[PATCH 2/2] This removes the warning unused name variable warning
Richi Dubey richidubey at gmail.com
Mon Apr 27 12:11:12 UTC 2020
 testsuites/sptests/sp37/init.c | 8 ++++----
 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/testsuites/sptests/sp37/init.c b/testsuites/sptests/sp37/init.c
index 22c7d4f2ef..4358e9fffb 100644
--- a/testsuites/sptests/sp37/init.c
+++ b/testsuites/sptests/sp37/init.c
@@ -169,9 +169,9 @@ static void test_isr_level( void )
 static void test_isr_locks( void )
-  static const char name[] = "test";
   ISR_Level normal_interrupt_level = _ISR_Get_level();
-  ISR_lock_Control initialized = ISR_LOCK_INITIALIZER( name );
+  ISR_lock_Control initialized = ISR_LOCK_INITIALIZER( "test" );
   ISR_lock_Control zero_initialized;
   union {
     ISR_lock_Control lock;
@@ -183,7 +183,7 @@ static void test_isr_locks( void )
   ISR_Level interrupt_level;
   memset( &container, 0xff, sizeof( container ) );
-  _ISR_lock_Initialize( &container.lock, name );
+  _ISR_lock_Initialize( &container.lock, "test" );
   bytes = (const uint8_t *) &initialized;
   for ( i = 0; i < sizeof( container ); ++i ) {
@@ -193,7 +193,7 @@ static void test_isr_locks( void )
   memset( &zero_initialized, 0, sizeof( zero_initialized ) );
-  _ISR_lock_Set_name( &zero_initialized, name );
+  _ISR_lock_Set_name( &zero_initialized, "test" );
   bytes = (const uint8_t *) &zero_initialized;
2.17.1
