RTEMS examples build failed
Vijay Kumar Banerjee
vijay at rtems.org
Mon Apr 27 09:47:05 UTC 2020
On Mon, Apr 27, 2020 at 3:33 AM Chris Johns <chrisj at rtems.org> wrote:
> On 26/4/20 8:24 pm, Vijay Kumar Banerjee wrote:
> > After reading through the Waf book and some different trials, I came up
> > with a
> > nice one-line solution that works like a charm:
> > https://lists.rtems.org/pipermail/devel/2020-April/059556.html
> Nice and thanks.
> > I used the find_or_declare function with it which returns a Node object
> > under the
> > source or build folders. If nothing is found, it creates the
> > corresponding node in
> > the build directory and the folder structure required for writing the
> > file during the
> > build phase. If the path is not under the build directory, then a fake
> > filesystem
> > structure is created for the output files. This makes the header
> > file searchable
> > after post_run, without the need to change the gccdeps.
> Thank you for the explanation.
> > I have tested it and it works great. Please review the patch and let me
> > know if it's good to go.
> Ok to push. Thanks.
> Thanks for the review. I pushed it.
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200427/2301e0ea/attachment-0001.html>
