[PATCH 1/1] Removed aio.h form cpukit/include and added to newlib
Eshan dhawan
eshandhawan51 at gmail.com
Thu Apr 23 18:55:48 UTC 2020
This posix header was in RTEMS and for simplicity had to be
shifted to newlib
The implementation of the aio.h still stays in posix/src but the
header is shifted to newlib/libc/include
Closes #3676
Signed-off-by: Eshan dhawan <eshandhawan51 at gmail.com>
cpukit/headers.am | 1 -
cpukit/include/aio.h | 193 -------------------------------------------
2 files changed, 194 deletions(-)
delete mode 100644 cpukit/include/aio.h
diff --git a/cpukit/headers.am b/cpukit/headers.am
index 185e3b8e38..8bf0e56a26 100644
--- a/cpukit/headers.am
+++ b/cpukit/headers.am
@@ -1,5 +1,4 @@
## This file was generated by "./boostrap -H".
-include_HEADERS += include/aio.h
include_HEADERS += include/crypt.h
include_HEADERS += include/dlfcn.h
include_HEADERS += include/endian.h
diff --git a/cpukit/include/aio.h b/cpukit/include/aio.h
deleted file mode 100644
index 95ed0fdb6c..0000000000
--- a/cpukit/include/aio.h
+++ /dev/null
@@ -1,193 +0,0 @@
- * @file
- * @brief POSIX Asynchronous Input and Output
- * This file contains the definitions related to POSIX Asynchronous
- * Input and Output,
- * COPYRIGHT (c) 1989-2011.
- * On-Line Applications Research Corporation (OAR).
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
-#ifndef _AIO_H
-#define _AIO_H
-#include <sys/cdefs.h>
-#include <unistd.h>
-#ifdef __cplusplus
-extern "C" {
-#endif
- * @defgroup POSIX_AIO POSIX Asynchronous I/O Support
- * @ingroup POSIXAPI
-#if defined(_POSIX_ASYNCHRONOUS_IO)
- * 6.7.1 Data Definitions for Asynchronous Input and Output,
- * P1003.1b-1993, p. 151
-#include <sys/types.h>
-#include <signal.h>
-#include <time.h>
-#include <fcntl.h>
- * 6.7.1.2 Manifest Constants, P1003.1b-1993, p. 153
-#define AIO_CANCELED 0 /* all requested operations have been canceled */
-#define AIO_NOTCANCELED 1 /* some of the operations could not be canceled */
- /* since they are in progress */
-#define AIO_ALLDONE 2 /* none of the requested operations could be */
- /* canceled since they are already complete */
-/* lio_listio() options */
- * LIO modes
-#define LIO_WAIT 0 /* calling process is to suspend until the */
- /* operation is complete */
-#define LIO_NOWAIT 1 /* calling process is to continue execution while */
- /* the operation is performed and no notification */
- /* shall be given when the operation is completed */
- * LIO opcodes
-#define LIO_NOP 0 /* no transfer is requested */
-#define LIO_READ 1 /* request a read() */
-#define LIO_WRITE 2 /* request a write() */
-#define LIO_SYNC 3 /* needed by aio_fsync() */
- * 6.7.1.1 Asynchronous I/O Control Block, P1003.1b-1993, p. 151
-struct aiocb {
- /* public */
- int aio_fildes; /* File descriptor */
- off_t aio_offset; /* File offset */
- volatile void *aio_buf; /* Location of buffer */
- size_t aio_nbytes; /* Length of transfer */
- int aio_reqprio; /* Request priority offset */
- struct sigevent aio_sigevent; /* Signal number and value */
- int aio_lio_opcode; /* Operation to be performed */
- /* private */
- int error_code; /* Used for aio_error() */
- ssize_t return_value; /* Used for aio_return() */
- * 6.7.2 Asynchronous Read, P1003.1b-1993, p. 154
-int aio_read(
- struct aiocb *aiocbp
- * 6.7.3 Asynchronous Write, P1003.1b-1993, p. 155
-int aio_write(
- * 6.7.4 List Directed I/O, P1003.1b-1993, p. 158
-int lio_listio(
- int mode,
- struct aiocb *__restrict const list[__restrict],
- int nent,
- struct sigevent *__restrict sig
- * 6.7.5 Retrieve Error of Asynchronous I/O Operation, P1003.1b-1993, p. 161
-int aio_error(
- const struct aiocb *aiocbp
- * 6.7.6 Retrieve Return Status of Asynchronous I/O Operation,
- * P1003.1b-1993, p. 162
-ssize_t aio_return(
- * @brief Cancel asynchronous I/O operation.
- * 6.7.7 Cancel Asynchronous I/O Operation, P1003.1b-1993, p. 163
- * @param[in] filedes is the file descriptor
- * @param[in] aiocbp is a pointer to the asynchronous I/O control block
- * @retval AIO_CANCELED The requested operation(s) were canceled.
- * @retval AIO_NOTCANCELED Some of the requested operation(s) cannot be
- * canceled since they are in progress.
- * @retval AIO_ALLDONE None of the requested operation(s) could be canceled
- * since they are already complete
-int aio_cancel(
- int filedes,
- * 6.7.7 Wait for Asynchronous I/O Request, P1003.1b-1993, p. 164
-int aio_suspend(
- const struct aiocb * const list[],
- int nent,
- const struct timespec *timeout
-#if defined(_POSIX_SYNCHRONIZED_IO)
- * 6.7.9 Asynchronous File Synchronization, P1003.1b-1993, p. 166
-int aio_fsync(
- int op,
-#endif /* _POSIX_SYNCHRONIZED_IO */
-#endif /* _POSIX_ASYNCHRONOUS_IO */
-#ifdef __cplusplus
-#endif
-#endif
-/* end of include file */
2.17.1
