtime,
adding it to the current test with CLOCK_MONOTONIC may break the existing cases.
>This test has a new case which tests for no change of delay with monotonic clock when
the realtime clock has been modified, this is easier to add in a new test.
 testsuites/psxtests/Makefile.am               |  10 +
 testsuites/psxtests/configure.ac              |   1 +
 testsuites/psxtests/psxclocknanosleep/init.c  | 182 ++++++++++++++++++
 .../psxclocknanosleep/psxclocknanosleep.doc   |  15 ++
 .../psxclocknanosleep/psxclocknanosleep.scn   |  14 ++
 5 files changed, 222 insertions(+)
 create mode 100644 testsuites/psxtests/psxclocknanosleep/init.c
 create mode 100644 testsuites/psxtests/psxclocknanosleep/psxclocknanosleep.doc
 create mode 100644 testsuites/psxtests/psxclocknanosleep/psxclocknanosleep.scn
diff --git a/testsuites/psxtests/Makefile.am b/testsuites/psxtests/Makefile.am
index 1f9e4233ec..ad6e41b400 100755
--- a/testsuites/psxtests/Makefile.am
+++ b/testsuites/psxtests/Makefile.am
@@ -312,6 +312,16 @@ psxclock01_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psxclock01) \
 	$(support_includes) -I$(top_srcdir)/include
 endif
+if TEST_psxclocknanosleep
+psx_tests += psxclocknanosleep
+psx_screens += psxclocknanosleep/psxclocknanosleep.scn
+psx_docs += psxclockrealtime01/psxclocknanosleep.doc
+psxclocknanosleep_SOURCES = psxclocknanosleep/init.c
+psxclocknanosleep_CPPFLAGS = $(AM_CPPFLAGS) \
+	$(TEST_FLAGS_psxclocknanosleep) $(support_includes)
+endif
 if TEST_psxclockrealtime01
 psx_tests += psxclockrealtime01
 psx_screens += psxclockrealtime01/psxclockrealtime01.scn
diff --git a/testsuites/psxtests/configure.ac b/testsuites/psxtests/configure.ac
index 139787cccb..52b5e1624b 100644
--- a/testsuites/psxtests/configure.ac
+++ b/testsuites/psxtests/configure.ac
@@ -75,6 +75,7 @@ RTEMS_TEST_CHECK([psxcleanup01])
 RTEMS_TEST_CHECK([psxcleanup02])
 RTEMS_TEST_CHECK([psxclock])
 RTEMS_TEST_CHECK([psxclock01])
+RTEMS_TEST_CHECK([psxclocknanosleep])
 RTEMS_TEST_CHECK([psxclockrealtime01])
 RTEMS_TEST_CHECK([psxconcurrency01])
 RTEMS_TEST_CHECK([psxcond01])
diff --git a/testsuites/psxtests/psxclocknanosleep/init.c b/testsuites/psxtests/psxclocknanosleep/init.c
new file mode 100644
index 0000000000..15e3ff396a
--- /dev/null
+++ b/testsuites/psxtests/psxclocknanosleep/init.c
@@ -0,0 +1,182 @@
+ *  Copyright (c) 2020 Utkarsh Rai.
+ *  The license and distribution terms for this file may be
+ *  found in the file LICENSE in this distribution or at
+ *  http://www.rtems.org/license/LICENSE.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <errno.h>
+#include <limits.h>
+#include <rtems.h>
+#include <time.h>
+#include <tmacros.h>
+static void assert_eno(const char *hint, int eno, int expected_eno)
+  const char *warn;
+  if (eno != expected_eno) {
+    warn = "WARNING: ";
+  } else {
+    warn = "";
+  printf(
+    "%s%s: actual '%s', expected '%s'\n",
+    warn,
+    hint,
+    strerror(eno),
+    strerror(expected_eno)
+  rtems_test_assert( eno == expected_eno );
+static void assert_rv(const char *hint, int rv, int expected_eno)
+  int eno;
+  if (rv != 0) {
+    eno = EINVAL;
+  } else {
+    eno = 0;
+  assert_eno(hint, eno, expected_eno);
+typedef enum {
+  MODE_TIMEOUT_FINITE,
+  MODE_TIMEOUT_NEGATIVE_SEC,
+  MODE_TIMEOUT_NEGATIVE_NSEC,
+  MODE_TIMEOUT_NEGATIVE_SEC_NSEC,
+  MODE_TIMEOUT_HUGE_NSEC,
+  MODE_TIMEOUT_CLOCK_MODIFY
+} test_mode;
+static void run(test_mode mode, const char* test_name)
+ struct timespec  delay_time;
+ struct timespec  configure_time;
+ int     rv;
+ int     expected_eno;
+ switch (mode) {
+ case MODE_TIMEOUT_FINITE:
+   rv = clock_gettime( CLOCK_MONOTONIC, &delay_time );
+   rtems_test_assert( rv == 0 );
+   delay_time.tv_sec += 1;
+   delay_time.tv_nsec += 1;
+   expected_eno = ETIMEDOUT;
+   break;
+ case MODE_TIMEOUT_HUGE_NSEC:
+   delay_time.tv_sec = 1;
+   delay_time.tv_nsec = LONG_MAX;
+   expected_eno = EINVAL;
+   break;
+ case MODE_TIMEOUT_NEGATIVE_NSEC:
+   delay_time.tv_nsec = -1;
+   break;
+ case MODE_TIMEOUT_NEGATIVE_SEC_NSEC:
+   delay_time.tv_sec = -1;
+   break;
+ case MODE_TIMEOUT_NEGATIVE_SEC:
+   delay_time.tv_nsec = 1;
+   break;
+ case MODE_TIMEOUT_CLOCK_MODIFY:
+   rv = clock_gettime( CLOCK_REALTIME, &configure_time );
+   configure_time.tv_sec += INT64_MAX;
+   rv = clock_settime( CLOCK_REALTIME, &configure_time );
+   break;
+ default:
+   rtems_test_assert(0);
+   break;
+ printf("*******%s*********\n", test_name);
+ rv = clock_nanosleep( CLOCK_MONOTONIC, TIMER_ABSTIME, &delay_time, NULL );
+ if (expected_eno == ETIMEDOUT) {
+          assert_rv( "clock_nanosleep(clock monotonic)", rv, 0 );
+        } else {
+          assert_rv( "clock_nanosleep(clock monotonic)", rv, expected_eno );
+static void timeout_finite(void)
+    run ( MODE_TIMEOUT_FINITE, "timeout finite" );
+static void timeout_huge_nsec(void)
+    run( MODE_TIMEOUT_HUGE_NSEC, "timeout huge nsec" );
+static void timeout_negative_nsec(void)
+    run( MODE_TIMEOUT_NEGATIVE_NSEC, "timeout negative nsec" );
+static void timeout_negative_sec_nsec(void)
+    run( MODE_TIMEOUT_NEGATIVE_SEC_NSEC, "timeout negative sec nsec" );
+static void timeout_negative_sec(void)
+    run( MODE_TIMEOUT_NEGATIVE_SEC, "timeout negative sec" );
+static void timeout_clock_modify(void)
+    run( MODE_TIMEOUT_CLOCK_MODIFY, "timeout clock modify" );
+const char rtems_test_name[] = "PSXCLOCKNANOSLEEP";
+static rtems_task Init(rtems_task_argument ignored)
+  TEST_BEGIN();
+  timeout_finite();
+  timeout_huge_nsec();
+  timeout_negative_sec_nsec();
+  timeout_negative_nsec();
+  timeout_negative_sec();
+  timeout_clock_modify();
+  TEST_END();
+  rtems_test_exit(0);
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#define CONFIGURE_MAXIMUM_TASKS  1
+#define CONFIGURE_INIT
+#include <rtems/confdefs.h>
\ No newline at end of file
diff --git a/testsuites/psxtests/psxclocknanosleep/psxclocknanosleep.doc b/testsuites/psxtests/psxclocknanosleep/psxclocknanosleep.doc
index 0000000000..a87874c627
--- /dev/null
+++ b/testsuites/psxtests/psxclocknanosleep/psxclocknanosleep.doc
@@ -0,0 +1,15 @@
+This file describes the directives and concepts tested by this test set.
+test set name: psxclocknanosleep
+directives:
+  - clock_nanosleep()
+concepts:
+  - Test some invalid and extreme timeout values.
+  - Ensure that the CLOCK_MONOTONIC based delay is not effected by changes to
+    CLOCK_REALTIME
diff --git a/testsuites/psxtests/psxclocknanosleep/psxclocknanosleep.scn b/testsuites/psxtests/psxclocknanosleep/psxclocknanosleep.scn
index 0000000000..af803c8b14
--- /dev/null
+++ b/testsuites/psxtests/psxclocknanosleep/psxclocknanosleep.scn
@@ -0,0 +1,14 @@
+*** BEGIN OF TEST PSXCLOCKNANOSLEEP ***
+*******timeout finite*********
+clock_nanosleep(clock monotonic): actual 'Success', expected 'Success'
+*******timeout huge nsec*********
+clock_nanosleep(clock monotonic): actual 'Invalid argument', expected 'Invalid argument'
+*******timeout negative sec nsec*********
+*******timeout negative nsec*********
+*******timeout negative sec*********
+*******timeout clock modify*********
+*** END OF TEST PSXCLOCKNANOSLEEP ***
2.17.1
