[PATCH] Removes build time warning for all the bsps using libtests/dl10 test
Richi Dubey
richidubey at gmail.com
Fri Apr 24 13:33:22 UTC 2020
Hey,
Can someone please check if this patch is correct? The warnings were:
log/sparc-leon3.log:../../../../../../rtems/c/src/../../testsuites/libtests/dl10/dl-load.c:109:12:
warning: 'dl_call' defined but not used [-Wunused-function]
log/sparc-leon3.log:../../../../../../rtems/c/src/../../testsuites/libtests/dl10/dl-load.c:99:13:
warning: 'dl_close' defined but not used [-Wunused-function]
I looked around and it seemed fine to delete these functions because
they weren't being called. Is it fine to remove them? I rebuilt the
leon3 bsp successfully with the new changes with no errors.
>From ce902f7107eab8485e8f7ba7b7ac8c37013d7a30 Mon Sep 17 00:00:00 2001
Date: Fri, 24 Apr 2020 18:42:16 +0530
Subject: [PATCH 2/2] Removed dl_call and dl_close
testsuites/libtests/dl10/dl-load.c | 21 +--------------------
1 file changed, 1 insertion(+), 20 deletions(-)
diff --git a/testsuites/libtests/dl10/dl-load.c
b/testsuites/libtests/dl10/dl-load.c
index dee1d6e9cc..d3fed3d69f 100644
--- a/testsuites/libtests/dl10/dl-load.c
+++ b/testsuites/libtests/dl10/dl-load.c
@@ -96,27 +96,8 @@ static void* dl_load_obj(const char* name, bool
has_unresolved)
return handle;
-static void dl_close (void* handle)
- int r;
- printf ("handle: %p closing\n", handle);
- r = dlclose (handle);
- if (r != 0)
- printf("dlclose failed: %s\n", dlerror());
- rtems_test_assert (r == 0);
-static int dl_call (void* handle, const char* func)
- call_sig call = dlsym (handle, func);
- if (call == NULL)
- printf("dlsym failed: symbol not found: %s\n", func);
- return 1;
- call ();
- return 0;
int dl_load_test(void)
2.17.1
