[PATCH] Removes build time warning for all smp-disabled bsps
Thu Apr 23 18:12:16 UTC 2020
Although this fixes the warning in the testsuite, it is hackish to
require users to copy this kind of conditional compilation to their
code, and I don't really like how it looks personally. I might prefer
Joel's approach, but applied to the test, e.g.,
static const char name[] = "test";
(void) name;
Alternatively, you might think about other approaches that might be
more user-friendly.  What about using ISR_LOCK_DEFINE() to declare the
initializer variable?
What about passing the string literal directly without a variable container?
On Thu, Apr 23, 2020 at 7:23 AM Richi Dubey <richidubey at gmail.com> wrote:
> Hey everyone,
> I made this small change and rebuilt the leon32 bsp. It stopped
> showing the earlier warnings:
>  log/sparc-leon3.log:../../../../../../rtems/c/src/../../testsuites/sptests/sp37/init.c:172:21:
> warning: unused variable 'name' [-Wunused-variable]
> warning: 'name' defined but not used [-Wunused-const-variable=]
> Can someone please check and let me know if this is correct and would
> work or not.
> Thanks.
> From c9eb205f37aa575a01ef446db3d7b4e34e1a1fae Mon Sep 17 00:00:00 2001
> From: Richi Dubey <richidubey at gmail.com>
> Date: Thu, 23 Apr 2020 18:38:56 +0530
> Subject: [PATCH 2/2] Added smp check
>  testsuites/sptests/sp37/init.c | 2 ++
>  1 file changed, 2 insertions(+)
> diff --git a/testsuites/sptests/sp37/init.c b/testsuites/sptests/sp37/init.c
> index 22c7d4f2ef..3b79682fa1 100644
> --- a/testsuites/sptests/sp37/init.c
> +++ b/testsuites/sptests/sp37/init.c
> @@ -169,7 +169,9 @@ static void test_isr_level( void )
>  static void test_isr_locks( void )
> +#if defined( RTEMS_SMP )
> +#endif
>    ISR_Level normal_interrupt_level = _ISR_Get_level();
>    ISR_lock_Control initialized = ISR_LOCK_INITIALIZER( name );
>    ISR_lock_Control zero_initialized;
> 2.17.1
> devel mailing list
> devel at rtems.org
