[PATCH] Removes build time warning for all smp-disabled bsps
Richi Dubey richidubey at gmail.com
Thu Apr 23 13:23:25 UTC 2020
Hey everyone,
I made this small change and rebuilt the leon32 bsp. It stopped
showing the earlier warnings:
 log/sparc-leon3.log:../../../../../../rtems/c/src/../../testsuites/sptests/sp37/init.c:172:21:
warning: unused variable 'name' [-Wunused-variable]
warning: 'name' defined but not used [-Wunused-const-variable=]
Can someone please check and let me know if this is correct and would
work or not.
Thanks.
>From c9eb205f37aa575a01ef446db3d7b4e34e1a1fae Mon Sep 17 00:00:00 2001
Date: Thu, 23 Apr 2020 18:38:56 +0530
Subject: [PATCH 2/2] Added smp check
 testsuites/sptests/sp37/init.c | 2 ++
 1 file changed, 2 insertions(+)
diff --git a/testsuites/sptests/sp37/init.c b/testsuites/sptests/sp37/init.c
index 22c7d4f2ef..3b79682fa1 100644
--- a/testsuites/sptests/sp37/init.c
+++ b/testsuites/sptests/sp37/init.c
@@ -169,7 +169,9 @@ static void test_isr_level( void )
 static void test_isr_locks( void )
+#if defined( RTEMS_SMP )
   static const char name[] = "test";
+#endif
   ISR_Level normal_interrupt_level = _ISR_Get_level();
   ISR_lock_Control initialized = ISR_LOCK_INITIALIZER( name );
   ISR_lock_Control zero_initialized;
2.17.1
