fdt_rw.c: Unchecked return value (CID #1047324) (#3947)
Sebastian Huber
Tue Apr 21 11:42:12 UTC 2020
On 21/04/2020 13:24, Christian Mauderer wrote:
> On 21/04/2020 11:57, Utkarsh Rai wrote:
>> As is suggested in the ticket<https://devel.rtems.org/ticket/3947> I
>> checked for return value checking in the upstream and it is not present.
>> Should I send a patch that checks for the error value (FDT_END)?
>> devel mailing list
>> devel at rtems.org
> Hello Utkarsh,
> libfdt is an imported package. Therefore it might would be a good idea
> to take a look at the upstream code whether it has been fixed and pull
> in that fix (assuming it still has a compatible license).
> If it isn't fixed upstream: Feel free to send patches that improve the
> code base. Again a special case: Maybe think about sending the same
> patch to the upstream sources if the problem still exists there.
Yes, please. This needs to get fixed in the upstream. With the
instructions in
https://git.rtems.org/rtems/tree/cpukit/dtc/VERSION
it is easy to keep in sync with the upstream.
