[PATCH] doxygen: Switch @brief and @ingroup
Mon Apr 27 14:15:35 UTC 2020
This order change fixes the Latex documentation build via Doxygen.
 cpukit/include/rtems/rtems-rfs.h                        | 3 ++-
 cpukit/libblock/src/bdpart-create.c                     | 3 ++-
 cpukit/libblock/src/bdpart-dump.c                       | 3 ++-
 cpukit/libblock/src/bdpart-mount.c                      | 3 ++-
 cpukit/libblock/src/bdpart-read.c                       | 3 ++-
 cpukit/libblock/src/bdpart-register.c                   | 3 ++-
 cpukit/libblock/src/bdpart-sort.c                       | 3 ++-
 cpukit/libblock/src/bdpart-write.c                      | 3 ++-
 cpukit/libblock/src/blkdev-blkstats.c                   | 3 ++-
 cpukit/libblock/src/blkdev-imfs.c                       | 3 ++-
 cpukit/libblock/src/blkdev-ioctl.c                      | 3 ++-
 cpukit/libblock/src/blkdev-print-stats.c                | 3 ++-
 cpukit/libblock/src/blkdev.c                            | 3 ++-
 cpukit/libblock/src/diskdevs-init.c                     | 3 ++-
 cpukit/libblock/src/flashdisk.c                         | 3 ++-
 cpukit/libblock/src/ide_part_table.c                    | 3 ++-
 cpukit/libblock/src/nvdisk-sram.c                       | 3 ++-
 cpukit/libblock/src/nvdisk.c                            | 3 ++-
 cpukit/libblock/src/show_bdbuf.c                        | 3 ++-
 cpukit/libcsupport/src/_realloc_r.c                     | 3 ++-
 cpukit/libcsupport/src/access.c                         | 3 ++-
 cpukit/libcsupport/src/assoclocalbyname.c               | 3 ++-
 cpukit/libcsupport/src/assocremotebylocalbitfield.c     | 3 ++-
 cpukit/libcsupport/src/chdir.c                          | 3 ++-
 cpukit/libcsupport/src/chroot.c                         | 3 ++-
 cpukit/libcsupport/src/close.c                          | 3 ++-
 cpukit/libcsupport/src/dup.c                            | 3 ++-
 cpukit/libcsupport/src/fcntl.c                          | 3 ++-
 cpukit/libcsupport/src/fdatasync.c                      | 3 ++-
 cpukit/libcsupport/src/free.c                           | 3 ++-
 cpukit/libcsupport/src/ioctl.c                          | 3 ++-
 cpukit/libcsupport/src/kill_noposix.c                   | 3 ++-
 cpukit/libcsupport/src/setegid.c                        | 3 ++-
 cpukit/libcsupport/src/sup_fs_mount_iterate.c           | 3 ++-
 cpukit/libcsupport/src/utsname.c                        | 3 ++-
 cpukit/libcsupport/src/write_r.c                        | 3 ++-
 cpukit/libfs/src/defaults/default_are_nodes_equal.c     | 3 ++-
 cpukit/libfs/src/defaults/default_clone.c               | 3 ++-
 cpukit/libfs/src/defaults/default_eval_path.c           | 3 ++-
 cpukit/libfs/src/defaults/default_fcntl.c               | 3 ++-
 cpukit/libfs/src/defaults/default_freenode.c            | 3 ++-
 cpukit/libfs/src/defaults/default_fstat.c               | 3 ++-
 cpukit/libfs/src/defaults/default_fsync.c               | 3 ++-
 cpukit/libfs/src/defaults/default_fsync_success.c       | 3 ++-
 cpukit/libfs/src/defaults/default_ftruncate.c           | 3 ++-
 cpukit/libfs/src/defaults/default_ftruncate_directory.c | 3 ++-
 cpukit/libfs/src/defaults/default_ioctl.c               | 3 ++-
 cpukit/libfs/src/defaults/default_lock_and_unlock.c     | 3 ++-
 cpukit/libfs/src/defaults/default_lseek.c               | 3 ++-
 cpukit/libfs/src/defaults/default_lseek_directory.c     | 3 ++-
 cpukit/libfs/src/defaults/default_lseek_file.c          | 3 ++-
 cpukit/libfs/src/defaults/default_mknod.c               | 3 ++-
 cpukit/libfs/src/defaults/default_mount.c               | 3 ++-
 cpukit/libfs/src/defaults/default_open.c                | 3 ++-
 cpukit/libfs/src/defaults/default_readlink.c            | 3 ++-
 cpukit/libfs/src/defaults/default_rename.c              | 3 ++-
 cpukit/libfs/src/defaults/default_rmnod.c               | 3 ++-
 cpukit/libfs/src/defaults/default_symlink.c             | 3 ++-
 cpukit/libfs/src/defaults/default_unmount.c             | 3 ++-
 cpukit/libfs/src/defaults/default_utime.c               | 3 ++-
 cpukit/libfs/src/defaults/default_write.c               | 3 ++-
 cpukit/libfs/src/dosfs/fat.c                            | 3 ++-
 cpukit/libfs/src/dosfs/fat_fat_operations.c             | 3 ++-
 cpukit/libfs/src/dosfs/fat_file.c                       | 3 ++-
 cpukit/libfs/src/dosfs/msdos_conv.c                     | 3 ++-
 cpukit/libfs/src/dosfs/msdos_create.c                   | 3 ++-
 cpukit/libfs/src/dosfs/msdos_dir.c                      | 3 ++-
 cpukit/libfs/src/dosfs/msdos_eval.c                     | 3 ++-
 cpukit/libfs/src/dosfs/msdos_file.c                     | 3 ++-
 cpukit/libfs/src/dosfs/msdos_format.c                   | 3 ++-
 cpukit/libfs/src/dosfs/msdos_free.c                     | 3 ++-
 cpukit/libfs/src/dosfs/msdos_fsunmount.c                | 3 ++-
 cpukit/libfs/src/dosfs/msdos_handlers_dir.c             | 3 ++-
 cpukit/libfs/src/dosfs/msdos_handlers_file.c            | 3 ++-
 cpukit/libfs/src/dosfs/msdos_init.c                     | 3 ++-
 cpukit/libfs/src/dosfs/msdos_initsupp.c                 | 3 ++-
 cpukit/libfs/src/dosfs/msdos_misc.c                     | 3 ++-
 cpukit/libfs/src/dosfs/msdos_mknod.c                    | 3 ++-
 cpukit/libfs/src/dosfs/msdos_rename.c                   | 3 ++-
 cpukit/libfs/src/dosfs/msdos_rmnod.c                    | 3 ++-
 cpukit/libfs/src/dosfs/msdos_statvfs.c                  | 3 ++-
 cpukit/libfs/src/imfs/deviceio.c                        | 3 ++-
 cpukit/libfs/src/imfs/imfs_chown.c                      | 3 ++-
 cpukit/libfs/src/imfs/imfs_config.c                     | 3 ++-
 cpukit/libfs/src/imfs/imfs_creat.c                      | 3 ++-
 cpukit/libfs/src/imfs/imfs_eval.c                       | 3 ++-
 cpukit/libfs/src/imfs/imfs_fchmod.c                     | 3 ++-
 cpukit/libfs/src/imfs/imfs_fifo.c                       | 3 ++-
 cpukit/libfs/src/imfs/imfs_fsunmount.c                  | 3 ++-
 cpukit/libfs/src/imfs/imfs_handlers_device.c            | 3 ++-
 cpukit/libfs/src/imfs/imfs_initsupp.c                   | 3 ++-
 cpukit/libfs/src/imfs/imfs_link.c                       | 3 ++-
 cpukit/libfs/src/imfs/imfs_load_tar.c                   | 3 ++-
 cpukit/libfs/src/imfs/imfs_make_generic_node.c          | 3 ++-
 cpukit/libfs/src/imfs/imfs_memfile.c                    | 3 ++-
 cpukit/libfs/src/imfs/imfs_mknod.c                      | 3 ++-
 cpukit/libfs/src/imfs/imfs_mount.c                      | 3 ++-
 cpukit/libfs/src/imfs/imfs_node.c                       | 3 ++-
 cpukit/libfs/src/imfs/imfs_rename.c                     | 3 ++-
 cpukit/libfs/src/imfs/imfs_rmnod.c                      | 3 ++-
 cpukit/libfs/src/imfs/imfs_stat.c                       | 3 ++-
 cpukit/libfs/src/imfs/imfs_symlink.c                    | 3 ++-
 cpukit/libfs/src/imfs/imfs_unmount.c                    | 3 ++-
 cpukit/libfs/src/imfs/imfs_utime.c                      | 3 ++-
 cpukit/libfs/src/imfs/ioman.c                           | 3 ++-
 cpukit/libfs/src/nfsclient/proto/mount_prot_xdr.c       | 3 ++-
 cpukit/libfs/src/nfsclient/proto/nfs_prot_xdr.c         | 3 ++-
 cpukit/libfs/src/nfsclient/src/nfs.c                    | 3 ++-
 cpukit/libfs/src/nfsclient/src/rpcio.c                  | 3 ++-
 cpukit/libfs/src/nfsclient/src/sock_mbuf.c              | 3 ++-
 cpukit/libfs/src/nfsclient/src/xdr_mbuf.c               | 3 ++-
 cpukit/libfs/src/pipe/fifo.c                            | 3 ++-
 cpukit/libfs/src/pipe/pipe.c                            | 3 ++-
 cpukit/libfs/src/rfs/rtems-rfs-bitmaps.c                | 3 ++-
 cpukit/libfs/src/rfs/rtems-rfs-block.c                  | 3 ++-
 cpukit/libfs/src/rfs/rtems-rfs-buffer-bdbuf.c           | 3 ++-
 cpukit/libfs/src/rfs/rtems-rfs-buffer-devio.c           | 3 ++-
 cpukit/libfs/src/rfs/rtems-rfs-buffer.c                 | 3 ++-
 cpukit/libfs/src/rfs/rtems-rfs-dir-hash.c               | 3 ++-
 cpukit/libfs/src/rfs/rtems-rfs-dir.c                    | 3 ++-
 cpukit/libfs/src/rfs/rtems-rfs-file-system.c            | 3 ++-
 cpukit/libfs/src/rfs/rtems-rfs-file.c                   | 3 ++-
 cpukit/libfs/src/rfs/rtems-rfs-format.c                 | 3 ++-
 cpukit/libfs/src/rfs/rtems-rfs-group.c                  | 3 ++-
 cpukit/libfs/src/rfs/rtems-rfs-inode.c                  | 3 ++-
 cpukit/libfs/src/rfs/rtems-rfs-link.c                   | 3 ++-
 cpukit/libfs/src/rfs/rtems-rfs-mutex.c                  | 3 ++-
 cpukit/libfs/src/rfs/rtems-rfs-rtems-dev.c              | 3 ++-
 cpukit/libfs/src/rfs/rtems-rfs-rtems-dir.c              | 3 ++-
 cpukit/libfs/src/rfs/rtems-rfs-rtems-file.c             | 3 ++-
 cpukit/libfs/src/rfs/rtems-rfs-rtems-utils.c            | 3 ++-
 cpukit/libfs/src/rfs/rtems-rfs-rtems.c                  | 3 ++-
 cpukit/libfs/src/rfs/rtems-rfs-shell.c                  | 3 ++-
 cpukit/libfs/src/rfs/rtems-rfs-trace.c                  | 3 ++-
 cpukit/libmisc/bspcmdline/bspcmdline_get.c              | 3 ++-
 cpukit/libmisc/bspcmdline/bspcmdline_getparam.c         | 3 ++-
 cpukit/libmisc/bspcmdline/bspcmdline_getparamraw.c      | 3 ++-
 cpukit/libmisc/bspcmdline/bspcmdline_getparamrhs.c      | 3 ++-
 cpukit/libmisc/cpuuse/cpuusagedata.c                    | 3 ++-
 cpukit/libmisc/cpuuse/cpuusagereport.c                  | 3 ++-
 cpukit/libmisc/cpuuse/cpuusagereset.c                   | 3 ++-
 cpukit/libmisc/cpuuse/cpuusagetop.c                     | 3 ++-
 cpukit/libmisc/devnull/devnull.c                        | 3 ++-
 cpukit/libmisc/devnull/devzero.c                        | 3 ++-
 cpukit/libmisc/dumpbuf/dumpbuf.c                        | 3 ++-
 cpukit/libmisc/fb/mw_print.c                            | 3 ++-
 cpukit/libmisc/fb/mw_uid.c                              | 3 ++-
 cpukit/libmisc/fsmount/fsmount.c                        | 3 ++-
 cpukit/libmisc/mouse/mouse_parser.c                     | 3 ++-
 cpukit/libmisc/mouse/serial_mouse.c                     | 3 ++-
 cpukit/libmisc/shell/main_df.c                          | 3 ++-
 cpukit/libmisc/stackchk/check.c                         | 3 ++-
 cpukit/libmisc/stringto/stringtodouble.c                | 3 ++-
 cpukit/libmisc/stringto/stringtofloat.c                 | 3 ++-
 cpukit/libmisc/stringto/stringtoint.c                   | 3 ++-
 cpukit/libmisc/stringto/stringtolong.c                  | 3 ++-
 cpukit/libmisc/stringto/stringtolongdouble.c            | 3 ++-
 cpukit/libmisc/stringto/stringtolonglong.c              | 3 ++-
 cpukit/libmisc/stringto/stringtopointer.c               | 3 ++-
 cpukit/libmisc/stringto/stringtounsignedchar.c          | 3 ++-
 cpukit/libmisc/stringto/stringtounsignedint.c           | 3 ++-
 cpukit/libmisc/stringto/stringtounsignedlong.c          | 3 ++-
 cpukit/libmisc/stringto/stringtounsignedlonglong.c      | 3 ++-
 cpukit/posix/src/_execve.c                              | 3 ++-
 cpukit/posix/src/aio_error.c                            | 3 ++-
 cpukit/posix/src/aio_fsync.c                            | 3 ++-
 cpukit/posix/src/aio_misc.c                             | 3 ++-
 cpukit/posix/src/aio_read.c                             | 3 ++-
 cpukit/posix/src/aio_return.c                           | 3 ++-
 cpukit/posix/src/aio_suspend.c                          | 3 ++-
 cpukit/posix/src/aio_write.c                            | 3 ++-
 cpukit/posix/src/alarm.c                                | 3 ++-
 cpukit/posix/src/barrierattrdestroy.c                   | 3 ++-
 cpukit/posix/src/barrierattrgetpshared.c                | 3 ++-
 cpukit/posix/src/cancel.c                               | 3 ++-
 cpukit/posix/src/cleanuppush.c                          | 3 ++-
 cpukit/posix/src/clockgetcpuclockid.c                   | 3 ++-
 cpukit/posix/src/clockgetres.c                          | 3 ++-
 cpukit/posix/src/clockgettime.c                         | 3 ++-
 cpukit/posix/src/clocksettime.c                         | 3 ++-
 cpukit/posix/src/condattrdestroy.c                      | 3 ++-
 cpukit/posix/src/condattrgetclock.c                     | 3 ++-
 cpukit/posix/src/condattrgetpshared.c                   | 3 ++-
 cpukit/posix/src/condattrinit.c                         | 3 ++-
 cpukit/posix/src/condattrsetclock.c                     | 3 ++-
 cpukit/posix/src/condattrsetpshared.c                   | 3 ++-
 cpukit/posix/src/conddefaultattributes.c                | 3 ++-
 cpukit/posix/src/condsignalsupp.c                       | 3 ++-
 cpukit/posix/src/condtimedwait.c                        | 3 ++-
 cpukit/posix/src/condwait.c                             | 3 ++-
 cpukit/posix/src/condwaitsupp.c                         | 3 ++-
 cpukit/posix/src/fork.c                                 | 3 ++-
 cpukit/posix/src/getitimer.c                            | 3 ++-
 cpukit/posix/src/keycreate.c                            | 3 ++-
 cpukit/posix/src/keydelete.c                            | 3 ++-
 cpukit/posix/src/keygetspecific.c                       | 3 ++-
 cpukit/posix/src/keysetspecific.c                       | 3 ++-
 cpukit/posix/src/kill.c                                 | 3 ++-
 cpukit/posix/src/kill_r.c                               | 3 ++-
 cpukit/posix/src/killinfo.c                             | 3 ++-
 cpukit/posix/src/lio_listio.c                           | 3 ++-
 cpukit/posix/src/mprotect.c                             | 3 ++-
 cpukit/posix/src/mqueueclose.c                          | 3 ++-
 cpukit/posix/src/mqueuegetattr.c                        | 3 ++-
 cpukit/posix/src/mqueuenotify.c                         | 3 ++-
 cpukit/posix/src/mqueueopen.c                           | 3 ++-
 cpukit/posix/src/mqueuerecvsupp.c                       | 3 ++-
 cpukit/posix/src/mqueuesend.c                           | 3 ++-
 cpukit/posix/src/mqueuesendsupp.c                       | 3 ++-
 cpukit/posix/src/mqueuesetattr.c                        | 3 ++-
 cpukit/posix/src/mqueuetimedreceive.c                   | 3 ++-
 cpukit/posix/src/mqueueunlink.c                         | 3 ++-
 cpukit/posix/src/mutexattrdestroy.c                     | 3 ++-
 cpukit/posix/src/mutexattrgetprioceiling.c              | 3 ++-
 cpukit/posix/src/mutexattrgetprotocol.c                 | 3 ++-
 cpukit/posix/src/mutexattrgetpshared.c                  | 3 ++-
 cpukit/posix/src/mutexattrgettype.c                     | 3 ++-
 cpukit/posix/src/mutexattrsetprioceiling.c              | 3 ++-
 cpukit/posix/src/mutexattrsetprotocol.c                 | 3 ++-
 cpukit/posix/src/mutexattrsetpshared.c                  | 3 ++-
 cpukit/posix/src/mutexdestroy.c                         | 3 ++-
 cpukit/posix/src/mutexgetprioceiling.c                  | 3 ++-
 cpukit/posix/src/mutexinit.c                            | 3 ++-
 cpukit/posix/src/mutexlock.c                            | 3 ++-
 cpukit/posix/src/mutexlocksupp.c                        | 3 ++-
 cpukit/posix/src/mutexsetprioceiling.c                  | 3 ++-
 cpukit/posix/src/mutextimedlock.c                       | 3 ++-
 cpukit/posix/src/mutextrylock.c                         | 3 ++-
 cpukit/posix/src/mutexunlock.c                          | 3 ++-
 cpukit/posix/src/nanosleep.c                            | 3 ++-
 cpukit/posix/src/pause.c                                | 3 ++-
 cpukit/posix/src/pbarrierinit.c                         | 3 ++-
 cpukit/posix/src/pbarrierwait.c                         | 3 ++-
 cpukit/posix/src/prwlockinit.c                          | 3 ++-
 cpukit/posix/src/prwlockrdlock.c                        | 3 ++-
 cpukit/posix/src/prwlocktimedrdlock.c                   | 3 ++-
 cpukit/posix/src/prwlocktimedwrlock.c                   | 3 ++-
 cpukit/posix/src/prwlocktryrdlock.c                     | 3 ++-
 cpukit/posix/src/prwlocktrywrlock.c                     | 3 ++-
 cpukit/posix/src/prwlockunlock.c                        | 3 ++-
 cpukit/posix/src/prwlockwrlock.c                        | 3 ++-
 cpukit/posix/src/psignalclearprocesssignals.c           | 3 ++-
 cpukit/posix/src/psignalclearsignals.c                  | 3 ++-
 cpukit/posix/src/psignalunblockthread.c                 | 3 ++-
 cpukit/posix/src/pspininit.c                            | 3 ++-
 cpukit/posix/src/pspinunlock.c                          | 3 ++-
 cpukit/posix/src/psxnametoid.c                          | 3 ++-
 cpukit/posix/src/psxtimercreate.c                       | 3 ++-
 cpukit/posix/src/psxtimerdelete.c                       | 3 ++-
 cpukit/posix/src/psxtransschedparam.c                   | 3 ++-
 cpukit/posix/src/pthread.c                              | 3 ++-
 cpukit/posix/src/pthreadattrdefault.c                   | 3 ++-
 cpukit/posix/src/pthreadattrdestroy.c                   | 3 ++-
 cpukit/posix/src/pthreadattrgetaffinitynp.c             | 3 ++-
 cpukit/posix/src/pthreadattrgetdetachstate.c            | 3 ++-
 cpukit/posix/src/pthreadattrgetguardsize.c              | 3 ++-
 cpukit/posix/src/pthreadattrgetinheritsched.c           | 3 ++-
 cpukit/posix/src/pthreadattrgetschedparam.c             | 3 ++-
 cpukit/posix/src/pthreadattrgetscope.c                  | 3 ++-
 cpukit/posix/src/pthreadattrgetstack.c                  | 3 ++-
 cpukit/posix/src/pthreadattrgetstackaddr.c              | 3 ++-
 cpukit/posix/src/pthreadattrgetstacksize.c              | 3 ++-
 cpukit/posix/src/pthreadattrinit.c                      | 3 ++-
 cpukit/posix/src/pthreadattrsetaffinitynp.c             | 3 ++-
 cpukit/posix/src/pthreadattrsetdetachstate.c            | 3 ++-
 cpukit/posix/src/pthreadattrsetguardsize.c              | 3 ++-
 cpukit/posix/src/pthreadattrsetinheritsched.c           | 3 ++-
 cpukit/posix/src/pthreadattrsetschedparam.c             | 3 ++-
 cpukit/posix/src/pthreadattrsetschedpolicy.c            | 3 ++-
 cpukit/posix/src/pthreadattrsetscope.c                  | 3 ++-
 cpukit/posix/src/pthreadattrsetstack.c                  | 3 ++-
 cpukit/posix/src/pthreadattrsetstackaddr.c              | 3 ++-
 cpukit/posix/src/pthreadattrsetstacksize.c              | 3 ++-
 cpukit/posix/src/pthreadconcurrency.c                   | 3 ++-
 cpukit/posix/src/pthreadcreate.c                        | 3 ++-
 cpukit/posix/src/pthreaddetach.c                        | 3 ++-
 cpukit/posix/src/pthreadequal.c                         | 3 ++-
 cpukit/posix/src/pthreadexit.c                          | 3 ++-
 cpukit/posix/src/pthreadgetaffinitynp.c                 | 3 ++-
 cpukit/posix/src/pthreadgetattrnp.c                     | 3 ++-
 cpukit/posix/src/pthreadgetcpuclockid.c                 | 3 ++-
 cpukit/posix/src/pthreadgetschedparam.c                 | 3 ++-
 cpukit/posix/src/pthreadinitthreads.c                   | 3 ++-
 cpukit/posix/src/pthreadjoin.c                          | 3 ++-
 cpukit/posix/src/pthreadkill.c                          | 3 ++-
 cpukit/posix/src/pthreadonce.c                          | 3 ++-
 cpukit/posix/src/pthreadself.c                          | 3 ++-
 cpukit/posix/src/pthreadsetaffinitynp.c                 | 3 ++-
 cpukit/posix/src/pthreadsetschedparam.c                 | 3 ++-
 cpukit/posix/src/pthreadsigmask.c                       | 3 ++-
 cpukit/posix/src/rwlockattrdestroy.c                    | 3 ++-
 cpukit/posix/src/rwlockattrinit.c                       | 3 ++-
 cpukit/posix/src/rwlockattrsetpshared.c                 | 3 ++-
 cpukit/posix/src/sched_getparam.c                       | 3 ++-
 cpukit/posix/src/sched_getprioritymax.c                 | 3 ++-
 cpukit/posix/src/sched_getscheduler.c                   | 3 ++-
 cpukit/posix/src/sched_rr_get_interval.c                | 3 ++-
 cpukit/posix/src/sched_setparam.c                       | 3 ++-
 cpukit/posix/src/sched_setscheduler.c                   | 3 ++-
 cpukit/posix/src/sched_yield.c                          | 3 ++-
 cpukit/posix/src/semclose.c                             | 3 ++-
 cpukit/posix/src/semgetvalue.c                          | 3 ++-
 cpukit/posix/src/seminit.c                              | 3 ++-
 cpukit/posix/src/semopen.c                              | 3 ++-
 cpukit/posix/src/semtimedwait.c                         | 3 ++-
 cpukit/posix/src/semunlink.c                            | 3 ++-
 cpukit/posix/src/setcancelstate.c                       | 3 ++-
 cpukit/posix/src/setcanceltype.c                        | 3 ++-
 cpukit/posix/src/setitimer.c                            | 3 ++-
 cpukit/posix/src/sigaction.c                            | 3 ++-
 cpukit/posix/src/sigaddset.c                            | 3 ++-
 cpukit/posix/src/sigdelset.c                            | 3 ++-
 cpukit/posix/src/sigemptyset.c                          | 3 ++-
 cpukit/posix/src/sigfillset.c                           | 3 ++-
 cpukit/posix/src/sigismember.c                          | 3 ++-
 cpukit/posix/src/signal_2.c                             | 3 ++-
 cpukit/posix/src/sigpending.c                           | 3 ++-
 cpukit/posix/src/sigprocmask.c                          | 3 ++-
 cpukit/posix/src/sigqueue.c                             | 3 ++-
 cpukit/posix/src/sigsuspend.c                           | 3 ++-
 cpukit/posix/src/sigwait.c                              | 3 ++-
 cpukit/posix/src/sysconf.c                              | 3 ++-
 cpukit/posix/src/testcancel.c                           | 3 ++-
 cpukit/posix/src/timergettime.c                         | 3 ++-
 cpukit/posix/src/timersettime.c                         | 3 ++-
 cpukit/posix/src/ualarm.c                               | 3 ++-
 cpukit/posix/src/vfork.c                                | 3 ++-
 cpukit/posix/src/wait.c                                 | 3 ++-
 cpukit/rtems/src/barriercreate.c                        | 3 ++-
 cpukit/rtems/src/barrierrelease.c                       | 3 ++-
 cpukit/rtems/src/clockgettod.c                          | 3 ++-
 cpukit/rtems/src/clockgetuptime.c                       | 3 ++-
 cpukit/rtems/src/clockgetuptimenanoseconds.c            | 3 ++-
 cpukit/rtems/src/eventreceive.c                         | 3 ++-
 cpukit/rtems/src/eventseize.c                           | 3 ++-
 cpukit/rtems/src/msgmp.c                                | 3 ++-
 cpukit/rtems/src/msgqflush.c                            | 3 ++-
 cpukit/rtems/src/msgqgetnumberpending.c                 | 3 ++-
 cpukit/rtems/src/msgqsend.c                             | 3 ++-
 cpukit/rtems/src/partcreate.c                           | 3 ++-
 cpukit/rtems/src/partmp.c                               | 3 ++-
 cpukit/rtems/src/ratemoncreate.c                        | 3 ++-
 cpukit/rtems/src/ratemonresetall.c                      | 3 ++-
 cpukit/rtems/src/ratemonresetstatistics.c               | 3 ++-
 cpukit/rtems/src/regioncreate.c                         | 3 ++-
 cpukit/rtems/src/rtemsbuildid.c                         | 3 ++-
 cpukit/rtems/src/rtemsobjectapiminimumclass.c           | 3 ++-
 cpukit/rtems/src/rtemsobjectidgetapi.c                  | 3 ++-
 cpukit/rtems/src/rtemsobjectsetname.c                   | 3 ++-
 cpukit/rtems/src/semcreate.c                            | 3 ++-
 cpukit/rtems/src/semrelease.c                           | 3 ++-
 cpukit/rtems/src/taskgetaffinity.c                      | 3 ++-
 cpukit/rtems/src/taskinitusers.c                        | 3 ++-
 cpukit/rtems/src/taskissuspended.c                      | 3 ++-
 cpukit/rtems/src/taskmp.c                               | 3 ++-
 cpukit/rtems/src/tasksetaffinity.c                      | 3 ++-
 cpukit/rtems/src/taskstart.c                            | 3 ++-
 cpukit/rtems/src/timerreset.c                           | 3 ++-
 cpukit/rtems/src/timerserverfirewhen.c                  | 3 ++-
 cpukit/sapi/src/rbtreefind.c                            | 3 ++-
 cpukit/score/src/coremsginsert.c                        | 3 ++-
 cpukit/score/src/corerwlock.c                           | 3 ++-
 cpukit/score/src/corerwlockobtainread.c                 | 3 ++-
 cpukit/score/src/corerwlockobtainwrite.c                | 3 ++-
 cpukit/score/src/coretodadjust.c                        | 3 ++-
 cpukit/score/src/coretodtickspersec.c                   | 3 ++-
 cpukit/score/src/interr.c                               | 3 ++-
 cpukit/score/src/mpci.c                                 | 3 ++-
 cpukit/score/src/mpcidefault.c                          | 3 ++-
 cpukit/score/src/objectextendinformation.c              | 3 ++-
 cpukit/score/src/objectgetnext.c                        | 3 ++-
 cpukit/score/src/objectinitializeinformation.c          | 3 ++-
 cpukit/score/src/objectnametoidstring.c                 | 3 ++-
 cpukit/score/src/objectsetname.c                        | 3 ++-
 cpukit/score/src/percpu.c                               | 3 ++-
 cpukit/score/src/scheduler.c                            | 3 ++-
 cpukit/score/src/schedulercbs.c                         | 3 ++-
 cpukit/score/src/schedulercbsgetparameters.c            | 3 ++-
 cpukit/score/src/scheduleredf.c                         | 3 ++-
 cpukit/score/src/scheduleredfreleasejob.c               | 3 ++-
 cpukit/score/src/scheduleredfunblock.c                  | 3 ++-
 cpukit/score/src/schedulerpriorityblock.c               | 3 ++-
 cpukit/score/src/schedulerpriorityschedule.c            | 3 ++-
 cpukit/score/src/schedulersimpleschedule.c              | 3 ++-
 cpukit/score/src/schedulersimpleunblock.c               | 3 ++-
 cpukit/score/src/schedulersimpleyield.c                 | 3 ++-
 cpukit/score/src/threaddispatch.c                       | 3 ++-
 cpukit/score/src/threadqenqueue.c                       | 3 ++-
 cpukit/score/src/threadqflush.c                         | 3 ++-
 cpukit/score/src/threadrestart.c                        | 3 ++-
 cpukit/score/src/timespecdivide.c                       | 3 ++-
 cpukit/score/src/watchdoginsert.c                       | 3 ++-
 cpukit/score/src/watchdogremove.c                       | 3 ++-
 393 files changed, 786 insertions(+), 393 deletions(-)
diff --git a/cpukit/include/rtems/rtems-rfs.h b/cpukit/include/rtems/rtems-rfs.h
index 958f9a636b..f0e76cf25c 100644
--- a/cpukit/include/rtems/rtems-rfs.h
+++ b/cpukit/include/rtems/rtems-rfs.h
@@ -1,9 +1,10 @@
  * @file
- * @brief RFS File system Initialization
  * @ingroup rtems_rfs
+ * @brief RFS File system Initialization
  * RTEMS File System
diff --git a/cpukit/libblock/src/bdpart-create.c b/cpukit/libblock/src/bdpart-create.c
index 52cdeeb989..8bfc1de302 100644
--- a/cpukit/libblock/src/bdpart-create.c
+++ b/cpukit/libblock/src/bdpart-create.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Manage Partitions of a Disk Device
  * @ingroup rtems_bdpart
+ * @brief Manage Partitions of a Disk Device
diff --git a/cpukit/libblock/src/bdpart-dump.c b/cpukit/libblock/src/bdpart-dump.c
index adf9296954..ce58a0020f 100644
--- a/cpukit/libblock/src/bdpart-dump.c
+++ b/cpukit/libblock/src/bdpart-dump.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Prints the Partition Table @a Partitions with @a Count Partitions
+ * @brief Prints the Partition Table @a Partitions with @a Count Partitions
diff --git a/cpukit/libblock/src/bdpart-mount.c b/cpukit/libblock/src/bdpart-mount.c
index 6cb281709e..cfc08ead30 100644
--- a/cpukit/libblock/src/bdpart-mount.c
+++ b/cpukit/libblock/src/bdpart-mount.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Block Device Partition Management
+ * @brief Block Device Partition Management
diff --git a/cpukit/libblock/src/bdpart-read.c b/cpukit/libblock/src/bdpart-read.c
index d8115288fa..cfebdbc9d4 100644
--- a/cpukit/libblock/src/bdpart-read.c
+++ b/cpukit/libblock/src/bdpart-read.c
@@ -1,8 +1,9 @@
  * @file
diff --git a/cpukit/libblock/src/bdpart-register.c b/cpukit/libblock/src/bdpart-register.c
index 66a7498e2c..9956e61a68 100644
--- a/cpukit/libblock/src/bdpart-register.c
+++ b/cpukit/libblock/src/bdpart-register.c
@@ -1,8 +1,9 @@
  * @file
diff --git a/cpukit/libblock/src/bdpart-sort.c b/cpukit/libblock/src/bdpart-sort.c
index 17fb64113c..52de38b442 100644
--- a/cpukit/libblock/src/bdpart-sort.c
+++ b/cpukit/libblock/src/bdpart-sort.c
@@ -1,8 +1,9 @@
  * @file
diff --git a/cpukit/libblock/src/bdpart-write.c b/cpukit/libblock/src/bdpart-write.c
index 9443bc63bc..0418e82850 100644
--- a/cpukit/libblock/src/bdpart-write.c
+++ b/cpukit/libblock/src/bdpart-write.c
@@ -1,8 +1,9 @@
  * @file
diff --git a/cpukit/libblock/src/blkdev-blkstats.c b/cpukit/libblock/src/blkdev-blkstats.c
index c035ee4ecb..a6b336af2d 100644
--- a/cpukit/libblock/src/blkdev-blkstats.c
+++ b/cpukit/libblock/src/blkdev-blkstats.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Block Device Statistics Command
  * @ingroup rtems_blkdev Block Device Management
+ * @brief Block Device Statistics Command
diff --git a/cpukit/libblock/src/blkdev-imfs.c b/cpukit/libblock/src/blkdev-imfs.c
index a6872f442d..c7e582cfbc 100644
--- a/cpukit/libblock/src/blkdev-imfs.c
+++ b/cpukit/libblock/src/blkdev-imfs.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Block Device IMFS
  * @ingroup libblock
+ * @brief Block Device IMFS
diff --git a/cpukit/libblock/src/blkdev-ioctl.c b/cpukit/libblock/src/blkdev-ioctl.c
index 3e8b081142..834f892d5c 100644
--- a/cpukit/libblock/src/blkdev-ioctl.c
+++ b/cpukit/libblock/src/blkdev-ioctl.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Common IO Control Primitive
+ * @brief Common IO Control Primitive
diff --git a/cpukit/libblock/src/blkdev-print-stats.c b/cpukit/libblock/src/blkdev-print-stats.c
index 6e43139374..8edf24fd8c 100644
--- a/cpukit/libblock/src/blkdev-print-stats.c
+++ b/cpukit/libblock/src/blkdev-print-stats.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Prints the Block Device Statistics
+ * @brief Prints the Block Device Statistics
diff --git a/cpukit/libblock/src/blkdev.c b/cpukit/libblock/src/blkdev.c
index f19c273d24..e818129196 100644
--- a/cpukit/libblock/src/blkdev.c
+++ b/cpukit/libblock/src/blkdev.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Block Device Management
+ * @brief Block Device Management
diff --git a/cpukit/libblock/src/diskdevs-init.c b/cpukit/libblock/src/diskdevs-init.c
index 5ed2c71b0f..35923506bc 100644
--- a/cpukit/libblock/src/diskdevs-init.c
+++ b/cpukit/libblock/src/diskdevs-init.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Block Device Disk Management Initialize
  * @ingroup rtems_disk Block Device Disk Management
+ * @brief Block Device Disk Management Initialize
diff --git a/cpukit/libblock/src/flashdisk.c b/cpukit/libblock/src/flashdisk.c
index a3fbbba119..91f99e0d52 100644
--- a/cpukit/libblock/src/flashdisk.c
+++ b/cpukit/libblock/src/flashdisk.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Flash Disk Block Device Implementation
  * @ingroup libblock
+ * @brief Flash Disk Block Device Implementation
diff --git a/cpukit/libblock/src/ide_part_table.c b/cpukit/libblock/src/ide_part_table.c
index 5f8f2116ed..a802be5dfb 100644
--- a/cpukit/libblock/src/ide_part_table.c
+++ b/cpukit/libblock/src/ide_part_table.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Library supporting "MS-DOS-style" Partition Table
  * @ingroup libblock
+ * @brief Library supporting "MS-DOS-style" Partition Table
diff --git a/cpukit/libblock/src/nvdisk-sram.c b/cpukit/libblock/src/nvdisk-sram.c
index 6ac709883a..aa6fe00977 100644
--- a/cpukit/libblock/src/nvdisk-sram.c
+++ b/cpukit/libblock/src/nvdisk-sram.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Provide SRAM support for the NV Disk
  * @ingroup libblock
+ * @brief Provide SRAM support for the NV Disk
diff --git a/cpukit/libblock/src/nvdisk.c b/cpukit/libblock/src/nvdisk.c
index d2042928ef..a7f4167d33 100644
--- a/cpukit/libblock/src/nvdisk.c
+++ b/cpukit/libblock/src/nvdisk.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Non-Volatile Disk Block Device Implementation
  * @ingroup libblock
+ * @brief Non-Volatile Disk Block Device Implementation
diff --git a/cpukit/libblock/src/show_bdbuf.c b/cpukit/libblock/src/show_bdbuf.c
index 29bf3d7e22..22564fe75b 100644
--- a/cpukit/libblock/src/show_bdbuf.c
+++ b/cpukit/libblock/src/show_bdbuf.c
@@ -1,9 +1,10 @@
  * @file
- * @brief Enable the Monitor to Show bdbuf Information
+ * @brief Enable the Monitor to Show bdbuf Information
  * This module inspects the bdbuf data structures,
  * assuming they are static, but in fact they are used very
  * dynamically. Therefore the results show MAY BE INCORRECT in
diff --git a/cpukit/libcsupport/src/_realloc_r.c b/cpukit/libcsupport/src/_realloc_r.c
index 57f0aaf834..95f9e054f5 100644
--- a/cpukit/libcsupport/src/_realloc_r.c
+++ b/cpukit/libcsupport/src/_realloc_r.c
@@ -1,8 +1,9 @@
  * @file
- * @brief  _realloc_r Implementation
  * @ingroup libcsupport
+ * @brief  _realloc_r Implementation
diff --git a/cpukit/libcsupport/src/access.c b/cpukit/libcsupport/src/access.c
index cc3dee7ffa..57276305ac 100644
--- a/cpukit/libcsupport/src/access.c
+++ b/cpukit/libcsupport/src/access.c
@@ -1,8 +1,9 @@
  * @file
- * @brief access() - POSIX 1003.1b 5.6.3 - File Accessibility
+ * @brief access() - POSIX 1003.1b 5.6.3 - File Accessibility
diff --git a/cpukit/libcsupport/src/assoclocalbyname.c b/cpukit/libcsupport/src/assoclocalbyname.c
index 2fba102abe..c0267f3f53 100644
--- a/cpukit/libcsupport/src/assoclocalbyname.c
+++ b/cpukit/libcsupport/src/assoclocalbyname.c
@@ -1,8 +1,9 @@
  * @file
- * @brief RTEMS Associate Local by Name
  * @ingroup Associativity Routines
+ * @brief RTEMS Associate Local by Name
diff --git a/cpukit/libcsupport/src/assocremotebylocalbitfield.c b/cpukit/libcsupport/src/assocremotebylocalbitfield.c
index efcc87a3c4..4a9cc0b175 100644
--- a/cpukit/libcsupport/src/assocremotebylocalbitfield.c
+++ b/cpukit/libcsupport/src/assocremotebylocalbitfield.c
@@ -1,8 +1,9 @@
  * @file
- * @brief RTEMS Assoc Routines
+ * @brief RTEMS Assoc Routines
diff --git a/cpukit/libcsupport/src/chdir.c b/cpukit/libcsupport/src/chdir.c
index 55425345e8..6ef551f06d 100644
--- a/cpukit/libcsupport/src/chdir.c
+++ b/cpukit/libcsupport/src/chdir.c
@@ -1,8 +1,9 @@
  * @file
- * @brief POSIX 1003.1b - 5.2.1 - Change Current Working Directory
  * @ingroup libio Internal Interface
+ * @brief POSIX 1003.1b - 5.2.1 - Change Current Working Directory
diff --git a/cpukit/libcsupport/src/chroot.c b/cpukit/libcsupport/src/chroot.c
index 3e7dfbae87..9db340174b 100644
--- a/cpukit/libcsupport/src/chroot.c
+++ b/cpukit/libcsupport/src/chroot.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Change Root Directory
+ * @brief Change Root Directory
diff --git a/cpukit/libcsupport/src/close.c b/cpukit/libcsupport/src/close.c
index 21b375149d..5e6aa2c041 100644
--- a/cpukit/libcsupport/src/close.c
+++ b/cpukit/libcsupport/src/close.c
@@ -1,8 +1,9 @@
  * @file
- * @brief POSIX 1003.1b 6.3.1 - Close a File
+ * @brief POSIX 1003.1b 6.3.1 - Close a File
diff --git a/cpukit/libcsupport/src/dup.c b/cpukit/libcsupport/src/dup.c
index 98ee8fdf1e..8fe2514c7d 100644
--- a/cpukit/libcsupport/src/dup.c
+++ b/cpukit/libcsupport/src/dup.c
@@ -1,8 +1,9 @@
  * @file
- * @brief POSIX 1003.1b 6.2.1 Duplicate an Open File Descriptor
+ * @brief POSIX 1003.1b 6.2.1 Duplicate an Open File Descriptor
diff --git a/cpukit/libcsupport/src/fcntl.c b/cpukit/libcsupport/src/fcntl.c
index 111fd188d4..ba824dced1 100644
--- a/cpukit/libcsupport/src/fcntl.c
+++ b/cpukit/libcsupport/src/fcntl.c
@@ -1,8 +1,9 @@
  * @file
- * @brief POSIX 1003.1b 6.5.2 - File Control
+ * @brief POSIX 1003.1b 6.5.2 - File Control
diff --git a/cpukit/libcsupport/src/fdatasync.c b/cpukit/libcsupport/src/fdatasync.c
index 3b9a4ff9bf..a1ac7bc81e 100644
--- a/cpukit/libcsupport/src/fdatasync.c
+++ b/cpukit/libcsupport/src/fdatasync.c
@@ -1,8 +1,9 @@
  * @file
- * @brief POSIX 1003.1b 6.6.2 - Synchronize the Data of a File
+ * @brief POSIX 1003.1b 6.6.2 - Synchronize the Data of a File
diff --git a/cpukit/libcsupport/src/free.c b/cpukit/libcsupport/src/free.c
index 18c8aaccf1..9f7c577852 100644
--- a/cpukit/libcsupport/src/free.c
+++ b/cpukit/libcsupport/src/free.c
@@ -1,8 +1,9 @@
  * @file
- * @brief calloc()
+ * @brief calloc()
diff --git a/cpukit/libcsupport/src/ioctl.c b/cpukit/libcsupport/src/ioctl.c
index e58889ae28..203a0aa5ba 100644
--- a/cpukit/libcsupport/src/ioctl.c
+++ b/cpukit/libcsupport/src/ioctl.c
@@ -1,8 +1,9 @@
  * @file
- * @brief ioctl() system call
+ * @brief ioctl() system call
diff --git a/cpukit/libcsupport/src/kill_noposix.c b/cpukit/libcsupport/src/kill_noposix.c
index a111f071d7..3792a81db8 100644
--- a/cpukit/libcsupport/src/kill_noposix.c
+++ b/cpukit/libcsupport/src/kill_noposix.c
@@ -1,9 +1,10 @@
  * @file
- * @brief Kill No POSIX
+ * @brief Kill No POSIX
  *  Marginal implementations of some POSIX API routines
  *  to be used when POSIX is disabled.
diff --git a/cpukit/libcsupport/src/setegid.c b/cpukit/libcsupport/src/setegid.c
index 2a3ef2f868..4303e73ebe 100644
--- a/cpukit/libcsupport/src/setegid.c
+++ b/cpukit/libcsupport/src/setegid.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Get Real User, Effective User, Ral Group, and Effective Group IDs
+ * @brief Get Real User, Effective User, Ral Group, and Effective Group IDs
diff --git a/cpukit/libcsupport/src/sup_fs_mount_iterate.c b/cpukit/libcsupport/src/sup_fs_mount_iterate.c
index 4d986090df..281dfc73e5 100644
--- a/cpukit/libcsupport/src/sup_fs_mount_iterate.c
+++ b/cpukit/libcsupport/src/sup_fs_mount_iterate.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Mount table entry visitor.
  * @ingroup Termios Termios
+ * @brief Mount table entry visitor.
diff --git a/cpukit/libcsupport/src/utsname.c b/cpukit/libcsupport/src/utsname.c
index 22442c192a..c1ca216eb3 100644
--- a/cpukit/libcsupport/src/utsname.c
+++ b/cpukit/libcsupport/src/utsname.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Get System Name
  * @ingroup utsname Service
+ * @brief Get System Name
diff --git a/cpukit/libcsupport/src/write_r.c b/cpukit/libcsupport/src/write_r.c
index 0ecfda106e..6597337efb 100644
--- a/cpukit/libcsupport/src/write_r.c
+++ b/cpukit/libcsupport/src/write_r.c
@@ -1,8 +1,9 @@
  * @file
- * @brief POSIX 1003.1b 6.4.2 - Write to a File
+ * @brief POSIX 1003.1b 6.4.2 - Write to a File
diff --git a/cpukit/libfs/src/defaults/default_are_nodes_equal.c b/cpukit/libfs/src/defaults/default_are_nodes_equal.c
index 2ba47dc1f9..3a6f6df658 100644
--- a/cpukit/libfs/src/defaults/default_are_nodes_equal.c
+++ b/cpukit/libfs/src/defaults/default_are_nodes_equal.c
@@ -1,8 +1,9 @@
  * @file
- * @brief RTEMS Default File System has nodes equal
  * @ingroup LibIOFSOps File System Operations
+ * @brief RTEMS Default File System has nodes equal
diff --git a/cpukit/libfs/src/defaults/default_clone.c b/cpukit/libfs/src/defaults/default_clone.c
index 30a6d256b1..3167c28388 100644
--- a/cpukit/libfs/src/defaults/default_clone.c
+++ b/cpukit/libfs/src/defaults/default_clone.c
@@ -1,8 +1,9 @@
  * @file
- * @brief RTEMS Default File System creates a child process
+ * @brief RTEMS Default File System creates a child process
diff --git a/cpukit/libfs/src/defaults/default_eval_path.c b/cpukit/libfs/src/defaults/default_eval_path.c
index ae4630b33a..4fda3017f4 100644
--- a/cpukit/libfs/src/defaults/default_eval_path.c
+++ b/cpukit/libfs/src/defaults/default_eval_path.c
@@ -1,8 +1,9 @@
  * @file
- * @brief RTEMS Default File System evaluates relative pathname to absolute
+ * @brief RTEMS Default File System evaluates relative pathname to absolute
diff --git a/cpukit/libfs/src/defaults/default_fcntl.c b/cpukit/libfs/src/defaults/default_fcntl.c
index df48ad01a3..c84bb9f08e 100644
--- a/cpukit/libfs/src/defaults/default_fcntl.c
+++ b/cpukit/libfs/src/defaults/default_fcntl.c
@@ -1,8 +1,9 @@
  * @file
- * @brief RTEMS Default Filesystem - Default FCNTL
  * @ingroup libfs
+ * @brief RTEMS Default Filesystem - Default FCNTL
diff --git a/cpukit/libfs/src/defaults/default_freenode.c b/cpukit/libfs/src/defaults/default_freenode.c
index 6ae60115a6..94cf79f35d 100644
--- a/cpukit/libfs/src/defaults/default_freenode.c
+++ b/cpukit/libfs/src/defaults/default_freenode.c
@@ -1,8 +1,9 @@
  * @file
- * @brief RTEMS Default Filesystem - Default Freenode
  * @ingroup libfs
+ * @brief RTEMS Default Filesystem - Default Freenode
diff --git a/cpukit/libfs/src/defaults/default_fstat.c b/cpukit/libfs/src/defaults/default_fstat.c
index dfb62a8171..4b0e151ea5 100644
--- a/cpukit/libfs/src/defaults/default_fstat.c
+++ b/cpukit/libfs/src/defaults/default_fstat.c
@@ -1,8 +1,9 @@
  * @file
- * @brief RTEMS Default File System gets file status
+ * @brief RTEMS Default File System gets file status
diff --git a/cpukit/libfs/src/defaults/default_fsync.c b/cpukit/libfs/src/defaults/default_fsync.c
index 0741eaf8e9..a7ff75d11f 100644
--- a/cpukit/libfs/src/defaults/default_fsync.c
+++ b/cpukit/libfs/src/defaults/default_fsync.c
@@ -1,8 +1,9 @@
  * @file
- * @brief RTEMS Default File System Synchronises changes to a file
+ * @brief RTEMS Default File System Synchronises changes to a file
diff --git a/cpukit/libfs/src/defaults/default_fsync_success.c b/cpukit/libfs/src/defaults/default_fsync_success.c
index b36b953fd0..3b14f46d39 100644
--- a/cpukit/libfs/src/defaults/default_fsync_success.c
+++ b/cpukit/libfs/src/defaults/default_fsync_success.c
@@ -1,8 +1,9 @@
  * @file
- * @brief RTEMS Default Filesystem succeeds synchronizing file's in-core state
+ * @brief RTEMS Default Filesystem succeeds synchronizing file's in-core state
diff --git a/cpukit/libfs/src/defaults/default_ftruncate.c b/cpukit/libfs/src/defaults/default_ftruncate.c
index 1270d6309c..194a94cf98 100644
--- a/cpukit/libfs/src/defaults/default_ftruncate.c
+++ b/cpukit/libfs/src/defaults/default_ftruncate.c
@@ -1,8 +1,9 @@
  * @file
- * @brief RTEMS Default File System Truncates a file to indicated length
+ * @brief RTEMS Default File System Truncates a file to indicated length
diff --git a/cpukit/libfs/src/defaults/default_ftruncate_directory.c b/cpukit/libfs/src/defaults/default_ftruncate_directory.c
index 6db07bd81d..f316bda215 100644
--- a/cpukit/libfs/src/defaults/default_ftruncate_directory.c
+++ b/cpukit/libfs/src/defaults/default_ftruncate_directory.c
@@ -1,8 +1,9 @@
  * @file
- * @brief RTEMS Default Filesystem - Default Ftruncate Directory
  * @ingroup libfs
+ * @brief RTEMS Default Filesystem - Default Ftruncate Directory
diff --git a/cpukit/libfs/src/defaults/default_ioctl.c b/cpukit/libfs/src/defaults/default_ioctl.c
index a6f12dde5d..5c21ffcf34 100644
--- a/cpukit/libfs/src/defaults/default_ioctl.c
+++ b/cpukit/libfs/src/defaults/default_ioctl.c
@@ -1,8 +1,9 @@
  * @file
- * @brief RTEMS Default File System controls a STREAMS device
+ * @brief RTEMS Default File System controls a STREAMS device
diff --git a/cpukit/libfs/src/defaults/default_lock_and_unlock.c b/cpukit/libfs/src/defaults/default_lock_and_unlock.c
index d543b9b6c2..5d73d8dba0 100644
--- a/cpukit/libfs/src/defaults/default_lock_and_unlock.c
+++ b/cpukit/libfs/src/defaults/default_lock_and_unlock.c
@@ -1,8 +1,9 @@
  * @file
- * @brief RTEMS Default File System locks and unlocks rtems filesystem
+ * @brief RTEMS Default File System locks and unlocks rtems filesystem
diff --git a/cpukit/libfs/src/defaults/default_lseek.c b/cpukit/libfs/src/defaults/default_lseek.c
index 3c41147b5a..33724682ee 100644
--- a/cpukit/libfs/src/defaults/default_lseek.c
+++ b/cpukit/libfs/src/defaults/default_lseek.c
@@ -1,8 +1,9 @@
  * @file
- * @brief RTEMS Default File System reposits the read/write file offset
+ * @brief RTEMS Default File System reposits the read/write file offset
diff --git a/cpukit/libfs/src/defaults/default_lseek_directory.c b/cpukit/libfs/src/defaults/default_lseek_directory.c
index bd600ea8b7..b92add50f7 100644
--- a/cpukit/libfs/src/defaults/default_lseek_directory.c
+++ b/cpukit/libfs/src/defaults/default_lseek_directory.c
@@ -1,8 +1,9 @@
  * @file
- * @brief RTEMS Default File System reposits read/write file offset directory
+ * @brief RTEMS Default File System reposits read/write file offset directory
diff --git a/cpukit/libfs/src/defaults/default_lseek_file.c b/cpukit/libfs/src/defaults/default_lseek_file.c
index 68bc8b7fc2..28646059dd 100644
--- a/cpukit/libfs/src/defaults/default_lseek_file.c
+++ b/cpukit/libfs/src/defaults/default_lseek_file.c
@@ -1,8 +1,9 @@
  * @file
- * @brief RTEMS Default File System reposits the offset of the open file fd
+ * @brief RTEMS Default File System reposits the offset of the open file fd
diff --git a/cpukit/libfs/src/defaults/default_mknod.c b/cpukit/libfs/src/defaults/default_mknod.c
index 0bcda6d5af..54abc144fa 100644
--- a/cpukit/libfs/src/defaults/default_mknod.c
+++ b/cpukit/libfs/src/defaults/default_mknod.c
@@ -1,8 +1,9 @@
  * @file
- * @brief RTEMS Default File System creates a special or ordinary file
+ * @brief RTEMS Default File System creates a special or ordinary file
diff --git a/cpukit/libfs/src/defaults/default_mount.c b/cpukit/libfs/src/defaults/default_mount.c
index e1caec49be..ce089c6090 100644
--- a/cpukit/libfs/src/defaults/default_mount.c
+++ b/cpukit/libfs/src/defaults/default_mount.c
@@ -1,8 +1,9 @@
  * @file
- * @brief RTEMS Default File System mounts a filesystem
+ * @brief RTEMS Default File System mounts a filesystem
diff --git a/cpukit/libfs/src/defaults/default_open.c b/cpukit/libfs/src/defaults/default_open.c
index d175515ec5..f868a8eb8e 100644
--- a/cpukit/libfs/src/defaults/default_open.c
+++ b/cpukit/libfs/src/defaults/default_open.c
@@ -1,8 +1,9 @@
  * @file
- * @brief RTEMS Default Filesystem - Default Open
  * @ingroup libfs
+ * @brief RTEMS Default Filesystem - Default Open
diff --git a/cpukit/libfs/src/defaults/default_readlink.c b/cpukit/libfs/src/defaults/default_readlink.c
index 21066b8204..1717b6174a 100644
--- a/cpukit/libfs/src/defaults/default_readlink.c
+++ b/cpukit/libfs/src/defaults/default_readlink.c
@@ -1,8 +1,9 @@
  * @file
- * @brief RTEMS Default Filesystem - Default Readlink
  * @ingroup libfs
+ * @brief RTEMS Default Filesystem - Default Readlink
diff --git a/cpukit/libfs/src/defaults/default_rename.c b/cpukit/libfs/src/defaults/default_rename.c
index f1d50f19b1..b2ae12b260 100644
--- a/cpukit/libfs/src/defaults/default_rename.c
+++ b/cpukit/libfs/src/defaults/default_rename.c
@@ -1,8 +1,9 @@
  * @file
- * @brief RTEMS Default File System Rename Files
+ * @brief RTEMS Default File System Rename Files
diff --git a/cpukit/libfs/src/defaults/default_rmnod.c b/cpukit/libfs/src/defaults/default_rmnod.c
index 60d9aa11ec..1a0f58c6fc 100644
--- a/cpukit/libfs/src/defaults/default_rmnod.c
+++ b/cpukit/libfs/src/defaults/default_rmnod.c
@@ -1,8 +1,9 @@
  * @file
- * @brief RTEMS Default Filesystem - Default Remove Node
  * @ingroup libfs
+ * @brief RTEMS Default Filesystem - Default Remove Node
diff --git a/cpukit/libfs/src/defaults/default_symlink.c b/cpukit/libfs/src/defaults/default_symlink.c
index a6cd10d5e5..a036471ed9 100644
--- a/cpukit/libfs/src/defaults/default_symlink.c
+++ b/cpukit/libfs/src/defaults/default_symlink.c
@@ -1,8 +1,9 @@
  * @file
- * @brief RTEMS Default File System creates a symbolic link to a file
+ * @brief RTEMS Default File System creates a symbolic link to a file
diff --git a/cpukit/libfs/src/defaults/default_unmount.c b/cpukit/libfs/src/defaults/default_unmount.c
index 100d69e451..ca9da15c50 100644
--- a/cpukit/libfs/src/defaults/default_unmount.c
+++ b/cpukit/libfs/src/defaults/default_unmount.c
@@ -1,8 +1,9 @@
  * @file
- * @brief RTEMS Default File System Unmounts
+ * @brief RTEMS Default File System Unmounts
diff --git a/cpukit/libfs/src/defaults/default_utime.c b/cpukit/libfs/src/defaults/default_utime.c
index 866d73ab64..aaf4e445b6 100644
--- a/cpukit/libfs/src/defaults/default_utime.c
+++ b/cpukit/libfs/src/defaults/default_utime.c
@@ -1,8 +1,9 @@
  * @file
- * @brief RTEMS Default File System sets file access and modification times
+ * @brief RTEMS Default File System sets file access and modification times
diff --git a/cpukit/libfs/src/defaults/default_write.c b/cpukit/libfs/src/defaults/default_write.c
index 4af0a4244a..49e451968a 100644
--- a/cpukit/libfs/src/defaults/default_write.c
+++ b/cpukit/libfs/src/defaults/default_write.c
@@ -1,8 +1,9 @@
  * @file
- * @brief RTEMS Default File System sends a message to another user
+ * @brief RTEMS Default File System sends a message to another user
diff --git a/cpukit/libfs/src/dosfs/fat.c b/cpukit/libfs/src/dosfs/fat.c
index d10589d19c..c687477d04 100644
--- a/cpukit/libfs/src/dosfs/fat.c
+++ b/cpukit/libfs/src/dosfs/fat.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Low-level Operations on a Volume with a DOSFS FAT filesystem
  * @ingroup libfs
+ * @brief Low-level Operations on a Volume with a DOSFS FAT filesystem
diff --git a/cpukit/libfs/src/dosfs/fat_fat_operations.c b/cpukit/libfs/src/dosfs/fat_fat_operations.c
index 4ded24074f..ab03c88fdc 100644
--- a/cpukit/libfs/src/dosfs/fat_fat_operations.c
+++ b/cpukit/libfs/src/dosfs/fat_fat_operations.c
@@ -1,8 +1,9 @@
  * @file
- * @brief General operations on File Allocation Table
  * @ingroup libfs_ffo Fat Fat Operations
+ * @brief General operations on File Allocation Table
diff --git a/cpukit/libfs/src/dosfs/fat_file.c b/cpukit/libfs/src/dosfs/fat_file.c
index 57b1f6d91f..b4af8a11ca 100644
--- a/cpukit/libfs/src/dosfs/fat_file.c
+++ b/cpukit/libfs/src/dosfs/fat_file.c
@@ -1,8 +1,9 @@
  * @file
- * @brief General operations on "fat-file"
  * @ingroup libfs_ff Fat File
+ * @brief General operations on "fat-file"
diff --git a/cpukit/libfs/src/dosfs/msdos_conv.c b/cpukit/libfs/src/dosfs/msdos_conv.c
index 1d2ff58105..7efd5a7e80 100644
--- a/cpukit/libfs/src/dosfs/msdos_conv.c
+++ b/cpukit/libfs/src/dosfs/msdos_conv.c
@@ -1,8 +1,9 @@
  * @file
- * @brief MDOS Date Conversion
  * @ingroup libfs_msdos MSDOS FileSystem
+ * @brief MDOS Date Conversion
diff --git a/cpukit/libfs/src/dosfs/msdos_create.c b/cpukit/libfs/src/dosfs/msdos_create.c
index b3a1c18014..1304cc27cd 100644
--- a/cpukit/libfs/src/dosfs/msdos_create.c
+++ b/cpukit/libfs/src/dosfs/msdos_create.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Create a new MSDOS FileSystem node
+ * @brief Create a new MSDOS FileSystem node
diff --git a/cpukit/libfs/src/dosfs/msdos_dir.c b/cpukit/libfs/src/dosfs/msdos_dir.c
index d5322229e3..8c8d43f130 100644
--- a/cpukit/libfs/src/dosfs/msdos_dir.c
+++ b/cpukit/libfs/src/dosfs/msdos_dir.c
@@ -1,8 +1,9 @@
  * @file
- * @brief MSDOS Directory Handlers Implementation
+ * @brief MSDOS Directory Handlers Implementation
diff --git a/cpukit/libfs/src/dosfs/msdos_eval.c b/cpukit/libfs/src/dosfs/msdos_eval.c
index 4220b9ec11..e3e0f5fe96 100644
--- a/cpukit/libfs/src/dosfs/msdos_eval.c
+++ b/cpukit/libfs/src/dosfs/msdos_eval.c
@@ -1,8 +1,9 @@
  * @file
- * @brief MSDOS Evaluation Routines
  * @ingroup libfs
+ * @brief MSDOS Evaluation Routines
diff --git a/cpukit/libfs/src/dosfs/msdos_file.c b/cpukit/libfs/src/dosfs/msdos_file.c
index 770c28ffcf..da6e54b6c6 100644
--- a/cpukit/libfs/src/dosfs/msdos_file.c
+++ b/cpukit/libfs/src/dosfs/msdos_file.c
@@ -1,8 +1,9 @@
  * @file
- * @brief MSDOS File Handlers Implementation
  * @ingroup libfs
+ * @brief MSDOS File Handlers Implementation
diff --git a/cpukit/libfs/src/dosfs/msdos_format.c b/cpukit/libfs/src/dosfs/msdos_format.c
index 008d2285dc..e1e27f2f50 100644
--- a/cpukit/libfs/src/dosfs/msdos_format.c
+++ b/cpukit/libfs/src/dosfs/msdos_format.c
@@ -1,9 +1,10 @@
  * @file
- * @brief RTEMS MSDOS Format Functionality
  * @ingroup libfs
+ * @brief RTEMS MSDOS Format Functionality
  * This function formats a disk partition conforming to MS-DOS conventions
diff --git a/cpukit/libfs/src/dosfs/msdos_free.c b/cpukit/libfs/src/dosfs/msdos_free.c
index 1e66078eff..664103d455 100644
--- a/cpukit/libfs/src/dosfs/msdos_free.c
+++ b/cpukit/libfs/src/dosfs/msdos_free.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Call Fat-File Close Routine
+ * @brief Call Fat-File Close Routine
diff --git a/cpukit/libfs/src/dosfs/msdos_fsunmount.c b/cpukit/libfs/src/dosfs/msdos_fsunmount.c
index e66602ccd8..f90de64069 100644
--- a/cpukit/libfs/src/dosfs/msdos_fsunmount.c
+++ b/cpukit/libfs/src/dosfs/msdos_fsunmount.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Shut Down MSDOS FileSystem
+ * @brief Shut Down MSDOS FileSystem
diff --git a/cpukit/libfs/src/dosfs/msdos_handlers_dir.c b/cpukit/libfs/src/dosfs/msdos_handlers_dir.c
index 805f239c95..77169d9c3f 100644
--- a/cpukit/libfs/src/dosfs/msdos_handlers_dir.c
+++ b/cpukit/libfs/src/dosfs/msdos_handlers_dir.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Directory Handlers Table for MSDOS FileSystem
  * @ingroup libfs
+ * @brief Directory Handlers Table for MSDOS FileSystem
diff --git a/cpukit/libfs/src/dosfs/msdos_handlers_file.c b/cpukit/libfs/src/dosfs/msdos_handlers_file.c
index 9399a4f2f0..73f67acb47 100644
--- a/cpukit/libfs/src/dosfs/msdos_handlers_file.c
+++ b/cpukit/libfs/src/dosfs/msdos_handlers_file.c
@@ -1,8 +1,9 @@
  * @file
- * @brief File Operations Table for MSDOS FileSystem
  * @ingroup libfs
+ * @brief File Operations Table for MSDOS FileSystem
diff --git a/cpukit/libfs/src/dosfs/msdos_init.c b/cpukit/libfs/src/dosfs/msdos_init.c
index dc9c76437d..3ea6f104e8 100644
--- a/cpukit/libfs/src/dosfs/msdos_init.c
+++ b/cpukit/libfs/src/dosfs/msdos_init.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Init Routine for MSDOS
  * @ingroup libfs
+ * @brief Init Routine for MSDOS
diff --git a/cpukit/libfs/src/dosfs/msdos_initsupp.c b/cpukit/libfs/src/dosfs/msdos_initsupp.c
index c581c8b685..e2ee85d4d4 100644
--- a/cpukit/libfs/src/dosfs/msdos_initsupp.c
+++ b/cpukit/libfs/src/dosfs/msdos_initsupp.c
@@ -1,8 +1,9 @@
  * @file
- * @brief MSDOS Filesystem Initialization
+ * @brief MSDOS Filesystem Initialization
diff --git a/cpukit/libfs/src/dosfs/msdos_misc.c b/cpukit/libfs/src/dosfs/msdos_misc.c
index 3f73bd9029..397e590ff5 100644
--- a/cpukit/libfs/src/dosfs/msdos_misc.c
+++ b/cpukit/libfs/src/dosfs/msdos_misc.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Miscellaneous Routines Implementation for MSDOS FileSystem
  * @ingroup libfs
+ * @brief Miscellaneous Routines Implementation for MSDOS FileSystem
diff --git a/cpukit/libfs/src/dosfs/msdos_mknod.c b/cpukit/libfs/src/dosfs/msdos_mknod.c
index b7270c86f8..934805c5f1 100644
--- a/cpukit/libfs/src/dosfs/msdos_mknod.c
+++ b/cpukit/libfs/src/dosfs/msdos_mknod.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Routine for Node Creation in MSDOS Filesystem
+ * @brief Routine for Node Creation in MSDOS Filesystem
diff --git a/cpukit/libfs/src/dosfs/msdos_rename.c b/cpukit/libfs/src/dosfs/msdos_rename.c
index e3beee6842..375ca80362 100644
--- a/cpukit/libfs/src/dosfs/msdos_rename.c
+++ b/cpukit/libfs/src/dosfs/msdos_rename.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Rename a MSDOS FileSystem Node
+ * @brief Rename a MSDOS FileSystem Node
diff --git a/cpukit/libfs/src/dosfs/msdos_rmnod.c b/cpukit/libfs/src/dosfs/msdos_rmnod.c
index 92f8bdb01e..77e280af07 100644
--- a/cpukit/libfs/src/dosfs/msdos_rmnod.c
+++ b/cpukit/libfs/src/dosfs/msdos_rmnod.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Remove Node from MSDOS Directory
+ * @brief Remove Node from MSDOS Directory
diff --git a/cpukit/libfs/src/dosfs/msdos_statvfs.c b/cpukit/libfs/src/dosfs/msdos_statvfs.c
index 59781dd7b9..ea808c05f0 100644
--- a/cpukit/libfs/src/dosfs/msdos_statvfs.c
+++ b/cpukit/libfs/src/dosfs/msdos_statvfs.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Obtain MS-DOS filesystem information
+ * @brief Obtain MS-DOS filesystem information
diff --git a/cpukit/libfs/src/imfs/deviceio.c b/cpukit/libfs/src/imfs/deviceio.c
index 16ce424aa4..c1577ed39f 100644
--- a/cpukit/libfs/src/imfs/deviceio.c
+++ b/cpukit/libfs/src/imfs/deviceio.c
@@ -1,8 +1,9 @@
  * @file
- * @brief IMFS Device Node Handlers
  * @ingroup IMFS
+ * @brief IMFS Device Node Handlers
diff --git a/cpukit/libfs/src/imfs/imfs_chown.c b/cpukit/libfs/src/imfs/imfs_chown.c
index 1b7fb9b5e4..268ed0fc56 100644
--- a/cpukit/libfs/src/imfs/imfs_chown.c
+++ b/cpukit/libfs/src/imfs/imfs_chown.c
@@ -1,8 +1,9 @@
  * @file
- * @brief IMFS Change Owner
  * @ingroup IMFS
+ * @brief IMFS Change Owner
diff --git a/cpukit/libfs/src/imfs/imfs_config.c b/cpukit/libfs/src/imfs/imfs_config.c
index fe65fa720a..72aa9424f9 100644
--- a/cpukit/libfs/src/imfs/imfs_config.c
+++ b/cpukit/libfs/src/imfs/imfs_config.c
@@ -1,8 +1,9 @@
  * @file
- * @brief IMFS Limits and Options
  * @ingroup IMFS
+ * @brief IMFS Limits and Options
diff --git a/cpukit/libfs/src/imfs/imfs_creat.c b/cpukit/libfs/src/imfs/imfs_creat.c
index 08bbc086bb..3a609e160d 100644
--- a/cpukit/libfs/src/imfs/imfs_creat.c
+++ b/cpukit/libfs/src/imfs/imfs_creat.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Create an IMFS Node
  * @ingroup IMFS
+ * @brief Create an IMFS Node
  *  COPYRIGHT (c) 1989-2010.
diff --git a/cpukit/libfs/src/imfs/imfs_eval.c b/cpukit/libfs/src/imfs/imfs_eval.c
index 512b80e58c..5f84e03153 100644
--- a/cpukit/libfs/src/imfs/imfs_eval.c
+++ b/cpukit/libfs/src/imfs/imfs_eval.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Evaluation IMFS Node Support
  * @ingroup IMFS
+ * @brief Evaluation IMFS Node Support
diff --git a/cpukit/libfs/src/imfs/imfs_fchmod.c b/cpukit/libfs/src/imfs/imfs_fchmod.c
index 8537529a19..e8814f73f7 100644
--- a/cpukit/libfs/src/imfs/imfs_fchmod.c
+++ b/cpukit/libfs/src/imfs/imfs_fchmod.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Change IMFS File Mode
  * @ingroup IMFS
+ * @brief Change IMFS File Mode
diff --git a/cpukit/libfs/src/imfs/imfs_fifo.c b/cpukit/libfs/src/imfs/imfs_fifo.c
index e66a436479..1973801cb6 100644
--- a/cpukit/libfs/src/imfs/imfs_fifo.c
+++ b/cpukit/libfs/src/imfs/imfs_fifo.c
@@ -1,8 +1,9 @@
  * @file
- * @brief FIFO Support
  * @ingroup IMFS
+ * @brief FIFO Support
diff --git a/cpukit/libfs/src/imfs/imfs_fsunmount.c b/cpukit/libfs/src/imfs/imfs_fsunmount.c
index 864c933420..4d29c400ef 100644
--- a/cpukit/libfs/src/imfs/imfs_fsunmount.c
+++ b/cpukit/libfs/src/imfs/imfs_fsunmount.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Unmount this Instance of IMFS
  * @ingroup IMFS
+ * @brief Unmount this Instance of IMFS
diff --git a/cpukit/libfs/src/imfs/imfs_handlers_device.c b/cpukit/libfs/src/imfs/imfs_handlers_device.c
index 12a19bd663..ab32ce4b73 100644
--- a/cpukit/libfs/src/imfs/imfs_handlers_device.c
+++ b/cpukit/libfs/src/imfs/imfs_handlers_device.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Device Operations Table
  * @ingroup IMFS
+ * @brief Device Operations Table
diff --git a/cpukit/libfs/src/imfs/imfs_initsupp.c b/cpukit/libfs/src/imfs/imfs_initsupp.c
index 2c75ef5ff2..4c09cf750e 100644
--- a/cpukit/libfs/src/imfs/imfs_initsupp.c
+++ b/cpukit/libfs/src/imfs/imfs_initsupp.c
@@ -1,8 +1,9 @@
  * @file
- * @brief IMFS Node Support
  * @ingroup IMFS
+ * @brief IMFS Node Support
diff --git a/cpukit/libfs/src/imfs/imfs_link.c b/cpukit/libfs/src/imfs/imfs_link.c
index 87211ad93e..16ad862a50 100644
--- a/cpukit/libfs/src/imfs/imfs_link.c
+++ b/cpukit/libfs/src/imfs/imfs_link.c
@@ -1,8 +1,9 @@
  * @file
- * @brief IMFS Create a New Link Node
  * @ingroup IMFS
+ * @brief IMFS Create a New Link Node
diff --git a/cpukit/libfs/src/imfs/imfs_load_tar.c b/cpukit/libfs/src/imfs/imfs_load_tar.c
index 47a506b042..a0cc115be4 100644
--- a/cpukit/libfs/src/imfs/imfs_load_tar.c
+++ b/cpukit/libfs/src/imfs/imfs_load_tar.c
@@ -1,8 +1,9 @@
  * @file
- * @brief RTEMS Load Tarfs
  * @ingroup IMFS
+ * @brief RTEMS Load Tarfs
diff --git a/cpukit/libfs/src/imfs/imfs_make_generic_node.c b/cpukit/libfs/src/imfs/imfs_make_generic_node.c
index 3d1af1da41..36426d7719 100644
--- a/cpukit/libfs/src/imfs/imfs_make_generic_node.c
+++ b/cpukit/libfs/src/imfs/imfs_make_generic_node.c
@@ -1,8 +1,9 @@
  * @file
- * @brief IMFS Make a Generic Node
  * @ingroup IMFS
+ * @brief IMFS Make a Generic Node
diff --git a/cpukit/libfs/src/imfs/imfs_memfile.c b/cpukit/libfs/src/imfs/imfs_memfile.c
index c48e253f8b..0f19859fac 100644
--- a/cpukit/libfs/src/imfs/imfs_memfile.c
+++ b/cpukit/libfs/src/imfs/imfs_memfile.c
@@ -1,8 +1,9 @@
  * @file
- * @brief IMFS Memory File Handlers
  * @ingroup IMFS
+ * @brief IMFS Memory File Handlers
diff --git a/cpukit/libfs/src/imfs/imfs_mknod.c b/cpukit/libfs/src/imfs/imfs_mknod.c
index 65f48416d1..8d23f12f55 100644
--- a/cpukit/libfs/src/imfs/imfs_mknod.c
+++ b/cpukit/libfs/src/imfs/imfs_mknod.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Create a IMFS Node
  * @ingroup IMFS
+ * @brief Create a IMFS Node
diff --git a/cpukit/libfs/src/imfs/imfs_mount.c b/cpukit/libfs/src/imfs/imfs_mount.c
index b00a59d85b..371e88e106 100644
--- a/cpukit/libfs/src/imfs/imfs_mount.c
+++ b/cpukit/libfs/src/imfs/imfs_mount.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Mount an IMFS
  * @ingroup IMFS
+ * @brief Mount an IMFS
diff --git a/cpukit/libfs/src/imfs/imfs_node.c b/cpukit/libfs/src/imfs/imfs_node.c
index f5266b650b..a89298ffc2 100644
--- a/cpukit/libfs/src/imfs/imfs_node.c
+++ b/cpukit/libfs/src/imfs/imfs_node.c
@@ -1,8 +1,9 @@
  * @file
  * @ingroup IMFS
diff --git a/cpukit/libfs/src/imfs/imfs_rename.c b/cpukit/libfs/src/imfs/imfs_rename.c
index 164a7896ab..701500872d 100644
--- a/cpukit/libfs/src/imfs/imfs_rename.c
+++ b/cpukit/libfs/src/imfs/imfs_rename.c
@@ -1,8 +1,9 @@
  * @file
- * @brief IMFS Rename
  * @ingroup IMFS
+ * @brief IMFS Rename
diff --git a/cpukit/libfs/src/imfs/imfs_rmnod.c b/cpukit/libfs/src/imfs/imfs_rmnod.c
index 9fad0b7d1b..0aaadb7ebe 100644
--- a/cpukit/libfs/src/imfs/imfs_rmnod.c
+++ b/cpukit/libfs/src/imfs/imfs_rmnod.c
@@ -1,8 +1,9 @@
  * @file
- * @brief IMFS Node Removal Handler
  * @ingroup IMFS
+ * @brief IMFS Node Removal Handler
diff --git a/cpukit/libfs/src/imfs/imfs_stat.c b/cpukit/libfs/src/imfs/imfs_stat.c
index 3e73a150b2..bbca49f8ef 100644
--- a/cpukit/libfs/src/imfs/imfs_stat.c
+++ b/cpukit/libfs/src/imfs/imfs_stat.c
@@ -1,8 +1,9 @@
  * @file
- * @brief IMFS Stat
  * @ingroup IMFS
+ * @brief IMFS Stat
diff --git a/cpukit/libfs/src/imfs/imfs_symlink.c b/cpukit/libfs/src/imfs/imfs_symlink.c
index 58eecae910..7323cc0241 100644
--- a/cpukit/libfs/src/imfs/imfs_symlink.c
+++ b/cpukit/libfs/src/imfs/imfs_symlink.c
@@ -1,8 +1,9 @@
  * @file
- * @brief IMFS Create a New Symbolic Link Node
  * @ingroup IMFS
+ * @brief IMFS Create a New Symbolic Link Node
diff --git a/cpukit/libfs/src/imfs/imfs_unmount.c b/cpukit/libfs/src/imfs/imfs_unmount.c
index 6ed3ba657e..0e9f5eee84 100644
--- a/cpukit/libfs/src/imfs/imfs_unmount.c
+++ b/cpukit/libfs/src/imfs/imfs_unmount.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Unmount an IMFS
  * @ingroup IMFS
+ * @brief Unmount an IMFS
diff --git a/cpukit/libfs/src/imfs/imfs_utime.c b/cpukit/libfs/src/imfs/imfs_utime.c
index e02545c167..21e5139ce7 100644
--- a/cpukit/libfs/src/imfs/imfs_utime.c
+++ b/cpukit/libfs/src/imfs/imfs_utime.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Set IMFS File Access and Modification Times
  * @ingroup IMFS
+ * @brief Set IMFS File Access and Modification Times
diff --git a/cpukit/libfs/src/imfs/ioman.c b/cpukit/libfs/src/imfs/ioman.c
index 60d4777980..59b93e400c 100644
--- a/cpukit/libfs/src/imfs/ioman.c
+++ b/cpukit/libfs/src/imfs/ioman.c
@@ -1,8 +1,9 @@
  * @file
- * @brief RTEMS Register IO Name
  * @ingroup ClassicIO
+ * @brief RTEMS Register IO Name
diff --git a/cpukit/libfs/src/nfsclient/proto/mount_prot_xdr.c b/cpukit/libfs/src/nfsclient/proto/mount_prot_xdr.c
index a7950c1b39..05bace6b83 100644
--- a/cpukit/libfs/src/nfsclient/proto/mount_prot_xdr.c
+++ b/cpukit/libfs/src/nfsclient/proto/mount_prot_xdr.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Mount Prot XDR
  * @ingroup libfs_nfsclient_mount_prot Mount Prot
+ * @brief Mount Prot XDR
diff --git a/cpukit/libfs/src/nfsclient/proto/nfs_prot_xdr.c b/cpukit/libfs/src/nfsclient/proto/nfs_prot_xdr.c
index 40496a72ff..c7a51a72bd 100644
--- a/cpukit/libfs/src/nfsclient/proto/nfs_prot_xdr.c
+++ b/cpukit/libfs/src/nfsclient/proto/nfs_prot_xdr.c
@@ -1,8 +1,9 @@
  * @file
- * @brief NFS Prot XDR
  * @ingroup libfs_nfsclient_nfs_prot NFS Prot
+ * @brief NFS Prot XDR
diff --git a/cpukit/libfs/src/nfsclient/src/nfs.c b/cpukit/libfs/src/nfsclient/src/nfs.c
index 411a478c0d..c482db9b2a 100644
--- a/cpukit/libfs/src/nfsclient/src/nfs.c
+++ b/cpukit/libfs/src/nfsclient/src/nfs.c
@@ -1,9 +1,10 @@
  * @file
- * @brief NFS Client Implementation for RTEMS
  * @ingroup libfs
+ * @brief NFS Client Implementation for RTEMS
  * Hooks Into the RTEMS NFS Filesystem
diff --git a/cpukit/libfs/src/nfsclient/src/rpcio.c b/cpukit/libfs/src/nfsclient/src/rpcio.c
index 886226e104..2e36ede164 100644
--- a/cpukit/libfs/src/nfsclient/src/rpcio.c
+++ b/cpukit/libfs/src/nfsclient/src/rpcio.c
@@ -1,9 +1,10 @@
  * @file
- * @brief RPC Multiplexor for a Multitasking Environment
  * @ingroup libfs
+ * @brief RPC Multiplexor for a Multitasking Environment
  * This code funnels arbitrary task's UDP/RPC requests
  * through one socket to arbitrary servers.
  * The replies are gathered and dispatched to the
diff --git a/cpukit/libfs/src/nfsclient/src/sock_mbuf.c b/cpukit/libfs/src/nfsclient/src/sock_mbuf.c
index 45a2cd6dcb..f48cd0dff8 100644
--- a/cpukit/libfs/src/nfsclient/src/sock_mbuf.c
+++ b/cpukit/libfs/src/nfsclient/src/sock_mbuf.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Sock Mbuf
  * @ingroup libfs
+ * @brief Sock Mbuf
diff --git a/cpukit/libfs/src/nfsclient/src/xdr_mbuf.c b/cpukit/libfs/src/nfsclient/src/xdr_mbuf.c
index 451c385b41..cf35c20cd2 100644
--- a/cpukit/libfs/src/nfsclient/src/xdr_mbuf.c
+++ b/cpukit/libfs/src/nfsclient/src/xdr_mbuf.c
@@ -1,9 +1,10 @@
  * @file
- * @brief XDR Implementation Using mbuf Buffers
  * @ingroup libfs
+ * @brief XDR Implementation Using mbuf Buffers
  * xdr_mbuf is derived from xdr_mem
diff --git a/cpukit/libfs/src/pipe/fifo.c b/cpukit/libfs/src/pipe/fifo.c
index 077d277021..2645dab099 100644
--- a/cpukit/libfs/src/pipe/fifo.c
+++ b/cpukit/libfs/src/pipe/fifo.c
@@ -1,8 +1,9 @@
  * @file
- * @brief FIFO/Pipe Support
  * @ingroup FIFO_PIPE
+ * @brief FIFO/Pipe Support
diff --git a/cpukit/libfs/src/pipe/pipe.c b/cpukit/libfs/src/pipe/pipe.c
index d8c1c2d551..93e3723185 100644
--- a/cpukit/libfs/src/pipe/pipe.c
+++ b/cpukit/libfs/src/pipe/pipe.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Create an Anonymous Pipe
+ * @brief Create an Anonymous Pipe
diff --git a/cpukit/libfs/src/rfs/rtems-rfs-bitmaps.c b/cpukit/libfs/src/rfs/rtems-rfs-bitmaps.c
index 7d3556f9aa..7973e85083 100644
--- a/cpukit/libfs/src/rfs/rtems-rfs-bitmaps.c
+++ b/cpukit/libfs/src/rfs/rtems-rfs-bitmaps.c
@@ -1,9 +1,10 @@
  * @file
- * @brief RTEMS File Systems Bitmap Routines
+ * @brief RTEMS File Systems Bitmap Routines
  * These functions manage bit maps. A bit map consists of the map of bit
  * allocated in a block and a search map where a bit represents 32 actual
  * bits. The search map allows for a faster search for an available bit as 32
diff --git a/cpukit/libfs/src/rfs/rtems-rfs-block.c b/cpukit/libfs/src/rfs/rtems-rfs-block.c
index da84d0b56f..5dc8634818 100644
--- a/cpukit/libfs/src/rfs/rtems-rfs-block.c
+++ b/cpukit/libfs/src/rfs/rtems-rfs-block.c
@@ -1,8 +1,9 @@
  * @file
- * @brief RTEMS File Systems Block Routines
+ * @brief RTEMS File Systems Block Routines
  * These functions manage blocks in the RFS file system. A block is an area of
  * the media and its size is set for a each specific media. The block size is
diff --git a/cpukit/libfs/src/rfs/rtems-rfs-buffer-bdbuf.c b/cpukit/libfs/src/rfs/rtems-rfs-buffer-bdbuf.c
index 11513bfbfa..b1b6027b83 100644
--- a/cpukit/libfs/src/rfs/rtems-rfs-buffer-bdbuf.c
+++ b/cpukit/libfs/src/rfs/rtems-rfs-buffer-bdbuf.c
@@ -1,9 +1,10 @@
  * @file
- * @brief RTEMS File Systems Buffer Routines
+ * @brief RTEMS File Systems Buffer Routines
  * RTEMS File Systems Buffer Routines for the RTEMS libblock BD buffer cache.
diff --git a/cpukit/libfs/src/rfs/rtems-rfs-buffer-devio.c b/cpukit/libfs/src/rfs/rtems-rfs-buffer-devio.c
index 4537eaf985..0f5931141a 100644
--- a/cpukit/libfs/src/rfs/rtems-rfs-buffer-devio.c
+++ b/cpukit/libfs/src/rfs/rtems-rfs-buffer-devio.c
@@ -1,8 +1,9 @@
  * @file
diff --git a/cpukit/libfs/src/rfs/rtems-rfs-buffer.c b/cpukit/libfs/src/rfs/rtems-rfs-buffer.c
index e5e5e7dad9..814de10dbe 100644
--- a/cpukit/libfs/src/rfs/rtems-rfs-buffer.c
+++ b/cpukit/libfs/src/rfs/rtems-rfs-buffer.c
@@ -1,8 +1,9 @@
  * @file
diff --git a/cpukit/libfs/src/rfs/rtems-rfs-dir-hash.c b/cpukit/libfs/src/rfs/rtems-rfs-dir-hash.c
index 75cbef2621..96da1a86fa 100644
--- a/cpukit/libfs/src/rfs/rtems-rfs-dir-hash.c
+++ b/cpukit/libfs/src/rfs/rtems-rfs-dir-hash.c
@@ -1,8 +1,9 @@
  * @file
- * @brief RTEMS File Systems Directory Hash function
+ * @brief RTEMS File Systems Directory Hash function
 #ifdef HAVE_CONFIG_H
diff --git a/cpukit/libfs/src/rfs/rtems-rfs-dir.c b/cpukit/libfs/src/rfs/rtems-rfs-dir.c
index 09e8782ffc..227fda3b91 100644
--- a/cpukit/libfs/src/rfs/rtems-rfs-dir.c
+++ b/cpukit/libfs/src/rfs/rtems-rfs-dir.c
@@ -1,9 +1,10 @@
  * @file
- * @brief RTEMS File Systems Directory Routines
+ * @brief RTEMS File Systems Directory Routines
  * These functions manage blocks in the directory format. A directory entry is
  * a variable length record in the block. The entry consists of a length, hash
  * and the string. The length allows the next entry to be located and the hash
diff --git a/cpukit/libfs/src/rfs/rtems-rfs-file-system.c b/cpukit/libfs/src/rfs/rtems-rfs-file-system.c
index 6089bf2d14..11ce9f353c 100644
--- a/cpukit/libfs/src/rfs/rtems-rfs-file-system.c
+++ b/cpukit/libfs/src/rfs/rtems-rfs-file-system.c
@@ -1,8 +1,9 @@
  * @file
- * @brief RTEMS File Systems Open
+ * @brief RTEMS File Systems Open
  * Open the file system by reading the superblock and then the group data.
diff --git a/cpukit/libfs/src/rfs/rtems-rfs-file.c b/cpukit/libfs/src/rfs/rtems-rfs-file.c
index 897cdc1bea..b59768defd 100644
--- a/cpukit/libfs/src/rfs/rtems-rfs-file.c
+++ b/cpukit/libfs/src/rfs/rtems-rfs-file.c
@@ -1,9 +1,10 @@
  * @file
- * @brief RTEMS File Systems File Routines
+ * @brief RTEMS File Systems File Routines
  * These functions manage files.
diff --git a/cpukit/libfs/src/rfs/rtems-rfs-format.c b/cpukit/libfs/src/rfs/rtems-rfs-format.c
index 82387538b4..9acf152061 100644
--- a/cpukit/libfs/src/rfs/rtems-rfs-format.c
+++ b/cpukit/libfs/src/rfs/rtems-rfs-format.c
@@ -1,8 +1,9 @@
  * @file
- * @brief RTEMS File Systems Format
+ * @brief RTEMS File Systems Format
  * Format the file system ready for use.
diff --git a/cpukit/libfs/src/rfs/rtems-rfs-group.c b/cpukit/libfs/src/rfs/rtems-rfs-group.c
index 1405f2afa3..5f2808f166 100644
--- a/cpukit/libfs/src/rfs/rtems-rfs-group.c
+++ b/cpukit/libfs/src/rfs/rtems-rfs-group.c
@@ -1,9 +1,10 @@
  * @file
- * @brief RTEMS File Systems Group Routines
+ * @brief RTEMS File Systems Group Routines
  * These functions open and close a group as well as manage bit allocations
  * within a group.
diff --git a/cpukit/libfs/src/rfs/rtems-rfs-inode.c b/cpukit/libfs/src/rfs/rtems-rfs-inode.c
index 8124b399a2..644042eb8c 100644
--- a/cpukit/libfs/src/rfs/rtems-rfs-inode.c
+++ b/cpukit/libfs/src/rfs/rtems-rfs-inode.c
@@ -1,9 +1,10 @@
  * @file
- * @brief RTEMS File Systems Inode Routines
+ * @brief RTEMS File Systems Inode Routines
  * These functions manage inodes in the RFS file system. An inode is part of a
  * block that reside after the bitmaps in the group.
diff --git a/cpukit/libfs/src/rfs/rtems-rfs-link.c b/cpukit/libfs/src/rfs/rtems-rfs-link.c
index 9689a56b09..5a8c70188b 100644
--- a/cpukit/libfs/src/rfs/rtems-rfs-link.c
+++ b/cpukit/libfs/src/rfs/rtems-rfs-link.c
@@ -1,8 +1,9 @@
  * @file
- * @brief RTEMS File Systems Link Routines
+ * @brief RTEMS File Systems Link Routines
  * These functions manage links. A link is the addition of a directory entry
  * in a parent directory and incrementing the links count in the inode.
diff --git a/cpukit/libfs/src/rfs/rtems-rfs-mutex.c b/cpukit/libfs/src/rfs/rtems-rfs-mutex.c
index f05c3e3155..34d0dbabec 100644
--- a/cpukit/libfs/src/rfs/rtems-rfs-mutex.c
+++ b/cpukit/libfs/src/rfs/rtems-rfs-mutex.c
@@ -1,8 +1,9 @@
  * @file
- * @brief RTEMS File System Mutex
+ * @brief RTEMS File System Mutex
  *  COPYRIGHT (c) 2010 Chris Johns <chrisj at rtems.org>
diff --git a/cpukit/libfs/src/rfs/rtems-rfs-rtems-dev.c b/cpukit/libfs/src/rfs/rtems-rfs-rtems-dev.c
index 1f28fa9b38..0f31a54fe2 100644
--- a/cpukit/libfs/src/rfs/rtems-rfs-rtems-dev.c
+++ b/cpukit/libfs/src/rfs/rtems-rfs-rtems-dev.c
@@ -1,8 +1,9 @@
  * @file
- * @brief RTEMS RFS Device Interface
+ * @brief RTEMS RFS Device Interface
  * This file contains the set of handlers used to map operations on RFS device
  * nodes onto calls to the RTEMS Classic API IO Manager.
diff --git a/cpukit/libfs/src/rfs/rtems-rfs-rtems-dir.c b/cpukit/libfs/src/rfs/rtems-rfs-rtems-dir.c
index 38e8f3764b..d1d28f5185 100644
--- a/cpukit/libfs/src/rfs/rtems-rfs-rtems-dir.c
+++ b/cpukit/libfs/src/rfs/rtems-rfs-rtems-dir.c
@@ -1,8 +1,9 @@
  * @file
- * @brief RTEMS RFS Directory Access Routines
+ * @brief RTEMS RFS Directory Access Routines
diff --git a/cpukit/libfs/src/rfs/rtems-rfs-rtems-file.c b/cpukit/libfs/src/rfs/rtems-rfs-rtems-file.c
index 8d94f1c909..2c406cee5b 100644
--- a/cpukit/libfs/src/rfs/rtems-rfs-rtems-file.c
+++ b/cpukit/libfs/src/rfs/rtems-rfs-rtems-file.c
@@ -1,9 +1,10 @@
  * @file
- * @brief RTEMS RFS File Handlers
+ * @brief RTEMS RFS File Handlers
  * This file contains the set of handlers used to process operations on
  * RFS file nodes.
diff --git a/cpukit/libfs/src/rfs/rtems-rfs-rtems-utils.c b/cpukit/libfs/src/rfs/rtems-rfs-rtems-utils.c
index 61ea42caeb..9db46fa902 100644
--- a/cpukit/libfs/src/rfs/rtems-rfs-rtems-utils.c
+++ b/cpukit/libfs/src/rfs/rtems-rfs-rtems-utils.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Set of Utility Functions to Support RTEMS RFS on RTEMS
+ * @brief Set of Utility Functions to Support RTEMS RFS on RTEMS
diff --git a/cpukit/libfs/src/rfs/rtems-rfs-rtems.c b/cpukit/libfs/src/rfs/rtems-rfs-rtems.c
index c4d3c06067..35db9eeca1 100644
--- a/cpukit/libfs/src/rfs/rtems-rfs-rtems.c
+++ b/cpukit/libfs/src/rfs/rtems-rfs-rtems.c
@@ -1,8 +1,9 @@
  * @file
- * @brief RTEMS File System Interface for RTEMS
+ * @brief RTEMS File System Interface for RTEMS
diff --git a/cpukit/libfs/src/rfs/rtems-rfs-shell.c b/cpukit/libfs/src/rfs/rtems-rfs-shell.c
index a3ad6b24d1..81d2d06037 100644
--- a/cpukit/libfs/src/rfs/rtems-rfs-shell.c
+++ b/cpukit/libfs/src/rfs/rtems-rfs-shell.c
@@ -1,8 +1,9 @@
  * @file
- * @brief RTEMS File Systems Shell Commands Support
+ * @brief RTEMS File Systems Shell Commands Support
diff --git a/cpukit/libfs/src/rfs/rtems-rfs-trace.c b/cpukit/libfs/src/rfs/rtems-rfs-trace.c
index f2cc2dbae2..b064898074 100644
--- a/cpukit/libfs/src/rfs/rtems-rfs-trace.c
+++ b/cpukit/libfs/src/rfs/rtems-rfs-trace.c
@@ -1,8 +1,9 @@
  * @file
- * @brief RTEMS File Systems Trace Support
+ * @brief RTEMS File Systems Trace Support
diff --git a/cpukit/libmisc/bspcmdline/bspcmdline_get.c b/cpukit/libmisc/bspcmdline/bspcmdline_get.c
index c518484e15..029cb6b8e6 100644
--- a/cpukit/libmisc/bspcmdline/bspcmdline_get.c
+++ b/cpukit/libmisc/bspcmdline/bspcmdline_get.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Obtain Pointer to BSP Boot Command String
  * @ingroup BSPCommandLine BSP Command Line Helpers
+ * @brief Obtain Pointer to BSP Boot Command String
diff --git a/cpukit/libmisc/bspcmdline/bspcmdline_getparam.c b/cpukit/libmisc/bspcmdline/bspcmdline_getparam.c
index 63da02dac3..f18773a49a 100644
--- a/cpukit/libmisc/bspcmdline/bspcmdline_getparam.c
+++ b/cpukit/libmisc/bspcmdline/bspcmdline_getparam.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Obtain COPY of the Entire Matching Argument
+ * @brief Obtain COPY of the Entire Matching Argument
diff --git a/cpukit/libmisc/bspcmdline/bspcmdline_getparamraw.c b/cpukit/libmisc/bspcmdline/bspcmdline_getparamraw.c
index d1f11c7bec..db4a01aed3 100644
--- a/cpukit/libmisc/bspcmdline/bspcmdline_getparamraw.c
+++ b/cpukit/libmisc/bspcmdline/bspcmdline_getparamraw.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Obtain Pointer to the Entire Matching Argument
+ * @brief Obtain Pointer to the Entire Matching Argument
diff --git a/cpukit/libmisc/bspcmdline/bspcmdline_getparamrhs.c b/cpukit/libmisc/bspcmdline/bspcmdline_getparamrhs.c
index 4bfe062afe..aab5b02850 100644
--- a/cpukit/libmisc/bspcmdline/bspcmdline_getparamrhs.c
+++ b/cpukit/libmisc/bspcmdline/bspcmdline_getparamrhs.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Obtain COPY of the Right Hand Side of the Matching Argument
+ * @brief Obtain COPY of the Right Hand Side of the Matching Argument
diff --git a/cpukit/libmisc/cpuuse/cpuusagedata.c b/cpukit/libmisc/cpuuse/cpuusagedata.c
index d855a4da90..0d06dd3e5c 100644
--- a/cpukit/libmisc/cpuuse/cpuusagedata.c
+++ b/cpukit/libmisc/cpuuse/cpuusagedata.c
@@ -1,9 +1,10 @@
  * @file
- * @brief CPU Usage Data
  * @ingroup libmisc_cpuuse CPU Usage
+ * @brief CPU Usage Data
  * CPU Usage Reporter - Shared Data
diff --git a/cpukit/libmisc/cpuuse/cpuusagereport.c b/cpukit/libmisc/cpuuse/cpuusagereport.c
index 2a01a8aa3d..08bc5bb541 100644
--- a/cpukit/libmisc/cpuuse/cpuusagereport.c
+++ b/cpukit/libmisc/cpuuse/cpuusagereport.c
@@ -1,8 +1,9 @@
  * @file
- * @brief CPU Usage Report
+ * @brief CPU Usage Report
diff --git a/cpukit/libmisc/cpuuse/cpuusagereset.c b/cpukit/libmisc/cpuuse/cpuusagereset.c
index 455651e19f..10d8ebec48 100644
--- a/cpukit/libmisc/cpuuse/cpuusagereset.c
+++ b/cpukit/libmisc/cpuuse/cpuusagereset.c
@@ -1,8 +1,9 @@
  * @file
- * @brief CPU Usage Reset
+ * @brief CPU Usage Reset
diff --git a/cpukit/libmisc/cpuuse/cpuusagetop.c b/cpukit/libmisc/cpuuse/cpuusagetop.c
index 66cbda9277..9f19b27439 100644
--- a/cpukit/libmisc/cpuuse/cpuusagetop.c
+++ b/cpukit/libmisc/cpuuse/cpuusagetop.c
@@ -1,8 +1,9 @@
  * @file
- * @brief CPU Usage Top
+ * @brief CPU Usage Top
diff --git a/cpukit/libmisc/devnull/devnull.c b/cpukit/libmisc/devnull/devnull.c
index 6ec70e85a4..9adc47c665 100644
--- a/cpukit/libmisc/devnull/devnull.c
+++ b/cpukit/libmisc/devnull/devnull.c
@@ -1,9 +1,10 @@
  * @file
- * @brief Null Device Driver Init Routine
  * @ingroup libmisc_devnull Device Driver
+ * @brief Null Device Driver Init Routine
  * Derived from rtems' stub driver.
diff --git a/cpukit/libmisc/devnull/devzero.c b/cpukit/libmisc/devnull/devzero.c
index 4aecec6528..a993e5c810 100644
--- a/cpukit/libmisc/devnull/devzero.c
+++ b/cpukit/libmisc/devnull/devzero.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Devzero
+ * @brief Devzero
diff --git a/cpukit/libmisc/dumpbuf/dumpbuf.c b/cpukit/libmisc/dumpbuf/dumpbuf.c
index ed4868cdb4..7f8128259f 100644
--- a/cpukit/libmisc/dumpbuf/dumpbuf.c
+++ b/cpukit/libmisc/dumpbuf/dumpbuf.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Dump Buffer
  * @ingroup libmisc_dumpbuf Print Memory Buffer
+ * @brief Dump Buffer
diff --git a/cpukit/libmisc/fb/mw_print.c b/cpukit/libmisc/fb/mw_print.c
index 1d226b7d0f..34979960c9 100644
--- a/cpukit/libmisc/fb/mw_print.c
+++ b/cpukit/libmisc/fb/mw_print.c
@@ -1,8 +1,9 @@
  * @file
- * @brief MicroWindows Print
  * @ingroup libmisc_fb_mw Input Devices for MicroWindows
+ * @brief MicroWindows Print
diff --git a/cpukit/libmisc/fb/mw_uid.c b/cpukit/libmisc/fb/mw_uid.c
index db98f1fa9c..c3933d6e99 100644
--- a/cpukit/libmisc/fb/mw_uid.c
+++ b/cpukit/libmisc/fb/mw_uid.c
@@ -1,9 +1,10 @@
  * @file
- * @brief MicroWindows UID
+ * @brief MicroWindows UID
  * This module implements the input devices interface used by MicroWindows
  * in an embedded system environment.  It uses the RTEMS message queue as
  * the repository for the messages posted by the devices registered.
diff --git a/cpukit/libmisc/fsmount/fsmount.c b/cpukit/libmisc/fsmount/fsmount.c
index 91b57388c1..190d0dd511 100644
--- a/cpukit/libmisc/fsmount/fsmount.c
+++ b/cpukit/libmisc/fsmount/fsmount.c
@@ -1,8 +1,9 @@
  * @file
- * @brief File System Mount Functions
  * @ingroup rtems_fstab File System Mount Support
+ * @brief File System Mount Functions
diff --git a/cpukit/libmisc/mouse/mouse_parser.c b/cpukit/libmisc/mouse/mouse_parser.c
index 573e6cf5fd..5701dcd9f5 100644
--- a/cpukit/libmisc/mouse/mouse_parser.c
+++ b/cpukit/libmisc/mouse/mouse_parser.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Opens a Serial Port Directly, and Interprets Serial Data
  * @ingroup libmisc_mouse Mouse Parser Engine
+ * @brief Opens a Serial Port Directly, and Interprets Serial Data
diff --git a/cpukit/libmisc/mouse/serial_mouse.c b/cpukit/libmisc/mouse/serial_mouse.c
index 874903a607..53a174df57 100644
--- a/cpukit/libmisc/mouse/serial_mouse.c
+++ b/cpukit/libmisc/mouse/serial_mouse.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Serial Mouse Driver
  * @ingroup libmisc_mouse Serial Mouse Driver
+ * @brief Serial Mouse Driver
diff --git a/cpukit/libmisc/shell/main_df.c b/cpukit/libmisc/shell/main_df.c
index ac1d5f6452..d4266147a6 100644
--- a/cpukit/libmisc/shell/main_df.c
+++ b/cpukit/libmisc/shell/main_df.c
@@ -1,8 +1,9 @@
  *  df Shell Command Implmentation
diff --git a/cpukit/libmisc/stackchk/check.c b/cpukit/libmisc/stackchk/check.c
index 0c859f6375..ab08155c92 100644
--- a/cpukit/libmisc/stackchk/check.c
+++ b/cpukit/libmisc/stackchk/check.c
@@ -1,9 +1,10 @@
  * @file
- * @brief Stack Overflow Check User Extension Set
  * @ingroup libmisc_stackchk Stack Checker Mechanism
+ * @brief Stack Overflow Check User Extension Set
  * NOTE:  This extension set automatically determines at
  *         initialization time whether the stack for this
  *         CPU grows up or down and installs the correct
diff --git a/cpukit/libmisc/stringto/stringtodouble.c b/cpukit/libmisc/stringto/stringtodouble.c
index 169719c210..c3cd851077 100644
--- a/cpukit/libmisc/stringto/stringtodouble.c
+++ b/cpukit/libmisc/stringto/stringtodouble.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Convert String to Double (with validation)
  * @ingroup libmisc_conv_help Conversion Helpers
+ * @brief Convert String to Double (with validation)
diff --git a/cpukit/libmisc/stringto/stringtofloat.c b/cpukit/libmisc/stringto/stringtofloat.c
index 2c3d407f7a..46326af960 100644
--- a/cpukit/libmisc/stringto/stringtofloat.c
+++ b/cpukit/libmisc/stringto/stringtofloat.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Convert String to Float (with validation)
+ * @brief Convert String to Float (with validation)
diff --git a/cpukit/libmisc/stringto/stringtoint.c b/cpukit/libmisc/stringto/stringtoint.c
index 16b95d02e1..fdd85cad3d 100644
--- a/cpukit/libmisc/stringto/stringtoint.c
+++ b/cpukit/libmisc/stringto/stringtoint.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Convert String to Int (with validation)
+ * @brief Convert String to Int (with validation)
diff --git a/cpukit/libmisc/stringto/stringtolong.c b/cpukit/libmisc/stringto/stringtolong.c
index 2c6abb96e8..7f5fa0b5aa 100644
--- a/cpukit/libmisc/stringto/stringtolong.c
+++ b/cpukit/libmisc/stringto/stringtolong.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Convert String to Long (with validation)
+ * @brief Convert String to Long (with validation)
diff --git a/cpukit/libmisc/stringto/stringtolongdouble.c b/cpukit/libmisc/stringto/stringtolongdouble.c
index e403653b80..754e0b11e7 100644
--- a/cpukit/libmisc/stringto/stringtolongdouble.c
+++ b/cpukit/libmisc/stringto/stringtolongdouble.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Convert String to long double (with validation)
+ * @brief Convert String to long double (with validation)
diff --git a/cpukit/libmisc/stringto/stringtolonglong.c b/cpukit/libmisc/stringto/stringtolonglong.c
index 11f259cd2a..c35188529e 100644
--- a/cpukit/libmisc/stringto/stringtolonglong.c
+++ b/cpukit/libmisc/stringto/stringtolonglong.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Convert String to Long Long (with validation)
+ * @brief Convert String to Long Long (with validation)
diff --git a/cpukit/libmisc/stringto/stringtopointer.c b/cpukit/libmisc/stringto/stringtopointer.c
index ecc4beabd9..5d69768742 100644
--- a/cpukit/libmisc/stringto/stringtopointer.c
+++ b/cpukit/libmisc/stringto/stringtopointer.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Convert String to Pointer (with validation)
+ * @brief Convert String to Pointer (with validation)
diff --git a/cpukit/libmisc/stringto/stringtounsignedchar.c b/cpukit/libmisc/stringto/stringtounsignedchar.c
index fbaa1cdfc6..6181cfeeaa 100644
--- a/cpukit/libmisc/stringto/stringtounsignedchar.c
+++ b/cpukit/libmisc/stringto/stringtounsignedchar.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Convert String to Unsigned Character (with validation)
+ * @brief Convert String to Unsigned Character (with validation)
diff --git a/cpukit/libmisc/stringto/stringtounsignedint.c b/cpukit/libmisc/stringto/stringtounsignedint.c
index 15ffe495fa..95c6c85ac9 100644
--- a/cpukit/libmisc/stringto/stringtounsignedint.c
+++ b/cpukit/libmisc/stringto/stringtounsignedint.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Convert String to Unsigned Int (with validation)
+ * @brief Convert String to Unsigned Int (with validation)
diff --git a/cpukit/libmisc/stringto/stringtounsignedlong.c b/cpukit/libmisc/stringto/stringtounsignedlong.c
index 5a9b57075a..16f109735e 100644
--- a/cpukit/libmisc/stringto/stringtounsignedlong.c
+++ b/cpukit/libmisc/stringto/stringtounsignedlong.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Convert String to Unsigned Long Long (with validation)
+ * @brief Convert String to Unsigned Long Long (with validation)
diff --git a/cpukit/libmisc/stringto/stringtounsignedlonglong.c b/cpukit/libmisc/stringto/stringtounsignedlonglong.c
index 28cd20d395..5dd9628166 100644
--- a/cpukit/libmisc/stringto/stringtounsignedlonglong.c
+++ b/cpukit/libmisc/stringto/stringtounsignedlonglong.c
@@ -1,8 +1,9 @@
  * @file
diff --git a/cpukit/posix/src/_execve.c b/cpukit/posix/src/_execve.c
index f719566dfa..2c8b436889 100644
--- a/cpukit/posix/src/_execve.c
+++ b/cpukit/posix/src/_execve.c
@@ -1,9 +1,10 @@
  * @file
- * @brief _execve()
  * @ingroup POSIXAPI
+ * @brief _execve()
  * The Newlib C Library contains all of the exec*() variants and assumes
  * the underlying OS support provides _execve(). This single method
  * ensures that all exec*() variants return ENOSYS.
diff --git a/cpukit/posix/src/aio_error.c b/cpukit/posix/src/aio_error.c
index bd41415af1..2669ab14b1 100644
--- a/cpukit/posix/src/aio_error.c
+++ b/cpukit/posix/src/aio_error.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Returns the error status for the Asynchronous I/O request
  * @ingroup POSIXAPI
+ * @brief Returns the error status for the Asynchronous I/O request
diff --git a/cpukit/posix/src/aio_fsync.c b/cpukit/posix/src/aio_fsync.c
index 212668dbb3..b34014230d 100644
--- a/cpukit/posix/src/aio_fsync.c
+++ b/cpukit/posix/src/aio_fsync.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Syncing of all Outstanding Asynchronous I/O Operations
  * @ingroup POSIXAPI
+ * @brief Syncing of all Outstanding Asynchronous I/O Operations
diff --git a/cpukit/posix/src/aio_misc.c b/cpukit/posix/src/aio_misc.c
index 5a281a94f5..6c5c6b981a 100644
--- a/cpukit/posix/src/aio_misc.c
+++ b/cpukit/posix/src/aio_misc.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Actual request being processed
  * @ingroup POSIXAPI
+ * @brief Actual request being processed
diff --git a/cpukit/posix/src/aio_read.c b/cpukit/posix/src/aio_read.c
index 014658c2c6..cf02341a7b 100644
--- a/cpukit/posix/src/aio_read.c
+++ b/cpukit/posix/src/aio_read.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Asynchronously reads Data from a File
  * @ingroup POSIXAPI
+ * @brief Asynchronously reads Data from a File
diff --git a/cpukit/posix/src/aio_return.c b/cpukit/posix/src/aio_return.c
index 307d384263..7342cbe9cf 100644
--- a/cpukit/posix/src/aio_return.c
+++ b/cpukit/posix/src/aio_return.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Final return status for Asynchronous I/O request pointed to by aiobcp
  * @ingroup POSIXAPI
+ * @brief Final return status for Asynchronous I/O request pointed to by aiobcp
diff --git a/cpukit/posix/src/aio_suspend.c b/cpukit/posix/src/aio_suspend.c
index 1fdec47291..43de0abe1c 100644
--- a/cpukit/posix/src/aio_suspend.c
+++ b/cpukit/posix/src/aio_suspend.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Suspends Process until Asynchronous I/O Operation completes
  * @ingroup POSIXAPI
+ * @brief Suspends Process until Asynchronous I/O Operation completes
diff --git a/cpukit/posix/src/aio_write.c b/cpukit/posix/src/aio_write.c
index db71c956a3..27a7399fe6 100644
--- a/cpukit/posix/src/aio_write.c
+++ b/cpukit/posix/src/aio_write.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Function queues I/O request described by buffer pointed by aiocb
  * @ingroup POSIXAPI
+ * @brief Function queues I/O request described by buffer pointed by aiocb
diff --git a/cpukit/posix/src/alarm.c b/cpukit/posix/src/alarm.c
index 49bdb573f5..64ac0fafc3 100644
--- a/cpukit/posix/src/alarm.c
+++ b/cpukit/posix/src/alarm.c
@@ -1,8 +1,9 @@
  * @file
- * @brief System Generates Signal for process after realtime seconds elapsed
  * @ingroup POSIXAPI
+ * @brief System Generates Signal for process after realtime seconds elapsed
diff --git a/cpukit/posix/src/barrierattrdestroy.c b/cpukit/posix/src/barrierattrdestroy.c
index f36d2fce31..1f8df41814 100644
--- a/cpukit/posix/src/barrierattrdestroy.c
+++ b/cpukit/posix/src/barrierattrdestroy.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Function shall Destroy a Barrier Attribues Object
  * @ingroup POSIXAPI
+ * @brief Function shall Destroy a Barrier Attribues Object
diff --git a/cpukit/posix/src/barrierattrgetpshared.c b/cpukit/posix/src/barrierattrgetpshared.c
index 5f346fe4d0..682d6dfbf1 100644
--- a/cpukit/posix/src/barrierattrgetpshared.c
+++ b/cpukit/posix/src/barrierattrgetpshared.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Barrier Attributes Get Process Shared
  * @ingroup POSIXAPI
+ * @brief Barrier Attributes Get Process Shared
diff --git a/cpukit/posix/src/cancel.c b/cpukit/posix/src/cancel.c
index 8c00f716cd..4756f10389 100644
--- a/cpukit/posix/src/cancel.c
+++ b/cpukit/posix/src/cancel.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Canceling Execution of a Thread
  * @ingroup POSIXAPI
+ * @brief Canceling Execution of a Thread
diff --git a/cpukit/posix/src/cleanuppush.c b/cpukit/posix/src/cleanuppush.c
index 25e4dcc1e9..a53e0ae531 100644
--- a/cpukit/posix/src/cleanuppush.c
+++ b/cpukit/posix/src/cleanuppush.c
@@ -1,8 +1,9 @@
  * @file
- * @brief POSIX Cleanup Support
  * @ingroup POSIXAPI
+ * @brief POSIX Cleanup Support
diff --git a/cpukit/posix/src/clockgetcpuclockid.c b/cpukit/posix/src/clockgetcpuclockid.c
index a3172b6c25..7803ef3547 100644
--- a/cpukit/posix/src/clockgetcpuclockid.c
+++ b/cpukit/posix/src/clockgetcpuclockid.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Function Returns Clock ID of CPU-time Clock of process specified
  * @ingroup POSIXAPI
+ * @brief Function Returns Clock ID of CPU-time Clock of process specified
diff --git a/cpukit/posix/src/clockgetres.c b/cpukit/posix/src/clockgetres.c
index 04b99e0595..1092c50865 100644
--- a/cpukit/posix/src/clockgetres.c
+++ b/cpukit/posix/src/clockgetres.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Function Returns the Resolution of any Clock
  * @ingroup POSIXAPI
+ * @brief Function Returns the Resolution of any Clock
diff --git a/cpukit/posix/src/clockgettime.c b/cpukit/posix/src/clockgettime.c
index a885a838b8..8f6dd9aa75 100644
--- a/cpukit/posix/src/clockgettime.c
+++ b/cpukit/posix/src/clockgettime.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Retrieves the Specified Clock Time
  * @ingroup POSIXAPI
+ * @brief Retrieves the Specified Clock Time
diff --git a/cpukit/posix/src/clocksettime.c b/cpukit/posix/src/clocksettime.c
index 8052ac0a9f..53e728762e 100644
--- a/cpukit/posix/src/clocksettime.c
+++ b/cpukit/posix/src/clocksettime.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Set Time of Clock
  * @ingroup POSIXAPI
+ * @brief Set Time of Clock
diff --git a/cpukit/posix/src/condattrdestroy.c b/cpukit/posix/src/condattrdestroy.c
index 31e8e5953c..84032ca56a 100644
--- a/cpukit/posix/src/condattrdestroy.c
+++ b/cpukit/posix/src/condattrdestroy.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Destroy Condition Attribute
  * @ingroup POSIXAPI
+ * @brief Destroy Condition Attribute
diff --git a/cpukit/posix/src/condattrgetclock.c b/cpukit/posix/src/condattrgetclock.c
index 29c7665222..c6dd3f35f8 100644
--- a/cpukit/posix/src/condattrgetclock.c
+++ b/cpukit/posix/src/condattrgetclock.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Get the Clock Condition Variable Attributes
  * @ingroup POSIXAPI
+ * @brief Get the Clock Condition Variable Attributes
diff --git a/cpukit/posix/src/condattrgetpshared.c b/cpukit/posix/src/condattrgetpshared.c
index 051a59577a..d5ec0dfe89 100644
--- a/cpukit/posix/src/condattrgetpshared.c
+++ b/cpukit/posix/src/condattrgetpshared.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Get the Process-Shared Condition Variable Attributes
  * @ingroup POSIXAPI
+ * @brief Get the Process-Shared Condition Variable Attributes
diff --git a/cpukit/posix/src/condattrinit.c b/cpukit/posix/src/condattrinit.c
index f2ab9b8772..01b85e2a13 100644
--- a/cpukit/posix/src/condattrinit.c
+++ b/cpukit/posix/src/condattrinit.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Initialization of Conditional Attributes
  * @ingroup POSIXAPI
+ * @brief Initialization of Conditional Attributes
diff --git a/cpukit/posix/src/condattrsetclock.c b/cpukit/posix/src/condattrsetclock.c
index a272d34e66..9be0bacbaf 100644
--- a/cpukit/posix/src/condattrsetclock.c
+++ b/cpukit/posix/src/condattrsetclock.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Set the Clock Condition Variable Attributes
  * @ingroup POSIXAPI
+ * @brief Set the Clock Condition Variable Attributes
diff --git a/cpukit/posix/src/condattrsetpshared.c b/cpukit/posix/src/condattrsetpshared.c
index 5228b45a4e..11b4d67e57 100644
--- a/cpukit/posix/src/condattrsetpshared.c
+++ b/cpukit/posix/src/condattrsetpshared.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Set the Process-Shared Condition Variable Attributes
  * @ingroup POSIXAPI
+ * @brief Set the Process-Shared Condition Variable Attributes
diff --git a/cpukit/posix/src/conddefaultattributes.c b/cpukit/posix/src/conddefaultattributes.c
index 409dd08aac..6c0e51317c 100644
--- a/cpukit/posix/src/conddefaultattributes.c
+++ b/cpukit/posix/src/conddefaultattributes.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Condition variable Attributes structure
  * @ingroup POSIXAPI
+ * @brief Condition variable Attributes structure
diff --git a/cpukit/posix/src/condsignalsupp.c b/cpukit/posix/src/condsignalsupp.c
index eabba064c6..dd3886ae69 100644
--- a/cpukit/posix/src/condsignalsupp.c
+++ b/cpukit/posix/src/condsignalsupp.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Implements wake up version of the "signal" operation
  * @ingroup POSIX_COND_VARS Condition Variables
+ * @brief Implements wake up version of the "signal" operation
diff --git a/cpukit/posix/src/condtimedwait.c b/cpukit/posix/src/condtimedwait.c
index 290a9d5161..0bc8bfc18e 100644
--- a/cpukit/posix/src/condtimedwait.c
+++ b/cpukit/posix/src/condtimedwait.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Waiting on a Condition
  * @ingroup POSIXAPI
+ * @brief Waiting on a Condition
diff --git a/cpukit/posix/src/condwait.c b/cpukit/posix/src/condwait.c
index bbebfe544d..09431e216d 100644
--- a/cpukit/posix/src/condwait.c
+++ b/cpukit/posix/src/condwait.c
@@ -1,8 +1,9 @@
  * @file
  * @ingroup POSIXAPI
diff --git a/cpukit/posix/src/condwaitsupp.c b/cpukit/posix/src/condwaitsupp.c
index b759ee54b8..296c03d1c6 100644
--- a/cpukit/posix/src/condwaitsupp.c
+++ b/cpukit/posix/src/condwaitsupp.c
@@ -1,8 +1,9 @@
  * @file
- * @brief POSIX Condition Variables Wait Support
+ * @brief POSIX Condition Variables Wait Support
diff --git a/cpukit/posix/src/fork.c b/cpukit/posix/src/fork.c
index 57e96937ca..252f240515 100644
--- a/cpukit/posix/src/fork.c
+++ b/cpukit/posix/src/fork.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Inoperable implementation of fork() for POSIX threads
  * @ingroup POSIXAPI
+ * @brief Inoperable implementation of fork() for POSIX threads
diff --git a/cpukit/posix/src/getitimer.c b/cpukit/posix/src/getitimer.c
index 35e940bff9..e0a767363d 100644
--- a/cpukit/posix/src/getitimer.c
+++ b/cpukit/posix/src/getitimer.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Function Gets Value of an Interval Timer
  * @ingroup POSIXAPI
+ * @brief Function Gets Value of an Interval Timer
diff --git a/cpukit/posix/src/keycreate.c b/cpukit/posix/src/keycreate.c
index f018133c1f..dc313488ae 100644
--- a/cpukit/posix/src/keycreate.c
+++ b/cpukit/posix/src/keycreate.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Thread-Specific Data Key Create
  * @ingroup POSIXAPI
+ * @brief Thread-Specific Data Key Create
diff --git a/cpukit/posix/src/keydelete.c b/cpukit/posix/src/keydelete.c
index 69b8559a83..0c0a429d6b 100644
--- a/cpukit/posix/src/keydelete.c
+++ b/cpukit/posix/src/keydelete.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Deletes Thread-specific Data Key Previously Returned by keycreate.c
  * @ingroup POSIXAPI
+ * @brief Deletes Thread-specific Data Key Previously Returned by keycreate.c
diff --git a/cpukit/posix/src/keygetspecific.c b/cpukit/posix/src/keygetspecific.c
index 5f1188d4b5..5abb24d21c 100644
--- a/cpukit/posix/src/keygetspecific.c
+++ b/cpukit/posix/src/keygetspecific.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Thread-Specific Data Management
  * @ingroup POSIXAPI
+ * @brief Thread-Specific Data Management
diff --git a/cpukit/posix/src/keysetspecific.c b/cpukit/posix/src/keysetspecific.c
index 5be2f8dd07..f5500f972f 100644
--- a/cpukit/posix/src/keysetspecific.c
+++ b/cpukit/posix/src/keysetspecific.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Set Specific Key
  * @ingroup POSIXAPI
+ * @brief Set Specific Key
diff --git a/cpukit/posix/src/kill.c b/cpukit/posix/src/kill.c
index a143c5dea3..d759cd1617 100644
--- a/cpukit/posix/src/kill.c
+++ b/cpukit/posix/src/kill.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Send a Signal to a Process
  * @ingroup POSIXAPI
+ * @brief Send a Signal to a Process
diff --git a/cpukit/posix/src/kill_r.c b/cpukit/posix/src/kill_r.c
index 2262c733b2..05d1bbde07 100644
--- a/cpukit/posix/src/kill_r.c
+++ b/cpukit/posix/src/kill_r.c
@@ -1,8 +1,9 @@
  * @file
  * @ingroup POSIXAPI
diff --git a/cpukit/posix/src/killinfo.c b/cpukit/posix/src/killinfo.c
index b815d79bcd..c765a14b9a 100644
--- a/cpukit/posix/src/killinfo.c
+++ b/cpukit/posix/src/killinfo.c
@@ -1,8 +1,9 @@
  * @file
  * @ingroup POSIXAPI
diff --git a/cpukit/posix/src/lio_listio.c b/cpukit/posix/src/lio_listio.c
index 26f0d9831d..806d357470 100644
--- a/cpukit/posix/src/lio_listio.c
+++ b/cpukit/posix/src/lio_listio.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Function Initiates a List of I/O Requests with Single Function Call
  * @ingroup POSIXAPI
+ * @brief Function Initiates a List of I/O Requests with Single Function Call
diff --git a/cpukit/posix/src/mprotect.c b/cpukit/posix/src/mprotect.c
index 17a63b47ce..87fe5cf355 100644
--- a/cpukit/posix/src/mprotect.c
+++ b/cpukit/posix/src/mprotect.c
@@ -1,9 +1,10 @@
  * @file
- * @brief Change Memory Protection
  * @ingroup POSIXAPI
+ * @brief Change Memory Protection
  * 12.2.3 Change Memory Protection, P1003.1b-1996, p. 277.
  * This is not a functional version of mprotect() but the SPARC backend
diff --git a/cpukit/posix/src/mqueueclose.c b/cpukit/posix/src/mqueueclose.c
index a9cadb4a0b..ea8f1502da 100644
--- a/cpukit/posix/src/mqueueclose.c
+++ b/cpukit/posix/src/mqueueclose.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Function closes the Message Queue
  * @ingroup POSIXAPI
+ * @brief Function closes the Message Queue
diff --git a/cpukit/posix/src/mqueuegetattr.c b/cpukit/posix/src/mqueuegetattr.c
index 20ade1107c..8c6bd5e78b 100644
--- a/cpukit/posix/src/mqueuegetattr.c
+++ b/cpukit/posix/src/mqueuegetattr.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Message Queue Attributes
  * @ingroup POSIXAPI
+ * @brief Message Queue Attributes
diff --git a/cpukit/posix/src/mqueuenotify.c b/cpukit/posix/src/mqueuenotify.c
index e8113e7018..04eb62a565 100644
--- a/cpukit/posix/src/mqueuenotify.c
+++ b/cpukit/posix/src/mqueuenotify.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Notify Process that a Message is Available on a Queue
  * @ingroup POSIX_MQUEUE
+ * @brief Notify Process that a Message is Available on a Queue
diff --git a/cpukit/posix/src/mqueueopen.c b/cpukit/posix/src/mqueueopen.c
index 821563f9c3..35b8c923b1 100644
--- a/cpukit/posix/src/mqueueopen.c
+++ b/cpukit/posix/src/mqueueopen.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Creates a new POSIX Message Queue or Opens an Existing Queue
  * @ingroup POSIXAPI
+ * @brief Creates a new POSIX Message Queue or Opens an Existing Queue
diff --git a/cpukit/posix/src/mqueuerecvsupp.c b/cpukit/posix/src/mqueuerecvsupp.c
index 32d7909c51..2adcb7b3b2 100644
--- a/cpukit/posix/src/mqueuerecvsupp.c
+++ b/cpukit/posix/src/mqueuerecvsupp.c
@@ -1,8 +1,9 @@
  * @file
- * @brief POSIX Message Queue Receive Support
  * @ingroup POSIX_MQUEUE_P Message Queues Private Support Information
+ * @brief POSIX Message Queue Receive Support
diff --git a/cpukit/posix/src/mqueuesend.c b/cpukit/posix/src/mqueuesend.c
index d7afdbdb91..38b7e3e41b 100644
--- a/cpukit/posix/src/mqueuesend.c
+++ b/cpukit/posix/src/mqueuesend.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Adds Message Pointed by msg_ptr to Message Queue Reffered by mqdes
  * @ingroup POSIXAPI
+ * @brief Adds Message Pointed by msg_ptr to Message Queue Reffered by mqdes
diff --git a/cpukit/posix/src/mqueuesendsupp.c b/cpukit/posix/src/mqueuesendsupp.c
index 8edc29de37..7be23fc595 100644
--- a/cpukit/posix/src/mqueuesendsupp.c
+++ b/cpukit/posix/src/mqueuesendsupp.c
@@ -1,8 +1,9 @@
  * @file
- * @brief POSIX Message Queue and Send Support
  * @ingroup POSIXAPI
+ * @brief POSIX Message Queue and Send Support
diff --git a/cpukit/posix/src/mqueuesetattr.c b/cpukit/posix/src/mqueuesetattr.c
index c8eafe7a0f..99e4bdf982 100644
--- a/cpukit/posix/src/mqueuesetattr.c
+++ b/cpukit/posix/src/mqueuesetattr.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Set Message Queue Attributes
+ * @brief Set Message Queue Attributes
diff --git a/cpukit/posix/src/mqueuetimedreceive.c b/cpukit/posix/src/mqueuetimedreceive.c
index a9fe5b5317..67161a8f88 100644
--- a/cpukit/posix/src/mqueuetimedreceive.c
+++ b/cpukit/posix/src/mqueuetimedreceive.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Receive Message from Message Queue
  * @ingroup POSIXAPI
+ * @brief Receive Message from Message Queue
diff --git a/cpukit/posix/src/mqueueunlink.c b/cpukit/posix/src/mqueueunlink.c
index c9737d57e6..0ddeaa86b2 100644
--- a/cpukit/posix/src/mqueueunlink.c
+++ b/cpukit/posix/src/mqueueunlink.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Remove a Message Queue
  * @ingroup POSIX_MQUEUE Message Queues
+ * @brief Remove a Message Queue
diff --git a/cpukit/posix/src/mutexattrdestroy.c b/cpukit/posix/src/mutexattrdestroy.c
index 1b78245b42..5c8d6c24f5 100644
--- a/cpukit/posix/src/mutexattrdestroy.c
+++ b/cpukit/posix/src/mutexattrdestroy.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Destroy Mutex Attributes Object
  * @ingroup POSIXAPI
+ * @brief Destroy Mutex Attributes Object
diff --git a/cpukit/posix/src/mutexattrgetprioceiling.c b/cpukit/posix/src/mutexattrgetprioceiling.c
index f0da17c223..eaf3250a7e 100644
--- a/cpukit/posix/src/mutexattrgetprioceiling.c
+++ b/cpukit/posix/src/mutexattrgetprioceiling.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Mutex Initialization Scheduling Attributes
  * @ingroup POSIXAPI
+ * @brief Mutex Initialization Scheduling Attributes
diff --git a/cpukit/posix/src/mutexattrgetprotocol.c b/cpukit/posix/src/mutexattrgetprotocol.c
index b4b30231b4..f8a35e60b4 100644
--- a/cpukit/posix/src/mutexattrgetprotocol.c
+++ b/cpukit/posix/src/mutexattrgetprotocol.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Get protocol Attribute of Mutex Attribute Obect
  * @ingroup POSIXAPI
+ * @brief Get protocol Attribute of Mutex Attribute Obect
diff --git a/cpukit/posix/src/mutexattrgetpshared.c b/cpukit/posix/src/mutexattrgetpshared.c
index 94547ad2b2..a7985164ce 100644
--- a/cpukit/posix/src/mutexattrgetpshared.c
+++ b/cpukit/posix/src/mutexattrgetpshared.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Obtaining process-shared Attribute Value from the Attributes Object
  * @ingroup POSIXAPI
+ * @brief Obtaining process-shared Attribute Value from the Attributes Object
diff --git a/cpukit/posix/src/mutexattrgettype.c b/cpukit/posix/src/mutexattrgettype.c
index c903099bee..88892f2212 100644
--- a/cpukit/posix/src/mutexattrgettype.c
+++ b/cpukit/posix/src/mutexattrgettype.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Function gets the Mutex Type Attribute
  * @ingroup POSIXAPI
+ * @brief Function gets the Mutex Type Attribute
diff --git a/cpukit/posix/src/mutexattrsetprioceiling.c b/cpukit/posix/src/mutexattrsetprioceiling.c
index b449215b66..6d3be649da 100644
--- a/cpukit/posix/src/mutexattrsetprioceiling.c
+++ b/cpukit/posix/src/mutexattrsetprioceiling.c
@@ -1,8 +1,9 @@
  * @file
  * @ingroup POSIXAPI
diff --git a/cpukit/posix/src/mutexattrsetprotocol.c b/cpukit/posix/src/mutexattrsetprotocol.c
index 7ac28946c5..1870db6804 100644
--- a/cpukit/posix/src/mutexattrsetprotocol.c
+++ b/cpukit/posix/src/mutexattrsetprotocol.c
@@ -1,8 +1,9 @@
  * @file
  * @ingroup POSIXAPI
diff --git a/cpukit/posix/src/mutexattrsetpshared.c b/cpukit/posix/src/mutexattrsetpshared.c
index d3efe2f481..acfe4881e1 100644
--- a/cpukit/posix/src/mutexattrsetpshared.c
+++ b/cpukit/posix/src/mutexattrsetpshared.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Function sets Current pshared Attribute for Mutex Attributes Object
  * @ingroup POSIXAPI
+ * @brief Function sets Current pshared Attribute for Mutex Attributes Object
diff --git a/cpukit/posix/src/mutexdestroy.c b/cpukit/posix/src/mutexdestroy.c
index 15d8aac447..a1662a6223 100644
--- a/cpukit/posix/src/mutexdestroy.c
+++ b/cpukit/posix/src/mutexdestroy.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Initializing and Destroying a Mutex
  * @ingroup POSIXAPI
+ * @brief Initializing and Destroying a Mutex
diff --git a/cpukit/posix/src/mutexgetprioceiling.c b/cpukit/posix/src/mutexgetprioceiling.c
index 41e6f1b8ea..e29a7e6be4 100644
--- a/cpukit/posix/src/mutexgetprioceiling.c
+++ b/cpukit/posix/src/mutexgetprioceiling.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Returns the Current Priority Ceiling of the Mutex
  * @ingroup POSIXAPI
+ * @brief Returns the Current Priority Ceiling of the Mutex
diff --git a/cpukit/posix/src/mutexinit.c b/cpukit/posix/src/mutexinit.c
index 07828f262d..2290bd6b39 100644
--- a/cpukit/posix/src/mutexinit.c
+++ b/cpukit/posix/src/mutexinit.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Initialize a Mutex
  * @ingroup POSIXAPI
+ * @brief Initialize a Mutex
diff --git a/cpukit/posix/src/mutexlock.c b/cpukit/posix/src/mutexlock.c
index 4efc8ac214..20efcdc6f2 100644
--- a/cpukit/posix/src/mutexlock.c
+++ b/cpukit/posix/src/mutexlock.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Call to function enables locking of Mutex Object referenced by mutex
  * @ingroup POSIXAPI
+ * @brief Call to function enables locking of Mutex Object referenced by mutex
diff --git a/cpukit/posix/src/mutexlocksupp.c b/cpukit/posix/src/mutexlocksupp.c
index 1cfc733cf9..e5bd1784ea 100644
--- a/cpukit/posix/src/mutexlocksupp.c
+++ b/cpukit/posix/src/mutexlocksupp.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Support Call to function Enables Locking of Mutex Object
  * @ingroup POSIXAPI
+ * @brief Support Call to function Enables Locking of Mutex Object
diff --git a/cpukit/posix/src/mutexsetprioceiling.c b/cpukit/posix/src/mutexsetprioceiling.c
index d78142283e..4bd5de9f12 100644
--- a/cpukit/posix/src/mutexsetprioceiling.c
+++ b/cpukit/posix/src/mutexsetprioceiling.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Changes the Priority Ceiling of a Mutex and Releases it
  * @ingroup POSIXAPI
+ * @brief Changes the Priority Ceiling of a Mutex and Releases it
diff --git a/cpukit/posix/src/mutextimedlock.c b/cpukit/posix/src/mutextimedlock.c
index 6ec813cb35..c5dcf7f1a7 100644
--- a/cpukit/posix/src/mutextimedlock.c
+++ b/cpukit/posix/src/mutextimedlock.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Mutex Timed Lock
  * @ingroup POSIXAPI
+ * @brief Mutex Timed Lock
diff --git a/cpukit/posix/src/mutextrylock.c b/cpukit/posix/src/mutextrylock.c
index af7903cb19..72d6e353ee 100644
--- a/cpukit/posix/src/mutextrylock.c
+++ b/cpukit/posix/src/mutextrylock.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Try to Lock Mutex
  * @ingroup POSIXAPI
+ * @brief Try to Lock Mutex
diff --git a/cpukit/posix/src/mutexunlock.c b/cpukit/posix/src/mutexunlock.c
index 1b00800bf4..c811a28192 100644
--- a/cpukit/posix/src/mutexunlock.c
+++ b/cpukit/posix/src/mutexunlock.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Locking and Unlocking a Mutex
  * @ingroup POSIXAPI
+ * @brief Locking and Unlocking a Mutex
diff --git a/cpukit/posix/src/nanosleep.c b/cpukit/posix/src/nanosleep.c
index afcc29051f..8d1a4b84e4 100644
--- a/cpukit/posix/src/nanosleep.c
+++ b/cpukit/posix/src/nanosleep.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Suspends Execution of calling thread until Time elapses
  * @ingroup POSIXAPI
+ * @brief Suspends Execution of calling thread until Time elapses
diff --git a/cpukit/posix/src/pause.c b/cpukit/posix/src/pause.c
index e2fb9d9f15..af660300a7 100644
--- a/cpukit/posix/src/pause.c
+++ b/cpukit/posix/src/pause.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Suspend Process Execution
  * @ingroup POSIXAPI
+ * @brief Suspend Process Execution
diff --git a/cpukit/posix/src/pbarrierinit.c b/cpukit/posix/src/pbarrierinit.c
index abe4224374..19279f8c4a 100644
--- a/cpukit/posix/src/pbarrierinit.c
+++ b/cpukit/posix/src/pbarrierinit.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Call to Function Enables Reinitializing of the Barrier
  * @ingroup POSIXAPI
+ * @brief Call to Function Enables Reinitializing of the Barrier
diff --git a/cpukit/posix/src/pbarrierwait.c b/cpukit/posix/src/pbarrierwait.c
index 865ccfe3f7..68e8a991eb 100644
--- a/cpukit/posix/src/pbarrierwait.c
+++ b/cpukit/posix/src/pbarrierwait.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Wait at a Barrier
  * @ingroup POSIXAPI
+ * @brief Wait at a Barrier
diff --git a/cpukit/posix/src/prwlockinit.c b/cpukit/posix/src/prwlockinit.c
index 0bd5991b0a..d7ed527cfb 100644
--- a/cpukit/posix/src/prwlockinit.c
+++ b/cpukit/posix/src/prwlockinit.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Allocate resources to use the read-write lock and Initialize it
  * @ingroup POSIXAPI
+ * @brief Allocate resources to use the read-write lock and Initialize it
diff --git a/cpukit/posix/src/prwlockrdlock.c b/cpukit/posix/src/prwlockrdlock.c
index f0bc9c2e85..8ca4b9307c 100644
--- a/cpukit/posix/src/prwlockrdlock.c
+++ b/cpukit/posix/src/prwlockrdlock.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Obtain a Read Lock on a RWLock Instance
  * @ingroup POSIXAPI
+ * @brief Obtain a Read Lock on a RWLock Instance
diff --git a/cpukit/posix/src/prwlocktimedrdlock.c b/cpukit/posix/src/prwlocktimedrdlock.c
index 1ccf534269..79059800bf 100644
--- a/cpukit/posix/src/prwlocktimedrdlock.c
+++ b/cpukit/posix/src/prwlocktimedrdlock.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Attempt to Obtain a Read Lock on a RWLock Instance
  * @ingroup POSIXAPI
+ * @brief Attempt to Obtain a Read Lock on a RWLock Instance
diff --git a/cpukit/posix/src/prwlocktimedwrlock.c b/cpukit/posix/src/prwlocktimedwrlock.c
index 01ce758d1c..9fb9a880a0 100644
--- a/cpukit/posix/src/prwlocktimedwrlock.c
+++ b/cpukit/posix/src/prwlocktimedwrlock.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Function applies a Write lock to RWLock referenced by rwlock
  * @ingroup POSIXAPI
+ * @brief Function applies a Write lock to RWLock referenced by rwlock
diff --git a/cpukit/posix/src/prwlocktryrdlock.c b/cpukit/posix/src/prwlocktryrdlock.c
index 1bc523ae40..c0c6154bfc 100644
--- a/cpukit/posix/src/prwlocktryrdlock.c
+++ b/cpukit/posix/src/prwlocktryrdlock.c
@@ -1,8 +1,9 @@
  * @file
  * @ingroup POSIXAPI
diff --git a/cpukit/posix/src/prwlocktrywrlock.c b/cpukit/posix/src/prwlocktrywrlock.c
index a4525d7119..0137b21217 100644
--- a/cpukit/posix/src/prwlocktrywrlock.c
+++ b/cpukit/posix/src/prwlocktrywrlock.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Attempt to Obtain a Write Lock on a RWLock Instance
  * @ingroup POSIXAPI
+ * @brief Attempt to Obtain a Write Lock on a RWLock Instance
diff --git a/cpukit/posix/src/prwlockunlock.c b/cpukit/posix/src/prwlockunlock.c
index 6caa020d66..01c8ccda73 100644
--- a/cpukit/posix/src/prwlockunlock.c
+++ b/cpukit/posix/src/prwlockunlock.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Function Releases a lock held on RWLock object referenced by rwlock
  * @ingroup POSIXAPI
+ * @brief Function Releases a lock held on RWLock object referenced by rwlock
diff --git a/cpukit/posix/src/prwlockwrlock.c b/cpukit/posix/src/prwlockwrlock.c
index 438d1f1fc1..08c9d8a9d7 100644
--- a/cpukit/posix/src/prwlockwrlock.c
+++ b/cpukit/posix/src/prwlockwrlock.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Obtain a Write Lock on a RWlock Instance
  * @ingroup POSIXAPI
+ * @brief Obtain a Write Lock on a RWlock Instance
diff --git a/cpukit/posix/src/psignalclearprocesssignals.c b/cpukit/posix/src/psignalclearprocesssignals.c
index 77dfc7f410..fff797dd26 100644
--- a/cpukit/posix/src/psignalclearprocesssignals.c
+++ b/cpukit/posix/src/psignalclearprocesssignals.c
@@ -1,8 +1,9 @@
  * @file
- * @brief POSIX_signals clear_process_signals
  * @ingroup POSIXAPI
+ * @brief POSIX_signals clear_process_signals
diff --git a/cpukit/posix/src/psignalclearsignals.c b/cpukit/posix/src/psignalclearsignals.c
index f231748944..c1a407afaa 100644
--- a/cpukit/posix/src/psignalclearsignals.c
+++ b/cpukit/posix/src/psignalclearsignals.c
@@ -1,8 +1,9 @@
  * @file
- * @brief POSIX Signals Clear Signals
  * @ingroup POSIX_SIGNALS POSIX Signals Support
+ * @brief POSIX Signals Clear Signals
diff --git a/cpukit/posix/src/psignalunblockthread.c b/cpukit/posix/src/psignalunblockthread.c
index d6666fb279..80a0f33a09 100644
--- a/cpukit/posix/src/psignalunblockthread.c
+++ b/cpukit/posix/src/psignalunblockthread.c
@@ -1,8 +1,9 @@
  * @file
- * @brief POSIX Signals Thread Unlock
+ * @brief POSIX Signals Thread Unlock
diff --git a/cpukit/posix/src/pspininit.c b/cpukit/posix/src/pspininit.c
index 2e103cb53a..5ffa9be859 100644
--- a/cpukit/posix/src/pspininit.c
+++ b/cpukit/posix/src/pspininit.c
@@ -1,8 +1,9 @@
  * @file
- * @brief POSIX Function Initializes a Spinlock Instance
  * @ingroup POSIXAPI
+ * @brief POSIX Function Initializes a Spinlock Instance
diff --git a/cpukit/posix/src/pspinunlock.c b/cpukit/posix/src/pspinunlock.c
index 9af4a33b6b..ca36a5fc76 100644
--- a/cpukit/posix/src/pspinunlock.c
+++ b/cpukit/posix/src/pspinunlock.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Function Unlocks a Spin Lock Object
  * @ingroup POSIXAPI
+ * @brief Function Unlocks a Spin Lock Object
diff --git a/cpukit/posix/src/psxnametoid.c b/cpukit/posix/src/psxnametoid.c
index 0ddb72a98e..47cf81b473 100644
--- a/cpukit/posix/src/psxnametoid.c
+++ b/cpukit/posix/src/psxnametoid.c
@@ -1,8 +1,9 @@
  * @file
- * @brief POSIX Name to ID
  * @ingroup POSIXAPI
+ * @brief POSIX Name to ID
diff --git a/cpukit/posix/src/psxtimercreate.c b/cpukit/posix/src/psxtimercreate.c
index c2c89c283f..a63cf1d100 100644
--- a/cpukit/posix/src/psxtimercreate.c
+++ b/cpukit/posix/src/psxtimercreate.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Create a Per-Process Timer
  * @ingroup POSIX_PRIV_TIMERS Timers
+ * @brief Create a Per-Process Timer
diff --git a/cpukit/posix/src/psxtimerdelete.c b/cpukit/posix/src/psxtimerdelete.c
index c55697fcf1..c39f2b0e12 100644
--- a/cpukit/posix/src/psxtimerdelete.c
+++ b/cpukit/posix/src/psxtimerdelete.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Deletes a POSIX Interval Timer
  * @ingroup POSIXAPI
+ * @brief Deletes a POSIX Interval Timer
diff --git a/cpukit/posix/src/psxtransschedparam.c b/cpukit/posix/src/psxtransschedparam.c
index f3842457fa..6fa7a43886 100644
--- a/cpukit/posix/src/psxtransschedparam.c
+++ b/cpukit/posix/src/psxtransschedparam.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Translate sched_param into SuperCore Terms
  * @ingroup POSIX_PTHREAD Private POSIX Threads
+ * @brief Translate sched_param into SuperCore Terms
diff --git a/cpukit/posix/src/pthread.c b/cpukit/posix/src/pthread.c
index 7e861a3d6b..790519ad9b 100644
--- a/cpukit/posix/src/pthread.c
+++ b/cpukit/posix/src/pthread.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Private Support Information for POSIX Threads
  * @ingroup POSIX_PTHREADS Private Threads
+ * @brief Private Support Information for POSIX Threads
diff --git a/cpukit/posix/src/pthreadattrdefault.c b/cpukit/posix/src/pthreadattrdefault.c
index 4b573d08fd..df87b9904e 100644
--- a/cpukit/posix/src/pthreadattrdefault.c
+++ b/cpukit/posix/src/pthreadattrdefault.c
@@ -1,8 +1,9 @@
  * @file
diff --git a/cpukit/posix/src/pthreadattrdestroy.c b/cpukit/posix/src/pthreadattrdestroy.c
index cb4837e9c9..7232be7b43 100644
--- a/cpukit/posix/src/pthreadattrdestroy.c
+++ b/cpukit/posix/src/pthreadattrdestroy.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Thread Creation Attributes
  * @ingroup POSIXAPI
+ * @brief Thread Creation Attributes
diff --git a/cpukit/posix/src/pthreadattrgetaffinitynp.c b/cpukit/posix/src/pthreadattrgetaffinitynp.c
index b0fae65348..3ab917bae0 100644
--- a/cpukit/posix/src/pthreadattrgetaffinitynp.c
+++ b/cpukit/posix/src/pthreadattrgetaffinitynp.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Pthread Attribute Get Affinity
  * @ingroup POSIXAPI
+ * @brief Pthread Attribute Get Affinity
diff --git a/cpukit/posix/src/pthreadattrgetdetachstate.c b/cpukit/posix/src/pthreadattrgetdetachstate.c
index 18c214b996..46ad6d2ee7 100644
--- a/cpukit/posix/src/pthreadattrgetdetachstate.c
+++ b/cpukit/posix/src/pthreadattrgetdetachstate.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Function gets the detachstate Attribute in the attr Object
  * @ingroup POSIXAPI
+ * @brief Function gets the detachstate Attribute in the attr Object
diff --git a/cpukit/posix/src/pthreadattrgetguardsize.c b/cpukit/posix/src/pthreadattrgetguardsize.c
index a5e9a31011..638d104b25 100644
--- a/cpukit/posix/src/pthreadattrgetguardsize.c
+++ b/cpukit/posix/src/pthreadattrgetguardsize.c
@@ -1,8 +1,9 @@
  * @file
  * @ingroup POSIXAPI
diff --git a/cpukit/posix/src/pthreadattrgetinheritsched.c b/cpukit/posix/src/pthreadattrgetinheritsched.c
index 6be61defa6..745bde2e6d 100644
--- a/cpukit/posix/src/pthreadattrgetinheritsched.c
+++ b/cpukit/posix/src/pthreadattrgetinheritsched.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Thread Creation Scheduling Attributes
  * @ingroup POSIXAPI
+ * @brief Thread Creation Scheduling Attributes
diff --git a/cpukit/posix/src/pthreadattrgetschedparam.c b/cpukit/posix/src/pthreadattrgetschedparam.c
index e1a1a79da1..b5b990f88a 100644
--- a/cpukit/posix/src/pthreadattrgetschedparam.c
+++ b/cpukit/posix/src/pthreadattrgetschedparam.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Returns Scheduling Parameter Attributes of Thread Attributes Object
  * @ingroup POSIXAPI
+ * @brief Returns Scheduling Parameter Attributes of Thread Attributes Object
diff --git a/cpukit/posix/src/pthreadattrgetscope.c b/cpukit/posix/src/pthreadattrgetscope.c
index c7eff2361b..2d04ad003e 100644
--- a/cpukit/posix/src/pthreadattrgetscope.c
+++ b/cpukit/posix/src/pthreadattrgetscope.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Function gets the Contentionscope Attribute in the attr object
  * @ingroup POSIXAPI
+ * @brief Function gets the Contentionscope Attribute in the attr object
diff --git a/cpukit/posix/src/pthreadattrgetstack.c b/cpukit/posix/src/pthreadattrgetstack.c
index 719a535915..306d618c65 100644
--- a/cpukit/posix/src/pthreadattrgetstack.c
+++ b/cpukit/posix/src/pthreadattrgetstack.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Function Gets the Thread Creation Stack Attributes in the attr
  * @ingroup POSIXAPI
+ * @brief Function Gets the Thread Creation Stack Attributes in the attr
diff --git a/cpukit/posix/src/pthreadattrgetstackaddr.c b/cpukit/posix/src/pthreadattrgetstackaddr.c
index 9da944a72c..dfc7156e99 100644
--- a/cpukit/posix/src/pthreadattrgetstackaddr.c
+++ b/cpukit/posix/src/pthreadattrgetstackaddr.c
@@ -1,8 +1,9 @@
  * @file
  * @ingroup POSIXAPI
diff --git a/cpukit/posix/src/pthreadattrgetstacksize.c b/cpukit/posix/src/pthreadattrgetstacksize.c
index e939205fa2..7729637f48 100644
--- a/cpukit/posix/src/pthreadattrgetstacksize.c
+++ b/cpukit/posix/src/pthreadattrgetstacksize.c
@@ -1,8 +1,9 @@
  * @file
  * @ingroup POSIXAPI
diff --git a/cpukit/posix/src/pthreadattrinit.c b/cpukit/posix/src/pthreadattrinit.c
index d0694eb7d7..fe893c390b 100644
--- a/cpukit/posix/src/pthreadattrinit.c
+++ b/cpukit/posix/src/pthreadattrinit.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Thread Attributes Creation
  * @ingroup POSIXAPI
+ * @brief Thread Attributes Creation
diff --git a/cpukit/posix/src/pthreadattrsetaffinitynp.c b/cpukit/posix/src/pthreadattrsetaffinitynp.c
index 30703fa663..1f72e94803 100644
--- a/cpukit/posix/src/pthreadattrsetaffinitynp.c
+++ b/cpukit/posix/src/pthreadattrsetaffinitynp.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Pthread Attribute Set Affinity
  * @ingroup POSIXAPI
+ * @brief Pthread Attribute Set Affinity
diff --git a/cpukit/posix/src/pthreadattrsetdetachstate.c b/cpukit/posix/src/pthreadattrsetdetachstate.c
index d6ca32eebb..90c949ec69 100644
--- a/cpukit/posix/src/pthreadattrsetdetachstate.c
+++ b/cpukit/posix/src/pthreadattrsetdetachstate.c
@@ -1,8 +1,9 @@
  * @file
  * @ingroup POSIXAPI
diff --git a/cpukit/posix/src/pthreadattrsetguardsize.c b/cpukit/posix/src/pthreadattrsetguardsize.c
index 3e92fa5bc5..011f37aa57 100644
--- a/cpukit/posix/src/pthreadattrsetguardsize.c
+++ b/cpukit/posix/src/pthreadattrsetguardsize.c
@@ -1,8 +1,9 @@
  * @file
  * @ingroup POSIXAPI
diff --git a/cpukit/posix/src/pthreadattrsetinheritsched.c b/cpukit/posix/src/pthreadattrsetinheritsched.c
index 0cc11f2b13..3b57d8a039 100644
--- a/cpukit/posix/src/pthreadattrsetinheritsched.c
+++ b/cpukit/posix/src/pthreadattrsetinheritsched.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Function sets the inheritsched Attribute in the attr Argument
  * @ingroup POSIXAPI
+ * @brief Function sets the inheritsched Attribute in the attr Argument
diff --git a/cpukit/posix/src/pthreadattrsetschedparam.c b/cpukit/posix/src/pthreadattrsetschedparam.c
index c3e6b4a7f3..5d29be7056 100644
--- a/cpukit/posix/src/pthreadattrsetschedparam.c
+++ b/cpukit/posix/src/pthreadattrsetschedparam.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Thread Creation Scheduling Parameters
  * @ingroup POSIXAPI
+ * @brief Thread Creation Scheduling Parameters
diff --git a/cpukit/posix/src/pthreadattrsetschedpolicy.c b/cpukit/posix/src/pthreadattrsetschedpolicy.c
index cd72164ef2..101838ff83 100644
--- a/cpukit/posix/src/pthreadattrsetschedpolicy.c
+++ b/cpukit/posix/src/pthreadattrsetschedpolicy.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Sets Scheduling policy Attributes of Thread Attributes Object
  * @ingroup POSIXAPI
+ * @brief Sets Scheduling policy Attributes of Thread Attributes Object
diff --git a/cpukit/posix/src/pthreadattrsetscope.c b/cpukit/posix/src/pthreadattrsetscope.c
index bdbc64d0f1..f68461b208 100644
--- a/cpukit/posix/src/pthreadattrsetscope.c
+++ b/cpukit/posix/src/pthreadattrsetscope.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Function Sets the Contentionscope Attribute in the attr Object
  * @ingroup POSIXAPI
+ * @brief Function Sets the Contentionscope Attribute in the attr Object
diff --git a/cpukit/posix/src/pthreadattrsetstack.c b/cpukit/posix/src/pthreadattrsetstack.c
index b95d0484ea..866dca8ae4 100644
--- a/cpukit/posix/src/pthreadattrsetstack.c
+++ b/cpukit/posix/src/pthreadattrsetstack.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Function Sets Thread Creation Stack Attributes in the attr object
  * @ingroup POSIXAPI
+ * @brief Function Sets Thread Creation Stack Attributes in the attr object
diff --git a/cpukit/posix/src/pthreadattrsetstackaddr.c b/cpukit/posix/src/pthreadattrsetstackaddr.c
index 5221080e9b..e38c302947 100644
--- a/cpukit/posix/src/pthreadattrsetstackaddr.c
+++ b/cpukit/posix/src/pthreadattrsetstackaddr.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Sets the Thread Creation stackaddr Attribute in the attr Object
  * @ingroup POSIXAPI
+ * @brief Sets the Thread Creation stackaddr Attribute in the attr Object
diff --git a/cpukit/posix/src/pthreadattrsetstacksize.c b/cpukit/posix/src/pthreadattrsetstacksize.c
index 2039da6d85..736c8122fd 100644
--- a/cpukit/posix/src/pthreadattrsetstacksize.c
+++ b/cpukit/posix/src/pthreadattrsetstacksize.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Sets the Thread Creation Stacksize Attribute in the attr object
  * @ingroup POSIXAPI
+ * @brief Sets the Thread Creation Stacksize Attribute in the attr object
diff --git a/cpukit/posix/src/pthreadconcurrency.c b/cpukit/posix/src/pthreadconcurrency.c
index be5d754a9e..b55ce10a65 100644
--- a/cpukit/posix/src/pthreadconcurrency.c
+++ b/cpukit/posix/src/pthreadconcurrency.c
@@ -5,9 +5,10 @@
  * @file
- * @brief Pthread Get/Set Concurrency
  * @ingroup POSIXAPI
+ * @brief Pthread Get/Set Concurrency
  * Per the Open Group specification, when user pthreads are mapped 1:1
  * onto kernel threads, the implementation simply tracks an internal
  * variable whose initial value is 0. If it is set, subsequent calls to
diff --git a/cpukit/posix/src/pthreadcreate.c b/cpukit/posix/src/pthreadcreate.c
index 03899758ee..33c5f8d03a 100644
--- a/cpukit/posix/src/pthreadcreate.c
+++ b/cpukit/posix/src/pthreadcreate.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Function Starts a New Thread in The Calling Process
  * @ingroup POSIXAPI
+ * @brief Function Starts a New Thread in The Calling Process
diff --git a/cpukit/posix/src/pthreaddetach.c b/cpukit/posix/src/pthreaddetach.c
index f316f65917..43fd70a5ce 100644
--- a/cpukit/posix/src/pthreaddetach.c
+++ b/cpukit/posix/src/pthreaddetach.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Detaching a Thread
  * @ingroup POSIXAPI
+ * @brief Detaching a Thread
diff --git a/cpukit/posix/src/pthreadequal.c b/cpukit/posix/src/pthreadequal.c
index d0b0f13baa..c0318baa93 100644
--- a/cpukit/posix/src/pthreadequal.c
+++ b/cpukit/posix/src/pthreadequal.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Compare Thread IDs
  * @ingroup POSIXAPI
+ * @brief Compare Thread IDs
diff --git a/cpukit/posix/src/pthreadexit.c b/cpukit/posix/src/pthreadexit.c
index 92a853e802..502476d141 100644
--- a/cpukit/posix/src/pthreadexit.c
+++ b/cpukit/posix/src/pthreadexit.c
@@ -1,8 +1,9 @@
  * @file
- * @brief POSIX Thread Exit Shared Helper
  * @ingroup POSIX_THREAD Thread API Extension
+ * @brief POSIX Thread Exit Shared Helper
diff --git a/cpukit/posix/src/pthreadgetaffinitynp.c b/cpukit/posix/src/pthreadgetaffinitynp.c
index 5324bfdc73..977f82c69b 100644
--- a/cpukit/posix/src/pthreadgetaffinitynp.c
+++ b/cpukit/posix/src/pthreadgetaffinitynp.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Pthread Get Affinity
  * @ingroup POSIXAPI
+ * @brief Pthread Get Affinity
diff --git a/cpukit/posix/src/pthreadgetattrnp.c b/cpukit/posix/src/pthreadgetattrnp.c
index 44c0edf0f0..a449ad48eb 100644
--- a/cpukit/posix/src/pthreadgetattrnp.c
+++ b/cpukit/posix/src/pthreadgetattrnp.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Pthread Get Attribute
  * @ingroup POSIXAPI
+ * @brief Pthread Get Attribute
diff --git a/cpukit/posix/src/pthreadgetcpuclockid.c b/cpukit/posix/src/pthreadgetcpuclockid.c
index b92fcdd7db..1452774a35 100644
--- a/cpukit/posix/src/pthreadgetcpuclockid.c
+++ b/cpukit/posix/src/pthreadgetcpuclockid.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Returns Clock ID for CPU time clock of the thread
  * @ingroup POSIXAPI
+ * @brief Returns Clock ID for CPU time clock of the thread
diff --git a/cpukit/posix/src/pthreadgetschedparam.c b/cpukit/posix/src/pthreadgetschedparam.c
index 0e9cc31ee2..a82d79c715 100644
--- a/cpukit/posix/src/pthreadgetschedparam.c
+++ b/cpukit/posix/src/pthreadgetschedparam.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Gets Scheduling Policy and Parameters of Individual Threads
  * @ingroup POSIXAPI
+ * @brief Gets Scheduling Policy and Parameters of Individual Threads
diff --git a/cpukit/posix/src/pthreadinitthreads.c b/cpukit/posix/src/pthreadinitthreads.c
index 4f08a72ffb..a144d10bf3 100644
--- a/cpukit/posix/src/pthreadinitthreads.c
+++ b/cpukit/posix/src/pthreadinitthreads.c
@@ -1,8 +1,9 @@
  * @file
- * @brief POSIX Threads Initialize User Threads Body
+ * @brief POSIX Threads Initialize User Threads Body
diff --git a/cpukit/posix/src/pthreadjoin.c b/cpukit/posix/src/pthreadjoin.c
index 383484183a..2cb0903367 100644
--- a/cpukit/posix/src/pthreadjoin.c
+++ b/cpukit/posix/src/pthreadjoin.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Suspends Execution of Calling Thread until Target Thread Terminates
  * @ingroup POSIXAPI
+ * @brief Suspends Execution of Calling Thread until Target Thread Terminates
diff --git a/cpukit/posix/src/pthreadkill.c b/cpukit/posix/src/pthreadkill.c
index a3a74cfacf..f39640e6db 100644
--- a/cpukit/posix/src/pthreadkill.c
+++ b/cpukit/posix/src/pthreadkill.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Sends a signal Asynchronously directed to a thread
  * @ingroup POSIXAPI
+ * @brief Sends a signal Asynchronously directed to a thread
diff --git a/cpukit/posix/src/pthreadonce.c b/cpukit/posix/src/pthreadonce.c
index b766926976..3210a1ab7f 100644
--- a/cpukit/posix/src/pthreadonce.c
+++ b/cpukit/posix/src/pthreadonce.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Call to function by Thread will call init_routine with no Arguments
  * @ingroup POSIXAPI
+ * @brief Call to function by Thread will call init_routine with no Arguments
diff --git a/cpukit/posix/src/pthreadself.c b/cpukit/posix/src/pthreadself.c
index 3cc161ff03..db5f2f189d 100644
--- a/cpukit/posix/src/pthreadself.c
+++ b/cpukit/posix/src/pthreadself.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Function returns the ID of the Calling Thread
  * @ingroup POSIXAPI
+ * @brief Function returns the ID of the Calling Thread
diff --git a/cpukit/posix/src/pthreadsetaffinitynp.c b/cpukit/posix/src/pthreadsetaffinitynp.c
index c2071720f0..ae91d135e1 100644
--- a/cpukit/posix/src/pthreadsetaffinitynp.c
+++ b/cpukit/posix/src/pthreadsetaffinitynp.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Pthread Set Affinity
  * @ingroup POSIXAPI
+ * @brief Pthread Set Affinity
diff --git a/cpukit/posix/src/pthreadsetschedparam.c b/cpukit/posix/src/pthreadsetschedparam.c
index 51dee9bca9..9ab543cd31 100644
--- a/cpukit/posix/src/pthreadsetschedparam.c
+++ b/cpukit/posix/src/pthreadsetschedparam.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Function sets scheduling policy and parameters of the thread
  * @ingroup POSIXAPI
+ * @brief Function sets scheduling policy and parameters of the thread
diff --git a/cpukit/posix/src/pthreadsigmask.c b/cpukit/posix/src/pthreadsigmask.c
index a989cb109b..c82a60c560 100644
--- a/cpukit/posix/src/pthreadsigmask.c
+++ b/cpukit/posix/src/pthreadsigmask.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Examine and/or change the calling thread's signal mask
  * @ingroup POSIXAPI
+ * @brief Examine and/or change the calling thread's signal mask
diff --git a/cpukit/posix/src/rwlockattrdestroy.c b/cpukit/posix/src/rwlockattrdestroy.c
index 3b7639445d..f8a2beb49c 100644
--- a/cpukit/posix/src/rwlockattrdestroy.c
+++ b/cpukit/posix/src/rwlockattrdestroy.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Function Destroys a read-write lock Attributes object
  * @ingroup POSIXAPI
+ * @brief Function Destroys a read-write lock Attributes object
diff --git a/cpukit/posix/src/rwlockattrinit.c b/cpukit/posix/src/rwlockattrinit.c
index 0e37d26636..e752e8c7c6 100644
--- a/cpukit/posix/src/rwlockattrinit.c
+++ b/cpukit/posix/src/rwlockattrinit.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Initialises a RWLock Attributes object attr with the default value
  * @ingroup POSIXAPI
+ * @brief Initialises a RWLock Attributes object attr with the default value
diff --git a/cpukit/posix/src/rwlockattrsetpshared.c b/cpukit/posix/src/rwlockattrsetpshared.c
index 99ae0efd10..a65c4152ff 100644
--- a/cpukit/posix/src/rwlockattrsetpshared.c
+++ b/cpukit/posix/src/rwlockattrsetpshared.c
@@ -1,8 +1,9 @@
  * @file
- * @brief RWLock Attributes Set Process Shared
  * @ingroup POSIXAPI
+ * @brief RWLock Attributes Set Process Shared
diff --git a/cpukit/posix/src/sched_getparam.c b/cpukit/posix/src/sched_getparam.c
index c84b6fdf2d..7db0c44377 100644
--- a/cpukit/posix/src/sched_getparam.c
+++ b/cpukit/posix/src/sched_getparam.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Set Scheduling Parameters
  * @ingroup POSIXAPI
+ * @brief Set Scheduling Parameters
diff --git a/cpukit/posix/src/sched_getprioritymax.c b/cpukit/posix/src/sched_getprioritymax.c
index ff7f4b4885..14acd16d82 100644
--- a/cpukit/posix/src/sched_getprioritymax.c
+++ b/cpukit/posix/src/sched_getprioritymax.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Returns the Appropriate Maximum for Scheduling policy
  * @ingroup POSIXAPI
+ * @brief Returns the Appropriate Maximum for Scheduling policy
diff --git a/cpukit/posix/src/sched_getscheduler.c b/cpukit/posix/src/sched_getscheduler.c
index 6762aa79a6..b176d170b9 100644
--- a/cpukit/posix/src/sched_getscheduler.c
+++ b/cpukit/posix/src/sched_getscheduler.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Function Returns Scheduling Policy of the process specified by pid
  * @ingroup POSIXAPI
+ * @brief Function Returns Scheduling Policy of the process specified by pid
diff --git a/cpukit/posix/src/sched_rr_get_interval.c b/cpukit/posix/src/sched_rr_get_interval.c
index 97186a3f74..e307985044 100644
--- a/cpukit/posix/src/sched_rr_get_interval.c
+++ b/cpukit/posix/src/sched_rr_get_interval.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Limits for Scheduling Parameter
  * @ingroup POSIXAPI
+ * @brief Limits for Scheduling Parameter
diff --git a/cpukit/posix/src/sched_setparam.c b/cpukit/posix/src/sched_setparam.c
index c917500edb..4aa56ec0f8 100644
--- a/cpukit/posix/src/sched_setparam.c
+++ b/cpukit/posix/src/sched_setparam.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Sets Scheduling Parameters Associated with Scheduling Policies
  * @ingroup POSIXAPI
+ * @brief Sets Scheduling Parameters Associated with Scheduling Policies
diff --git a/cpukit/posix/src/sched_setscheduler.c b/cpukit/posix/src/sched_setscheduler.c
index 73036e65d3..49c77119f9 100644
--- a/cpukit/posix/src/sched_setscheduler.c
+++ b/cpukit/posix/src/sched_setscheduler.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Set Scheduling Policy and Scheduling Parameters
  * @ingroup POSIXAPI
+ * @brief Set Scheduling Policy and Scheduling Parameters
diff --git a/cpukit/posix/src/sched_yield.c b/cpukit/posix/src/sched_yield.c
index 34242b759b..1f3be3654b 100644
--- a/cpukit/posix/src/sched_yield.c
+++ b/cpukit/posix/src/sched_yield.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Yield Processor
  * @ingroup POSIXAPI
+ * @brief Yield Processor
diff --git a/cpukit/posix/src/semclose.c b/cpukit/posix/src/semclose.c
index 79c5861db0..432ab1aafa 100644
--- a/cpukit/posix/src/semclose.c
+++ b/cpukit/posix/src/semclose.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Close a Named Semaphore
  * @ingroup POSIX_SEMAPHORE
+ * @brief Close a Named Semaphore
diff --git a/cpukit/posix/src/semgetvalue.c b/cpukit/posix/src/semgetvalue.c
index 1e2670dd25..1389027cc7 100644
--- a/cpukit/posix/src/semgetvalue.c
+++ b/cpukit/posix/src/semgetvalue.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Get the Value of a Semaphore
+ * @brief Get the Value of a Semaphore
diff --git a/cpukit/posix/src/seminit.c b/cpukit/posix/src/seminit.c
index 09fc95f7a3..447d48749e 100644
--- a/cpukit/posix/src/seminit.c
+++ b/cpukit/posix/src/seminit.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Initializing of an Unnamed Semaphore
  * @ingroup POSIXAPI
+ * @brief Initializing of an Unnamed Semaphore
diff --git a/cpukit/posix/src/semopen.c b/cpukit/posix/src/semopen.c
index 97c513ec3a..3691add324 100644
--- a/cpukit/posix/src/semopen.c
+++ b/cpukit/posix/src/semopen.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Function Creates New POSIX semaphore or Opens an existing Semaphore
  * @ingroup POSIXAPI
+ * @brief Function Creates New POSIX semaphore or Opens an existing Semaphore
diff --git a/cpukit/posix/src/semtimedwait.c b/cpukit/posix/src/semtimedwait.c
index b2057016c5..21a8320b50 100644
--- a/cpukit/posix/src/semtimedwait.c
+++ b/cpukit/posix/src/semtimedwait.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Lock a Semaphore
  * @ingroup POSIX_SEMAPHORE POSIX Semaphores Support
+ * @brief Lock a Semaphore
diff --git a/cpukit/posix/src/semunlink.c b/cpukit/posix/src/semunlink.c
index 021cee3343..3d73ab5887 100644
--- a/cpukit/posix/src/semunlink.c
+++ b/cpukit/posix/src/semunlink.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Remove a Named Semaphore
+ * @brief Remove a Named Semaphore
diff --git a/cpukit/posix/src/setcancelstate.c b/cpukit/posix/src/setcancelstate.c
index 4040c37b55..2227321e07 100644
--- a/cpukit/posix/src/setcancelstate.c
+++ b/cpukit/posix/src/setcancelstate.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Setting Cancelability State
  * @ingroup POSIXAPI
+ * @brief Setting Cancelability State
diff --git a/cpukit/posix/src/setcanceltype.c b/cpukit/posix/src/setcanceltype.c
index 302f901a74..4a7a7e3486 100644
--- a/cpukit/posix/src/setcanceltype.c
+++ b/cpukit/posix/src/setcanceltype.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Sets the Cancelability Type of Calling Thread to value given in type
  * @ingroup POSIXAPI
+ * @brief Sets the Cancelability Type of Calling Thread to value given in type
diff --git a/cpukit/posix/src/setitimer.c b/cpukit/posix/src/setitimer.c
index 02aeb320c7..3cb04db018 100644
--- a/cpukit/posix/src/setitimer.c
+++ b/cpukit/posix/src/setitimer.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Set the Timer
  * @ingroup POSIXAPI
+ * @brief Set the Timer
diff --git a/cpukit/posix/src/sigaction.c b/cpukit/posix/src/sigaction.c
index 86d66480fc..112360af0d 100644
--- a/cpukit/posix/src/sigaction.c
+++ b/cpukit/posix/src/sigaction.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Allows calling process to examine action of a Specific Signal
  * @ingroup POSIXAPI
+ * @brief Allows calling process to examine action of a Specific Signal
diff --git a/cpukit/posix/src/sigaddset.c b/cpukit/posix/src/sigaddset.c
index 2dc17cd6b6..c9394f4c20 100644
--- a/cpukit/posix/src/sigaddset.c
+++ b/cpukit/posix/src/sigaddset.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Function Adds Signal from Set
  * @ingroup POSIXAPI
+ * @brief Function Adds Signal from Set
diff --git a/cpukit/posix/src/sigdelset.c b/cpukit/posix/src/sigdelset.c
index 20f91e6ecf..991023ac9e 100644
--- a/cpukit/posix/src/sigdelset.c
+++ b/cpukit/posix/src/sigdelset.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Deleted Signal from Set
  * @ingroup POSIXAPI
+ * @brief Deleted Signal from Set
diff --git a/cpukit/posix/src/sigemptyset.c b/cpukit/posix/src/sigemptyset.c
index 50e24daa59..d64d4cd42a 100644
--- a/cpukit/posix/src/sigemptyset.c
+++ b/cpukit/posix/src/sigemptyset.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Manipulate Signal Sets
  * @ingroup POSIXAPI
+ * @brief Manipulate Signal Sets
diff --git a/cpukit/posix/src/sigfillset.c b/cpukit/posix/src/sigfillset.c
index 6adc372775..334a81f5ad 100644
--- a/cpukit/posix/src/sigfillset.c
+++ b/cpukit/posix/src/sigfillset.c
@@ -1,8 +1,9 @@
  * @file
  * @ingroup POSIXAPI
diff --git a/cpukit/posix/src/sigismember.c b/cpukit/posix/src/sigismember.c
index 9928e18e6f..c7ddeda433 100644
--- a/cpukit/posix/src/sigismember.c
+++ b/cpukit/posix/src/sigismember.c
@@ -1,8 +1,9 @@
  * @file
  * @ingroup POSIXAPI
diff --git a/cpukit/posix/src/signal_2.c b/cpukit/posix/src/signal_2.c
index bd891e22ee..a98430ebf3 100644
--- a/cpukit/posix/src/signal_2.c
+++ b/cpukit/posix/src/signal_2.c
@@ -1,8 +1,9 @@
  * @file
- * @brief POSIX Function Installs signal Handler
  * @ingroup POSIXAPI
+ * @brief POSIX Function Installs signal Handler
diff --git a/cpukit/posix/src/sigpending.c b/cpukit/posix/src/sigpending.c
index d65fe0586f..7b8e9e0d9a 100644
--- a/cpukit/posix/src/sigpending.c
+++ b/cpukit/posix/src/sigpending.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Examine Pending Signals
  * @ingroup POSIXAPI
+ * @brief Examine Pending Signals
diff --git a/cpukit/posix/src/sigprocmask.c b/cpukit/posix/src/sigprocmask.c
index 235a58c52c..db923d3af0 100644
--- a/cpukit/posix/src/sigprocmask.c
+++ b/cpukit/posix/src/sigprocmask.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Examine and Change Blocked Signals
  * @ingroup POSIXAPI
+ * @brief Examine and Change Blocked Signals
diff --git a/cpukit/posix/src/sigqueue.c b/cpukit/posix/src/sigqueue.c
index 5446ca9701..dadf70abd3 100644
--- a/cpukit/posix/src/sigqueue.c
+++ b/cpukit/posix/src/sigqueue.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Queue a Signal to a Process
  * @ingroup POSIXAPI
+ * @brief Queue a Signal to a Process
diff --git a/cpukit/posix/src/sigsuspend.c b/cpukit/posix/src/sigsuspend.c
index 79c93fc457..b8dc191d15 100644
--- a/cpukit/posix/src/sigsuspend.c
+++ b/cpukit/posix/src/sigsuspend.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Replacing signal mask with *sigmask and suspending calling process
  * @ingroup POSIXAPI
+ * @brief Replacing signal mask with *sigmask and suspending calling process
diff --git a/cpukit/posix/src/sigwait.c b/cpukit/posix/src/sigwait.c
index 3b07cc2c49..b247503b5d 100644
--- a/cpukit/posix/src/sigwait.c
+++ b/cpukit/posix/src/sigwait.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Synchronously Accept a Signal
  * @ingroup POSIXAPI
+ * @brief Synchronously Accept a Signal
diff --git a/cpukit/posix/src/sysconf.c b/cpukit/posix/src/sysconf.c
index f905a82f07..1696ec51bb 100644
--- a/cpukit/posix/src/sysconf.c
+++ b/cpukit/posix/src/sysconf.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Get Configurable System Variables
  * @ingroup POSIXAPI
+ * @brief Get Configurable System Variables
diff --git a/cpukit/posix/src/testcancel.c b/cpukit/posix/src/testcancel.c
index 0d6471f818..e0ead6e323 100644
--- a/cpukit/posix/src/testcancel.c
+++ b/cpukit/posix/src/testcancel.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Setting test on Cancelability State
  * @ingroup POSIXAPI
+ * @brief Setting test on Cancelability State
diff --git a/cpukit/posix/src/timergettime.c b/cpukit/posix/src/timergettime.c
index 4b884b8cbb..ee2a566f0e 100644
--- a/cpukit/posix/src/timergettime.c
+++ b/cpukit/posix/src/timergettime.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Function Fetches State of POSIX Per-Process Timers
  * @ingroup POSIXAPI
+ * @brief Function Fetches State of POSIX Per-Process Timers
diff --git a/cpukit/posix/src/timersettime.c b/cpukit/posix/src/timersettime.c
index b83c8b07c9..f88485410e 100644
--- a/cpukit/posix/src/timersettime.c
+++ b/cpukit/posix/src/timersettime.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Function Arms or Disarms the Timer Identified by timerid
  * @ingroup POSIXAPI
+ * @brief Function Arms or Disarms the Timer Identified by timerid
diff --git a/cpukit/posix/src/ualarm.c b/cpukit/posix/src/ualarm.c
index 292ae36e2e..857f8ce881 100644
--- a/cpukit/posix/src/ualarm.c
+++ b/cpukit/posix/src/ualarm.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Schedule Alarm
  * @ingroup POSIXAPI
+ * @brief Schedule Alarm
diff --git a/cpukit/posix/src/vfork.c b/cpukit/posix/src/vfork.c
index 6483d1961a..3a62efbb23 100644
--- a/cpukit/posix/src/vfork.c
+++ b/cpukit/posix/src/vfork.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Creates Child process Of The Calling process
  * @ingroup POSIXAPI
+ * @brief Creates Child process Of The Calling process
diff --git a/cpukit/posix/src/wait.c b/cpukit/posix/src/wait.c
index da248c9870..fe48b71e9c 100644
--- a/cpukit/posix/src/wait.c
+++ b/cpukit/posix/src/wait.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Wait for Process to Change State
  * @ingroup POSIXAPI
+ * @brief Wait for Process to Change State
diff --git a/cpukit/rtems/src/barriercreate.c b/cpukit/rtems/src/barriercreate.c
index a4a362239b..74cedab27a 100644
--- a/cpukit/rtems/src/barriercreate.c
+++ b/cpukit/rtems/src/barriercreate.c
@@ -1,8 +1,9 @@
  * @file
- * @brief RTEMS Create Barrier
  * @ingroup ClassicBarrier Barriers
+ * @brief RTEMS Create Barrier
diff --git a/cpukit/rtems/src/barrierrelease.c b/cpukit/rtems/src/barrierrelease.c
index c4385b02fa..801c07afcb 100644
--- a/cpukit/rtems/src/barrierrelease.c
+++ b/cpukit/rtems/src/barrierrelease.c
@@ -1,8 +1,9 @@
  * @file
- * @brief RTEMS Barrier Release
+ * @brief RTEMS Barrier Release
diff --git a/cpukit/rtems/src/clockgettod.c b/cpukit/rtems/src/clockgettod.c
index f65f5e2f4b..4610c6a519 100644
--- a/cpukit/rtems/src/clockgettod.c
+++ b/cpukit/rtems/src/clockgettod.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Obtain Current Time of Day (Classic TOD)
  * @ingroup ClassicClock Clocks
+ * @brief Obtain Current Time of Day (Classic TOD)
diff --git a/cpukit/rtems/src/clockgetuptime.c b/cpukit/rtems/src/clockgetuptime.c
index e60f47186d..b79745b035 100644
--- a/cpukit/rtems/src/clockgetuptime.c
+++ b/cpukit/rtems/src/clockgetuptime.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Obtain the System Uptime
+ * @brief Obtain the System Uptime
diff --git a/cpukit/rtems/src/clockgetuptimenanoseconds.c b/cpukit/rtems/src/clockgetuptimenanoseconds.c
index 30d5cd77fa..3eb1a2daea 100644
--- a/cpukit/rtems/src/clockgetuptimenanoseconds.c
+++ b/cpukit/rtems/src/clockgetuptimenanoseconds.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Returns the system uptime in seconds.
+ * @brief Returns the system uptime in seconds.
diff --git a/cpukit/rtems/src/eventreceive.c b/cpukit/rtems/src/eventreceive.c
index 190ee8234d..c638ec543c 100644
--- a/cpukit/rtems/src/eventreceive.c
+++ b/cpukit/rtems/src/eventreceive.c
@@ -1,8 +1,9 @@
  * @file
- * @brief  Constant used to receive the set of currently pending events in
  * @ingroup ClassicEventSet Event Set
+ * @brief  Constant used to receive the set of currently pending events in
diff --git a/cpukit/rtems/src/eventseize.c b/cpukit/rtems/src/eventseize.c
index 6c2b82da36..8230959ec0 100644
--- a/cpukit/rtems/src/eventseize.c
+++ b/cpukit/rtems/src/eventseize.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Event Manager Initialization
  * @ingroup ClassicEvent Events
+ * @brief Event Manager Initialization
diff --git a/cpukit/rtems/src/msgmp.c b/cpukit/rtems/src/msgmp.c
index 4971b94809..f49c254fbd 100644
--- a/cpukit/rtems/src/msgmp.c
+++ b/cpukit/rtems/src/msgmp.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Multiprocessing Support for the Message Queue Manager
  * @ingroup ClassicMsgMP Message Queue MP Support
+ * @brief Multiprocessing Support for the Message Queue Manager
diff --git a/cpukit/rtems/src/msgqflush.c b/cpukit/rtems/src/msgqflush.c
index 7e7442b34a..010ad0aa6d 100644
--- a/cpukit/rtems/src/msgqflush.c
+++ b/cpukit/rtems/src/msgqflush.c
@@ -1,8 +1,9 @@
  * @file
- * @brief rtems_message_queue_flush
  * @ingroup ClassicMessageQueue Message Queues
+ * @brief rtems_message_queue_flush
diff --git a/cpukit/rtems/src/msgqgetnumberpending.c b/cpukit/rtems/src/msgqgetnumberpending.c
index 0a62f724f2..0b95ca9eeb 100644
--- a/cpukit/rtems/src/msgqgetnumberpending.c
+++ b/cpukit/rtems/src/msgqgetnumberpending.c
@@ -1,8 +1,9 @@
  * @file
- * @brief RTEMS Message Queue Get Number Pending
+ * @brief RTEMS Message Queue Get Number Pending
diff --git a/cpukit/rtems/src/msgqsend.c b/cpukit/rtems/src/msgqsend.c
index 71a1ab492b..2ddba4d0a6 100644
--- a/cpukit/rtems/src/msgqsend.c
+++ b/cpukit/rtems/src/msgqsend.c
@@ -1,8 +1,9 @@
  * @file
- * @brief rtems_message_queue_send
+ * @brief rtems_message_queue_send
diff --git a/cpukit/rtems/src/partcreate.c b/cpukit/rtems/src/partcreate.c
index 9378408e5b..2aefce8067 100644
--- a/cpukit/rtems/src/partcreate.c
+++ b/cpukit/rtems/src/partcreate.c
@@ -1,8 +1,9 @@
  * @file
- * @brief RTEMS Partition Create
  * @ingroup ClassicPart Partitions
+ * @brief RTEMS Partition Create
diff --git a/cpukit/rtems/src/partmp.c b/cpukit/rtems/src/partmp.c
index 3d7abc1e5d..ac2b48aba4 100644
--- a/cpukit/rtems/src/partmp.c
+++ b/cpukit/rtems/src/partmp.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Partition_MP_Send_process_packet
  * @ingroup ClassicPartMP Partition MP Support
+ * @brief Partition_MP_Send_process_packet
diff --git a/cpukit/rtems/src/ratemoncreate.c b/cpukit/rtems/src/ratemoncreate.c
index 440b093bfa..3eff5f0716 100644
--- a/cpukit/rtems/src/ratemoncreate.c
+++ b/cpukit/rtems/src/ratemoncreate.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Create a Period
  * @ingroup ClassicRateMon Rate Monotonic Scheduler
+ * @brief Create a Period
diff --git a/cpukit/rtems/src/ratemonresetall.c b/cpukit/rtems/src/ratemonresetall.c
index c9e9089528..978a33ace7 100644
--- a/cpukit/rtems/src/ratemonresetall.c
+++ b/cpukit/rtems/src/ratemonresetall.c
@@ -1,8 +1,9 @@
  * @file
- * @brief rtems_rate_monotonic_reset_all_statistics
+ * @brief rtems_rate_monotonic_reset_all_statistics
diff --git a/cpukit/rtems/src/ratemonresetstatistics.c b/cpukit/rtems/src/ratemonresetstatistics.c
index 3e133a478e..4567451a18 100644
--- a/cpukit/rtems/src/ratemonresetstatistics.c
+++ b/cpukit/rtems/src/ratemonresetstatistics.c
@@ -1,8 +1,9 @@
  * @file
- * @brief RTEMS Rate Monotonic Reset Statistics
+ * @brief RTEMS Rate Monotonic Reset Statistics
diff --git a/cpukit/rtems/src/regioncreate.c b/cpukit/rtems/src/regioncreate.c
index 5d3d8a60bc..de8f165fe7 100644
--- a/cpukit/rtems/src/regioncreate.c
+++ b/cpukit/rtems/src/regioncreate.c
@@ -1,8 +1,9 @@
  * @file
- * @brief rtems_region_create
  * @ingroup ClassicRegion Regions
+ * @brief rtems_region_create
diff --git a/cpukit/rtems/src/rtemsbuildid.c b/cpukit/rtems/src/rtemsbuildid.c
index 4e7bc51e54..b8a375a33c 100644
--- a/cpukit/rtems/src/rtemsbuildid.c
+++ b/cpukit/rtems/src/rtemsbuildid.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Build Object Id
  * @ingroup ClassicClassInfo Object Class Information
+ * @brief Build Object Id
diff --git a/cpukit/rtems/src/rtemsobjectapiminimumclass.c b/cpukit/rtems/src/rtemsobjectapiminimumclass.c
index 820892f303..1e3501c065 100644
--- a/cpukit/rtems/src/rtemsobjectapiminimumclass.c
+++ b/cpukit/rtems/src/rtemsobjectapiminimumclass.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Get Lowest Valid Class Value
+ * @brief Get Lowest Valid Class Value
diff --git a/cpukit/rtems/src/rtemsobjectidgetapi.c b/cpukit/rtems/src/rtemsobjectidgetapi.c
index 6c8eb153f7..2842a82615 100644
--- a/cpukit/rtems/src/rtemsobjectidgetapi.c
+++ b/cpukit/rtems/src/rtemsobjectidgetapi.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Get API Portion of Object Id
+ * @brief Get API Portion of Object Id
diff --git a/cpukit/rtems/src/rtemsobjectsetname.c b/cpukit/rtems/src/rtemsobjectsetname.c
index ccdda15737..9e1b3a4039 100644
--- a/cpukit/rtems/src/rtemsobjectsetname.c
+++ b/cpukit/rtems/src/rtemsobjectsetname.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Set Name of Object
+ * @brief Set Name of Object
diff --git a/cpukit/rtems/src/semcreate.c b/cpukit/rtems/src/semcreate.c
index 10f7b33f7c..6cdd877cce 100644
--- a/cpukit/rtems/src/semcreate.c
+++ b/cpukit/rtems/src/semcreate.c
@@ -1,8 +1,9 @@
  * @file
- * @brief rtems_semaphore_create
  * @ingroup ClassicSem Semaphores
+ * @brief rtems_semaphore_create
diff --git a/cpukit/rtems/src/semrelease.c b/cpukit/rtems/src/semrelease.c
index 4de2543a92..e5b0e4834d 100644
--- a/cpukit/rtems/src/semrelease.c
+++ b/cpukit/rtems/src/semrelease.c
@@ -1,9 +1,10 @@
  * @file
- * @brief RTEMS Semaphore Release
+ * @brief RTEMS Semaphore Release
  * This file contains the implementation of the Classic API directive
  * rtems_semaphore_release().
diff --git a/cpukit/rtems/src/taskgetaffinity.c b/cpukit/rtems/src/taskgetaffinity.c
index ebcdab9ee3..9f4b653d4c 100644
--- a/cpukit/rtems/src/taskgetaffinity.c
+++ b/cpukit/rtems/src/taskgetaffinity.c
@@ -1,8 +1,9 @@
  * @file
- * @brief  RTEMS Task Get Affinity
  * @ingroup ClassicTasks Tasks
+ * @brief  RTEMS Task Get Affinity
diff --git a/cpukit/rtems/src/taskinitusers.c b/cpukit/rtems/src/taskinitusers.c
index 104cb8b880..0b23d8bc86 100644
--- a/cpukit/rtems/src/taskinitusers.c
+++ b/cpukit/rtems/src/taskinitusers.c
@@ -1,8 +1,9 @@
  * @file
- * @brief _RTEMS_tasks_Initialize_user_tasks_body
+ * @brief _RTEMS_tasks_Initialize_user_tasks_body
diff --git a/cpukit/rtems/src/taskissuspended.c b/cpukit/rtems/src/taskissuspended.c
index 2706d76269..db9850ccb1 100644
--- a/cpukit/rtems/src/taskissuspended.c
+++ b/cpukit/rtems/src/taskissuspended.c
@@ -1,8 +1,9 @@
  * @file
- * @brief rtems_task_is_suspended
+ * @brief rtems_task_is_suspended
diff --git a/cpukit/rtems/src/taskmp.c b/cpukit/rtems/src/taskmp.c
index c5dcb89603..525c595ae3 100644
--- a/cpukit/rtems/src/taskmp.c
+++ b/cpukit/rtems/src/taskmp.c
@@ -1,8 +1,9 @@
  * @file
- * @brief RTEMS Tasks MP Send Process Packet
  * @ingroup ClassicTaskMP Task MP Support
+ * @brief RTEMS Tasks MP Send Process Packet
diff --git a/cpukit/rtems/src/tasksetaffinity.c b/cpukit/rtems/src/tasksetaffinity.c
index 1ba8343729..826c18dca3 100644
--- a/cpukit/rtems/src/tasksetaffinity.c
+++ b/cpukit/rtems/src/tasksetaffinity.c
@@ -1,8 +1,9 @@
  * @file
- * @brief  RTEMS Task Set Affinity
+ * @brief  RTEMS Task Set Affinity
diff --git a/cpukit/rtems/src/taskstart.c b/cpukit/rtems/src/taskstart.c
index e781734bdf..247756fcb1 100644
--- a/cpukit/rtems/src/taskstart.c
+++ b/cpukit/rtems/src/taskstart.c
@@ -1,8 +1,9 @@
  * @file
- * @brief  RTEMS Start Task
+ * @brief  RTEMS Start Task
diff --git a/cpukit/rtems/src/timerreset.c b/cpukit/rtems/src/timerreset.c
index 1465952c12..683264d839 100644
--- a/cpukit/rtems/src/timerreset.c
+++ b/cpukit/rtems/src/timerreset.c
@@ -1,8 +1,9 @@
  * @file
- * @brief RTEMS Timer Reset
  * @ingroup ClassicTimer Timers
+ * @brief RTEMS Timer Reset
diff --git a/cpukit/rtems/src/timerserverfirewhen.c b/cpukit/rtems/src/timerserverfirewhen.c
index 8d62c80c58..ca3961e1e5 100644
--- a/cpukit/rtems/src/timerserverfirewhen.c
+++ b/cpukit/rtems/src/timerserverfirewhen.c
@@ -1,8 +1,9 @@
  * @file
- * @brief RTEMS Timer Server Fire When Directive
+ * @brief RTEMS Timer Server Fire When Directive
diff --git a/cpukit/sapi/src/rbtreefind.c b/cpukit/sapi/src/rbtreefind.c
index f58799f19f..7c8fcb8952 100644
--- a/cpukit/sapi/src/rbtreefind.c
+++ b/cpukit/sapi/src/rbtreefind.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Find the control structure of the tree containing the given node
  * @ingroup RTEMSScorertems_rbtree
+ * @brief Find the control structure of the tree containing the given node
diff --git a/cpukit/score/src/coremsginsert.c b/cpukit/score/src/coremsginsert.c
index e377cff9cf..850e1cd457 100644
--- a/cpukit/score/src/coremsginsert.c
+++ b/cpukit/score/src/coremsginsert.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Insert a Message into the Message Queue
  * @ingroup RTEMSScoreMessageQueue
+ * @brief Insert a Message into the Message Queue
diff --git a/cpukit/score/src/corerwlock.c b/cpukit/score/src/corerwlock.c
index 933f6c1013..068a412861 100644
--- a/cpukit/score/src/corerwlock.c
+++ b/cpukit/score/src/corerwlock.c
@@ -1,8 +1,9 @@
  * @file
- * @brief
  * @ingroup RTEMSScoreRWLock
+ * @brief
diff --git a/cpukit/score/src/corerwlockobtainread.c b/cpukit/score/src/corerwlockobtainread.c
index 3f74da98ad..ee74c3dc6d 100644
--- a/cpukit/score/src/corerwlockobtainread.c
+++ b/cpukit/score/src/corerwlockobtainread.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Obtain RWLock for reading
+ * @brief Obtain RWLock for reading
diff --git a/cpukit/score/src/corerwlockobtainwrite.c b/cpukit/score/src/corerwlockobtainwrite.c
index 43ab8a74c0..ea0cdabcdc 100644
--- a/cpukit/score/src/corerwlockobtainwrite.c
+++ b/cpukit/score/src/corerwlockobtainwrite.c
@@ -1,8 +1,9 @@
  * @file
- * @brief RWLock Obtain for Writing
+ * @brief RWLock Obtain for Writing
diff --git a/cpukit/score/src/coretodadjust.c b/cpukit/score/src/coretodadjust.c
index f06515447e..e58d1e5d69 100644
--- a/cpukit/score/src/coretodadjust.c
+++ b/cpukit/score/src/coretodadjust.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Adjust the Time of Time
  * @ingroup RTEMSScoreTOD
+ * @brief Adjust the Time of Time
diff --git a/cpukit/score/src/coretodtickspersec.c b/cpukit/score/src/coretodtickspersec.c
index d319f6f74f..107614c730 100644
--- a/cpukit/score/src/coretodtickspersec.c
+++ b/cpukit/score/src/coretodtickspersec.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Convert Ticks To Seconds
+ * @brief Convert Ticks To Seconds
 /*  COPYRIGHT (c) 1989-2014.
diff --git a/cpukit/score/src/interr.c b/cpukit/score/src/interr.c
index 5908381c67..f59f352ba2 100644
--- a/cpukit/score/src/interr.c
+++ b/cpukit/score/src/interr.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Initiates system termination
  * @ingroup RTEMSScoreIntErr
+ * @brief Initiates system termination
diff --git a/cpukit/score/src/mpci.c b/cpukit/score/src/mpci.c
index 8f1b218aca..dff2338ed6 100644
--- a/cpukit/score/src/mpci.c
+++ b/cpukit/score/src/mpci.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Multiprocessing Communications Interface (MPCI) Handler
  * @ingroup RTEMSScoreMPCI
+ * @brief Multiprocessing Communications Interface (MPCI) Handler
diff --git a/cpukit/score/src/mpcidefault.c b/cpukit/score/src/mpcidefault.c
index 101cbcd7b6..ea3e2eaf41 100644
--- a/cpukit/score/src/mpcidefault.c
+++ b/cpukit/score/src/mpcidefault.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Multiprocessing Communications Interface (MPCI) Default Configuration
+ * @brief Multiprocessing Communications Interface (MPCI) Default Configuration
diff --git a/cpukit/score/src/objectextendinformation.c b/cpukit/score/src/objectextendinformation.c
index a21257d1f5..f4c96462bf 100644
--- a/cpukit/score/src/objectextendinformation.c
+++ b/cpukit/score/src/objectextendinformation.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Extend Set of Objects
  * @ingroup RTEMSScoreObject
+ * @brief Extend Set of Objects
diff --git a/cpukit/score/src/objectgetnext.c b/cpukit/score/src/objectgetnext.c
index eb347e8ac0..841d5aa8e2 100644
--- a/cpukit/score/src/objectgetnext.c
+++ b/cpukit/score/src/objectgetnext.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Get Pointer to Next Object that is Active
+ * @brief Get Pointer to Next Object that is Active
diff --git a/cpukit/score/src/objectinitializeinformation.c b/cpukit/score/src/objectinitializeinformation.c
index 910112e223..b2cb85322f 100644
--- a/cpukit/score/src/objectinitializeinformation.c
+++ b/cpukit/score/src/objectinitializeinformation.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Initialize Object Information
+ * @brief Initialize Object Information
diff --git a/cpukit/score/src/objectnametoidstring.c b/cpukit/score/src/objectnametoidstring.c
index 3fd4141b03..38054bface 100644
--- a/cpukit/score/src/objectnametoidstring.c
+++ b/cpukit/score/src/objectnametoidstring.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Object ID to Name
+ * @brief Object ID to Name
diff --git a/cpukit/score/src/objectsetname.c b/cpukit/score/src/objectsetname.c
index 30b640ed52..0808ab87af 100644
--- a/cpukit/score/src/objectsetname.c
+++ b/cpukit/score/src/objectsetname.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Set Objects Name
+ * @brief Set Objects Name
diff --git a/cpukit/score/src/percpu.c b/cpukit/score/src/percpu.c
index 9d1620907b..6aebfc2637 100644
--- a/cpukit/score/src/percpu.c
+++ b/cpukit/score/src/percpu.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Allocate and Initialize Per CPU Structures
  * @ingroup PerCPU
+ * @brief Allocate and Initialize Per CPU Structures
diff --git a/cpukit/score/src/scheduler.c b/cpukit/score/src/scheduler.c
index a48f0e4783..45c0496838 100644
--- a/cpukit/score/src/scheduler.c
+++ b/cpukit/score/src/scheduler.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Scheduler Initialize
  * @ingroup RTEMSScoreScheduler
+ * @brief Scheduler Initialize
diff --git a/cpukit/score/src/schedulercbs.c b/cpukit/score/src/schedulercbs.c
index 94c4f49789..12a7a76251 100644
--- a/cpukit/score/src/schedulercbs.c
+++ b/cpukit/score/src/schedulercbs.c
@@ -1,8 +1,9 @@
  * @file
- * @brief CBS Scheduler Budget Handler
+ * @brief CBS Scheduler Budget Handler
diff --git a/cpukit/score/src/schedulercbsgetparameters.c b/cpukit/score/src/schedulercbsgetparameters.c
index de27c31370..65e4965176 100644
--- a/cpukit/score/src/schedulercbsgetparameters.c
+++ b/cpukit/score/src/schedulercbsgetparameters.c
@@ -1,8 +1,9 @@
  * @file
- * @brief _Scheduler_CBS_Get_parameters
+ * @brief _Scheduler_CBS_Get_parameters
diff --git a/cpukit/score/src/scheduleredf.c b/cpukit/score/src/scheduleredf.c
index 2ffdeb8040..3b0c62c0c3 100644
--- a/cpukit/score/src/scheduleredf.c
+++ b/cpukit/score/src/scheduleredf.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Scheduler EDF Initialize and Support
+ * @brief Scheduler EDF Initialize and Support
diff --git a/cpukit/score/src/scheduleredfreleasejob.c b/cpukit/score/src/scheduleredfreleasejob.c
index 1f01f9cfa5..0e3e527109 100644
--- a/cpukit/score/src/scheduleredfreleasejob.c
+++ b/cpukit/score/src/scheduleredfreleasejob.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Scheduler EDF Release Job
+ * @brief Scheduler EDF Release Job
diff --git a/cpukit/score/src/scheduleredfunblock.c b/cpukit/score/src/scheduleredfunblock.c
index 3302a478c0..a1c45af91c 100644
--- a/cpukit/score/src/scheduleredfunblock.c
+++ b/cpukit/score/src/scheduleredfunblock.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Scheduler EDF Unblock
+ * @brief Scheduler EDF Unblock
diff --git a/cpukit/score/src/schedulerpriorityblock.c b/cpukit/score/src/schedulerpriorityblock.c
index 50830f6176..ae44710ea6 100644
--- a/cpukit/score/src/schedulerpriorityblock.c
+++ b/cpukit/score/src/schedulerpriorityblock.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Scheduler Priority Block
+ * @brief Scheduler Priority Block
diff --git a/cpukit/score/src/schedulerpriorityschedule.c b/cpukit/score/src/schedulerpriorityschedule.c
index 3e1acb07c8..7861a5861e 100644
--- a/cpukit/score/src/schedulerpriorityschedule.c
+++ b/cpukit/score/src/schedulerpriorityschedule.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Priority Scheduler Schedule Method
+ * @brief Priority Scheduler Schedule Method
diff --git a/cpukit/score/src/schedulersimpleschedule.c b/cpukit/score/src/schedulersimpleschedule.c
index ee17219349..a48475828c 100644
--- a/cpukit/score/src/schedulersimpleschedule.c
+++ b/cpukit/score/src/schedulersimpleschedule.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Simple Schedule Determine Heir
+ * @brief Simple Schedule Determine Heir
diff --git a/cpukit/score/src/schedulersimpleunblock.c b/cpukit/score/src/schedulersimpleunblock.c
index 9bc1635b3d..516b5f2675 100644
--- a/cpukit/score/src/schedulersimpleunblock.c
+++ b/cpukit/score/src/schedulersimpleunblock.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Scheduler Simple Handler / Unblock
+ * @brief Scheduler Simple Handler / Unblock
diff --git a/cpukit/score/src/schedulersimpleyield.c b/cpukit/score/src/schedulersimpleyield.c
index 79b3f86c37..db78660719 100644
--- a/cpukit/score/src/schedulersimpleyield.c
+++ b/cpukit/score/src/schedulersimpleyield.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Simple Schedule Yield CPU
+ * @brief Simple Schedule Yield CPU
diff --git a/cpukit/score/src/threaddispatch.c b/cpukit/score/src/threaddispatch.c
index b2ac57b401..c57ddb01ae 100644
--- a/cpukit/score/src/threaddispatch.c
+++ b/cpukit/score/src/threaddispatch.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Dispatch Thread
  * @ingroup RTEMSScoreThread
+ * @brief Dispatch Thread
diff --git a/cpukit/score/src/threadqenqueue.c b/cpukit/score/src/threadqenqueue.c
index 44fabb24c7..972736f3f2 100644
--- a/cpukit/score/src/threadqenqueue.c
+++ b/cpukit/score/src/threadqenqueue.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Thread Queue Operations
  * @ingroup RTEMSScoreThreadQ
+ * @brief Thread Queue Operations
diff --git a/cpukit/score/src/threadqflush.c b/cpukit/score/src/threadqflush.c
index f9303f4eec..5666aaf22c 100644
--- a/cpukit/score/src/threadqflush.c
+++ b/cpukit/score/src/threadqflush.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Thread Queue Flush
+ * @brief Thread Queue Flush
diff --git a/cpukit/score/src/threadrestart.c b/cpukit/score/src/threadrestart.c
index 9ecf654f3b..fcae5b1e3c 100644
--- a/cpukit/score/src/threadrestart.c
+++ b/cpukit/score/src/threadrestart.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Restart Thread
+ * @brief Restart Thread
diff --git a/cpukit/score/src/timespecdivide.c b/cpukit/score/src/timespecdivide.c
index a163375c92..3c075fa75f 100644
--- a/cpukit/score/src/timespecdivide.c
+++ b/cpukit/score/src/timespecdivide.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Divide Timespec By Integer
  * @ingroup Timespec
+ * @brief Divide Timespec By Integer
diff --git a/cpukit/score/src/watchdoginsert.c b/cpukit/score/src/watchdoginsert.c
index 5a031d3a70..766b828368 100644
--- a/cpukit/score/src/watchdoginsert.c
+++ b/cpukit/score/src/watchdoginsert.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Watchdog Insert
  * @ingroup RTEMSScoreWatchdog
+ * @brief Watchdog Insert
diff --git a/cpukit/score/src/watchdogremove.c b/cpukit/score/src/watchdogremove.c
index def0ef5496..44a5ea26f3 100644
--- a/cpukit/score/src/watchdogremove.c
+++ b/cpukit/score/src/watchdogremove.c
@@ -1,8 +1,9 @@
  * @file
- * @brief Remove Watchdog
+ * @brief Remove Watchdog
2.16.4
