porting aio.h to newlib
Eshan Dhawan
eshandhawan51 at gmail.com
Tue Apr 21 17:07:33 UTC 2020
On Tue, Apr 21, 2020 at 4:32 AM Joel Sherrill <joel at rtems.org> wrote:
> On Mon, Apr 20, 2020 at 5:11 PM Eshan Dhawan <eshandhawan51 at gmail.com>
> wrote:
>> hello everyone,
>> RTEMS has the implementation of aio.h.
>> But for simplicity it needs to be shifted to newlib.
>> where would be the header file added and
>> where would be the source code files added??
>> Also what would be the other changes that would be required to setup the
>> methods ??
> You wouldn't be porting the aio implementation to newlib, just moving the
> .h file.
> The implementation is very RTEMS specific and there is no reason to move
> it since it can't be shared.
> If our aio.h is portable enough to apply to other environments, then it
> can go in the main include directory of newlib.
> If not, then it goes under an RTEMS specific directory.
> Do you think it is portable or RTEMS specific in its contents?
It seems to be portable and not RTEMS specific. So it can be added to the
main include folder.
> And before it is moved, we may want to make a sweep to update the D7 page
> numbers. That is like a 1993 paper draft of POSIX. :)
Could you elaborate this part, please?
-Eshan
> --joel
>> Thanks:)
>> -Eshan
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200421/b643b5ce/attachment.html>
