Small doubt in a build time warning of sp test of leon3
Richi Dubey
richidubey at gmail.com
Thu Apr 23 13:24:43 UTC 2020
Dear Dr. Sherill and Huber,
Thanks a lot for your help. I have made a patch and sent it on devel.
Please check it out.
On Thu, Apr 23, 2020 at 12:28 AM Joel Sherrill <joel at rtems.org> wrote:
> On Wed, Apr 22, 2020 at 1:55 PM Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
>> On 22/04/2020 16:12, Joel Sherrill wrote:
>> > the code I added is an accepted idiom for telling the compiler a
>> > variable or parameter is used for its analysis purposes. Does this
>> > make sense?
>> > diff --git a/cpukit/include/rtems/score/isrlock.h
>> > b/cpukit/include/rtems/score/i
>> > index 14ea88b..52645a3 100644
>> > --- a/cpukit/include/rtems/score/isrlock.h
>> > +++ b/cpukit/include/rtems/score/isrlock.h
>> > @@ -147,7 +147,7 @@ typedef struct {
>> > { SMP_LOCK_INITIALIZER( _name ) }
>> > #else
>> > #define ISR_LOCK_INITIALIZER( _name ) \
>> > + { (void) (_name); }
>> > #endif
>> For a function-like macro it would be all right, however, this if an
>> initializer macro. I guess this test needs some #ifdef RTEMS_SMP to fix
>> the warnings.
> Yeah. I didn't actually compile it. It looked like a function macro
> and terminated for uniprocessor systems like that. Other cases
> may need indicate something else.
> Just another example of how warnings can look easy. :)
> --joel
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
