Release task request for help
Niteesh G. S. niteesh.gs at gmail.com
Thu Apr 23 06:42:39 UTC 2020
Hello Chris,
> Message: 4
> Date: Thu, 23 Apr 2020 14:35:12 +1000
> From: Chris Johns <chrisj at rtems.org>
> To: RTEMS Devel <rtems-devel at rtems.org>
> Subject: Release task request for help
> Message-ID: <7976c497-cff1-7c73-f673-596dd831c478 at rtems.org>
> Content-Type: text/plain; charset=utf-8; format=flowed
> Hello,
> I need a script to be used in the release process and I was wondering if
> a GSoC student would be able to help.
I am willing to help with this. I went through the docs you mentioned.
I also had a look at the rtems-release-tag script.
I have a question, why is it shell script instead of python?
> The release process is started by branching all the required repos.
> These are listed in the Software Engineering manual ...
> https://docs.rtems.org/branches/master/eng/release-process.html#release-repositories
> I need a script along the lines of the `rtems-release-tag` script called
> `rtems-release-branch` that will branch with a push all the release
> repositories.
> If you are interested in helping please let me know. The doco here ..
> ... should provide a context.
> Thanks
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200423/01401853/attachment.html>
