RTEMS examples build failed
Chris Johns
chrisj at rtems.org
Sun Apr 26 22:03:04 UTC 2020
On 26/4/20 8:24 pm, Vijay Kumar Banerjee wrote:
> After reading through the Waf book and some different trials, I came up
> with a
> nice one-line solution that works like a charm:
> https://lists.rtems.org/pipermail/devel/2020-April/059556.html
Nice and thanks.
> I used the find_or_declare function with it which returns a Node object
> under the
> source or build folders. If nothing is found, it creates the
> corresponding node in
> the build directory and the folder structure required for writing the
> file during the
> build phase. If the path is not under the build directory, then a fake
> filesystem
> structure is created for the output files. This makes the header
> file searchable
> after post_run, without the need to change the gccdeps.
Thank you for the explanation.
> I have tested it and it works great. Please review the patch and let me
> know if it's good to go.
Ok to push. Thanks.
