[PATCH] doxygen: Switch @brief and @ingroup
Joel Sherrill
joel at rtems.org
Mon Apr 27 14:44:30 UTC 2020
How does it change the output with Latex or HTML?
Thanks.
--joel
On Mon, Apr 27, 2020 at 9:15 AM Sebastian Huber <
> This order change fixes the Latex documentation build via Doxygen.
> cpukit/include/rtems/rtems-rfs.h | 3 ++-
> cpukit/libblock/src/bdpart-create.c | 3 ++-
> cpukit/libblock/src/bdpart-dump.c | 3 ++-
> cpukit/libblock/src/bdpart-mount.c | 3 ++-
> cpukit/libblock/src/bdpart-read.c | 3 ++-
> cpukit/libblock/src/bdpart-register.c | 3 ++-
> cpukit/libblock/src/bdpart-sort.c | 3 ++-
> cpukit/libblock/src/bdpart-write.c | 3 ++-
> cpukit/libblock/src/blkdev-blkstats.c | 3 ++-
> cpukit/libblock/src/blkdev-imfs.c | 3 ++-
> cpukit/libblock/src/blkdev-ioctl.c | 3 ++-
> cpukit/libblock/src/blkdev-print-stats.c | 3 ++-
> cpukit/libblock/src/blkdev.c | 3 ++-
> cpukit/libblock/src/diskdevs-init.c | 3 ++-
> cpukit/libblock/src/flashdisk.c | 3 ++-
> cpukit/libblock/src/ide_part_table.c | 3 ++-
> cpukit/libblock/src/nvdisk-sram.c | 3 ++-
> cpukit/libblock/src/nvdisk.c | 3 ++-
> cpukit/libblock/src/show_bdbuf.c | 3 ++-
> cpukit/libcsupport/src/_realloc_r.c | 3 ++-
> cpukit/libcsupport/src/access.c | 3 ++-
> cpukit/libcsupport/src/assoclocalbyname.c | 3 ++-
> cpukit/libcsupport/src/assocremotebylocalbitfield.c | 3 ++-
> cpukit/libcsupport/src/chdir.c | 3 ++-
> cpukit/libcsupport/src/chroot.c | 3 ++-
> cpukit/libcsupport/src/close.c | 3 ++-
> cpukit/libcsupport/src/dup.c | 3 ++-
> cpukit/libcsupport/src/fcntl.c | 3 ++-
> cpukit/libcsupport/src/fdatasync.c | 3 ++-
> cpukit/libcsupport/src/free.c | 3 ++-
> cpukit/libcsupport/src/ioctl.c | 3 ++-
> cpukit/libcsupport/src/kill_noposix.c | 3 ++-
> cpukit/libcsupport/src/setegid.c | 3 ++-
> cpukit/libcsupport/src/sup_fs_mount_iterate.c | 3 ++-
> cpukit/libcsupport/src/utsname.c | 3 ++-
> cpukit/libcsupport/src/write_r.c | 3 ++-
> cpukit/libfs/src/defaults/default_are_nodes_equal.c | 3 ++-
> cpukit/libfs/src/defaults/default_clone.c | 3 ++-
> cpukit/libfs/src/defaults/default_eval_path.c | 3 ++-
> cpukit/libfs/src/defaults/default_fcntl.c | 3 ++-
> cpukit/libfs/src/defaults/default_freenode.c | 3 ++-
> cpukit/libfs/src/defaults/default_fstat.c | 3 ++-
> cpukit/libfs/src/defaults/default_fsync.c | 3 ++-
> cpukit/libfs/src/defaults/default_fsync_success.c | 3 ++-
> cpukit/libfs/src/defaults/default_ftruncate.c | 3 ++-
> cpukit/libfs/src/defaults/default_ftruncate_directory.c | 3 ++-
> cpukit/libfs/src/defaults/default_ioctl.c | 3 ++-
> cpukit/libfs/src/defaults/default_lock_and_unlock.c | 3 ++-
> cpukit/libfs/src/defaults/default_lseek.c | 3 ++-
> cpukit/libfs/src/defaults/default_lseek_directory.c | 3 ++-
> cpukit/libfs/src/defaults/default_lseek_file.c | 3 ++-
> cpukit/libfs/src/defaults/default_mknod.c | 3 ++-
> cpukit/libfs/src/defaults/default_mount.c | 3 ++-
> cpukit/libfs/src/defaults/default_open.c | 3 ++-
> cpukit/libfs/src/defaults/default_readlink.c | 3 ++-
> cpukit/libfs/src/defaults/default_rename.c | 3 ++-
> cpukit/libfs/src/defaults/default_rmnod.c | 3 ++-
> cpukit/libfs/src/defaults/default_symlink.c | 3 ++-
> cpukit/libfs/src/defaults/default_unmount.c | 3 ++-
> cpukit/libfs/src/defaults/default_utime.c | 3 ++-
> cpukit/libfs/src/defaults/default_write.c | 3 ++-
> cpukit/libfs/src/dosfs/fat.c | 3 ++-
> cpukit/libfs/src/dosfs/fat_fat_operations.c | 3 ++-
> cpukit/libfs/src/dosfs/fat_file.c | 3 ++-
> cpukit/libfs/src/dosfs/msdos_conv.c | 3 ++-
> cpukit/libfs/src/dosfs/msdos_create.c | 3 ++-
> cpukit/libfs/src/dosfs/msdos_dir.c | 3 ++-
> cpukit/libfs/src/dosfs/msdos_eval.c | 3 ++-
> cpukit/libfs/src/dosfs/msdos_file.c | 3 ++-
> cpukit/libfs/src/dosfs/msdos_format.c | 3 ++-
> cpukit/libfs/src/dosfs/msdos_free.c | 3 ++-
> cpukit/libfs/src/dosfs/msdos_fsunmount.c | 3 ++-
> cpukit/libfs/src/dosfs/msdos_handlers_dir.c | 3 ++-
> cpukit/libfs/src/dosfs/msdos_handlers_file.c | 3 ++-
> cpukit/libfs/src/dosfs/msdos_init.c | 3 ++-
> cpukit/libfs/src/dosfs/msdos_initsupp.c | 3 ++-
> cpukit/libfs/src/dosfs/msdos_misc.c | 3 ++-
> cpukit/libfs/src/dosfs/msdos_mknod.c | 3 ++-
> cpukit/libfs/src/dosfs/msdos_rename.c | 3 ++-
> cpukit/libfs/src/dosfs/msdos_rmnod.c | 3 ++-
> cpukit/libfs/src/dosfs/msdos_statvfs.c | 3 ++-
> cpukit/libfs/src/imfs/deviceio.c | 3 ++-
> cpukit/libfs/src/imfs/imfs_chown.c | 3 ++-
> cpukit/libfs/src/imfs/imfs_config.c | 3 ++-
> cpukit/libfs/src/imfs/imfs_creat.c | 3 ++-
> cpukit/libfs/src/imfs/imfs_eval.c | 3 ++-
> cpukit/libfs/src/imfs/imfs_fchmod.c | 3 ++-
> cpukit/libfs/src/imfs/imfs_fifo.c | 3 ++-
> cpukit/libfs/src/imfs/imfs_fsunmount.c | 3 ++-
> cpukit/libfs/src/imfs/imfs_handlers_device.c | 3 ++-
> cpukit/libfs/src/imfs/imfs_initsupp.c | 3 ++-
> cpukit/libfs/src/imfs/imfs_link.c | 3 ++-
> cpukit/libfs/src/imfs/imfs_load_tar.c | 3 ++-
> cpukit/libfs/src/imfs/imfs_make_generic_node.c | 3 ++-
> cpukit/libfs/src/imfs/imfs_memfile.c | 3 ++-
> cpukit/libfs/src/imfs/imfs_mknod.c | 3 ++-
> cpukit/libfs/src/imfs/imfs_mount.c | 3 ++-
> cpukit/libfs/src/imfs/imfs_node.c | 3 ++-
> cpukit/libfs/src/imfs/imfs_rename.c | 3 ++-
> cpukit/libfs/src/imfs/imfs_rmnod.c | 3 ++-
> cpukit/libfs/src/imfs/imfs_stat.c | 3 ++-
> cpukit/libfs/src/imfs/imfs_symlink.c | 3 ++-
> cpukit/libfs/src/imfs/imfs_unmount.c | 3 ++-
> cpukit/libfs/src/imfs/imfs_utime.c | 3 ++-
> cpukit/libfs/src/imfs/ioman.c | 3 ++-
> cpukit/libfs/src/nfsclient/proto/mount_prot_xdr.c | 3 ++-
> cpukit/libfs/src/nfsclient/proto/nfs_prot_xdr.c | 3 ++-
> cpukit/libfs/src/nfsclient/src/nfs.c | 3 ++-
> cpukit/libfs/src/nfsclient/src/rpcio.c | 3 ++-
> cpukit/libfs/src/nfsclient/src/sock_mbuf.c | 3 ++-
> cpukit/libfs/src/nfsclient/src/xdr_mbuf.c | 3 ++-
> cpukit/libfs/src/pipe/fifo.c | 3 ++-
> cpukit/libfs/src/pipe/pipe.c | 3 ++-
> cpukit/libfs/src/rfs/rtems-rfs-bitmaps.c | 3 ++-
> cpukit/libfs/src/rfs/rtems-rfs-block.c | 3 ++-
> cpukit/libfs/src/rfs/rtems-rfs-buffer-bdbuf.c | 3 ++-
> cpukit/libfs/src/rfs/rtems-rfs-buffer-devio.c | 3 ++-
> cpukit/libfs/src/rfs/rtems-rfs-buffer.c | 3 ++-
> cpukit/libfs/src/rfs/rtems-rfs-dir-hash.c | 3 ++-
> cpukit/libfs/src/rfs/rtems-rfs-dir.c | 3 ++-
> cpukit/libfs/src/rfs/rtems-rfs-file-system.c | 3 ++-
> cpukit/libfs/src/rfs/rtems-rfs-file.c | 3 ++-
> cpukit/libfs/src/rfs/rtems-rfs-format.c | 3 ++-
> cpukit/libfs/src/rfs/rtems-rfs-group.c | 3 ++-
> cpukit/libfs/src/rfs/rtems-rfs-inode.c | 3 ++-
> cpukit/libfs/src/rfs/rtems-rfs-link.c | 3 ++-
> cpukit/libfs/src/rfs/rtems-rfs-mutex.c | 3 ++-
> cpukit/libfs/src/rfs/rtems-rfs-rtems-dev.c | 3 ++-
> cpukit/libfs/src/rfs/rtems-rfs-rtems-dir.c | 3 ++-
> cpukit/libfs/src/rfs/rtems-rfs-rtems-file.c | 3 ++-
> cpukit/libfs/src/rfs/rtems-rfs-rtems-utils.c | 3 ++-
> cpukit/libfs/src/rfs/rtems-rfs-rtems.c | 3 ++-
> cpukit/libfs/src/rfs/rtems-rfs-shell.c | 3 ++-
> cpukit/libfs/src/rfs/rtems-rfs-trace.c | 3 ++-
> cpukit/libmisc/bspcmdline/bspcmdline_get.c | 3 ++-
> cpukit/libmisc/bspcmdline/bspcmdline_getparam.c | 3 ++-
> cpukit/libmisc/bspcmdline/bspcmdline_getparamraw.c | 3 ++-
> cpukit/libmisc/bspcmdline/bspcmdline_getparamrhs.c | 3 ++-
> cpukit/libmisc/cpuuse/cpuusagedata.c | 3 ++-
> cpukit/libmisc/cpuuse/cpuusagereport.c | 3 ++-
> cpukit/libmisc/cpuuse/cpuusagereset.c | 3 ++-
> cpukit/libmisc/cpuuse/cpuusagetop.c | 3 ++-
> cpukit/libmisc/devnull/devnull.c | 3 ++-
> cpukit/libmisc/devnull/devzero.c | 3 ++-
> cpukit/libmisc/dumpbuf/dumpbuf.c | 3 ++-
> cpukit/libmisc/fb/mw_print.c | 3 ++-
> cpukit/libmisc/fb/mw_uid.c | 3 ++-
> cpukit/libmisc/fsmount/fsmount.c | 3 ++-
> cpukit/libmisc/mouse/mouse_parser.c | 3 ++-
> cpukit/libmisc/mouse/serial_mouse.c | 3 ++-
> cpukit/libmisc/shell/main_df.c | 3 ++-
> cpukit/libmisc/stackchk/check.c | 3 ++-
> cpukit/libmisc/stringto/stringtodouble.c | 3 ++-
> cpukit/libmisc/stringto/stringtofloat.c | 3 ++-
> cpukit/libmisc/stringto/stringtoint.c | 3 ++-
> cpukit/libmisc/stringto/stringtolong.c | 3 ++-
> cpukit/libmisc/stringto/stringtolongdouble.c | 3 ++-
> cpukit/libmisc/stringto/stringtolonglong.c | 3 ++-
> cpukit/libmisc/stringto/stringtopointer.c | 3 ++-
> cpukit/libmisc/stringto/stringtounsignedchar.c | 3 ++-
> cpukit/libmisc/stringto/stringtounsignedint.c | 3 ++-
> cpukit/libmisc/stringto/stringtounsignedlong.c | 3 ++-
> cpukit/libmisc/stringto/stringtounsignedlonglong.c | 3 ++-
> cpukit/posix/src/_execve.c | 3 ++-
> cpukit/posix/src/aio_error.c | 3 ++-
> cpukit/posix/src/aio_fsync.c | 3 ++-
> cpukit/posix/src/aio_misc.c | 3 ++-
> cpukit/posix/src/aio_read.c | 3 ++-
> cpukit/posix/src/aio_return.c | 3 ++-
> cpukit/posix/src/aio_suspend.c | 3 ++-
> cpukit/posix/src/aio_write.c | 3 ++-
> cpukit/posix/src/alarm.c | 3 ++-
> cpukit/posix/src/barrierattrdestroy.c | 3 ++-
> cpukit/posix/src/barrierattrgetpshared.c | 3 ++-
> cpukit/posix/src/cancel.c | 3 ++-
> cpukit/posix/src/cleanuppush.c | 3 ++-
> cpukit/posix/src/clockgetcpuclockid.c | 3 ++-
> cpukit/posix/src/clockgetres.c | 3 ++-
> cpukit/posix/src/clockgettime.c | 3 ++-
> cpukit/posix/src/clocksettime.c | 3 ++-
> cpukit/posix/src/condattrdestroy.c | 3 ++-
> cpukit/posix/src/condattrgetclock.c | 3 ++-
> cpukit/posix/src/condattrgetpshared.c | 3 ++-
> cpukit/posix/src/condattrinit.c | 3 ++-
> cpukit/posix/src/condattrsetclock.c | 3 ++-
> cpukit/posix/src/condattrsetpshared.c | 3 ++-
> cpukit/posix/src/conddefaultattributes.c | 3 ++-
> cpukit/posix/src/condsignalsupp.c | 3 ++-
> cpukit/posix/src/condtimedwait.c | 3 ++-
> cpukit/posix/src/condwait.c | 3 ++-
> cpukit/posix/src/condwaitsupp.c | 3 ++-
> cpukit/posix/src/fork.c | 3 ++-
> cpukit/posix/src/getitimer.c | 3 ++-
> cpukit/posix/src/keycreate.c | 3 ++-
> cpukit/posix/src/keydelete.c | 3 ++-
> cpukit/posix/src/keygetspecific.c | 3 ++-
> cpukit/posix/src/keysetspecific.c | 3 ++-
> cpukit/posix/src/kill.c | 3 ++-
> cpukit/posix/src/kill_r.c | 3 ++-
> cpukit/posix/src/killinfo.c | 3 ++-
> cpukit/posix/src/lio_listio.c | 3 ++-
> cpukit/posix/src/mprotect.c | 3 ++-
> cpukit/posix/src/mqueueclose.c | 3 ++-
> cpukit/posix/src/mqueuegetattr.c | 3 ++-
> cpukit/posix/src/mqueuenotify.c | 3 ++-
> cpukit/posix/src/mqueueopen.c | 3 ++-
> cpukit/posix/src/mqueuerecvsupp.c | 3 ++-
> cpukit/posix/src/mqueuesend.c | 3 ++-
> cpukit/posix/src/mqueuesendsupp.c | 3 ++-
> cpukit/posix/src/mqueuesetattr.c | 3 ++-
> cpukit/posix/src/mqueuetimedreceive.c | 3 ++-
> cpukit/posix/src/mqueueunlink.c | 3 ++-
> cpukit/posix/src/mutexattrdestroy.c | 3 ++-
> cpukit/posix/src/mutexattrgetprioceiling.c | 3 ++-
> cpukit/posix/src/mutexattrgetprotocol.c | 3 ++-
> cpukit/posix/src/mutexattrgetpshared.c | 3 ++-
> cpukit/posix/src/mutexattrgettype.c | 3 ++-
> cpukit/posix/src/mutexattrsetprioceiling.c | 3 ++-
> cpukit/posix/src/mutexattrsetprotocol.c | 3 ++-
> cpukit/posix/src/mutexattrsetpshared.c | 3 ++-
> cpukit/posix/src/mutexdestroy.c | 3 ++-
> cpukit/posix/src/mutexgetprioceiling.c | 3 ++-
> cpukit/posix/src/mutexinit.c | 3 ++-
> cpukit/posix/src/mutexlock.c | 3 ++-
> cpukit/posix/src/mutexlocksupp.c | 3 ++-
> cpukit/posix/src/mutexsetprioceiling.c | 3 ++-
> cpukit/posix/src/mutextimedlock.c | 3 ++-
> cpukit/posix/src/mutextrylock.c | 3 ++-
> cpukit/posix/src/mutexunlock.c | 3 ++-
> cpukit/posix/src/nanosleep.c | 3 ++-
> cpukit/posix/src/pause.c | 3 ++-
> cpukit/posix/src/pbarrierinit.c | 3 ++-
> cpukit/posix/src/pbarrierwait.c | 3 ++-
> cpukit/posix/src/prwlockinit.c | 3 ++-
> cpukit/posix/src/prwlockrdlock.c | 3 ++-
> cpukit/posix/src/prwlocktimedrdlock.c | 3 ++-
> cpukit/posix/src/prwlocktimedwrlock.c | 3 ++-
> cpukit/posix/src/prwlocktryrdlock.c | 3 ++-
> cpukit/posix/src/prwlocktrywrlock.c | 3 ++-
> cpukit/posix/src/prwlockunlock.c | 3 ++-
> cpukit/posix/src/prwlockwrlock.c | 3 ++-
> cpukit/posix/src/psignalclearprocesssignals.c | 3 ++-
> cpukit/posix/src/psignalclearsignals.c | 3 ++-
> cpukit/posix/src/psignalunblockthread.c | 3 ++-
> cpukit/posix/src/pspininit.c | 3 ++-
> cpukit/posix/src/pspinunlock.c | 3 ++-
> cpukit/posix/src/psxnametoid.c | 3 ++-
> cpukit/posix/src/psxtimercreate.c | 3 ++-
> cpukit/posix/src/psxtimerdelete.c | 3 ++-
> cpukit/posix/src/psxtransschedparam.c | 3 ++-
> cpukit/posix/src/pthread.c | 3 ++-
> cpukit/posix/src/pthreadattrdefault.c | 3 ++-
> cpukit/posix/src/pthreadattrdestroy.c | 3 ++-
> cpukit/posix/src/pthreadattrgetaffinitynp.c | 3 ++-
> cpukit/posix/src/pthreadattrgetdetachstate.c | 3 ++-
> cpukit/posix/src/pthreadattrgetguardsize.c | 3 ++-
> cpukit/posix/src/pthreadattrgetinheritsched.c | 3 ++-
> cpukit/posix/src/pthreadattrgetschedparam.c | 3 ++-
> cpukit/posix/src/pthreadattrgetscope.c | 3 ++-
> cpukit/posix/src/pthreadattrgetstack.c | 3 ++-
> cpukit/posix/src/pthreadattrgetstackaddr.c | 3 ++-
> cpukit/posix/src/pthreadattrgetstacksize.c | 3 ++-
> cpukit/posix/src/pthreadattrinit.c | 3 ++-
> cpukit/posix/src/pthreadattrsetaffinitynp.c | 3 ++-
> cpukit/posix/src/pthreadattrsetdetachstate.c | 3 ++-
> cpukit/posix/src/pthreadattrsetguardsize.c | 3 ++-
> cpukit/posix/src/pthreadattrsetinheritsched.c | 3 ++-
> cpukit/posix/src/pthreadattrsetschedparam.c | 3 ++-
> cpukit/posix/src/pthreadattrsetschedpolicy.c | 3 ++-
> cpukit/posix/src/pthreadattrsetscope.c | 3 ++-
> cpukit/posix/src/pthreadattrsetstack.c | 3 ++-
> cpukit/posix/src/pthreadattrsetstackaddr.c | 3 ++-
> cpukit/posix/src/pthreadattrsetstacksize.c | 3 ++-
> cpukit/posix/src/pthreadconcurrency.c | 3 ++-
> cpukit/posix/src/pthreadcreate.c | 3 ++-
> cpukit/posix/src/pthreaddetach.c | 3 ++-
> cpukit/posix/src/pthreadequal.c | 3 ++-
> cpukit/posix/src/pthreadexit.c | 3 ++-
> cpukit/posix/src/pthreadgetaffinitynp.c | 3 ++-
> cpukit/posix/src/pthreadgetattrnp.c | 3 ++-
> cpukit/posix/src/pthreadgetcpuclockid.c | 3 ++-
> cpukit/posix/src/pthreadgetschedparam.c | 3 ++-
> cpukit/posix/src/pthreadinitthreads.c | 3 ++-
> cpukit/posix/src/pthreadjoin.c | 3 ++-
> cpukit/posix/src/pthreadkill.c | 3 ++-
> cpukit/posix/src/pthreadonce.c | 3 ++-
> cpukit/posix/src/pthreadself.c | 3 ++-
> cpukit/posix/src/pthreadsetaffinitynp.c | 3 ++-
> cpukit/posix/src/pthreadsetschedparam.c | 3 ++-
> cpukit/posix/src/pthreadsigmask.c | 3 ++-
> cpukit/posix/src/rwlockattrdestroy.c | 3 ++-
> cpukit/posix/src/rwlockattrinit.c | 3 ++-
> cpukit/posix/src/rwlockattrsetpshared.c | 3 ++-
> cpukit/posix/src/sched_getparam.c | 3 ++-
> cpukit/posix/src/sched_getprioritymax.c | 3 ++-
> cpukit/posix/src/sched_getscheduler.c | 3 ++-
> cpukit/posix/src/sched_rr_get_interval.c | 3 ++-
> cpukit/posix/src/sched_setparam.c | 3 ++-
> cpukit/posix/src/sched_setscheduler.c | 3 ++-
> cpukit/posix/src/sched_yield.c | 3 ++-
> cpukit/posix/src/semclose.c | 3 ++-
> cpukit/posix/src/semgetvalue.c | 3 ++-
> cpukit/posix/src/seminit.c | 3 ++-
> cpukit/posix/src/semopen.c | 3 ++-
> cpukit/posix/src/semtimedwait.c | 3 ++-
> cpukit/posix/src/semunlink.c | 3 ++-
> cpukit/posix/src/setcancelstate.c | 3 ++-
> cpukit/posix/src/setcanceltype.c | 3 ++-
> cpukit/posix/src/setitimer.c | 3 ++-
> cpukit/posix/src/sigaction.c | 3 ++-
> cpukit/posix/src/sigaddset.c | 3 ++-
> cpukit/posix/src/sigdelset.c | 3 ++-
> cpukit/posix/src/sigemptyset.c | 3 ++-
> cpukit/posix/src/sigfillset.c | 3 ++-
> cpukit/posix/src/sigismember.c | 3 ++-
> cpukit/posix/src/signal_2.c | 3 ++-
> cpukit/posix/src/sigpending.c | 3 ++-
> cpukit/posix/src/sigprocmask.c | 3 ++-
> cpukit/posix/src/sigqueue.c | 3 ++-
> cpukit/posix/src/sigsuspend.c | 3 ++-
> cpukit/posix/src/sigwait.c | 3 ++-
> cpukit/posix/src/sysconf.c | 3 ++-
> cpukit/posix/src/testcancel.c | 3 ++-
> cpukit/posix/src/timergettime.c | 3 ++-
> cpukit/posix/src/timersettime.c | 3 ++-
> cpukit/posix/src/ualarm.c | 3 ++-
> cpukit/posix/src/vfork.c | 3 ++-
> cpukit/posix/src/wait.c | 3 ++-
> cpukit/rtems/src/barriercreate.c | 3 ++-
> cpukit/rtems/src/barrierrelease.c | 3 ++-
> cpukit/rtems/src/clockgettod.c | 3 ++-
> cpukit/rtems/src/clockgetuptime.c | 3 ++-
> cpukit/rtems/src/clockgetuptimenanoseconds.c | 3 ++-
> cpukit/rtems/src/eventreceive.c | 3 ++-
> cpukit/rtems/src/eventseize.c | 3 ++-
> cpukit/rtems/src/msgmp.c | 3 ++-
> cpukit/rtems/src/msgqflush.c | 3 ++-
> cpukit/rtems/src/msgqgetnumberpending.c | 3 ++-
> cpukit/rtems/src/msgqsend.c | 3 ++-
> cpukit/rtems/src/partcreate.c | 3 ++-
> cpukit/rtems/src/partmp.c | 3 ++-
> cpukit/rtems/src/ratemoncreate.c | 3 ++-
> cpukit/rtems/src/ratemonresetall.c | 3 ++-
> cpukit/rtems/src/ratemonresetstatistics.c | 3 ++-
> cpukit/rtems/src/regioncreate.c | 3 ++-
> cpukit/rtems/src/rtemsbuildid.c | 3 ++-
> cpukit/rtems/src/rtemsobjectapiminimumclass.c | 3 ++-
> cpukit/rtems/src/rtemsobjectidgetapi.c | 3 ++-
> cpukit/rtems/src/rtemsobjectsetname.c | 3 ++-
> cpukit/rtems/src/semcreate.c | 3 ++-
> cpukit/rtems/src/semrelease.c | 3 ++-
> cpukit/rtems/src/taskgetaffinity.c | 3 ++-
> cpukit/rtems/src/taskinitusers.c | 3 ++-
> cpukit/rtems/src/taskissuspended.c | 3 ++-
> cpukit/rtems/src/taskmp.c | 3 ++-
> cpukit/rtems/src/tasksetaffinity.c | 3 ++-
> cpukit/rtems/src/taskstart.c | 3 ++-
> cpukit/rtems/src/timerreset.c | 3 ++-
> cpukit/rtems/src/timerserverfirewhen.c | 3 ++-
> cpukit/sapi/src/rbtreefind.c | 3 ++-
> cpukit/score/src/coremsginsert.c | 3 ++-
> cpukit/score/src/corerwlock.c | 3 ++-
> cpukit/score/src/corerwlockobtainread.c | 3 ++-
> cpukit/score/src/corerwlockobtainwrite.c | 3 ++-
> cpukit/score/src/coretodadjust.c | 3 ++-
> cpukit/score/src/coretodtickspersec.c | 3 ++-
> cpukit/score/src/interr.c | 3 ++-
> cpukit/score/src/mpci.c | 3 ++-
> cpukit/score/src/mpcidefault.c | 3 ++-
> cpukit/score/src/objectextendinformation.c | 3 ++-
> cpukit/score/src/objectgetnext.c | 3 ++-
> cpukit/score/src/objectinitializeinformation.c | 3 ++-
> cpukit/score/src/objectnametoidstring.c | 3 ++-
> cpukit/score/src/objectsetname.c | 3 ++-
> cpukit/score/src/percpu.c | 3 ++-
> cpukit/score/src/scheduler.c | 3 ++-
> cpukit/score/src/schedulercbs.c | 3 ++-
> cpukit/score/src/schedulercbsgetparameters.c | 3 ++-
> cpukit/score/src/scheduleredf.c | 3 ++-
> cpukit/score/src/scheduleredfreleasejob.c | 3 ++-
> cpukit/score/src/scheduleredfunblock.c | 3 ++-
> cpukit/score/src/schedulerpriorityblock.c | 3 ++-
> cpukit/score/src/schedulerpriorityschedule.c | 3 ++-
> cpukit/score/src/schedulersimpleschedule.c | 3 ++-
> cpukit/score/src/schedulersimpleunblock.c | 3 ++-
> cpukit/score/src/schedulersimpleyield.c | 3 ++-
> cpukit/score/src/threaddispatch.c | 3 ++-
> cpukit/score/src/threadqenqueue.c | 3 ++-
> cpukit/score/src/threadqflush.c | 3 ++-
> cpukit/score/src/threadrestart.c | 3 ++-
> cpukit/score/src/timespecdivide.c | 3 ++-
> cpukit/score/src/watchdoginsert.c | 3 ++-
> cpukit/score/src/watchdogremove.c | 3 ++-
> 393 files changed, 786 insertions(+), 393 deletions(-)
> diff --git a/cpukit/include/rtems/rtems-rfs.h
> b/cpukit/include/rtems/rtems-rfs.h
> index 958f9a636b..f0e76cf25c 100644
> --- a/cpukit/include/rtems/rtems-rfs.h
> +++ b/cpukit/include/rtems/rtems-rfs.h
> @@ -1,9 +1,10 @@
> * @file
> - * @brief RFS File system Initialization
> * @ingroup rtems_rfs
> + * @brief RFS File system Initialization
> * RTEMS File System
> diff --git a/cpukit/libblock/src/bdpart-create.c
> b/cpukit/libblock/src/bdpart-create.c
> index 52cdeeb989..8bfc1de302 100644
> --- a/cpukit/libblock/src/bdpart-create.c
> +++ b/cpukit/libblock/src/bdpart-create.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Manage Partitions of a Disk Device
> * @ingroup rtems_bdpart
> + * @brief Manage Partitions of a Disk Device
> diff --git a/cpukit/libblock/src/bdpart-dump.c
> b/cpukit/libblock/src/bdpart-dump.c
> index adf9296954..ce58a0020f 100644
> --- a/cpukit/libblock/src/bdpart-dump.c
> +++ b/cpukit/libblock/src/bdpart-dump.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Prints the Partition Table @a Partitions with @a Count
> Partitions
> + * @brief Prints the Partition Table @a Partitions with @a Count
> Partitions
> diff --git a/cpukit/libblock/src/bdpart-mount.c
> b/cpukit/libblock/src/bdpart-mount.c
> index 6cb281709e..cfc08ead30 100644
> --- a/cpukit/libblock/src/bdpart-mount.c
> +++ b/cpukit/libblock/src/bdpart-mount.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Block Device Partition Management
> + * @brief Block Device Partition Management
> diff --git a/cpukit/libblock/src/bdpart-read.c
> b/cpukit/libblock/src/bdpart-read.c
> index d8115288fa..cfebdbc9d4 100644
> --- a/cpukit/libblock/src/bdpart-read.c
> +++ b/cpukit/libblock/src/bdpart-read.c
> @@ -1,8 +1,9 @@
> * @file
> diff --git a/cpukit/libblock/src/bdpart-register.c
> b/cpukit/libblock/src/bdpart-register.c
> index 66a7498e2c..9956e61a68 100644
> --- a/cpukit/libblock/src/bdpart-register.c
> +++ b/cpukit/libblock/src/bdpart-register.c
> @@ -1,8 +1,9 @@
> * @file
> diff --git a/cpukit/libblock/src/bdpart-sort.c
> b/cpukit/libblock/src/bdpart-sort.c
> index 17fb64113c..52de38b442 100644
> --- a/cpukit/libblock/src/bdpart-sort.c
> +++ b/cpukit/libblock/src/bdpart-sort.c
> @@ -1,8 +1,9 @@
> * @file
> diff --git a/cpukit/libblock/src/bdpart-write.c
> b/cpukit/libblock/src/bdpart-write.c
> index 9443bc63bc..0418e82850 100644
> --- a/cpukit/libblock/src/bdpart-write.c
> +++ b/cpukit/libblock/src/bdpart-write.c
> @@ -1,8 +1,9 @@
> * @file
> diff --git a/cpukit/libblock/src/blkdev-blkstats.c
> b/cpukit/libblock/src/blkdev-blkstats.c
> index c035ee4ecb..a6b336af2d 100644
> --- a/cpukit/libblock/src/blkdev-blkstats.c
> +++ b/cpukit/libblock/src/blkdev-blkstats.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Block Device Statistics Command
> * @ingroup rtems_blkdev Block Device Management
> + * @brief Block Device Statistics Command
> diff --git a/cpukit/libblock/src/blkdev-imfs.c
> b/cpukit/libblock/src/blkdev-imfs.c
> index a6872f442d..c7e582cfbc 100644
> --- a/cpukit/libblock/src/blkdev-imfs.c
> +++ b/cpukit/libblock/src/blkdev-imfs.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Block Device IMFS
> * @ingroup libblock
> + * @brief Block Device IMFS
> diff --git a/cpukit/libblock/src/blkdev-ioctl.c
> b/cpukit/libblock/src/blkdev-ioctl.c
> index 3e8b081142..834f892d5c 100644
> --- a/cpukit/libblock/src/blkdev-ioctl.c
> +++ b/cpukit/libblock/src/blkdev-ioctl.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Common IO Control Primitive
> + * @brief Common IO Control Primitive
> diff --git a/cpukit/libblock/src/blkdev-print-stats.c
> b/cpukit/libblock/src/blkdev-print-stats.c
> index 6e43139374..8edf24fd8c 100644
> --- a/cpukit/libblock/src/blkdev-print-stats.c
> +++ b/cpukit/libblock/src/blkdev-print-stats.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Prints the Block Device Statistics
> + * @brief Prints the Block Device Statistics
> diff --git a/cpukit/libblock/src/blkdev.c b/cpukit/libblock/src/blkdev.c
> index f19c273d24..e818129196 100644
> --- a/cpukit/libblock/src/blkdev.c
> +++ b/cpukit/libblock/src/blkdev.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Block Device Management
> + * @brief Block Device Management
> diff --git a/cpukit/libblock/src/diskdevs-init.c
> b/cpukit/libblock/src/diskdevs-init.c
> index 5ed2c71b0f..35923506bc 100644
> --- a/cpukit/libblock/src/diskdevs-init.c
> +++ b/cpukit/libblock/src/diskdevs-init.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Block Device Disk Management Initialize
> * @ingroup rtems_disk Block Device Disk Management
> + * @brief Block Device Disk Management Initialize
> diff --git a/cpukit/libblock/src/flashdisk.c
> b/cpukit/libblock/src/flashdisk.c
> index a3fbbba119..91f99e0d52 100644
> --- a/cpukit/libblock/src/flashdisk.c
> +++ b/cpukit/libblock/src/flashdisk.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Flash Disk Block Device Implementation
> * @ingroup libblock
> + * @brief Flash Disk Block Device Implementation
> diff --git a/cpukit/libblock/src/ide_part_table.c
> b/cpukit/libblock/src/ide_part_table.c
> index 5f8f2116ed..a802be5dfb 100644
> --- a/cpukit/libblock/src/ide_part_table.c
> +++ b/cpukit/libblock/src/ide_part_table.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Library supporting "MS-DOS-style" Partition Table
> * @ingroup libblock
> + * @brief Library supporting "MS-DOS-style" Partition Table
> diff --git a/cpukit/libblock/src/nvdisk-sram.c
> b/cpukit/libblock/src/nvdisk-sram.c
> index 6ac709883a..aa6fe00977 100644
> --- a/cpukit/libblock/src/nvdisk-sram.c
> +++ b/cpukit/libblock/src/nvdisk-sram.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Provide SRAM support for the NV Disk
> * @ingroup libblock
> + * @brief Provide SRAM support for the NV Disk
> diff --git a/cpukit/libblock/src/nvdisk.c b/cpukit/libblock/src/nvdisk.c
> index d2042928ef..a7f4167d33 100644
> --- a/cpukit/libblock/src/nvdisk.c
> +++ b/cpukit/libblock/src/nvdisk.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Non-Volatile Disk Block Device Implementation
> * @ingroup libblock
> + * @brief Non-Volatile Disk Block Device Implementation
> diff --git a/cpukit/libblock/src/show_bdbuf.c
> b/cpukit/libblock/src/show_bdbuf.c
> index 29bf3d7e22..22564fe75b 100644
> --- a/cpukit/libblock/src/show_bdbuf.c
> +++ b/cpukit/libblock/src/show_bdbuf.c
> @@ -1,9 +1,10 @@
> * @file
> - * @brief Enable the Monitor to Show bdbuf Information
> + * @brief Enable the Monitor to Show bdbuf Information
> * This module inspects the bdbuf data structures,
> * assuming they are static, but in fact they are used very
> * dynamically. Therefore the results show MAY BE INCORRECT in
> diff --git a/cpukit/libcsupport/src/_realloc_r.c
> b/cpukit/libcsupport/src/_realloc_r.c
> index 57f0aaf834..95f9e054f5 100644
> --- a/cpukit/libcsupport/src/_realloc_r.c
> +++ b/cpukit/libcsupport/src/_realloc_r.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief _realloc_r Implementation
> * @ingroup libcsupport
> + * @brief _realloc_r Implementation
> diff --git a/cpukit/libcsupport/src/access.c
> b/cpukit/libcsupport/src/access.c
> index cc3dee7ffa..57276305ac 100644
> --- a/cpukit/libcsupport/src/access.c
> +++ b/cpukit/libcsupport/src/access.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief access() - POSIX 1003.1b 5.6.3 - File Accessibility
> + * @brief access() - POSIX 1003.1b 5.6.3 - File Accessibility
> diff --git a/cpukit/libcsupport/src/assoclocalbyname.c
> b/cpukit/libcsupport/src/assoclocalbyname.c
> index 2fba102abe..c0267f3f53 100644
> --- a/cpukit/libcsupport/src/assoclocalbyname.c
> +++ b/cpukit/libcsupport/src/assoclocalbyname.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief RTEMS Associate Local by Name
> * @ingroup Associativity Routines
> + * @brief RTEMS Associate Local by Name
> diff --git a/cpukit/libcsupport/src/assocremotebylocalbitfield.c
> b/cpukit/libcsupport/src/assocremotebylocalbitfield.c
> index efcc87a3c4..4a9cc0b175 100644
> --- a/cpukit/libcsupport/src/assocremotebylocalbitfield.c
> +++ b/cpukit/libcsupport/src/assocremotebylocalbitfield.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief RTEMS Assoc Routines
> + * @brief RTEMS Assoc Routines
> diff --git a/cpukit/libcsupport/src/chdir.c
> b/cpukit/libcsupport/src/chdir.c
> index 55425345e8..6ef551f06d 100644
> --- a/cpukit/libcsupport/src/chdir.c
> +++ b/cpukit/libcsupport/src/chdir.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief POSIX 1003.1b - 5.2.1 - Change Current Working Directory
> * @ingroup libio Internal Interface
> + * @brief POSIX 1003.1b - 5.2.1 - Change Current Working Directory
> diff --git a/cpukit/libcsupport/src/chroot.c
> b/cpukit/libcsupport/src/chroot.c
> index 3e7dfbae87..9db340174b 100644
> --- a/cpukit/libcsupport/src/chroot.c
> +++ b/cpukit/libcsupport/src/chroot.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Change Root Directory
> + * @brief Change Root Directory
> diff --git a/cpukit/libcsupport/src/close.c
> b/cpukit/libcsupport/src/close.c
> index 21b375149d..5e6aa2c041 100644
> --- a/cpukit/libcsupport/src/close.c
> +++ b/cpukit/libcsupport/src/close.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief POSIX 1003.1b 6.3.1 - Close a File
> + * @brief POSIX 1003.1b 6.3.1 - Close a File
> diff --git a/cpukit/libcsupport/src/dup.c b/cpukit/libcsupport/src/dup.c
> index 98ee8fdf1e..8fe2514c7d 100644
> --- a/cpukit/libcsupport/src/dup.c
> +++ b/cpukit/libcsupport/src/dup.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief POSIX 1003.1b 6.2.1 Duplicate an Open File Descriptor
> + * @brief POSIX 1003.1b 6.2.1 Duplicate an Open File Descriptor
> diff --git a/cpukit/libcsupport/src/fcntl.c
> b/cpukit/libcsupport/src/fcntl.c
> index 111fd188d4..ba824dced1 100644
> --- a/cpukit/libcsupport/src/fcntl.c
> +++ b/cpukit/libcsupport/src/fcntl.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief POSIX 1003.1b 6.5.2 - File Control
> + * @brief POSIX 1003.1b 6.5.2 - File Control
> diff --git a/cpukit/libcsupport/src/fdatasync.c
> b/cpukit/libcsupport/src/fdatasync.c
> index 3b9a4ff9bf..a1ac7bc81e 100644
> --- a/cpukit/libcsupport/src/fdatasync.c
> +++ b/cpukit/libcsupport/src/fdatasync.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief POSIX 1003.1b 6.6.2 - Synchronize the Data of a File
> + * @brief POSIX 1003.1b 6.6.2 - Synchronize the Data of a File
> diff --git a/cpukit/libcsupport/src/free.c b/cpukit/libcsupport/src/free.c
> index 18c8aaccf1..9f7c577852 100644
> --- a/cpukit/libcsupport/src/free.c
> +++ b/cpukit/libcsupport/src/free.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief calloc()
> + * @brief calloc()
> diff --git a/cpukit/libcsupport/src/ioctl.c
> b/cpukit/libcsupport/src/ioctl.c
> index e58889ae28..203a0aa5ba 100644
> --- a/cpukit/libcsupport/src/ioctl.c
> +++ b/cpukit/libcsupport/src/ioctl.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief ioctl() system call
> + * @brief ioctl() system call
> diff --git a/cpukit/libcsupport/src/kill_noposix.c
> b/cpukit/libcsupport/src/kill_noposix.c
> index a111f071d7..3792a81db8 100644
> --- a/cpukit/libcsupport/src/kill_noposix.c
> +++ b/cpukit/libcsupport/src/kill_noposix.c
> @@ -1,9 +1,10 @@
> * @file
> - * @brief Kill No POSIX
> + * @brief Kill No POSIX
> * Marginal implementations of some POSIX API routines
> * to be used when POSIX is disabled.
> diff --git a/cpukit/libcsupport/src/setegid.c
> b/cpukit/libcsupport/src/setegid.c
> index 2a3ef2f868..4303e73ebe 100644
> --- a/cpukit/libcsupport/src/setegid.c
> +++ b/cpukit/libcsupport/src/setegid.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Get Real User, Effective User, Ral Group, and Effective Group
> IDs
> + * @brief Get Real User, Effective User, Ral Group, and Effective Group
> IDs
> diff --git a/cpukit/libcsupport/src/sup_fs_mount_iterate.c
> b/cpukit/libcsupport/src/sup_fs_mount_iterate.c
> index 4d986090df..281dfc73e5 100644
> --- a/cpukit/libcsupport/src/sup_fs_mount_iterate.c
> +++ b/cpukit/libcsupport/src/sup_fs_mount_iterate.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Mount table entry visitor.
> * @ingroup Termios Termios
> + * @brief Mount table entry visitor.
> diff --git a/cpukit/libcsupport/src/utsname.c
> b/cpukit/libcsupport/src/utsname.c
> index 22442c192a..c1ca216eb3 100644
> --- a/cpukit/libcsupport/src/utsname.c
> +++ b/cpukit/libcsupport/src/utsname.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Get System Name
> * @ingroup utsname Service
> + * @brief Get System Name
> diff --git a/cpukit/libcsupport/src/write_r.c
> b/cpukit/libcsupport/src/write_r.c
> index 0ecfda106e..6597337efb 100644
> --- a/cpukit/libcsupport/src/write_r.c
> +++ b/cpukit/libcsupport/src/write_r.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief POSIX 1003.1b 6.4.2 - Write to a File
> + * @brief POSIX 1003.1b 6.4.2 - Write to a File
> diff --git a/cpukit/libfs/src/defaults/default_are_nodes_equal.c
> b/cpukit/libfs/src/defaults/default_are_nodes_equal.c
> index 2ba47dc1f9..3a6f6df658 100644
> --- a/cpukit/libfs/src/defaults/default_are_nodes_equal.c
> +++ b/cpukit/libfs/src/defaults/default_are_nodes_equal.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief RTEMS Default File System has nodes equal
> * @ingroup LibIOFSOps File System Operations
> + * @brief RTEMS Default File System has nodes equal
> diff --git a/cpukit/libfs/src/defaults/default_clone.c
> b/cpukit/libfs/src/defaults/default_clone.c
> index 30a6d256b1..3167c28388 100644
> --- a/cpukit/libfs/src/defaults/default_clone.c
> +++ b/cpukit/libfs/src/defaults/default_clone.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief RTEMS Default File System creates a child process
> + * @brief RTEMS Default File System creates a child process
> diff --git a/cpukit/libfs/src/defaults/default_eval_path.c
> b/cpukit/libfs/src/defaults/default_eval_path.c
> index ae4630b33a..4fda3017f4 100644
> --- a/cpukit/libfs/src/defaults/default_eval_path.c
> +++ b/cpukit/libfs/src/defaults/default_eval_path.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief RTEMS Default File System evaluates relative pathname to
> absolute
> + * @brief RTEMS Default File System evaluates relative pathname to
> absolute
> diff --git a/cpukit/libfs/src/defaults/default_fcntl.c
> b/cpukit/libfs/src/defaults/default_fcntl.c
> index df48ad01a3..c84bb9f08e 100644
> --- a/cpukit/libfs/src/defaults/default_fcntl.c
> +++ b/cpukit/libfs/src/defaults/default_fcntl.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief RTEMS Default Filesystem - Default FCNTL
> * @ingroup libfs
> + * @brief RTEMS Default Filesystem - Default FCNTL
> diff --git a/cpukit/libfs/src/defaults/default_freenode.c
> b/cpukit/libfs/src/defaults/default_freenode.c
> index 6ae60115a6..94cf79f35d 100644
> --- a/cpukit/libfs/src/defaults/default_freenode.c
> +++ b/cpukit/libfs/src/defaults/default_freenode.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief RTEMS Default Filesystem - Default Freenode
> * @ingroup libfs
> + * @brief RTEMS Default Filesystem - Default Freenode
> diff --git a/cpukit/libfs/src/defaults/default_fstat.c
> b/cpukit/libfs/src/defaults/default_fstat.c
> index dfb62a8171..4b0e151ea5 100644
> --- a/cpukit/libfs/src/defaults/default_fstat.c
> +++ b/cpukit/libfs/src/defaults/default_fstat.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief RTEMS Default File System gets file status
> + * @brief RTEMS Default File System gets file status
> diff --git a/cpukit/libfs/src/defaults/default_fsync.c
> b/cpukit/libfs/src/defaults/default_fsync.c
> index 0741eaf8e9..a7ff75d11f 100644
> --- a/cpukit/libfs/src/defaults/default_fsync.c
> +++ b/cpukit/libfs/src/defaults/default_fsync.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief RTEMS Default File System Synchronises changes to a file
> + * @brief RTEMS Default File System Synchronises changes to a file
> diff --git a/cpukit/libfs/src/defaults/default_fsync_success.c
> b/cpukit/libfs/src/defaults/default_fsync_success.c
> index b36b953fd0..3b14f46d39 100644
> --- a/cpukit/libfs/src/defaults/default_fsync_success.c
> +++ b/cpukit/libfs/src/defaults/default_fsync_success.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief RTEMS Default Filesystem succeeds synchronizing file's in-core
> state
> + * @brief RTEMS Default Filesystem succeeds synchronizing file's in-core
> state
> diff --git a/cpukit/libfs/src/defaults/default_ftruncate.c
> b/cpukit/libfs/src/defaults/default_ftruncate.c
> index 1270d6309c..194a94cf98 100644
> --- a/cpukit/libfs/src/defaults/default_ftruncate.c
> +++ b/cpukit/libfs/src/defaults/default_ftruncate.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief RTEMS Default File System Truncates a file to indicated length
> + * @brief RTEMS Default File System Truncates a file to indicated length
> diff --git a/cpukit/libfs/src/defaults/default_ftruncate_directory.c
> b/cpukit/libfs/src/defaults/default_ftruncate_directory.c
> index 6db07bd81d..f316bda215 100644
> --- a/cpukit/libfs/src/defaults/default_ftruncate_directory.c
> +++ b/cpukit/libfs/src/defaults/default_ftruncate_directory.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief RTEMS Default Filesystem - Default Ftruncate Directory
> * @ingroup libfs
> + * @brief RTEMS Default Filesystem - Default Ftruncate Directory
> diff --git a/cpukit/libfs/src/defaults/default_ioctl.c
> b/cpukit/libfs/src/defaults/default_ioctl.c
> index a6f12dde5d..5c21ffcf34 100644
> --- a/cpukit/libfs/src/defaults/default_ioctl.c
> +++ b/cpukit/libfs/src/defaults/default_ioctl.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief RTEMS Default File System controls a STREAMS device
> + * @brief RTEMS Default File System controls a STREAMS device
> diff --git a/cpukit/libfs/src/defaults/default_lock_and_unlock.c
> b/cpukit/libfs/src/defaults/default_lock_and_unlock.c
> index d543b9b6c2..5d73d8dba0 100644
> --- a/cpukit/libfs/src/defaults/default_lock_and_unlock.c
> +++ b/cpukit/libfs/src/defaults/default_lock_and_unlock.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief RTEMS Default File System locks and unlocks rtems filesystem
> + * @brief RTEMS Default File System locks and unlocks rtems filesystem
> diff --git a/cpukit/libfs/src/defaults/default_lseek.c
> b/cpukit/libfs/src/defaults/default_lseek.c
> index 3c41147b5a..33724682ee 100644
> --- a/cpukit/libfs/src/defaults/default_lseek.c
> +++ b/cpukit/libfs/src/defaults/default_lseek.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief RTEMS Default File System reposits the read/write file offset
> + * @brief RTEMS Default File System reposits the read/write file offset
> diff --git a/cpukit/libfs/src/defaults/default_lseek_directory.c
> b/cpukit/libfs/src/defaults/default_lseek_directory.c
> index bd600ea8b7..b92add50f7 100644
> --- a/cpukit/libfs/src/defaults/default_lseek_directory.c
> +++ b/cpukit/libfs/src/defaults/default_lseek_directory.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief RTEMS Default File System reposits read/write file offset
> directory
> + * @brief RTEMS Default File System reposits read/write file offset
> directory
> diff --git a/cpukit/libfs/src/defaults/default_lseek_file.c
> b/cpukit/libfs/src/defaults/default_lseek_file.c
> index 68bc8b7fc2..28646059dd 100644
> --- a/cpukit/libfs/src/defaults/default_lseek_file.c
> +++ b/cpukit/libfs/src/defaults/default_lseek_file.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief RTEMS Default File System reposits the offset of the open file
> fd
> + * @brief RTEMS Default File System reposits the offset of the open file
> fd
> diff --git a/cpukit/libfs/src/defaults/default_mknod.c
> b/cpukit/libfs/src/defaults/default_mknod.c
> index 0bcda6d5af..54abc144fa 100644
> --- a/cpukit/libfs/src/defaults/default_mknod.c
> +++ b/cpukit/libfs/src/defaults/default_mknod.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief RTEMS Default File System creates a special or ordinary file
> + * @brief RTEMS Default File System creates a special or ordinary file
> diff --git a/cpukit/libfs/src/defaults/default_mount.c
> b/cpukit/libfs/src/defaults/default_mount.c
> index e1caec49be..ce089c6090 100644
> --- a/cpukit/libfs/src/defaults/default_mount.c
> +++ b/cpukit/libfs/src/defaults/default_mount.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief RTEMS Default File System mounts a filesystem
> + * @brief RTEMS Default File System mounts a filesystem
> diff --git a/cpukit/libfs/src/defaults/default_open.c
> b/cpukit/libfs/src/defaults/default_open.c
> index d175515ec5..f868a8eb8e 100644
> --- a/cpukit/libfs/src/defaults/default_open.c
> +++ b/cpukit/libfs/src/defaults/default_open.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief RTEMS Default Filesystem - Default Open
> * @ingroup libfs
> + * @brief RTEMS Default Filesystem - Default Open
> diff --git a/cpukit/libfs/src/defaults/default_readlink.c
> b/cpukit/libfs/src/defaults/default_readlink.c
> index 21066b8204..1717b6174a 100644
> --- a/cpukit/libfs/src/defaults/default_readlink.c
> +++ b/cpukit/libfs/src/defaults/default_readlink.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief RTEMS Default Filesystem - Default Readlink
> * @ingroup libfs
> + * @brief RTEMS Default Filesystem - Default Readlink
> diff --git a/cpukit/libfs/src/defaults/default_rename.c
> b/cpukit/libfs/src/defaults/default_rename.c
> index f1d50f19b1..b2ae12b260 100644
> --- a/cpukit/libfs/src/defaults/default_rename.c
> +++ b/cpukit/libfs/src/defaults/default_rename.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief RTEMS Default File System Rename Files
> + * @brief RTEMS Default File System Rename Files
> diff --git a/cpukit/libfs/src/defaults/default_rmnod.c
> b/cpukit/libfs/src/defaults/default_rmnod.c
> index 60d9aa11ec..1a0f58c6fc 100644
> --- a/cpukit/libfs/src/defaults/default_rmnod.c
> +++ b/cpukit/libfs/src/defaults/default_rmnod.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief RTEMS Default Filesystem - Default Remove Node
> * @ingroup libfs
> + * @brief RTEMS Default Filesystem - Default Remove Node
> diff --git a/cpukit/libfs/src/defaults/default_symlink.c
> b/cpukit/libfs/src/defaults/default_symlink.c
> index a6cd10d5e5..a036471ed9 100644
> --- a/cpukit/libfs/src/defaults/default_symlink.c
> +++ b/cpukit/libfs/src/defaults/default_symlink.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief RTEMS Default File System creates a symbolic link to a file
> + * @brief RTEMS Default File System creates a symbolic link to a file
> diff --git a/cpukit/libfs/src/defaults/default_unmount.c
> b/cpukit/libfs/src/defaults/default_unmount.c
> index 100d69e451..ca9da15c50 100644
> --- a/cpukit/libfs/src/defaults/default_unmount.c
> +++ b/cpukit/libfs/src/defaults/default_unmount.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief RTEMS Default File System Unmounts
> + * @brief RTEMS Default File System Unmounts
> diff --git a/cpukit/libfs/src/defaults/default_utime.c
> b/cpukit/libfs/src/defaults/default_utime.c
> index 866d73ab64..aaf4e445b6 100644
> --- a/cpukit/libfs/src/defaults/default_utime.c
> +++ b/cpukit/libfs/src/defaults/default_utime.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief RTEMS Default File System sets file access and modification
> times
> + * @brief RTEMS Default File System sets file access and modification
> times
> diff --git a/cpukit/libfs/src/defaults/default_write.c
> b/cpukit/libfs/src/defaults/default_write.c
> index 4af0a4244a..49e451968a 100644
> --- a/cpukit/libfs/src/defaults/default_write.c
> +++ b/cpukit/libfs/src/defaults/default_write.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief RTEMS Default File System sends a message to another user
> + * @brief RTEMS Default File System sends a message to another user
> diff --git a/cpukit/libfs/src/dosfs/fat.c b/cpukit/libfs/src/dosfs/fat.c
> index d10589d19c..c687477d04 100644
> --- a/cpukit/libfs/src/dosfs/fat.c
> +++ b/cpukit/libfs/src/dosfs/fat.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Low-level Operations on a Volume with a DOSFS FAT filesystem
> * @ingroup libfs
> + * @brief Low-level Operations on a Volume with a DOSFS FAT filesystem
> diff --git a/cpukit/libfs/src/dosfs/fat_fat_operations.c
> b/cpukit/libfs/src/dosfs/fat_fat_operations.c
> index 4ded24074f..ab03c88fdc 100644
> --- a/cpukit/libfs/src/dosfs/fat_fat_operations.c
> +++ b/cpukit/libfs/src/dosfs/fat_fat_operations.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief General operations on File Allocation Table
> * @ingroup libfs_ffo Fat Fat Operations
> + * @brief General operations on File Allocation Table
> diff --git a/cpukit/libfs/src/dosfs/fat_file.c
> b/cpukit/libfs/src/dosfs/fat_file.c
> index 57b1f6d91f..b4af8a11ca 100644
> --- a/cpukit/libfs/src/dosfs/fat_file.c
> +++ b/cpukit/libfs/src/dosfs/fat_file.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief General operations on "fat-file"
> * @ingroup libfs_ff Fat File
> + * @brief General operations on "fat-file"
> diff --git a/cpukit/libfs/src/dosfs/msdos_conv.c
> b/cpukit/libfs/src/dosfs/msdos_conv.c
> index 1d2ff58105..7efd5a7e80 100644
> --- a/cpukit/libfs/src/dosfs/msdos_conv.c
> +++ b/cpukit/libfs/src/dosfs/msdos_conv.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief MDOS Date Conversion
> * @ingroup libfs_msdos MSDOS FileSystem
> + * @brief MDOS Date Conversion
> diff --git a/cpukit/libfs/src/dosfs/msdos_create.c
> b/cpukit/libfs/src/dosfs/msdos_create.c
> index b3a1c18014..1304cc27cd 100644
> --- a/cpukit/libfs/src/dosfs/msdos_create.c
> +++ b/cpukit/libfs/src/dosfs/msdos_create.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Create a new MSDOS FileSystem node
> + * @brief Create a new MSDOS FileSystem node
> diff --git a/cpukit/libfs/src/dosfs/msdos_dir.c
> b/cpukit/libfs/src/dosfs/msdos_dir.c
> index d5322229e3..8c8d43f130 100644
> --- a/cpukit/libfs/src/dosfs/msdos_dir.c
> +++ b/cpukit/libfs/src/dosfs/msdos_dir.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief MSDOS Directory Handlers Implementation
> + * @brief MSDOS Directory Handlers Implementation
> diff --git a/cpukit/libfs/src/dosfs/msdos_eval.c
> b/cpukit/libfs/src/dosfs/msdos_eval.c
> index 4220b9ec11..e3e0f5fe96 100644
> --- a/cpukit/libfs/src/dosfs/msdos_eval.c
> +++ b/cpukit/libfs/src/dosfs/msdos_eval.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief MSDOS Evaluation Routines
> * @ingroup libfs
> + * @brief MSDOS Evaluation Routines
> diff --git a/cpukit/libfs/src/dosfs/msdos_file.c
> b/cpukit/libfs/src/dosfs/msdos_file.c
> index 770c28ffcf..da6e54b6c6 100644
> --- a/cpukit/libfs/src/dosfs/msdos_file.c
> +++ b/cpukit/libfs/src/dosfs/msdos_file.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief MSDOS File Handlers Implementation
> * @ingroup libfs
> + * @brief MSDOS File Handlers Implementation
> diff --git a/cpukit/libfs/src/dosfs/msdos_format.c
> b/cpukit/libfs/src/dosfs/msdos_format.c
> index 008d2285dc..e1e27f2f50 100644
> --- a/cpukit/libfs/src/dosfs/msdos_format.c
> +++ b/cpukit/libfs/src/dosfs/msdos_format.c
> @@ -1,9 +1,10 @@
> * @file
> - * @brief RTEMS MSDOS Format Functionality
> * @ingroup libfs
> + * @brief RTEMS MSDOS Format Functionality
> * This function formats a disk partition conforming to MS-DOS conventions
> diff --git a/cpukit/libfs/src/dosfs/msdos_free.c
> b/cpukit/libfs/src/dosfs/msdos_free.c
> index 1e66078eff..664103d455 100644
> --- a/cpukit/libfs/src/dosfs/msdos_free.c
> +++ b/cpukit/libfs/src/dosfs/msdos_free.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Call Fat-File Close Routine
> + * @brief Call Fat-File Close Routine
> diff --git a/cpukit/libfs/src/dosfs/msdos_fsunmount.c
> b/cpukit/libfs/src/dosfs/msdos_fsunmount.c
> index e66602ccd8..f90de64069 100644
> --- a/cpukit/libfs/src/dosfs/msdos_fsunmount.c
> +++ b/cpukit/libfs/src/dosfs/msdos_fsunmount.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Shut Down MSDOS FileSystem
> + * @brief Shut Down MSDOS FileSystem
> diff --git a/cpukit/libfs/src/dosfs/msdos_handlers_dir.c
> b/cpukit/libfs/src/dosfs/msdos_handlers_dir.c
> index 805f239c95..77169d9c3f 100644
> --- a/cpukit/libfs/src/dosfs/msdos_handlers_dir.c
> +++ b/cpukit/libfs/src/dosfs/msdos_handlers_dir.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Directory Handlers Table for MSDOS FileSystem
> * @ingroup libfs
> + * @brief Directory Handlers Table for MSDOS FileSystem
> diff --git a/cpukit/libfs/src/dosfs/msdos_handlers_file.c
> b/cpukit/libfs/src/dosfs/msdos_handlers_file.c
> index 9399a4f2f0..73f67acb47 100644
> --- a/cpukit/libfs/src/dosfs/msdos_handlers_file.c
> +++ b/cpukit/libfs/src/dosfs/msdos_handlers_file.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief File Operations Table for MSDOS FileSystem
> * @ingroup libfs
> + * @brief File Operations Table for MSDOS FileSystem
> diff --git a/cpukit/libfs/src/dosfs/msdos_init.c
> b/cpukit/libfs/src/dosfs/msdos_init.c
> index dc9c76437d..3ea6f104e8 100644
> --- a/cpukit/libfs/src/dosfs/msdos_init.c
> +++ b/cpukit/libfs/src/dosfs/msdos_init.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Init Routine for MSDOS
> * @ingroup libfs
> + * @brief Init Routine for MSDOS
> diff --git a/cpukit/libfs/src/dosfs/msdos_initsupp.c
> b/cpukit/libfs/src/dosfs/msdos_initsupp.c
> index c581c8b685..e2ee85d4d4 100644
> --- a/cpukit/libfs/src/dosfs/msdos_initsupp.c
> +++ b/cpukit/libfs/src/dosfs/msdos_initsupp.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief MSDOS Filesystem Initialization
> + * @brief MSDOS Filesystem Initialization
> diff --git a/cpukit/libfs/src/dosfs/msdos_misc.c
> b/cpukit/libfs/src/dosfs/msdos_misc.c
> index 3f73bd9029..397e590ff5 100644
> --- a/cpukit/libfs/src/dosfs/msdos_misc.c
> +++ b/cpukit/libfs/src/dosfs/msdos_misc.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Miscellaneous Routines Implementation for MSDOS FileSystem
> * @ingroup libfs
> + * @brief Miscellaneous Routines Implementation for MSDOS FileSystem
> diff --git a/cpukit/libfs/src/dosfs/msdos_mknod.c
> b/cpukit/libfs/src/dosfs/msdos_mknod.c
> index b7270c86f8..934805c5f1 100644
> --- a/cpukit/libfs/src/dosfs/msdos_mknod.c
> +++ b/cpukit/libfs/src/dosfs/msdos_mknod.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Routine for Node Creation in MSDOS Filesystem
> + * @brief Routine for Node Creation in MSDOS Filesystem
> diff --git a/cpukit/libfs/src/dosfs/msdos_rename.c
> b/cpukit/libfs/src/dosfs/msdos_rename.c
> index e3beee6842..375ca80362 100644
> --- a/cpukit/libfs/src/dosfs/msdos_rename.c
> +++ b/cpukit/libfs/src/dosfs/msdos_rename.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Rename a MSDOS FileSystem Node
> + * @brief Rename a MSDOS FileSystem Node
> diff --git a/cpukit/libfs/src/dosfs/msdos_rmnod.c
> b/cpukit/libfs/src/dosfs/msdos_rmnod.c
> index 92f8bdb01e..77e280af07 100644
> --- a/cpukit/libfs/src/dosfs/msdos_rmnod.c
> +++ b/cpukit/libfs/src/dosfs/msdos_rmnod.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Remove Node from MSDOS Directory
> + * @brief Remove Node from MSDOS Directory
> diff --git a/cpukit/libfs/src/dosfs/msdos_statvfs.c
> b/cpukit/libfs/src/dosfs/msdos_statvfs.c
> index 59781dd7b9..ea808c05f0 100644
> --- a/cpukit/libfs/src/dosfs/msdos_statvfs.c
> +++ b/cpukit/libfs/src/dosfs/msdos_statvfs.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Obtain MS-DOS filesystem information
> + * @brief Obtain MS-DOS filesystem information
> diff --git a/cpukit/libfs/src/imfs/deviceio.c
> b/cpukit/libfs/src/imfs/deviceio.c
> index 16ce424aa4..c1577ed39f 100644
> --- a/cpukit/libfs/src/imfs/deviceio.c
> +++ b/cpukit/libfs/src/imfs/deviceio.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief IMFS Device Node Handlers
> * @ingroup IMFS
> + * @brief IMFS Device Node Handlers
> diff --git a/cpukit/libfs/src/imfs/imfs_chown.c
> b/cpukit/libfs/src/imfs/imfs_chown.c
> index 1b7fb9b5e4..268ed0fc56 100644
> --- a/cpukit/libfs/src/imfs/imfs_chown.c
> +++ b/cpukit/libfs/src/imfs/imfs_chown.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief IMFS Change Owner
> * @ingroup IMFS
> + * @brief IMFS Change Owner
> diff --git a/cpukit/libfs/src/imfs/imfs_config.c
> b/cpukit/libfs/src/imfs/imfs_config.c
> index fe65fa720a..72aa9424f9 100644
> --- a/cpukit/libfs/src/imfs/imfs_config.c
> +++ b/cpukit/libfs/src/imfs/imfs_config.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief IMFS Limits and Options
> * @ingroup IMFS
> + * @brief IMFS Limits and Options
> diff --git a/cpukit/libfs/src/imfs/imfs_creat.c
> b/cpukit/libfs/src/imfs/imfs_creat.c
> index 08bbc086bb..3a609e160d 100644
> --- a/cpukit/libfs/src/imfs/imfs_creat.c
> +++ b/cpukit/libfs/src/imfs/imfs_creat.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Create an IMFS Node
> * @ingroup IMFS
> + * @brief Create an IMFS Node
> * COPYRIGHT (c) 1989-2010.
> diff --git a/cpukit/libfs/src/imfs/imfs_eval.c
> b/cpukit/libfs/src/imfs/imfs_eval.c
> index 512b80e58c..5f84e03153 100644
> --- a/cpukit/libfs/src/imfs/imfs_eval.c
> +++ b/cpukit/libfs/src/imfs/imfs_eval.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Evaluation IMFS Node Support
> * @ingroup IMFS
> + * @brief Evaluation IMFS Node Support
> diff --git a/cpukit/libfs/src/imfs/imfs_fchmod.c
> b/cpukit/libfs/src/imfs/imfs_fchmod.c
> index 8537529a19..e8814f73f7 100644
> --- a/cpukit/libfs/src/imfs/imfs_fchmod.c
> +++ b/cpukit/libfs/src/imfs/imfs_fchmod.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Change IMFS File Mode
> * @ingroup IMFS
> + * @brief Change IMFS File Mode
> diff --git a/cpukit/libfs/src/imfs/imfs_fifo.c
> b/cpukit/libfs/src/imfs/imfs_fifo.c
> index e66a436479..1973801cb6 100644
> --- a/cpukit/libfs/src/imfs/imfs_fifo.c
> +++ b/cpukit/libfs/src/imfs/imfs_fifo.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief FIFO Support
> * @ingroup IMFS
> + * @brief FIFO Support
> diff --git a/cpukit/libfs/src/imfs/imfs_fsunmount.c
> b/cpukit/libfs/src/imfs/imfs_fsunmount.c
> index 864c933420..4d29c400ef 100644
> --- a/cpukit/libfs/src/imfs/imfs_fsunmount.c
> +++ b/cpukit/libfs/src/imfs/imfs_fsunmount.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Unmount this Instance of IMFS
> * @ingroup IMFS
> + * @brief Unmount this Instance of IMFS
> diff --git a/cpukit/libfs/src/imfs/imfs_handlers_device.c
> b/cpukit/libfs/src/imfs/imfs_handlers_device.c
> index 12a19bd663..ab32ce4b73 100644
> --- a/cpukit/libfs/src/imfs/imfs_handlers_device.c
> +++ b/cpukit/libfs/src/imfs/imfs_handlers_device.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Device Operations Table
> * @ingroup IMFS
> + * @brief Device Operations Table
> diff --git a/cpukit/libfs/src/imfs/imfs_initsupp.c
> b/cpukit/libfs/src/imfs/imfs_initsupp.c
> index 2c75ef5ff2..4c09cf750e 100644
> --- a/cpukit/libfs/src/imfs/imfs_initsupp.c
> +++ b/cpukit/libfs/src/imfs/imfs_initsupp.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief IMFS Node Support
> * @ingroup IMFS
> + * @brief IMFS Node Support
> diff --git a/cpukit/libfs/src/imfs/imfs_link.c
> b/cpukit/libfs/src/imfs/imfs_link.c
> index 87211ad93e..16ad862a50 100644
> --- a/cpukit/libfs/src/imfs/imfs_link.c
> +++ b/cpukit/libfs/src/imfs/imfs_link.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief IMFS Create a New Link Node
> * @ingroup IMFS
> + * @brief IMFS Create a New Link Node
> diff --git a/cpukit/libfs/src/imfs/imfs_load_tar.c
> b/cpukit/libfs/src/imfs/imfs_load_tar.c
> index 47a506b042..a0cc115be4 100644
> --- a/cpukit/libfs/src/imfs/imfs_load_tar.c
> +++ b/cpukit/libfs/src/imfs/imfs_load_tar.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief RTEMS Load Tarfs
> * @ingroup IMFS
> + * @brief RTEMS Load Tarfs
> diff --git a/cpukit/libfs/src/imfs/imfs_make_generic_node.c
> b/cpukit/libfs/src/imfs/imfs_make_generic_node.c
> index 3d1af1da41..36426d7719 100644
> --- a/cpukit/libfs/src/imfs/imfs_make_generic_node.c
> +++ b/cpukit/libfs/src/imfs/imfs_make_generic_node.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief IMFS Make a Generic Node
> * @ingroup IMFS
> + * @brief IMFS Make a Generic Node
> diff --git a/cpukit/libfs/src/imfs/imfs_memfile.c
> b/cpukit/libfs/src/imfs/imfs_memfile.c
> index c48e253f8b..0f19859fac 100644
> --- a/cpukit/libfs/src/imfs/imfs_memfile.c
> +++ b/cpukit/libfs/src/imfs/imfs_memfile.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief IMFS Memory File Handlers
> * @ingroup IMFS
> + * @brief IMFS Memory File Handlers
> diff --git a/cpukit/libfs/src/imfs/imfs_mknod.c
> b/cpukit/libfs/src/imfs/imfs_mknod.c
> index 65f48416d1..8d23f12f55 100644
> --- a/cpukit/libfs/src/imfs/imfs_mknod.c
> +++ b/cpukit/libfs/src/imfs/imfs_mknod.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Create a IMFS Node
> * @ingroup IMFS
> + * @brief Create a IMFS Node
> diff --git a/cpukit/libfs/src/imfs/imfs_mount.c
> b/cpukit/libfs/src/imfs/imfs_mount.c
> index b00a59d85b..371e88e106 100644
> --- a/cpukit/libfs/src/imfs/imfs_mount.c
> +++ b/cpukit/libfs/src/imfs/imfs_mount.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Mount an IMFS
> * @ingroup IMFS
> + * @brief Mount an IMFS
> diff --git a/cpukit/libfs/src/imfs/imfs_node.c
> b/cpukit/libfs/src/imfs/imfs_node.c
> index f5266b650b..a89298ffc2 100644
> --- a/cpukit/libfs/src/imfs/imfs_node.c
> +++ b/cpukit/libfs/src/imfs/imfs_node.c
> @@ -1,8 +1,9 @@
> * @file
> * @ingroup IMFS
> diff --git a/cpukit/libfs/src/imfs/imfs_rename.c
> b/cpukit/libfs/src/imfs/imfs_rename.c
> index 164a7896ab..701500872d 100644
> --- a/cpukit/libfs/src/imfs/imfs_rename.c
> +++ b/cpukit/libfs/src/imfs/imfs_rename.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief IMFS Rename
> * @ingroup IMFS
> + * @brief IMFS Rename
> diff --git a/cpukit/libfs/src/imfs/imfs_rmnod.c
> b/cpukit/libfs/src/imfs/imfs_rmnod.c
> index 9fad0b7d1b..0aaadb7ebe 100644
> --- a/cpukit/libfs/src/imfs/imfs_rmnod.c
> +++ b/cpukit/libfs/src/imfs/imfs_rmnod.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief IMFS Node Removal Handler
> * @ingroup IMFS
> + * @brief IMFS Node Removal Handler
> diff --git a/cpukit/libfs/src/imfs/imfs_stat.c
> b/cpukit/libfs/src/imfs/imfs_stat.c
> index 3e73a150b2..bbca49f8ef 100644
> --- a/cpukit/libfs/src/imfs/imfs_stat.c
> +++ b/cpukit/libfs/src/imfs/imfs_stat.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief IMFS Stat
> * @ingroup IMFS
> + * @brief IMFS Stat
> diff --git a/cpukit/libfs/src/imfs/imfs_symlink.c
> b/cpukit/libfs/src/imfs/imfs_symlink.c
> index 58eecae910..7323cc0241 100644
> --- a/cpukit/libfs/src/imfs/imfs_symlink.c
> +++ b/cpukit/libfs/src/imfs/imfs_symlink.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief IMFS Create a New Symbolic Link Node
> * @ingroup IMFS
> + * @brief IMFS Create a New Symbolic Link Node
> diff --git a/cpukit/libfs/src/imfs/imfs_unmount.c
> b/cpukit/libfs/src/imfs/imfs_unmount.c
> index 6ed3ba657e..0e9f5eee84 100644
> --- a/cpukit/libfs/src/imfs/imfs_unmount.c
> +++ b/cpukit/libfs/src/imfs/imfs_unmount.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Unmount an IMFS
> * @ingroup IMFS
> + * @brief Unmount an IMFS
> diff --git a/cpukit/libfs/src/imfs/imfs_utime.c
> b/cpukit/libfs/src/imfs/imfs_utime.c
> index e02545c167..21e5139ce7 100644
> --- a/cpukit/libfs/src/imfs/imfs_utime.c
> +++ b/cpukit/libfs/src/imfs/imfs_utime.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Set IMFS File Access and Modification Times
> * @ingroup IMFS
> + * @brief Set IMFS File Access and Modification Times
> diff --git a/cpukit/libfs/src/imfs/ioman.c b/cpukit/libfs/src/imfs/ioman.c
> index 60d4777980..59b93e400c 100644
> --- a/cpukit/libfs/src/imfs/ioman.c
> +++ b/cpukit/libfs/src/imfs/ioman.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief RTEMS Register IO Name
> * @ingroup ClassicIO
> + * @brief RTEMS Register IO Name
> diff --git a/cpukit/libfs/src/nfsclient/proto/mount_prot_xdr.c
> b/cpukit/libfs/src/nfsclient/proto/mount_prot_xdr.c
> index a7950c1b39..05bace6b83 100644
> --- a/cpukit/libfs/src/nfsclient/proto/mount_prot_xdr.c
> +++ b/cpukit/libfs/src/nfsclient/proto/mount_prot_xdr.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Mount Prot XDR
> * @ingroup libfs_nfsclient_mount_prot Mount Prot
> + * @brief Mount Prot XDR
> diff --git a/cpukit/libfs/src/nfsclient/proto/nfs_prot_xdr.c
> b/cpukit/libfs/src/nfsclient/proto/nfs_prot_xdr.c
> index 40496a72ff..c7a51a72bd 100644
> --- a/cpukit/libfs/src/nfsclient/proto/nfs_prot_xdr.c
> +++ b/cpukit/libfs/src/nfsclient/proto/nfs_prot_xdr.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief NFS Prot XDR
> * @ingroup libfs_nfsclient_nfs_prot NFS Prot
> + * @brief NFS Prot XDR
> diff --git a/cpukit/libfs/src/nfsclient/src/nfs.c
> b/cpukit/libfs/src/nfsclient/src/nfs.c
> index 411a478c0d..c482db9b2a 100644
> --- a/cpukit/libfs/src/nfsclient/src/nfs.c
> +++ b/cpukit/libfs/src/nfsclient/src/nfs.c
> @@ -1,9 +1,10 @@
> * @file
> - * @brief NFS Client Implementation for RTEMS
> * @ingroup libfs
> + * @brief NFS Client Implementation for RTEMS
> * Hooks Into the RTEMS NFS Filesystem
> diff --git a/cpukit/libfs/src/nfsclient/src/rpcio.c
> b/cpukit/libfs/src/nfsclient/src/rpcio.c
> index 886226e104..2e36ede164 100644
> --- a/cpukit/libfs/src/nfsclient/src/rpcio.c
> +++ b/cpukit/libfs/src/nfsclient/src/rpcio.c
> @@ -1,9 +1,10 @@
> * @file
> - * @brief RPC Multiplexor for a Multitasking Environment
> * @ingroup libfs
> + * @brief RPC Multiplexor for a Multitasking Environment
> * This code funnels arbitrary task's UDP/RPC requests
> * through one socket to arbitrary servers.
> * The replies are gathered and dispatched to the
> diff --git a/cpukit/libfs/src/nfsclient/src/sock_mbuf.c
> b/cpukit/libfs/src/nfsclient/src/sock_mbuf.c
> index 45a2cd6dcb..f48cd0dff8 100644
> --- a/cpukit/libfs/src/nfsclient/src/sock_mbuf.c
> +++ b/cpukit/libfs/src/nfsclient/src/sock_mbuf.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Sock Mbuf
> * @ingroup libfs
> + * @brief Sock Mbuf
> diff --git a/cpukit/libfs/src/nfsclient/src/xdr_mbuf.c
> b/cpukit/libfs/src/nfsclient/src/xdr_mbuf.c
> index 451c385b41..cf35c20cd2 100644
> --- a/cpukit/libfs/src/nfsclient/src/xdr_mbuf.c
> +++ b/cpukit/libfs/src/nfsclient/src/xdr_mbuf.c
> @@ -1,9 +1,10 @@
> * @file
> - * @brief XDR Implementation Using mbuf Buffers
> * @ingroup libfs
> + * @brief XDR Implementation Using mbuf Buffers
> * xdr_mbuf is derived from xdr_mem
> diff --git a/cpukit/libfs/src/pipe/fifo.c b/cpukit/libfs/src/pipe/fifo.c
> index 077d277021..2645dab099 100644
> --- a/cpukit/libfs/src/pipe/fifo.c
> +++ b/cpukit/libfs/src/pipe/fifo.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief FIFO/Pipe Support
> * @ingroup FIFO_PIPE
> + * @brief FIFO/Pipe Support
> diff --git a/cpukit/libfs/src/pipe/pipe.c b/cpukit/libfs/src/pipe/pipe.c
> index d8c1c2d551..93e3723185 100644
> --- a/cpukit/libfs/src/pipe/pipe.c
> +++ b/cpukit/libfs/src/pipe/pipe.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Create an Anonymous Pipe
> + * @brief Create an Anonymous Pipe
> diff --git a/cpukit/libfs/src/rfs/rtems-rfs-bitmaps.c
> b/cpukit/libfs/src/rfs/rtems-rfs-bitmaps.c
> index 7d3556f9aa..7973e85083 100644
> --- a/cpukit/libfs/src/rfs/rtems-rfs-bitmaps.c
> +++ b/cpukit/libfs/src/rfs/rtems-rfs-bitmaps.c
> @@ -1,9 +1,10 @@
> * @file
> - * @brief RTEMS File Systems Bitmap Routines
> + * @brief RTEMS File Systems Bitmap Routines
> * These functions manage bit maps. A bit map consists of the map of bit
> * allocated in a block and a search map where a bit represents 32 actual
> * bits. The search map allows for a faster search for an available bit
> as 32
> diff --git a/cpukit/libfs/src/rfs/rtems-rfs-block.c
> b/cpukit/libfs/src/rfs/rtems-rfs-block.c
> index da84d0b56f..5dc8634818 100644
> --- a/cpukit/libfs/src/rfs/rtems-rfs-block.c
> +++ b/cpukit/libfs/src/rfs/rtems-rfs-block.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief RTEMS File Systems Block Routines
> + * @brief RTEMS File Systems Block Routines
> * These functions manage blocks in the RFS file system. A block is an
> area of
> * the media and its size is set for a each specific media. The block
> size is
> diff --git a/cpukit/libfs/src/rfs/rtems-rfs-buffer-bdbuf.c
> b/cpukit/libfs/src/rfs/rtems-rfs-buffer-bdbuf.c
> index 11513bfbfa..b1b6027b83 100644
> --- a/cpukit/libfs/src/rfs/rtems-rfs-buffer-bdbuf.c
> +++ b/cpukit/libfs/src/rfs/rtems-rfs-buffer-bdbuf.c
> @@ -1,9 +1,10 @@
> * @file
> - * @brief RTEMS File Systems Buffer Routines
> + * @brief RTEMS File Systems Buffer Routines
> * RTEMS File Systems Buffer Routines for the RTEMS libblock BD buffer
> cache.
> diff --git a/cpukit/libfs/src/rfs/rtems-rfs-buffer-devio.c
> b/cpukit/libfs/src/rfs/rtems-rfs-buffer-devio.c
> index 4537eaf985..0f5931141a 100644
> --- a/cpukit/libfs/src/rfs/rtems-rfs-buffer-devio.c
> +++ b/cpukit/libfs/src/rfs/rtems-rfs-buffer-devio.c
> @@ -1,8 +1,9 @@
> * @file
> diff --git a/cpukit/libfs/src/rfs/rtems-rfs-buffer.c
> b/cpukit/libfs/src/rfs/rtems-rfs-buffer.c
> index e5e5e7dad9..814de10dbe 100644
> --- a/cpukit/libfs/src/rfs/rtems-rfs-buffer.c
> +++ b/cpukit/libfs/src/rfs/rtems-rfs-buffer.c
> @@ -1,8 +1,9 @@
> * @file
> diff --git a/cpukit/libfs/src/rfs/rtems-rfs-dir-hash.c
> b/cpukit/libfs/src/rfs/rtems-rfs-dir-hash.c
> index 75cbef2621..96da1a86fa 100644
> --- a/cpukit/libfs/src/rfs/rtems-rfs-dir-hash.c
> +++ b/cpukit/libfs/src/rfs/rtems-rfs-dir-hash.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief RTEMS File Systems Directory Hash function
> + * @brief RTEMS File Systems Directory Hash function
> #ifdef HAVE_CONFIG_H
> diff --git a/cpukit/libfs/src/rfs/rtems-rfs-dir.c
> b/cpukit/libfs/src/rfs/rtems-rfs-dir.c
> index 09e8782ffc..227fda3b91 100644
> --- a/cpukit/libfs/src/rfs/rtems-rfs-dir.c
> +++ b/cpukit/libfs/src/rfs/rtems-rfs-dir.c
> @@ -1,9 +1,10 @@
> * @file
> - * @brief RTEMS File Systems Directory Routines
> + * @brief RTEMS File Systems Directory Routines
> * These functions manage blocks in the directory format. A directory
> entry is
> * a variable length record in the block. The entry consists of a length,
> hash
> * and the string. The length allows the next entry to be located and the
> hash
> diff --git a/cpukit/libfs/src/rfs/rtems-rfs-file-system.c
> b/cpukit/libfs/src/rfs/rtems-rfs-file-system.c
> index 6089bf2d14..11ce9f353c 100644
> --- a/cpukit/libfs/src/rfs/rtems-rfs-file-system.c
> +++ b/cpukit/libfs/src/rfs/rtems-rfs-file-system.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief RTEMS File Systems Open
> + * @brief RTEMS File Systems Open
> * Open the file system by reading the superblock and then the group data.
> diff --git a/cpukit/libfs/src/rfs/rtems-rfs-file.c
> b/cpukit/libfs/src/rfs/rtems-rfs-file.c
> index 897cdc1bea..b59768defd 100644
> --- a/cpukit/libfs/src/rfs/rtems-rfs-file.c
> +++ b/cpukit/libfs/src/rfs/rtems-rfs-file.c
> @@ -1,9 +1,10 @@
> * @file
> - * @brief RTEMS File Systems File Routines
> + * @brief RTEMS File Systems File Routines
> * These functions manage files.
> diff --git a/cpukit/libfs/src/rfs/rtems-rfs-format.c
> b/cpukit/libfs/src/rfs/rtems-rfs-format.c
> index 82387538b4..9acf152061 100644
> --- a/cpukit/libfs/src/rfs/rtems-rfs-format.c
> +++ b/cpukit/libfs/src/rfs/rtems-rfs-format.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief RTEMS File Systems Format
> + * @brief RTEMS File Systems Format
> * Format the file system ready for use.
> diff --git a/cpukit/libfs/src/rfs/rtems-rfs-group.c
> b/cpukit/libfs/src/rfs/rtems-rfs-group.c
> index 1405f2afa3..5f2808f166 100644
> --- a/cpukit/libfs/src/rfs/rtems-rfs-group.c
> +++ b/cpukit/libfs/src/rfs/rtems-rfs-group.c
> @@ -1,9 +1,10 @@
> * @file
> - * @brief RTEMS File Systems Group Routines
> + * @brief RTEMS File Systems Group Routines
> * These functions open and close a group as well as manage bit
> allocations
> * within a group.
> diff --git a/cpukit/libfs/src/rfs/rtems-rfs-inode.c
> b/cpukit/libfs/src/rfs/rtems-rfs-inode.c
> index 8124b399a2..644042eb8c 100644
> --- a/cpukit/libfs/src/rfs/rtems-rfs-inode.c
> +++ b/cpukit/libfs/src/rfs/rtems-rfs-inode.c
> @@ -1,9 +1,10 @@
> * @file
> - * @brief RTEMS File Systems Inode Routines
> + * @brief RTEMS File Systems Inode Routines
> * These functions manage inodes in the RFS file system. An inode is part
> of a
> * block that reside after the bitmaps in the group.
> diff --git a/cpukit/libfs/src/rfs/rtems-rfs-link.c
> b/cpukit/libfs/src/rfs/rtems-rfs-link.c
> index 9689a56b09..5a8c70188b 100644
> --- a/cpukit/libfs/src/rfs/rtems-rfs-link.c
> +++ b/cpukit/libfs/src/rfs/rtems-rfs-link.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief RTEMS File Systems Link Routines
> + * @brief RTEMS File Systems Link Routines
> * These functions manage links. A link is the addition of a directory
> entry
> * in a parent directory and incrementing the links count in the inode.
> diff --git a/cpukit/libfs/src/rfs/rtems-rfs-mutex.c
> b/cpukit/libfs/src/rfs/rtems-rfs-mutex.c
> index f05c3e3155..34d0dbabec 100644
> --- a/cpukit/libfs/src/rfs/rtems-rfs-mutex.c
> +++ b/cpukit/libfs/src/rfs/rtems-rfs-mutex.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief RTEMS File System Mutex
> + * @brief RTEMS File System Mutex
> * COPYRIGHT (c) 2010 Chris Johns <chrisj at rtems.org>
> diff --git a/cpukit/libfs/src/rfs/rtems-rfs-rtems-dev.c
> b/cpukit/libfs/src/rfs/rtems-rfs-rtems-dev.c
> index 1f28fa9b38..0f31a54fe2 100644
> --- a/cpukit/libfs/src/rfs/rtems-rfs-rtems-dev.c
> +++ b/cpukit/libfs/src/rfs/rtems-rfs-rtems-dev.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief RTEMS RFS Device Interface
> + * @brief RTEMS RFS Device Interface
> * This file contains the set of handlers used to map operations on RFS
> device
> * nodes onto calls to the RTEMS Classic API IO Manager.
> diff --git a/cpukit/libfs/src/rfs/rtems-rfs-rtems-dir.c
> b/cpukit/libfs/src/rfs/rtems-rfs-rtems-dir.c
> index 38e8f3764b..d1d28f5185 100644
> --- a/cpukit/libfs/src/rfs/rtems-rfs-rtems-dir.c
> +++ b/cpukit/libfs/src/rfs/rtems-rfs-rtems-dir.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief RTEMS RFS Directory Access Routines
> + * @brief RTEMS RFS Directory Access Routines
> diff --git a/cpukit/libfs/src/rfs/rtems-rfs-rtems-file.c
> b/cpukit/libfs/src/rfs/rtems-rfs-rtems-file.c
> index 8d94f1c909..2c406cee5b 100644
> --- a/cpukit/libfs/src/rfs/rtems-rfs-rtems-file.c
> +++ b/cpukit/libfs/src/rfs/rtems-rfs-rtems-file.c
> @@ -1,9 +1,10 @@
> * @file
> - * @brief RTEMS RFS File Handlers
> + * @brief RTEMS RFS File Handlers
> * This file contains the set of handlers used to process operations on
> * RFS file nodes.
> diff --git a/cpukit/libfs/src/rfs/rtems-rfs-rtems-utils.c
> b/cpukit/libfs/src/rfs/rtems-rfs-rtems-utils.c
> index 61ea42caeb..9db46fa902 100644
> --- a/cpukit/libfs/src/rfs/rtems-rfs-rtems-utils.c
> +++ b/cpukit/libfs/src/rfs/rtems-rfs-rtems-utils.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Set of Utility Functions to Support RTEMS RFS on RTEMS
> + * @brief Set of Utility Functions to Support RTEMS RFS on RTEMS
> diff --git a/cpukit/libfs/src/rfs/rtems-rfs-rtems.c
> b/cpukit/libfs/src/rfs/rtems-rfs-rtems.c
> index c4d3c06067..35db9eeca1 100644
> --- a/cpukit/libfs/src/rfs/rtems-rfs-rtems.c
> +++ b/cpukit/libfs/src/rfs/rtems-rfs-rtems.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief RTEMS File System Interface for RTEMS
> + * @brief RTEMS File System Interface for RTEMS
> diff --git a/cpukit/libfs/src/rfs/rtems-rfs-shell.c
> b/cpukit/libfs/src/rfs/rtems-rfs-shell.c
> index a3ad6b24d1..81d2d06037 100644
> --- a/cpukit/libfs/src/rfs/rtems-rfs-shell.c
> +++ b/cpukit/libfs/src/rfs/rtems-rfs-shell.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief RTEMS File Systems Shell Commands Support
> + * @brief RTEMS File Systems Shell Commands Support
> diff --git a/cpukit/libfs/src/rfs/rtems-rfs-trace.c
> b/cpukit/libfs/src/rfs/rtems-rfs-trace.c
> index f2cc2dbae2..b064898074 100644
> --- a/cpukit/libfs/src/rfs/rtems-rfs-trace.c
> +++ b/cpukit/libfs/src/rfs/rtems-rfs-trace.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief RTEMS File Systems Trace Support
> + * @brief RTEMS File Systems Trace Support
> diff --git a/cpukit/libmisc/bspcmdline/bspcmdline_get.c
> b/cpukit/libmisc/bspcmdline/bspcmdline_get.c
> index c518484e15..029cb6b8e6 100644
> --- a/cpukit/libmisc/bspcmdline/bspcmdline_get.c
> +++ b/cpukit/libmisc/bspcmdline/bspcmdline_get.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Obtain Pointer to BSP Boot Command String
> * @ingroup BSPCommandLine BSP Command Line Helpers
> + * @brief Obtain Pointer to BSP Boot Command String
> diff --git a/cpukit/libmisc/bspcmdline/bspcmdline_getparam.c
> b/cpukit/libmisc/bspcmdline/bspcmdline_getparam.c
> index 63da02dac3..f18773a49a 100644
> --- a/cpukit/libmisc/bspcmdline/bspcmdline_getparam.c
> +++ b/cpukit/libmisc/bspcmdline/bspcmdline_getparam.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Obtain COPY of the Entire Matching Argument
> + * @brief Obtain COPY of the Entire Matching Argument
> diff --git a/cpukit/libmisc/bspcmdline/bspcmdline_getparamraw.c
> b/cpukit/libmisc/bspcmdline/bspcmdline_getparamraw.c
> index d1f11c7bec..db4a01aed3 100644
> --- a/cpukit/libmisc/bspcmdline/bspcmdline_getparamraw.c
> +++ b/cpukit/libmisc/bspcmdline/bspcmdline_getparamraw.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Obtain Pointer to the Entire Matching Argument
> + * @brief Obtain Pointer to the Entire Matching Argument
> diff --git a/cpukit/libmisc/bspcmdline/bspcmdline_getparamrhs.c
> b/cpukit/libmisc/bspcmdline/bspcmdline_getparamrhs.c
> index 4bfe062afe..aab5b02850 100644
> --- a/cpukit/libmisc/bspcmdline/bspcmdline_getparamrhs.c
> +++ b/cpukit/libmisc/bspcmdline/bspcmdline_getparamrhs.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Obtain COPY of the Right Hand Side of the Matching Argument
> + * @brief Obtain COPY of the Right Hand Side of the Matching Argument
> diff --git a/cpukit/libmisc/cpuuse/cpuusagedata.c
> b/cpukit/libmisc/cpuuse/cpuusagedata.c
> index d855a4da90..0d06dd3e5c 100644
> --- a/cpukit/libmisc/cpuuse/cpuusagedata.c
> +++ b/cpukit/libmisc/cpuuse/cpuusagedata.c
> @@ -1,9 +1,10 @@
> * @file
> - * @brief CPU Usage Data
> * @ingroup libmisc_cpuuse CPU Usage
> + * @brief CPU Usage Data
> * CPU Usage Reporter - Shared Data
> diff --git a/cpukit/libmisc/cpuuse/cpuusagereport.c
> b/cpukit/libmisc/cpuuse/cpuusagereport.c
> index 2a01a8aa3d..08bc5bb541 100644
> --- a/cpukit/libmisc/cpuuse/cpuusagereport.c
> +++ b/cpukit/libmisc/cpuuse/cpuusagereport.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief CPU Usage Report
> + * @brief CPU Usage Report
> diff --git a/cpukit/libmisc/cpuuse/cpuusagereset.c
> b/cpukit/libmisc/cpuuse/cpuusagereset.c
> index 455651e19f..10d8ebec48 100644
> --- a/cpukit/libmisc/cpuuse/cpuusagereset.c
> +++ b/cpukit/libmisc/cpuuse/cpuusagereset.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief CPU Usage Reset
> + * @brief CPU Usage Reset
> diff --git a/cpukit/libmisc/cpuuse/cpuusagetop.c
> b/cpukit/libmisc/cpuuse/cpuusagetop.c
> index 66cbda9277..9f19b27439 100644
> --- a/cpukit/libmisc/cpuuse/cpuusagetop.c
> +++ b/cpukit/libmisc/cpuuse/cpuusagetop.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief CPU Usage Top
> + * @brief CPU Usage Top
> diff --git a/cpukit/libmisc/devnull/devnull.c
> b/cpukit/libmisc/devnull/devnull.c
> index 6ec70e85a4..9adc47c665 100644
> --- a/cpukit/libmisc/devnull/devnull.c
> +++ b/cpukit/libmisc/devnull/devnull.c
> @@ -1,9 +1,10 @@
> * @file
> - * @brief Null Device Driver Init Routine
> * @ingroup libmisc_devnull Device Driver
> + * @brief Null Device Driver Init Routine
> * Derived from rtems' stub driver.
> diff --git a/cpukit/libmisc/devnull/devzero.c
> b/cpukit/libmisc/devnull/devzero.c
> index 4aecec6528..a993e5c810 100644
> --- a/cpukit/libmisc/devnull/devzero.c
> +++ b/cpukit/libmisc/devnull/devzero.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Devzero
> + * @brief Devzero
> diff --git a/cpukit/libmisc/dumpbuf/dumpbuf.c
> b/cpukit/libmisc/dumpbuf/dumpbuf.c
> index ed4868cdb4..7f8128259f 100644
> --- a/cpukit/libmisc/dumpbuf/dumpbuf.c
> +++ b/cpukit/libmisc/dumpbuf/dumpbuf.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Dump Buffer
> * @ingroup libmisc_dumpbuf Print Memory Buffer
> + * @brief Dump Buffer
> diff --git a/cpukit/libmisc/fb/mw_print.c b/cpukit/libmisc/fb/mw_print.c
> index 1d226b7d0f..34979960c9 100644
> --- a/cpukit/libmisc/fb/mw_print.c
> +++ b/cpukit/libmisc/fb/mw_print.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief MicroWindows Print
> * @ingroup libmisc_fb_mw Input Devices for MicroWindows
> + * @brief MicroWindows Print
> diff --git a/cpukit/libmisc/fb/mw_uid.c b/cpukit/libmisc/fb/mw_uid.c
> index db98f1fa9c..c3933d6e99 100644
> --- a/cpukit/libmisc/fb/mw_uid.c
> +++ b/cpukit/libmisc/fb/mw_uid.c
> @@ -1,9 +1,10 @@
> * @file
> - * @brief MicroWindows UID
> + * @brief MicroWindows UID
> * This module implements the input devices interface used by MicroWindows
> * in an embedded system environment. It uses the RTEMS message queue as
> * the repository for the messages posted by the devices registered.
> diff --git a/cpukit/libmisc/fsmount/fsmount.c
> b/cpukit/libmisc/fsmount/fsmount.c
> index 91b57388c1..190d0dd511 100644
> --- a/cpukit/libmisc/fsmount/fsmount.c
> +++ b/cpukit/libmisc/fsmount/fsmount.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief File System Mount Functions
> * @ingroup rtems_fstab File System Mount Support
> + * @brief File System Mount Functions
> diff --git a/cpukit/libmisc/mouse/mouse_parser.c
> b/cpukit/libmisc/mouse/mouse_parser.c
> index 573e6cf5fd..5701dcd9f5 100644
> --- a/cpukit/libmisc/mouse/mouse_parser.c
> +++ b/cpukit/libmisc/mouse/mouse_parser.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Opens a Serial Port Directly, and Interprets Serial Data
> * @ingroup libmisc_mouse Mouse Parser Engine
> + * @brief Opens a Serial Port Directly, and Interprets Serial Data
> diff --git a/cpukit/libmisc/mouse/serial_mouse.c
> b/cpukit/libmisc/mouse/serial_mouse.c
> index 874903a607..53a174df57 100644
> --- a/cpukit/libmisc/mouse/serial_mouse.c
> +++ b/cpukit/libmisc/mouse/serial_mouse.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Serial Mouse Driver
> * @ingroup libmisc_mouse Serial Mouse Driver
> + * @brief Serial Mouse Driver
> diff --git a/cpukit/libmisc/shell/main_df.c
> b/cpukit/libmisc/shell/main_df.c
> index ac1d5f6452..d4266147a6 100644
> --- a/cpukit/libmisc/shell/main_df.c
> +++ b/cpukit/libmisc/shell/main_df.c
> @@ -1,8 +1,9 @@
> * df Shell Command Implmentation
> diff --git a/cpukit/libmisc/stackchk/check.c
> b/cpukit/libmisc/stackchk/check.c
> index 0c859f6375..ab08155c92 100644
> --- a/cpukit/libmisc/stackchk/check.c
> +++ b/cpukit/libmisc/stackchk/check.c
> @@ -1,9 +1,10 @@
> * @file
> - * @brief Stack Overflow Check User Extension Set
> * @ingroup libmisc_stackchk Stack Checker Mechanism
> + * @brief Stack Overflow Check User Extension Set
> * NOTE: This extension set automatically determines at
> * initialization time whether the stack for this
> * CPU grows up or down and installs the correct
> diff --git a/cpukit/libmisc/stringto/stringtodouble.c
> b/cpukit/libmisc/stringto/stringtodouble.c
> index 169719c210..c3cd851077 100644
> --- a/cpukit/libmisc/stringto/stringtodouble.c
> +++ b/cpukit/libmisc/stringto/stringtodouble.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Convert String to Double (with validation)
> * @ingroup libmisc_conv_help Conversion Helpers
> + * @brief Convert String to Double (with validation)
> diff --git a/cpukit/libmisc/stringto/stringtofloat.c
> b/cpukit/libmisc/stringto/stringtofloat.c
> index 2c3d407f7a..46326af960 100644
> --- a/cpukit/libmisc/stringto/stringtofloat.c
> +++ b/cpukit/libmisc/stringto/stringtofloat.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Convert String to Float (with validation)
> + * @brief Convert String to Float (with validation)
> diff --git a/cpukit/libmisc/stringto/stringtoint.c
> b/cpukit/libmisc/stringto/stringtoint.c
> index 16b95d02e1..fdd85cad3d 100644
> --- a/cpukit/libmisc/stringto/stringtoint.c
> +++ b/cpukit/libmisc/stringto/stringtoint.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Convert String to Int (with validation)
> + * @brief Convert String to Int (with validation)
> diff --git a/cpukit/libmisc/stringto/stringtolong.c
> b/cpukit/libmisc/stringto/stringtolong.c
> index 2c6abb96e8..7f5fa0b5aa 100644
> --- a/cpukit/libmisc/stringto/stringtolong.c
> +++ b/cpukit/libmisc/stringto/stringtolong.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Convert String to Long (with validation)
> + * @brief Convert String to Long (with validation)
> diff --git a/cpukit/libmisc/stringto/stringtolongdouble.c
> b/cpukit/libmisc/stringto/stringtolongdouble.c
> index e403653b80..754e0b11e7 100644
> --- a/cpukit/libmisc/stringto/stringtolongdouble.c
> +++ b/cpukit/libmisc/stringto/stringtolongdouble.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Convert String to long double (with validation)
> + * @brief Convert String to long double (with validation)
> diff --git a/cpukit/libmisc/stringto/stringtolonglong.c
> b/cpukit/libmisc/stringto/stringtolonglong.c
> index 11f259cd2a..c35188529e 100644
> --- a/cpukit/libmisc/stringto/stringtolonglong.c
> +++ b/cpukit/libmisc/stringto/stringtolonglong.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Convert String to Long Long (with validation)
> + * @brief Convert String to Long Long (with validation)
> diff --git a/cpukit/libmisc/stringto/stringtopointer.c
> b/cpukit/libmisc/stringto/stringtopointer.c
> index ecc4beabd9..5d69768742 100644
> --- a/cpukit/libmisc/stringto/stringtopointer.c
> +++ b/cpukit/libmisc/stringto/stringtopointer.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Convert String to Pointer (with validation)
> + * @brief Convert String to Pointer (with validation)
> diff --git a/cpukit/libmisc/stringto/stringtounsignedchar.c
> b/cpukit/libmisc/stringto/stringtounsignedchar.c
> index fbaa1cdfc6..6181cfeeaa 100644
> --- a/cpukit/libmisc/stringto/stringtounsignedchar.c
> +++ b/cpukit/libmisc/stringto/stringtounsignedchar.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Convert String to Unsigned Character (with validation)
> + * @brief Convert String to Unsigned Character (with validation)
> diff --git a/cpukit/libmisc/stringto/stringtounsignedint.c
> b/cpukit/libmisc/stringto/stringtounsignedint.c
> index 15ffe495fa..95c6c85ac9 100644
> --- a/cpukit/libmisc/stringto/stringtounsignedint.c
> +++ b/cpukit/libmisc/stringto/stringtounsignedint.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Convert String to Unsigned Int (with validation)
> + * @brief Convert String to Unsigned Int (with validation)
> diff --git a/cpukit/libmisc/stringto/stringtounsignedlong.c
> b/cpukit/libmisc/stringto/stringtounsignedlong.c
> index 5a9b57075a..16f109735e 100644
> --- a/cpukit/libmisc/stringto/stringtounsignedlong.c
> +++ b/cpukit/libmisc/stringto/stringtounsignedlong.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Convert String to Unsigned Long Long (with validation)
> + * @brief Convert String to Unsigned Long Long (with validation)
> diff --git a/cpukit/libmisc/stringto/stringtounsignedlonglong.c
> b/cpukit/libmisc/stringto/stringtounsignedlonglong.c
> index 28cd20d395..5dd9628166 100644
> --- a/cpukit/libmisc/stringto/stringtounsignedlonglong.c
> +++ b/cpukit/libmisc/stringto/stringtounsignedlonglong.c
> @@ -1,8 +1,9 @@
> * @file
> diff --git a/cpukit/posix/src/_execve.c b/cpukit/posix/src/_execve.c
> index f719566dfa..2c8b436889 100644
> --- a/cpukit/posix/src/_execve.c
> +++ b/cpukit/posix/src/_execve.c
> @@ -1,9 +1,10 @@
> * @file
> - * @brief _execve()
> * @ingroup POSIXAPI
> + * @brief _execve()
> * The Newlib C Library contains all of the exec*() variants and assumes
> * the underlying OS support provides _execve(). This single method
> * ensures that all exec*() variants return ENOSYS.
> diff --git a/cpukit/posix/src/aio_error.c b/cpukit/posix/src/aio_error.c
> index bd41415af1..2669ab14b1 100644
> --- a/cpukit/posix/src/aio_error.c
> +++ b/cpukit/posix/src/aio_error.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Returns the error status for the Asynchronous I/O request
> * @ingroup POSIXAPI
> + * @brief Returns the error status for the Asynchronous I/O request
> diff --git a/cpukit/posix/src/aio_fsync.c b/cpukit/posix/src/aio_fsync.c
> index 212668dbb3..b34014230d 100644
> --- a/cpukit/posix/src/aio_fsync.c
> +++ b/cpukit/posix/src/aio_fsync.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Syncing of all Outstanding Asynchronous I/O Operations
> * @ingroup POSIXAPI
> + * @brief Syncing of all Outstanding Asynchronous I/O Operations
> diff --git a/cpukit/posix/src/aio_misc.c b/cpukit/posix/src/aio_misc.c
> index 5a281a94f5..6c5c6b981a 100644
> --- a/cpukit/posix/src/aio_misc.c
> +++ b/cpukit/posix/src/aio_misc.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Actual request being processed
> * @ingroup POSIXAPI
> + * @brief Actual request being processed
> diff --git a/cpukit/posix/src/aio_read.c b/cpukit/posix/src/aio_read.c
> index 014658c2c6..cf02341a7b 100644
> --- a/cpukit/posix/src/aio_read.c
> +++ b/cpukit/posix/src/aio_read.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Asynchronously reads Data from a File
> * @ingroup POSIXAPI
> + * @brief Asynchronously reads Data from a File
> diff --git a/cpukit/posix/src/aio_return.c b/cpukit/posix/src/aio_return.c
> index 307d384263..7342cbe9cf 100644
> --- a/cpukit/posix/src/aio_return.c
> +++ b/cpukit/posix/src/aio_return.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Final return status for Asynchronous I/O request pointed to by
> aiobcp
> * @ingroup POSIXAPI
> + * @brief Final return status for Asynchronous I/O request pointed to by
> aiobcp
> diff --git a/cpukit/posix/src/aio_suspend.c
> b/cpukit/posix/src/aio_suspend.c
> index 1fdec47291..43de0abe1c 100644
> --- a/cpukit/posix/src/aio_suspend.c
> +++ b/cpukit/posix/src/aio_suspend.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Suspends Process until Asynchronous I/O Operation completes
> * @ingroup POSIXAPI
> + * @brief Suspends Process until Asynchronous I/O Operation completes
> diff --git a/cpukit/posix/src/aio_write.c b/cpukit/posix/src/aio_write.c
> index db71c956a3..27a7399fe6 100644
> --- a/cpukit/posix/src/aio_write.c
> +++ b/cpukit/posix/src/aio_write.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Function queues I/O request described by buffer pointed by
> aiocb
> * @ingroup POSIXAPI
> + * @brief Function queues I/O request described by buffer pointed by
> aiocb
> diff --git a/cpukit/posix/src/alarm.c b/cpukit/posix/src/alarm.c
> index 49bdb573f5..64ac0fafc3 100644
> --- a/cpukit/posix/src/alarm.c
> +++ b/cpukit/posix/src/alarm.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief System Generates Signal for process after realtime seconds
> elapsed
> * @ingroup POSIXAPI
> + * @brief System Generates Signal for process after realtime seconds
> elapsed
> diff --git a/cpukit/posix/src/barrierattrdestroy.c
> b/cpukit/posix/src/barrierattrdestroy.c
> index f36d2fce31..1f8df41814 100644
> --- a/cpukit/posix/src/barrierattrdestroy.c
> +++ b/cpukit/posix/src/barrierattrdestroy.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Function shall Destroy a Barrier Attribues Object
> * @ingroup POSIXAPI
> + * @brief Function shall Destroy a Barrier Attribues Object
> diff --git a/cpukit/posix/src/barrierattrgetpshared.c
> b/cpukit/posix/src/barrierattrgetpshared.c
> index 5f346fe4d0..682d6dfbf1 100644
> --- a/cpukit/posix/src/barrierattrgetpshared.c
> +++ b/cpukit/posix/src/barrierattrgetpshared.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Barrier Attributes Get Process Shared
> * @ingroup POSIXAPI
> + * @brief Barrier Attributes Get Process Shared
> diff --git a/cpukit/posix/src/cancel.c b/cpukit/posix/src/cancel.c
> index 8c00f716cd..4756f10389 100644
> --- a/cpukit/posix/src/cancel.c
> +++ b/cpukit/posix/src/cancel.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Canceling Execution of a Thread
> * @ingroup POSIXAPI
> + * @brief Canceling Execution of a Thread
> diff --git a/cpukit/posix/src/cleanuppush.c
> b/cpukit/posix/src/cleanuppush.c
> index 25e4dcc1e9..a53e0ae531 100644
> --- a/cpukit/posix/src/cleanuppush.c
> +++ b/cpukit/posix/src/cleanuppush.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief POSIX Cleanup Support
> * @ingroup POSIXAPI
> + * @brief POSIX Cleanup Support
> diff --git a/cpukit/posix/src/clockgetcpuclockid.c
> b/cpukit/posix/src/clockgetcpuclockid.c
> index a3172b6c25..7803ef3547 100644
> --- a/cpukit/posix/src/clockgetcpuclockid.c
> +++ b/cpukit/posix/src/clockgetcpuclockid.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Function Returns Clock ID of CPU-time Clock of process
> specified
> * @ingroup POSIXAPI
> + * @brief Function Returns Clock ID of CPU-time Clock of process
> specified
> diff --git a/cpukit/posix/src/clockgetres.c
> b/cpukit/posix/src/clockgetres.c
> index 04b99e0595..1092c50865 100644
> --- a/cpukit/posix/src/clockgetres.c
> +++ b/cpukit/posix/src/clockgetres.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Function Returns the Resolution of any Clock
> * @ingroup POSIXAPI
> + * @brief Function Returns the Resolution of any Clock
> diff --git a/cpukit/posix/src/clockgettime.c
> b/cpukit/posix/src/clockgettime.c
> index a885a838b8..8f6dd9aa75 100644
> --- a/cpukit/posix/src/clockgettime.c
> +++ b/cpukit/posix/src/clockgettime.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Retrieves the Specified Clock Time
> * @ingroup POSIXAPI
> + * @brief Retrieves the Specified Clock Time
> diff --git a/cpukit/posix/src/clocksettime.c
> b/cpukit/posix/src/clocksettime.c
> index 8052ac0a9f..53e728762e 100644
> --- a/cpukit/posix/src/clocksettime.c
> +++ b/cpukit/posix/src/clocksettime.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Set Time of Clock
> * @ingroup POSIXAPI
> + * @brief Set Time of Clock
> diff --git a/cpukit/posix/src/condattrdestroy.c
> b/cpukit/posix/src/condattrdestroy.c
> index 31e8e5953c..84032ca56a 100644
> --- a/cpukit/posix/src/condattrdestroy.c
> +++ b/cpukit/posix/src/condattrdestroy.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Destroy Condition Attribute
> * @ingroup POSIXAPI
> + * @brief Destroy Condition Attribute
> diff --git a/cpukit/posix/src/condattrgetclock.c
> b/cpukit/posix/src/condattrgetclock.c
> index 29c7665222..c6dd3f35f8 100644
> --- a/cpukit/posix/src/condattrgetclock.c
> +++ b/cpukit/posix/src/condattrgetclock.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Get the Clock Condition Variable Attributes
> * @ingroup POSIXAPI
> + * @brief Get the Clock Condition Variable Attributes
> diff --git a/cpukit/posix/src/condattrgetpshared.c
> b/cpukit/posix/src/condattrgetpshared.c
> index 051a59577a..d5ec0dfe89 100644
> --- a/cpukit/posix/src/condattrgetpshared.c
> +++ b/cpukit/posix/src/condattrgetpshared.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Get the Process-Shared Condition Variable Attributes
> * @ingroup POSIXAPI
> + * @brief Get the Process-Shared Condition Variable Attributes
> diff --git a/cpukit/posix/src/condattrinit.c
> b/cpukit/posix/src/condattrinit.c
> index f2ab9b8772..01b85e2a13 100644
> --- a/cpukit/posix/src/condattrinit.c
> +++ b/cpukit/posix/src/condattrinit.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Initialization of Conditional Attributes
> * @ingroup POSIXAPI
> + * @brief Initialization of Conditional Attributes
> diff --git a/cpukit/posix/src/condattrsetclock.c
> b/cpukit/posix/src/condattrsetclock.c
> index a272d34e66..9be0bacbaf 100644
> --- a/cpukit/posix/src/condattrsetclock.c
> +++ b/cpukit/posix/src/condattrsetclock.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Set the Clock Condition Variable Attributes
> * @ingroup POSIXAPI
> + * @brief Set the Clock Condition Variable Attributes
> diff --git a/cpukit/posix/src/condattrsetpshared.c
> b/cpukit/posix/src/condattrsetpshared.c
> index 5228b45a4e..11b4d67e57 100644
> --- a/cpukit/posix/src/condattrsetpshared.c
> +++ b/cpukit/posix/src/condattrsetpshared.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Set the Process-Shared Condition Variable Attributes
> * @ingroup POSIXAPI
> + * @brief Set the Process-Shared Condition Variable Attributes
> diff --git a/cpukit/posix/src/conddefaultattributes.c
> b/cpukit/posix/src/conddefaultattributes.c
> index 409dd08aac..6c0e51317c 100644
> --- a/cpukit/posix/src/conddefaultattributes.c
> +++ b/cpukit/posix/src/conddefaultattributes.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Condition variable Attributes structure
> * @ingroup POSIXAPI
> + * @brief Condition variable Attributes structure
> diff --git a/cpukit/posix/src/condsignalsupp.c
> b/cpukit/posix/src/condsignalsupp.c
> index eabba064c6..dd3886ae69 100644
> --- a/cpukit/posix/src/condsignalsupp.c
> +++ b/cpukit/posix/src/condsignalsupp.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Implements wake up version of the "signal" operation
> * @ingroup POSIX_COND_VARS Condition Variables
> + * @brief Implements wake up version of the "signal" operation
> diff --git a/cpukit/posix/src/condtimedwait.c
> b/cpukit/posix/src/condtimedwait.c
> index 290a9d5161..0bc8bfc18e 100644
> --- a/cpukit/posix/src/condtimedwait.c
> +++ b/cpukit/posix/src/condtimedwait.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Waiting on a Condition
> * @ingroup POSIXAPI
> + * @brief Waiting on a Condition
> diff --git a/cpukit/posix/src/condwait.c b/cpukit/posix/src/condwait.c
> index bbebfe544d..09431e216d 100644
> --- a/cpukit/posix/src/condwait.c
> +++ b/cpukit/posix/src/condwait.c
> @@ -1,8 +1,9 @@
> * @file
> * @ingroup POSIXAPI
> diff --git a/cpukit/posix/src/condwaitsupp.c
> b/cpukit/posix/src/condwaitsupp.c
> index b759ee54b8..296c03d1c6 100644
> --- a/cpukit/posix/src/condwaitsupp.c
> +++ b/cpukit/posix/src/condwaitsupp.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief POSIX Condition Variables Wait Support
> + * @brief POSIX Condition Variables Wait Support
> diff --git a/cpukit/posix/src/fork.c b/cpukit/posix/src/fork.c
> index 57e96937ca..252f240515 100644
> --- a/cpukit/posix/src/fork.c
> +++ b/cpukit/posix/src/fork.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Inoperable implementation of fork() for POSIX threads
> * @ingroup POSIXAPI
> + * @brief Inoperable implementation of fork() for POSIX threads
> diff --git a/cpukit/posix/src/getitimer.c b/cpukit/posix/src/getitimer.c
> index 35e940bff9..e0a767363d 100644
> --- a/cpukit/posix/src/getitimer.c
> +++ b/cpukit/posix/src/getitimer.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Function Gets Value of an Interval Timer
> * @ingroup POSIXAPI
> + * @brief Function Gets Value of an Interval Timer
> diff --git a/cpukit/posix/src/keycreate.c b/cpukit/posix/src/keycreate.c
> index f018133c1f..dc313488ae 100644
> --- a/cpukit/posix/src/keycreate.c
> +++ b/cpukit/posix/src/keycreate.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Thread-Specific Data Key Create
> * @ingroup POSIXAPI
> + * @brief Thread-Specific Data Key Create
> diff --git a/cpukit/posix/src/keydelete.c b/cpukit/posix/src/keydelete.c
> index 69b8559a83..0c0a429d6b 100644
> --- a/cpukit/posix/src/keydelete.c
> +++ b/cpukit/posix/src/keydelete.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Deletes Thread-specific Data Key Previously Returned by
> keycreate.c
> * @ingroup POSIXAPI
> + * @brief Deletes Thread-specific Data Key Previously Returned by
> keycreate.c
> diff --git a/cpukit/posix/src/keygetspecific.c
> b/cpukit/posix/src/keygetspecific.c
> index 5f1188d4b5..5abb24d21c 100644
> --- a/cpukit/posix/src/keygetspecific.c
> +++ b/cpukit/posix/src/keygetspecific.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Thread-Specific Data Management
> * @ingroup POSIXAPI
> + * @brief Thread-Specific Data Management
> diff --git a/cpukit/posix/src/keysetspecific.c
> b/cpukit/posix/src/keysetspecific.c
> index 5be2f8dd07..f5500f972f 100644
> --- a/cpukit/posix/src/keysetspecific.c
> +++ b/cpukit/posix/src/keysetspecific.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Set Specific Key
> * @ingroup POSIXAPI
> + * @brief Set Specific Key
> diff --git a/cpukit/posix/src/kill.c b/cpukit/posix/src/kill.c
> index a143c5dea3..d759cd1617 100644
> --- a/cpukit/posix/src/kill.c
> +++ b/cpukit/posix/src/kill.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Send a Signal to a Process
> * @ingroup POSIXAPI
> + * @brief Send a Signal to a Process
> diff --git a/cpukit/posix/src/kill_r.c b/cpukit/posix/src/kill_r.c
> index 2262c733b2..05d1bbde07 100644
> --- a/cpukit/posix/src/kill_r.c
> +++ b/cpukit/posix/src/kill_r.c
> @@ -1,8 +1,9 @@
> * @file
> * @ingroup POSIXAPI
> diff --git a/cpukit/posix/src/killinfo.c b/cpukit/posix/src/killinfo.c
> index b815d79bcd..c765a14b9a 100644
> --- a/cpukit/posix/src/killinfo.c
> +++ b/cpukit/posix/src/killinfo.c
> @@ -1,8 +1,9 @@
> * @file
> * @ingroup POSIXAPI
> diff --git a/cpukit/posix/src/lio_listio.c b/cpukit/posix/src/lio_listio.c
> index 26f0d9831d..806d357470 100644
> --- a/cpukit/posix/src/lio_listio.c
> +++ b/cpukit/posix/src/lio_listio.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Function Initiates a List of I/O Requests with Single Function
> Call
> * @ingroup POSIXAPI
> + * @brief Function Initiates a List of I/O Requests with Single Function
> Call
> diff --git a/cpukit/posix/src/mprotect.c b/cpukit/posix/src/mprotect.c
> index 17a63b47ce..87fe5cf355 100644
> --- a/cpukit/posix/src/mprotect.c
> +++ b/cpukit/posix/src/mprotect.c
> @@ -1,9 +1,10 @@
> * @file
> - * @brief Change Memory Protection
> * @ingroup POSIXAPI
> + * @brief Change Memory Protection
> * 12.2.3 Change Memory Protection, P1003.1b-1996, p. 277.
> * This is not a functional version of mprotect() but the SPARC backend
> diff --git a/cpukit/posix/src/mqueueclose.c
> b/cpukit/posix/src/mqueueclose.c
> index a9cadb4a0b..ea8f1502da 100644
> --- a/cpukit/posix/src/mqueueclose.c
> +++ b/cpukit/posix/src/mqueueclose.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Function closes the Message Queue
> * @ingroup POSIXAPI
> + * @brief Function closes the Message Queue
> diff --git a/cpukit/posix/src/mqueuegetattr.c
> b/cpukit/posix/src/mqueuegetattr.c
> index 20ade1107c..8c6bd5e78b 100644
> --- a/cpukit/posix/src/mqueuegetattr.c
> +++ b/cpukit/posix/src/mqueuegetattr.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Message Queue Attributes
> * @ingroup POSIXAPI
> + * @brief Message Queue Attributes
> diff --git a/cpukit/posix/src/mqueuenotify.c
> b/cpukit/posix/src/mqueuenotify.c
> index e8113e7018..04eb62a565 100644
> --- a/cpukit/posix/src/mqueuenotify.c
> +++ b/cpukit/posix/src/mqueuenotify.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Notify Process that a Message is Available on a Queue
> * @ingroup POSIX_MQUEUE
> + * @brief Notify Process that a Message is Available on a Queue
> diff --git a/cpukit/posix/src/mqueueopen.c b/cpukit/posix/src/mqueueopen.c
> index 821563f9c3..35b8c923b1 100644
> --- a/cpukit/posix/src/mqueueopen.c
> +++ b/cpukit/posix/src/mqueueopen.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Creates a new POSIX Message Queue or Opens an Existing Queue
> * @ingroup POSIXAPI
> + * @brief Creates a new POSIX Message Queue or Opens an Existing Queue
> diff --git a/cpukit/posix/src/mqueuerecvsupp.c
> b/cpukit/posix/src/mqueuerecvsupp.c
> index 32d7909c51..2adcb7b3b2 100644
> --- a/cpukit/posix/src/mqueuerecvsupp.c
> +++ b/cpukit/posix/src/mqueuerecvsupp.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief POSIX Message Queue Receive Support
> * @ingroup POSIX_MQUEUE_P Message Queues Private Support Information
> + * @brief POSIX Message Queue Receive Support
> diff --git a/cpukit/posix/src/mqueuesend.c b/cpukit/posix/src/mqueuesend.c
> index d7afdbdb91..38b7e3e41b 100644
> --- a/cpukit/posix/src/mqueuesend.c
> +++ b/cpukit/posix/src/mqueuesend.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Adds Message Pointed by msg_ptr to Message Queue Reffered by
> mqdes
> * @ingroup POSIXAPI
> + * @brief Adds Message Pointed by msg_ptr to Message Queue Reffered by
> mqdes
> diff --git a/cpukit/posix/src/mqueuesendsupp.c
> b/cpukit/posix/src/mqueuesendsupp.c
> index 8edc29de37..7be23fc595 100644
> --- a/cpukit/posix/src/mqueuesendsupp.c
> +++ b/cpukit/posix/src/mqueuesendsupp.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief POSIX Message Queue and Send Support
> * @ingroup POSIXAPI
> + * @brief POSIX Message Queue and Send Support
> diff --git a/cpukit/posix/src/mqueuesetattr.c
> b/cpukit/posix/src/mqueuesetattr.c
> index c8eafe7a0f..99e4bdf982 100644
> --- a/cpukit/posix/src/mqueuesetattr.c
> +++ b/cpukit/posix/src/mqueuesetattr.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Set Message Queue Attributes
> + * @brief Set Message Queue Attributes
> diff --git a/cpukit/posix/src/mqueuetimedreceive.c
> b/cpukit/posix/src/mqueuetimedreceive.c
> index a9fe5b5317..67161a8f88 100644
> --- a/cpukit/posix/src/mqueuetimedreceive.c
> +++ b/cpukit/posix/src/mqueuetimedreceive.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Receive Message from Message Queue
> * @ingroup POSIXAPI
> + * @brief Receive Message from Message Queue
> diff --git a/cpukit/posix/src/mqueueunlink.c
> b/cpukit/posix/src/mqueueunlink.c
> index c9737d57e6..0ddeaa86b2 100644
> --- a/cpukit/posix/src/mqueueunlink.c
> +++ b/cpukit/posix/src/mqueueunlink.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Remove a Message Queue
> * @ingroup POSIX_MQUEUE Message Queues
> + * @brief Remove a Message Queue
> diff --git a/cpukit/posix/src/mutexattrdestroy.c
> b/cpukit/posix/src/mutexattrdestroy.c
> index 1b78245b42..5c8d6c24f5 100644
> --- a/cpukit/posix/src/mutexattrdestroy.c
> +++ b/cpukit/posix/src/mutexattrdestroy.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Destroy Mutex Attributes Object
> * @ingroup POSIXAPI
> + * @brief Destroy Mutex Attributes Object
> diff --git a/cpukit/posix/src/mutexattrgetprioceiling.c
> b/cpukit/posix/src/mutexattrgetprioceiling.c
> index f0da17c223..eaf3250a7e 100644
> --- a/cpukit/posix/src/mutexattrgetprioceiling.c
> +++ b/cpukit/posix/src/mutexattrgetprioceiling.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Mutex Initialization Scheduling Attributes
> * @ingroup POSIXAPI
> + * @brief Mutex Initialization Scheduling Attributes
> diff --git a/cpukit/posix/src/mutexattrgetprotocol.c
> b/cpukit/posix/src/mutexattrgetprotocol.c
> index b4b30231b4..f8a35e60b4 100644
> --- a/cpukit/posix/src/mutexattrgetprotocol.c
> +++ b/cpukit/posix/src/mutexattrgetprotocol.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Get protocol Attribute of Mutex Attribute Obect
> * @ingroup POSIXAPI
> + * @brief Get protocol Attribute of Mutex Attribute Obect
> diff --git a/cpukit/posix/src/mutexattrgetpshared.c
> b/cpukit/posix/src/mutexattrgetpshared.c
> index 94547ad2b2..a7985164ce 100644
> --- a/cpukit/posix/src/mutexattrgetpshared.c
> +++ b/cpukit/posix/src/mutexattrgetpshared.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Obtaining process-shared Attribute Value from the Attributes
> Object
> * @ingroup POSIXAPI
> + * @brief Obtaining process-shared Attribute Value from the Attributes
> Object
> diff --git a/cpukit/posix/src/mutexattrgettype.c
> b/cpukit/posix/src/mutexattrgettype.c
> index c903099bee..88892f2212 100644
> --- a/cpukit/posix/src/mutexattrgettype.c
> +++ b/cpukit/posix/src/mutexattrgettype.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Function gets the Mutex Type Attribute
> * @ingroup POSIXAPI
> + * @brief Function gets the Mutex Type Attribute
> diff --git a/cpukit/posix/src/mutexattrsetprioceiling.c
> b/cpukit/posix/src/mutexattrsetprioceiling.c
> index b449215b66..6d3be649da 100644
> --- a/cpukit/posix/src/mutexattrsetprioceiling.c
> +++ b/cpukit/posix/src/mutexattrsetprioceiling.c
> @@ -1,8 +1,9 @@
> * @file
> * @ingroup POSIXAPI
> diff --git a/cpukit/posix/src/mutexattrsetprotocol.c
> b/cpukit/posix/src/mutexattrsetprotocol.c
> index 7ac28946c5..1870db6804 100644
> --- a/cpukit/posix/src/mutexattrsetprotocol.c
> +++ b/cpukit/posix/src/mutexattrsetprotocol.c
> @@ -1,8 +1,9 @@
> * @file
> * @ingroup POSIXAPI
> diff --git a/cpukit/posix/src/mutexattrsetpshared.c
> b/cpukit/posix/src/mutexattrsetpshared.c
> index d3efe2f481..acfe4881e1 100644
> --- a/cpukit/posix/src/mutexattrsetpshared.c
> +++ b/cpukit/posix/src/mutexattrsetpshared.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Function sets Current pshared Attribute for Mutex Attributes
> Object
> * @ingroup POSIXAPI
> + * @brief Function sets Current pshared Attribute for Mutex Attributes
> Object
> diff --git a/cpukit/posix/src/mutexdestroy.c
> b/cpukit/posix/src/mutexdestroy.c
> index 15d8aac447..a1662a6223 100644
> --- a/cpukit/posix/src/mutexdestroy.c
> +++ b/cpukit/posix/src/mutexdestroy.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Initializing and Destroying a Mutex
> * @ingroup POSIXAPI
> + * @brief Initializing and Destroying a Mutex
> diff --git a/cpukit/posix/src/mutexgetprioceiling.c
> b/cpukit/posix/src/mutexgetprioceiling.c
> index 41e6f1b8ea..e29a7e6be4 100644
> --- a/cpukit/posix/src/mutexgetprioceiling.c
> +++ b/cpukit/posix/src/mutexgetprioceiling.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Returns the Current Priority Ceiling of the Mutex
> * @ingroup POSIXAPI
> + * @brief Returns the Current Priority Ceiling of the Mutex
> diff --git a/cpukit/posix/src/mutexinit.c b/cpukit/posix/src/mutexinit.c
> index 07828f262d..2290bd6b39 100644
> --- a/cpukit/posix/src/mutexinit.c
> +++ b/cpukit/posix/src/mutexinit.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Initialize a Mutex
> * @ingroup POSIXAPI
> + * @brief Initialize a Mutex
> diff --git a/cpukit/posix/src/mutexlock.c b/cpukit/posix/src/mutexlock.c
> index 4efc8ac214..20efcdc6f2 100644
> --- a/cpukit/posix/src/mutexlock.c
> +++ b/cpukit/posix/src/mutexlock.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Call to function enables locking of Mutex Object referenced by
> mutex
> * @ingroup POSIXAPI
> + * @brief Call to function enables locking of Mutex Object referenced by
> mutex
> diff --git a/cpukit/posix/src/mutexlocksupp.c
> b/cpukit/posix/src/mutexlocksupp.c
> index 1cfc733cf9..e5bd1784ea 100644
> --- a/cpukit/posix/src/mutexlocksupp.c
> +++ b/cpukit/posix/src/mutexlocksupp.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Support Call to function Enables Locking of Mutex Object
> * @ingroup POSIXAPI
> + * @brief Support Call to function Enables Locking of Mutex Object
> diff --git a/cpukit/posix/src/mutexsetprioceiling.c
> b/cpukit/posix/src/mutexsetprioceiling.c
> index d78142283e..4bd5de9f12 100644
> --- a/cpukit/posix/src/mutexsetprioceiling.c
> +++ b/cpukit/posix/src/mutexsetprioceiling.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Changes the Priority Ceiling of a Mutex and Releases it
> * @ingroup POSIXAPI
> + * @brief Changes the Priority Ceiling of a Mutex and Releases it
> diff --git a/cpukit/posix/src/mutextimedlock.c
> b/cpukit/posix/src/mutextimedlock.c
> index 6ec813cb35..c5dcf7f1a7 100644
> --- a/cpukit/posix/src/mutextimedlock.c
> +++ b/cpukit/posix/src/mutextimedlock.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Mutex Timed Lock
> * @ingroup POSIXAPI
> + * @brief Mutex Timed Lock
> diff --git a/cpukit/posix/src/mutextrylock.c
> b/cpukit/posix/src/mutextrylock.c
> index af7903cb19..72d6e353ee 100644
> --- a/cpukit/posix/src/mutextrylock.c
> +++ b/cpukit/posix/src/mutextrylock.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Try to Lock Mutex
> * @ingroup POSIXAPI
> + * @brief Try to Lock Mutex
> diff --git a/cpukit/posix/src/mutexunlock.c
> b/cpukit/posix/src/mutexunlock.c
> index 1b00800bf4..c811a28192 100644
> --- a/cpukit/posix/src/mutexunlock.c
> +++ b/cpukit/posix/src/mutexunlock.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Locking and Unlocking a Mutex
> * @ingroup POSIXAPI
> + * @brief Locking and Unlocking a Mutex
> diff --git a/cpukit/posix/src/nanosleep.c b/cpukit/posix/src/nanosleep.c
> index afcc29051f..8d1a4b84e4 100644
> --- a/cpukit/posix/src/nanosleep.c
> +++ b/cpukit/posix/src/nanosleep.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Suspends Execution of calling thread until Time elapses
> * @ingroup POSIXAPI
> + * @brief Suspends Execution of calling thread until Time elapses
> diff --git a/cpukit/posix/src/pause.c b/cpukit/posix/src/pause.c
> index e2fb9d9f15..af660300a7 100644
> --- a/cpukit/posix/src/pause.c
> +++ b/cpukit/posix/src/pause.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Suspend Process Execution
> * @ingroup POSIXAPI
> + * @brief Suspend Process Execution
> diff --git a/cpukit/posix/src/pbarrierinit.c
> b/cpukit/posix/src/pbarrierinit.c
> index abe4224374..19279f8c4a 100644
> --- a/cpukit/posix/src/pbarrierinit.c
> +++ b/cpukit/posix/src/pbarrierinit.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Call to Function Enables Reinitializing of the Barrier
> * @ingroup POSIXAPI
> + * @brief Call to Function Enables Reinitializing of the Barrier
> diff --git a/cpukit/posix/src/pbarrierwait.c
> b/cpukit/posix/src/pbarrierwait.c
> index 865ccfe3f7..68e8a991eb 100644
> --- a/cpukit/posix/src/pbarrierwait.c
> +++ b/cpukit/posix/src/pbarrierwait.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Wait at a Barrier
> * @ingroup POSIXAPI
> + * @brief Wait at a Barrier
> diff --git a/cpukit/posix/src/prwlockinit.c
> b/cpukit/posix/src/prwlockinit.c
> index 0bd5991b0a..d7ed527cfb 100644
> --- a/cpukit/posix/src/prwlockinit.c
> +++ b/cpukit/posix/src/prwlockinit.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Allocate resources to use the read-write lock and Initialize it
> * @ingroup POSIXAPI
> + * @brief Allocate resources to use the read-write lock and Initialize it
> diff --git a/cpukit/posix/src/prwlockrdlock.c
> b/cpukit/posix/src/prwlockrdlock.c
> index f0bc9c2e85..8ca4b9307c 100644
> --- a/cpukit/posix/src/prwlockrdlock.c
> +++ b/cpukit/posix/src/prwlockrdlock.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Obtain a Read Lock on a RWLock Instance
> * @ingroup POSIXAPI
> + * @brief Obtain a Read Lock on a RWLock Instance
> diff --git a/cpukit/posix/src/prwlocktimedrdlock.c
> b/cpukit/posix/src/prwlocktimedrdlock.c
> index 1ccf534269..79059800bf 100644
> --- a/cpukit/posix/src/prwlocktimedrdlock.c
> +++ b/cpukit/posix/src/prwlocktimedrdlock.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Attempt to Obtain a Read Lock on a RWLock Instance
> * @ingroup POSIXAPI
> + * @brief Attempt to Obtain a Read Lock on a RWLock Instance
> diff --git a/cpukit/posix/src/prwlocktimedwrlock.c
> b/cpukit/posix/src/prwlocktimedwrlock.c
> index 01ce758d1c..9fb9a880a0 100644
> --- a/cpukit/posix/src/prwlocktimedwrlock.c
> +++ b/cpukit/posix/src/prwlocktimedwrlock.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Function applies a Write lock to RWLock referenced by rwlock
> * @ingroup POSIXAPI
> + * @brief Function applies a Write lock to RWLock referenced by rwlock
> diff --git a/cpukit/posix/src/prwlocktryrdlock.c
> b/cpukit/posix/src/prwlocktryrdlock.c
> index 1bc523ae40..c0c6154bfc 100644
> --- a/cpukit/posix/src/prwlocktryrdlock.c
> +++ b/cpukit/posix/src/prwlocktryrdlock.c
> @@ -1,8 +1,9 @@
> * @file
> * @ingroup POSIXAPI
> diff --git a/cpukit/posix/src/prwlocktrywrlock.c
> b/cpukit/posix/src/prwlocktrywrlock.c
> index a4525d7119..0137b21217 100644
> --- a/cpukit/posix/src/prwlocktrywrlock.c
> +++ b/cpukit/posix/src/prwlocktrywrlock.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Attempt to Obtain a Write Lock on a RWLock Instance
> * @ingroup POSIXAPI
> + * @brief Attempt to Obtain a Write Lock on a RWLock Instance
> diff --git a/cpukit/posix/src/prwlockunlock.c
> b/cpukit/posix/src/prwlockunlock.c
> index 6caa020d66..01c8ccda73 100644
> --- a/cpukit/posix/src/prwlockunlock.c
> +++ b/cpukit/posix/src/prwlockunlock.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Function Releases a lock held on RWLock object referenced by
> rwlock
> * @ingroup POSIXAPI
> + * @brief Function Releases a lock held on RWLock object referenced by
> rwlock
> diff --git a/cpukit/posix/src/prwlockwrlock.c
> b/cpukit/posix/src/prwlockwrlock.c
> index 438d1f1fc1..08c9d8a9d7 100644
> --- a/cpukit/posix/src/prwlockwrlock.c
> +++ b/cpukit/posix/src/prwlockwrlock.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Obtain a Write Lock on a RWlock Instance
> * @ingroup POSIXAPI
> + * @brief Obtain a Write Lock on a RWlock Instance
> diff --git a/cpukit/posix/src/psignalclearprocesssignals.c
> b/cpukit/posix/src/psignalclearprocesssignals.c
> index 77dfc7f410..fff797dd26 100644
> --- a/cpukit/posix/src/psignalclearprocesssignals.c
> +++ b/cpukit/posix/src/psignalclearprocesssignals.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief POSIX_signals clear_process_signals
> * @ingroup POSIXAPI
> + * @brief POSIX_signals clear_process_signals
> diff --git a/cpukit/posix/src/psignalclearsignals.c
> b/cpukit/posix/src/psignalclearsignals.c
> index f231748944..c1a407afaa 100644
> --- a/cpukit/posix/src/psignalclearsignals.c
> +++ b/cpukit/posix/src/psignalclearsignals.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief POSIX Signals Clear Signals
> * @ingroup POSIX_SIGNALS POSIX Signals Support
> + * @brief POSIX Signals Clear Signals
> diff --git a/cpukit/posix/src/psignalunblockthread.c
> b/cpukit/posix/src/psignalunblockthread.c
> index d6666fb279..80a0f33a09 100644
> --- a/cpukit/posix/src/psignalunblockthread.c
> +++ b/cpukit/posix/src/psignalunblockthread.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief POSIX Signals Thread Unlock
> + * @brief POSIX Signals Thread Unlock
> diff --git a/cpukit/posix/src/pspininit.c b/cpukit/posix/src/pspininit.c
> index 2e103cb53a..5ffa9be859 100644
> --- a/cpukit/posix/src/pspininit.c
> +++ b/cpukit/posix/src/pspininit.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief POSIX Function Initializes a Spinlock Instance
> * @ingroup POSIXAPI
> + * @brief POSIX Function Initializes a Spinlock Instance
> diff --git a/cpukit/posix/src/pspinunlock.c
> b/cpukit/posix/src/pspinunlock.c
> index 9af4a33b6b..ca36a5fc76 100644
> --- a/cpukit/posix/src/pspinunlock.c
> +++ b/cpukit/posix/src/pspinunlock.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Function Unlocks a Spin Lock Object
> * @ingroup POSIXAPI
> + * @brief Function Unlocks a Spin Lock Object
> diff --git a/cpukit/posix/src/psxnametoid.c
> b/cpukit/posix/src/psxnametoid.c
> index 0ddb72a98e..47cf81b473 100644
> --- a/cpukit/posix/src/psxnametoid.c
> +++ b/cpukit/posix/src/psxnametoid.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief POSIX Name to ID
> * @ingroup POSIXAPI
> + * @brief POSIX Name to ID
> diff --git a/cpukit/posix/src/psxtimercreate.c
> b/cpukit/posix/src/psxtimercreate.c
> index c2c89c283f..a63cf1d100 100644
> --- a/cpukit/posix/src/psxtimercreate.c
> +++ b/cpukit/posix/src/psxtimercreate.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Create a Per-Process Timer
> * @ingroup POSIX_PRIV_TIMERS Timers
> + * @brief Create a Per-Process Timer
> diff --git a/cpukit/posix/src/psxtimerdelete.c
> b/cpukit/posix/src/psxtimerdelete.c
> index c55697fcf1..c39f2b0e12 100644
> --- a/cpukit/posix/src/psxtimerdelete.c
> +++ b/cpukit/posix/src/psxtimerdelete.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Deletes a POSIX Interval Timer
> * @ingroup POSIXAPI
> + * @brief Deletes a POSIX Interval Timer
> diff --git a/cpukit/posix/src/psxtransschedparam.c
> b/cpukit/posix/src/psxtransschedparam.c
> index f3842457fa..6fa7a43886 100644
> --- a/cpukit/posix/src/psxtransschedparam.c
> +++ b/cpukit/posix/src/psxtransschedparam.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Translate sched_param into SuperCore Terms
> * @ingroup POSIX_PTHREAD Private POSIX Threads
> + * @brief Translate sched_param into SuperCore Terms
> diff --git a/cpukit/posix/src/pthread.c b/cpukit/posix/src/pthread.c
> index 7e861a3d6b..790519ad9b 100644
> --- a/cpukit/posix/src/pthread.c
> +++ b/cpukit/posix/src/pthread.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Private Support Information for POSIX Threads
> * @ingroup POSIX_PTHREADS Private Threads
> + * @brief Private Support Information for POSIX Threads
> diff --git a/cpukit/posix/src/pthreadattrdefault.c
> b/cpukit/posix/src/pthreadattrdefault.c
> index 4b573d08fd..df87b9904e 100644
> --- a/cpukit/posix/src/pthreadattrdefault.c
> +++ b/cpukit/posix/src/pthreadattrdefault.c
> @@ -1,8 +1,9 @@
> * @file
> diff --git a/cpukit/posix/src/pthreadattrdestroy.c
> b/cpukit/posix/src/pthreadattrdestroy.c
> index cb4837e9c9..7232be7b43 100644
> --- a/cpukit/posix/src/pthreadattrdestroy.c
> +++ b/cpukit/posix/src/pthreadattrdestroy.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Thread Creation Attributes
> * @ingroup POSIXAPI
> + * @brief Thread Creation Attributes
> diff --git a/cpukit/posix/src/pthreadattrgetaffinitynp.c
> b/cpukit/posix/src/pthreadattrgetaffinitynp.c
> index b0fae65348..3ab917bae0 100644
> --- a/cpukit/posix/src/pthreadattrgetaffinitynp.c
> +++ b/cpukit/posix/src/pthreadattrgetaffinitynp.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Pthread Attribute Get Affinity
> * @ingroup POSIXAPI
> + * @brief Pthread Attribute Get Affinity
> diff --git a/cpukit/posix/src/pthreadattrgetdetachstate.c
> b/cpukit/posix/src/pthreadattrgetdetachstate.c
> index 18c214b996..46ad6d2ee7 100644
> --- a/cpukit/posix/src/pthreadattrgetdetachstate.c
> +++ b/cpukit/posix/src/pthreadattrgetdetachstate.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Function gets the detachstate Attribute in the attr Object
> * @ingroup POSIXAPI
> + * @brief Function gets the detachstate Attribute in the attr Object
> diff --git a/cpukit/posix/src/pthreadattrgetguardsize.c
> b/cpukit/posix/src/pthreadattrgetguardsize.c
> index a5e9a31011..638d104b25 100644
> --- a/cpukit/posix/src/pthreadattrgetguardsize.c
> +++ b/cpukit/posix/src/pthreadattrgetguardsize.c
> @@ -1,8 +1,9 @@
> * @file
> * @ingroup POSIXAPI
> diff --git a/cpukit/posix/src/pthreadattrgetinheritsched.c
> b/cpukit/posix/src/pthreadattrgetinheritsched.c
> index 6be61defa6..745bde2e6d 100644
> --- a/cpukit/posix/src/pthreadattrgetinheritsched.c
> +++ b/cpukit/posix/src/pthreadattrgetinheritsched.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Thread Creation Scheduling Attributes
> * @ingroup POSIXAPI
> + * @brief Thread Creation Scheduling Attributes
> diff --git a/cpukit/posix/src/pthreadattrgetschedparam.c
> b/cpukit/posix/src/pthreadattrgetschedparam.c
> index e1a1a79da1..b5b990f88a 100644
> --- a/cpukit/posix/src/pthreadattrgetschedparam.c
> +++ b/cpukit/posix/src/pthreadattrgetschedparam.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Returns Scheduling Parameter Attributes of Thread Attributes
> Object
> * @ingroup POSIXAPI
> + * @brief Returns Scheduling Parameter Attributes of Thread Attributes
> Object
> diff --git a/cpukit/posix/src/pthreadattrgetscope.c
> b/cpukit/posix/src/pthreadattrgetscope.c
> index c7eff2361b..2d04ad003e 100644
> --- a/cpukit/posix/src/pthreadattrgetscope.c
> +++ b/cpukit/posix/src/pthreadattrgetscope.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Function gets the Contentionscope Attribute in the attr object
> * @ingroup POSIXAPI
> + * @brief Function gets the Contentionscope Attribute in the attr object
> diff --git a/cpukit/posix/src/pthreadattrgetstack.c
> b/cpukit/posix/src/pthreadattrgetstack.c
> index 719a535915..306d618c65 100644
> --- a/cpukit/posix/src/pthreadattrgetstack.c
> +++ b/cpukit/posix/src/pthreadattrgetstack.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Function Gets the Thread Creation Stack Attributes in the attr
> * @ingroup POSIXAPI
> + * @brief Function Gets the Thread Creation Stack Attributes in the attr
> diff --git a/cpukit/posix/src/pthreadattrgetstackaddr.c
> b/cpukit/posix/src/pthreadattrgetstackaddr.c
> index 9da944a72c..dfc7156e99 100644
> --- a/cpukit/posix/src/pthreadattrgetstackaddr.c
> +++ b/cpukit/posix/src/pthreadattrgetstackaddr.c
> @@ -1,8 +1,9 @@
> * @file
> * @ingroup POSIXAPI
> diff --git a/cpukit/posix/src/pthreadattrgetstacksize.c
> b/cpukit/posix/src/pthreadattrgetstacksize.c
> index e939205fa2..7729637f48 100644
> --- a/cpukit/posix/src/pthreadattrgetstacksize.c
> +++ b/cpukit/posix/src/pthreadattrgetstacksize.c
> @@ -1,8 +1,9 @@
> * @file
> * @ingroup POSIXAPI
> diff --git a/cpukit/posix/src/pthreadattrinit.c
> b/cpukit/posix/src/pthreadattrinit.c
> index d0694eb7d7..fe893c390b 100644
> --- a/cpukit/posix/src/pthreadattrinit.c
> +++ b/cpukit/posix/src/pthreadattrinit.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Thread Attributes Creation
> * @ingroup POSIXAPI
> + * @brief Thread Attributes Creation
> diff --git a/cpukit/posix/src/pthreadattrsetaffinitynp.c
> b/cpukit/posix/src/pthreadattrsetaffinitynp.c
> index 30703fa663..1f72e94803 100644
> --- a/cpukit/posix/src/pthreadattrsetaffinitynp.c
> +++ b/cpukit/posix/src/pthreadattrsetaffinitynp.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Pthread Attribute Set Affinity
> * @ingroup POSIXAPI
> + * @brief Pthread Attribute Set Affinity
> diff --git a/cpukit/posix/src/pthreadattrsetdetachstate.c
> b/cpukit/posix/src/pthreadattrsetdetachstate.c
> index d6ca32eebb..90c949ec69 100644
> --- a/cpukit/posix/src/pthreadattrsetdetachstate.c
> +++ b/cpukit/posix/src/pthreadattrsetdetachstate.c
> @@ -1,8 +1,9 @@
> * @file
> * @ingroup POSIXAPI
> diff --git a/cpukit/posix/src/pthreadattrsetguardsize.c
> b/cpukit/posix/src/pthreadattrsetguardsize.c
> index 3e92fa5bc5..011f37aa57 100644
> --- a/cpukit/posix/src/pthreadattrsetguardsize.c
> +++ b/cpukit/posix/src/pthreadattrsetguardsize.c
> @@ -1,8 +1,9 @@
> * @file
> * @ingroup POSIXAPI
> diff --git a/cpukit/posix/src/pthreadattrsetinheritsched.c
> b/cpukit/posix/src/pthreadattrsetinheritsched.c
> index 0cc11f2b13..3b57d8a039 100644
> --- a/cpukit/posix/src/pthreadattrsetinheritsched.c
> +++ b/cpukit/posix/src/pthreadattrsetinheritsched.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Function sets the inheritsched Attribute in the attr Argument
> * @ingroup POSIXAPI
> + * @brief Function sets the inheritsched Attribute in the attr Argument
> diff --git a/cpukit/posix/src/pthreadattrsetschedparam.c
> b/cpukit/posix/src/pthreadattrsetschedparam.c
> index c3e6b4a7f3..5d29be7056 100644
> --- a/cpukit/posix/src/pthreadattrsetschedparam.c
> +++ b/cpukit/posix/src/pthreadattrsetschedparam.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Thread Creation Scheduling Parameters
> * @ingroup POSIXAPI
> + * @brief Thread Creation Scheduling Parameters
> diff --git a/cpukit/posix/src/pthreadattrsetschedpolicy.c
> b/cpukit/posix/src/pthreadattrsetschedpolicy.c
> index cd72164ef2..101838ff83 100644
> --- a/cpukit/posix/src/pthreadattrsetschedpolicy.c
> +++ b/cpukit/posix/src/pthreadattrsetschedpolicy.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Sets Scheduling policy Attributes of Thread Attributes Object
> * @ingroup POSIXAPI
> + * @brief Sets Scheduling policy Attributes of Thread Attributes Object
> diff --git a/cpukit/posix/src/pthreadattrsetscope.c
> b/cpukit/posix/src/pthreadattrsetscope.c
> index bdbc64d0f1..f68461b208 100644
> --- a/cpukit/posix/src/pthreadattrsetscope.c
> +++ b/cpukit/posix/src/pthreadattrsetscope.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Function Sets the Contentionscope Attribute in the attr Object
> * @ingroup POSIXAPI
> + * @brief Function Sets the Contentionscope Attribute in the attr Object
> diff --git a/cpukit/posix/src/pthreadattrsetstack.c
> b/cpukit/posix/src/pthreadattrsetstack.c
> index b95d0484ea..866dca8ae4 100644
> --- a/cpukit/posix/src/pthreadattrsetstack.c
> +++ b/cpukit/posix/src/pthreadattrsetstack.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Function Sets Thread Creation Stack Attributes in the attr
> object
> * @ingroup POSIXAPI
> + * @brief Function Sets Thread Creation Stack Attributes in the attr
> object
> diff --git a/cpukit/posix/src/pthreadattrsetstackaddr.c
> b/cpukit/posix/src/pthreadattrsetstackaddr.c
> index 5221080e9b..e38c302947 100644
> --- a/cpukit/posix/src/pthreadattrsetstackaddr.c
> +++ b/cpukit/posix/src/pthreadattrsetstackaddr.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Sets the Thread Creation stackaddr Attribute in the attr Object
> * @ingroup POSIXAPI
> + * @brief Sets the Thread Creation stackaddr Attribute in the attr Object
> diff --git a/cpukit/posix/src/pthreadattrsetstacksize.c
> b/cpukit/posix/src/pthreadattrsetstacksize.c
> index 2039da6d85..736c8122fd 100644
> --- a/cpukit/posix/src/pthreadattrsetstacksize.c
> +++ b/cpukit/posix/src/pthreadattrsetstacksize.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Sets the Thread Creation Stacksize Attribute in the attr object
> * @ingroup POSIXAPI
> + * @brief Sets the Thread Creation Stacksize Attribute in the attr object
> diff --git a/cpukit/posix/src/pthreadconcurrency.c
> b/cpukit/posix/src/pthreadconcurrency.c
> index be5d754a9e..b55ce10a65 100644
> --- a/cpukit/posix/src/pthreadconcurrency.c
> +++ b/cpukit/posix/src/pthreadconcurrency.c
> @@ -5,9 +5,10 @@
> * @file
> - * @brief Pthread Get/Set Concurrency
> * @ingroup POSIXAPI
> + * @brief Pthread Get/Set Concurrency
> * Per the Open Group specification, when user pthreads are mapped 1:1
> * onto kernel threads, the implementation simply tracks an internal
> * variable whose initial value is 0. If it is set, subsequent calls to
> diff --git a/cpukit/posix/src/pthreadcreate.c
> b/cpukit/posix/src/pthreadcreate.c
> index 03899758ee..33c5f8d03a 100644
> --- a/cpukit/posix/src/pthreadcreate.c
> +++ b/cpukit/posix/src/pthreadcreate.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Function Starts a New Thread in The Calling Process
> * @ingroup POSIXAPI
> + * @brief Function Starts a New Thread in The Calling Process
> diff --git a/cpukit/posix/src/pthreaddetach.c
> b/cpukit/posix/src/pthreaddetach.c
> index f316f65917..43fd70a5ce 100644
> --- a/cpukit/posix/src/pthreaddetach.c
> +++ b/cpukit/posix/src/pthreaddetach.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Detaching a Thread
> * @ingroup POSIXAPI
> + * @brief Detaching a Thread
> diff --git a/cpukit/posix/src/pthreadequal.c
> b/cpukit/posix/src/pthreadequal.c
> index d0b0f13baa..c0318baa93 100644
> --- a/cpukit/posix/src/pthreadequal.c
> +++ b/cpukit/posix/src/pthreadequal.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Compare Thread IDs
> * @ingroup POSIXAPI
> + * @brief Compare Thread IDs
> diff --git a/cpukit/posix/src/pthreadexit.c
> b/cpukit/posix/src/pthreadexit.c
> index 92a853e802..502476d141 100644
> --- a/cpukit/posix/src/pthreadexit.c
> +++ b/cpukit/posix/src/pthreadexit.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief POSIX Thread Exit Shared Helper
> * @ingroup POSIX_THREAD Thread API Extension
> + * @brief POSIX Thread Exit Shared Helper
> diff --git a/cpukit/posix/src/pthreadgetaffinitynp.c
> b/cpukit/posix/src/pthreadgetaffinitynp.c
> index 5324bfdc73..977f82c69b 100644
> --- a/cpukit/posix/src/pthreadgetaffinitynp.c
> +++ b/cpukit/posix/src/pthreadgetaffinitynp.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Pthread Get Affinity
> * @ingroup POSIXAPI
> + * @brief Pthread Get Affinity
> diff --git a/cpukit/posix/src/pthreadgetattrnp.c
> b/cpukit/posix/src/pthreadgetattrnp.c
> index 44c0edf0f0..a449ad48eb 100644
> --- a/cpukit/posix/src/pthreadgetattrnp.c
> +++ b/cpukit/posix/src/pthreadgetattrnp.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Pthread Get Attribute
> * @ingroup POSIXAPI
> + * @brief Pthread Get Attribute
> diff --git a/cpukit/posix/src/pthreadgetcpuclockid.c
> b/cpukit/posix/src/pthreadgetcpuclockid.c
> index b92fcdd7db..1452774a35 100644
> --- a/cpukit/posix/src/pthreadgetcpuclockid.c
> +++ b/cpukit/posix/src/pthreadgetcpuclockid.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Returns Clock ID for CPU time clock of the thread
> * @ingroup POSIXAPI
> + * @brief Returns Clock ID for CPU time clock of the thread
> diff --git a/cpukit/posix/src/pthreadgetschedparam.c
> b/cpukit/posix/src/pthreadgetschedparam.c
> index 0e9cc31ee2..a82d79c715 100644
> --- a/cpukit/posix/src/pthreadgetschedparam.c
> +++ b/cpukit/posix/src/pthreadgetschedparam.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Gets Scheduling Policy and Parameters of Individual Threads
> * @ingroup POSIXAPI
> + * @brief Gets Scheduling Policy and Parameters of Individual Threads
> diff --git a/cpukit/posix/src/pthreadinitthreads.c
> b/cpukit/posix/src/pthreadinitthreads.c
> index 4f08a72ffb..a144d10bf3 100644
> --- a/cpukit/posix/src/pthreadinitthreads.c
> +++ b/cpukit/posix/src/pthreadinitthreads.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief POSIX Threads Initialize User Threads Body
> + * @brief POSIX Threads Initialize User Threads Body
> diff --git a/cpukit/posix/src/pthreadjoin.c
> b/cpukit/posix/src/pthreadjoin.c
> index 383484183a..2cb0903367 100644
> --- a/cpukit/posix/src/pthreadjoin.c
> +++ b/cpukit/posix/src/pthreadjoin.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Suspends Execution of Calling Thread until Target Thread
> Terminates
> * @ingroup POSIXAPI
> + * @brief Suspends Execution of Calling Thread until Target Thread
> Terminates
> diff --git a/cpukit/posix/src/pthreadkill.c
> b/cpukit/posix/src/pthreadkill.c
> index a3a74cfacf..f39640e6db 100644
> --- a/cpukit/posix/src/pthreadkill.c
> +++ b/cpukit/posix/src/pthreadkill.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Sends a signal Asynchronously directed to a thread
> * @ingroup POSIXAPI
> + * @brief Sends a signal Asynchronously directed to a thread
> diff --git a/cpukit/posix/src/pthreadonce.c
> b/cpukit/posix/src/pthreadonce.c
> index b766926976..3210a1ab7f 100644
> --- a/cpukit/posix/src/pthreadonce.c
> +++ b/cpukit/posix/src/pthreadonce.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Call to function by Thread will call init_routine with no
> Arguments
> * @ingroup POSIXAPI
> + * @brief Call to function by Thread will call init_routine with no
> Arguments
> diff --git a/cpukit/posix/src/pthreadself.c
> b/cpukit/posix/src/pthreadself.c
> index 3cc161ff03..db5f2f189d 100644
> --- a/cpukit/posix/src/pthreadself.c
> +++ b/cpukit/posix/src/pthreadself.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Function returns the ID of the Calling Thread
> * @ingroup POSIXAPI
> + * @brief Function returns the ID of the Calling Thread
> diff --git a/cpukit/posix/src/pthreadsetaffinitynp.c
> b/cpukit/posix/src/pthreadsetaffinitynp.c
> index c2071720f0..ae91d135e1 100644
> --- a/cpukit/posix/src/pthreadsetaffinitynp.c
> +++ b/cpukit/posix/src/pthreadsetaffinitynp.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Pthread Set Affinity
> * @ingroup POSIXAPI
> + * @brief Pthread Set Affinity
> diff --git a/cpukit/posix/src/pthreadsetschedparam.c
> b/cpukit/posix/src/pthreadsetschedparam.c
> index 51dee9bca9..9ab543cd31 100644
> --- a/cpukit/posix/src/pthreadsetschedparam.c
> +++ b/cpukit/posix/src/pthreadsetschedparam.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Function sets scheduling policy and parameters of the thread
> * @ingroup POSIXAPI
> + * @brief Function sets scheduling policy and parameters of the thread
> diff --git a/cpukit/posix/src/pthreadsigmask.c
> b/cpukit/posix/src/pthreadsigmask.c
> index a989cb109b..c82a60c560 100644
> --- a/cpukit/posix/src/pthreadsigmask.c
> +++ b/cpukit/posix/src/pthreadsigmask.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Examine and/or change the calling thread's signal mask
> * @ingroup POSIXAPI
> + * @brief Examine and/or change the calling thread's signal mask
> diff --git a/cpukit/posix/src/rwlockattrdestroy.c
> b/cpukit/posix/src/rwlockattrdestroy.c
> index 3b7639445d..f8a2beb49c 100644
> --- a/cpukit/posix/src/rwlockattrdestroy.c
> +++ b/cpukit/posix/src/rwlockattrdestroy.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Function Destroys a read-write lock Attributes object
> * @ingroup POSIXAPI
> + * @brief Function Destroys a read-write lock Attributes object
> diff --git a/cpukit/posix/src/rwlockattrinit.c
> b/cpukit/posix/src/rwlockattrinit.c
> index 0e37d26636..e752e8c7c6 100644
> --- a/cpukit/posix/src/rwlockattrinit.c
> +++ b/cpukit/posix/src/rwlockattrinit.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Initialises a RWLock Attributes object attr with the default
> value
> * @ingroup POSIXAPI
> + * @brief Initialises a RWLock Attributes object attr with the default
> value
> diff --git a/cpukit/posix/src/rwlockattrsetpshared.c
> b/cpukit/posix/src/rwlockattrsetpshared.c
> index 99ae0efd10..a65c4152ff 100644
> --- a/cpukit/posix/src/rwlockattrsetpshared.c
> +++ b/cpukit/posix/src/rwlockattrsetpshared.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief RWLock Attributes Set Process Shared
> * @ingroup POSIXAPI
> + * @brief RWLock Attributes Set Process Shared
> diff --git a/cpukit/posix/src/sched_getparam.c
> b/cpukit/posix/src/sched_getparam.c
> index c84b6fdf2d..7db0c44377 100644
> --- a/cpukit/posix/src/sched_getparam.c
> +++ b/cpukit/posix/src/sched_getparam.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Set Scheduling Parameters
> * @ingroup POSIXAPI
> + * @brief Set Scheduling Parameters
> diff --git a/cpukit/posix/src/sched_getprioritymax.c
> b/cpukit/posix/src/sched_getprioritymax.c
> index ff7f4b4885..14acd16d82 100644
> --- a/cpukit/posix/src/sched_getprioritymax.c
> +++ b/cpukit/posix/src/sched_getprioritymax.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Returns the Appropriate Maximum for Scheduling policy
> * @ingroup POSIXAPI
> + * @brief Returns the Appropriate Maximum for Scheduling policy
> diff --git a/cpukit/posix/src/sched_getscheduler.c
> b/cpukit/posix/src/sched_getscheduler.c
> index 6762aa79a6..b176d170b9 100644
> --- a/cpukit/posix/src/sched_getscheduler.c
> +++ b/cpukit/posix/src/sched_getscheduler.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Function Returns Scheduling Policy of the process specified by
> pid
> * @ingroup POSIXAPI
> + * @brief Function Returns Scheduling Policy of the process specified by
> pid
> diff --git a/cpukit/posix/src/sched_rr_get_interval.c
> b/cpukit/posix/src/sched_rr_get_interval.c
> index 97186a3f74..e307985044 100644
> --- a/cpukit/posix/src/sched_rr_get_interval.c
> +++ b/cpukit/posix/src/sched_rr_get_interval.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Limits for Scheduling Parameter
> * @ingroup POSIXAPI
> + * @brief Limits for Scheduling Parameter
> diff --git a/cpukit/posix/src/sched_setparam.c
> b/cpukit/posix/src/sched_setparam.c
> index c917500edb..4aa56ec0f8 100644
> --- a/cpukit/posix/src/sched_setparam.c
> +++ b/cpukit/posix/src/sched_setparam.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Sets Scheduling Parameters Associated with Scheduling Policies
> * @ingroup POSIXAPI
> + * @brief Sets Scheduling Parameters Associated with Scheduling Policies
> diff --git a/cpukit/posix/src/sched_setscheduler.c
> b/cpukit/posix/src/sched_setscheduler.c
> index 73036e65d3..49c77119f9 100644
> --- a/cpukit/posix/src/sched_setscheduler.c
> +++ b/cpukit/posix/src/sched_setscheduler.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Set Scheduling Policy and Scheduling Parameters
> * @ingroup POSIXAPI
> + * @brief Set Scheduling Policy and Scheduling Parameters
> diff --git a/cpukit/posix/src/sched_yield.c
> b/cpukit/posix/src/sched_yield.c
> index 34242b759b..1f3be3654b 100644
> --- a/cpukit/posix/src/sched_yield.c
> +++ b/cpukit/posix/src/sched_yield.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Yield Processor
> * @ingroup POSIXAPI
> + * @brief Yield Processor
> diff --git a/cpukit/posix/src/semclose.c b/cpukit/posix/src/semclose.c
> index 79c5861db0..432ab1aafa 100644
> --- a/cpukit/posix/src/semclose.c
> +++ b/cpukit/posix/src/semclose.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Close a Named Semaphore
> * @ingroup POSIX_SEMAPHORE
> + * @brief Close a Named Semaphore
> diff --git a/cpukit/posix/src/semgetvalue.c
> b/cpukit/posix/src/semgetvalue.c
> index 1e2670dd25..1389027cc7 100644
> --- a/cpukit/posix/src/semgetvalue.c
> +++ b/cpukit/posix/src/semgetvalue.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Get the Value of a Semaphore
> + * @brief Get the Value of a Semaphore
> diff --git a/cpukit/posix/src/seminit.c b/cpukit/posix/src/seminit.c
> index 09fc95f7a3..447d48749e 100644
> --- a/cpukit/posix/src/seminit.c
> +++ b/cpukit/posix/src/seminit.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Initializing of an Unnamed Semaphore
> * @ingroup POSIXAPI
> + * @brief Initializing of an Unnamed Semaphore
> diff --git a/cpukit/posix/src/semopen.c b/cpukit/posix/src/semopen.c
> index 97c513ec3a..3691add324 100644
> --- a/cpukit/posix/src/semopen.c
> +++ b/cpukit/posix/src/semopen.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Function Creates New POSIX semaphore or Opens an existing
> Semaphore
> * @ingroup POSIXAPI
> + * @brief Function Creates New POSIX semaphore or Opens an existing
> Semaphore
> diff --git a/cpukit/posix/src/semtimedwait.c
> b/cpukit/posix/src/semtimedwait.c
> index b2057016c5..21a8320b50 100644
> --- a/cpukit/posix/src/semtimedwait.c
> +++ b/cpukit/posix/src/semtimedwait.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Lock a Semaphore
> * @ingroup POSIX_SEMAPHORE POSIX Semaphores Support
> + * @brief Lock a Semaphore
> diff --git a/cpukit/posix/src/semunlink.c b/cpukit/posix/src/semunlink.c
> index 021cee3343..3d73ab5887 100644
> --- a/cpukit/posix/src/semunlink.c
> +++ b/cpukit/posix/src/semunlink.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Remove a Named Semaphore
> + * @brief Remove a Named Semaphore
> diff --git a/cpukit/posix/src/setcancelstate.c
> b/cpukit/posix/src/setcancelstate.c
> index 4040c37b55..2227321e07 100644
> --- a/cpukit/posix/src/setcancelstate.c
> +++ b/cpukit/posix/src/setcancelstate.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Setting Cancelability State
> * @ingroup POSIXAPI
> + * @brief Setting Cancelability State
> diff --git a/cpukit/posix/src/setcanceltype.c
> b/cpukit/posix/src/setcanceltype.c
> index 302f901a74..4a7a7e3486 100644
> --- a/cpukit/posix/src/setcanceltype.c
> +++ b/cpukit/posix/src/setcanceltype.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Sets the Cancelability Type of Calling Thread to value given in
> type
> * @ingroup POSIXAPI
> + * @brief Sets the Cancelability Type of Calling Thread to value given in
> type
> diff --git a/cpukit/posix/src/setitimer.c b/cpukit/posix/src/setitimer.c
> index 02aeb320c7..3cb04db018 100644
> --- a/cpukit/posix/src/setitimer.c
> +++ b/cpukit/posix/src/setitimer.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Set the Timer
> * @ingroup POSIXAPI
> + * @brief Set the Timer
> diff --git a/cpukit/posix/src/sigaction.c b/cpukit/posix/src/sigaction.c
> index 86d66480fc..112360af0d 100644
> --- a/cpukit/posix/src/sigaction.c
> +++ b/cpukit/posix/src/sigaction.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Allows calling process to examine action of a Specific Signal
> * @ingroup POSIXAPI
> + * @brief Allows calling process to examine action of a Specific Signal
> diff --git a/cpukit/posix/src/sigaddset.c b/cpukit/posix/src/sigaddset.c
> index 2dc17cd6b6..c9394f4c20 100644
> --- a/cpukit/posix/src/sigaddset.c
> +++ b/cpukit/posix/src/sigaddset.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Function Adds Signal from Set
> * @ingroup POSIXAPI
> + * @brief Function Adds Signal from Set
> diff --git a/cpukit/posix/src/sigdelset.c b/cpukit/posix/src/sigdelset.c
> index 20f91e6ecf..991023ac9e 100644
> --- a/cpukit/posix/src/sigdelset.c
> +++ b/cpukit/posix/src/sigdelset.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Deleted Signal from Set
> * @ingroup POSIXAPI
> + * @brief Deleted Signal from Set
> diff --git a/cpukit/posix/src/sigemptyset.c
> b/cpukit/posix/src/sigemptyset.c
> index 50e24daa59..d64d4cd42a 100644
> --- a/cpukit/posix/src/sigemptyset.c
> +++ b/cpukit/posix/src/sigemptyset.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Manipulate Signal Sets
> * @ingroup POSIXAPI
> + * @brief Manipulate Signal Sets
> diff --git a/cpukit/posix/src/sigfillset.c b/cpukit/posix/src/sigfillset.c
> index 6adc372775..334a81f5ad 100644
> --- a/cpukit/posix/src/sigfillset.c
> +++ b/cpukit/posix/src/sigfillset.c
> @@ -1,8 +1,9 @@
> * @file
> * @ingroup POSIXAPI
> diff --git a/cpukit/posix/src/sigismember.c
> b/cpukit/posix/src/sigismember.c
> index 9928e18e6f..c7ddeda433 100644
> --- a/cpukit/posix/src/sigismember.c
> +++ b/cpukit/posix/src/sigismember.c
> @@ -1,8 +1,9 @@
> * @file
> * @ingroup POSIXAPI
> diff --git a/cpukit/posix/src/signal_2.c b/cpukit/posix/src/signal_2.c
> index bd891e22ee..a98430ebf3 100644
> --- a/cpukit/posix/src/signal_2.c
> +++ b/cpukit/posix/src/signal_2.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief POSIX Function Installs signal Handler
> * @ingroup POSIXAPI
> + * @brief POSIX Function Installs signal Handler
> diff --git a/cpukit/posix/src/sigpending.c b/cpukit/posix/src/sigpending.c
> index d65fe0586f..7b8e9e0d9a 100644
> --- a/cpukit/posix/src/sigpending.c
> +++ b/cpukit/posix/src/sigpending.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Examine Pending Signals
> * @ingroup POSIXAPI
> + * @brief Examine Pending Signals
> diff --git a/cpukit/posix/src/sigprocmask.c
> b/cpukit/posix/src/sigprocmask.c
> index 235a58c52c..db923d3af0 100644
> --- a/cpukit/posix/src/sigprocmask.c
> +++ b/cpukit/posix/src/sigprocmask.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Examine and Change Blocked Signals
> * @ingroup POSIXAPI
> + * @brief Examine and Change Blocked Signals
> diff --git a/cpukit/posix/src/sigqueue.c b/cpukit/posix/src/sigqueue.c
> index 5446ca9701..dadf70abd3 100644
> --- a/cpukit/posix/src/sigqueue.c
> +++ b/cpukit/posix/src/sigqueue.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Queue a Signal to a Process
> * @ingroup POSIXAPI
> + * @brief Queue a Signal to a Process
> diff --git a/cpukit/posix/src/sigsuspend.c b/cpukit/posix/src/sigsuspend.c
> index 79c93fc457..b8dc191d15 100644
> --- a/cpukit/posix/src/sigsuspend.c
> +++ b/cpukit/posix/src/sigsuspend.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Replacing signal mask with *sigmask and suspending calling
> process
> * @ingroup POSIXAPI
> + * @brief Replacing signal mask with *sigmask and suspending calling
> process
> diff --git a/cpukit/posix/src/sigwait.c b/cpukit/posix/src/sigwait.c
> index 3b07cc2c49..b247503b5d 100644
> --- a/cpukit/posix/src/sigwait.c
> +++ b/cpukit/posix/src/sigwait.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Synchronously Accept a Signal
> * @ingroup POSIXAPI
> + * @brief Synchronously Accept a Signal
> diff --git a/cpukit/posix/src/sysconf.c b/cpukit/posix/src/sysconf.c
> index f905a82f07..1696ec51bb 100644
> --- a/cpukit/posix/src/sysconf.c
> +++ b/cpukit/posix/src/sysconf.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Get Configurable System Variables
> * @ingroup POSIXAPI
> + * @brief Get Configurable System Variables
> diff --git a/cpukit/posix/src/testcancel.c b/cpukit/posix/src/testcancel.c
> index 0d6471f818..e0ead6e323 100644
> --- a/cpukit/posix/src/testcancel.c
> +++ b/cpukit/posix/src/testcancel.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Setting test on Cancelability State
> * @ingroup POSIXAPI
> + * @brief Setting test on Cancelability State
> diff --git a/cpukit/posix/src/timergettime.c
> b/cpukit/posix/src/timergettime.c
> index 4b884b8cbb..ee2a566f0e 100644
> --- a/cpukit/posix/src/timergettime.c
> +++ b/cpukit/posix/src/timergettime.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Function Fetches State of POSIX Per-Process Timers
> * @ingroup POSIXAPI
> + * @brief Function Fetches State of POSIX Per-Process Timers
> diff --git a/cpukit/posix/src/timersettime.c
> b/cpukit/posix/src/timersettime.c
> index b83c8b07c9..f88485410e 100644
> --- a/cpukit/posix/src/timersettime.c
> +++ b/cpukit/posix/src/timersettime.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Function Arms or Disarms the Timer Identified by timerid
> * @ingroup POSIXAPI
> + * @brief Function Arms or Disarms the Timer Identified by timerid
> diff --git a/cpukit/posix/src/ualarm.c b/cpukit/posix/src/ualarm.c
> index 292ae36e2e..857f8ce881 100644
> --- a/cpukit/posix/src/ualarm.c
> +++ b/cpukit/posix/src/ualarm.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Schedule Alarm
> * @ingroup POSIXAPI
> + * @brief Schedule Alarm
> diff --git a/cpukit/posix/src/vfork.c b/cpukit/posix/src/vfork.c
> index 6483d1961a..3a62efbb23 100644
> --- a/cpukit/posix/src/vfork.c
> +++ b/cpukit/posix/src/vfork.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Creates Child process Of The Calling process
> * @ingroup POSIXAPI
> + * @brief Creates Child process Of The Calling process
> diff --git a/cpukit/posix/src/wait.c b/cpukit/posix/src/wait.c
> index da248c9870..fe48b71e9c 100644
> --- a/cpukit/posix/src/wait.c
> +++ b/cpukit/posix/src/wait.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Wait for Process to Change State
> * @ingroup POSIXAPI
> + * @brief Wait for Process to Change State
> diff --git a/cpukit/rtems/src/barriercreate.c
> b/cpukit/rtems/src/barriercreate.c
> index a4a362239b..74cedab27a 100644
> --- a/cpukit/rtems/src/barriercreate.c
> +++ b/cpukit/rtems/src/barriercreate.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief RTEMS Create Barrier
> * @ingroup ClassicBarrier Barriers
> + * @brief RTEMS Create Barrier
> diff --git a/cpukit/rtems/src/barrierrelease.c
> b/cpukit/rtems/src/barrierrelease.c
> index c4385b02fa..801c07afcb 100644
> --- a/cpukit/rtems/src/barrierrelease.c
> +++ b/cpukit/rtems/src/barrierrelease.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief RTEMS Barrier Release
> + * @brief RTEMS Barrier Release
> diff --git a/cpukit/rtems/src/clockgettod.c
> b/cpukit/rtems/src/clockgettod.c
> index f65f5e2f4b..4610c6a519 100644
> --- a/cpukit/rtems/src/clockgettod.c
> +++ b/cpukit/rtems/src/clockgettod.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Obtain Current Time of Day (Classic TOD)
> * @ingroup ClassicClock Clocks
> + * @brief Obtain Current Time of Day (Classic TOD)
> diff --git a/cpukit/rtems/src/clockgetuptime.c
> b/cpukit/rtems/src/clockgetuptime.c
> index e60f47186d..b79745b035 100644
> --- a/cpukit/rtems/src/clockgetuptime.c
> +++ b/cpukit/rtems/src/clockgetuptime.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Obtain the System Uptime
> + * @brief Obtain the System Uptime
> diff --git a/cpukit/rtems/src/clockgetuptimenanoseconds.c
> b/cpukit/rtems/src/clockgetuptimenanoseconds.c
> index 30d5cd77fa..3eb1a2daea 100644
> --- a/cpukit/rtems/src/clockgetuptimenanoseconds.c
> +++ b/cpukit/rtems/src/clockgetuptimenanoseconds.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Returns the system uptime in seconds.
> + * @brief Returns the system uptime in seconds.
> diff --git a/cpukit/rtems/src/eventreceive.c
> b/cpukit/rtems/src/eventreceive.c
> index 190ee8234d..c638ec543c 100644
> --- a/cpukit/rtems/src/eventreceive.c
> +++ b/cpukit/rtems/src/eventreceive.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Constant used to receive the set of currently pending events in
> * @ingroup ClassicEventSet Event Set
> + * @brief Constant used to receive the set of currently pending events in
> diff --git a/cpukit/rtems/src/eventseize.c b/cpukit/rtems/src/eventseize.c
> index 6c2b82da36..8230959ec0 100644
> --- a/cpukit/rtems/src/eventseize.c
> +++ b/cpukit/rtems/src/eventseize.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Event Manager Initialization
> * @ingroup ClassicEvent Events
> + * @brief Event Manager Initialization
> diff --git a/cpukit/rtems/src/msgmp.c b/cpukit/rtems/src/msgmp.c
> index 4971b94809..f49c254fbd 100644
> --- a/cpukit/rtems/src/msgmp.c
> +++ b/cpukit/rtems/src/msgmp.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Multiprocessing Support for the Message Queue Manager
> * @ingroup ClassicMsgMP Message Queue MP Support
> + * @brief Multiprocessing Support for the Message Queue Manager
> diff --git a/cpukit/rtems/src/msgqflush.c b/cpukit/rtems/src/msgqflush.c
> index 7e7442b34a..010ad0aa6d 100644
> --- a/cpukit/rtems/src/msgqflush.c
> +++ b/cpukit/rtems/src/msgqflush.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief rtems_message_queue_flush
> * @ingroup ClassicMessageQueue Message Queues
> + * @brief rtems_message_queue_flush
> diff --git a/cpukit/rtems/src/msgqgetnumberpending.c
> b/cpukit/rtems/src/msgqgetnumberpending.c
> index 0a62f724f2..0b95ca9eeb 100644
> --- a/cpukit/rtems/src/msgqgetnumberpending.c
> +++ b/cpukit/rtems/src/msgqgetnumberpending.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief RTEMS Message Queue Get Number Pending
> + * @brief RTEMS Message Queue Get Number Pending
> diff --git a/cpukit/rtems/src/msgqsend.c b/cpukit/rtems/src/msgqsend.c
> index 71a1ab492b..2ddba4d0a6 100644
> --- a/cpukit/rtems/src/msgqsend.c
> +++ b/cpukit/rtems/src/msgqsend.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief rtems_message_queue_send
> + * @brief rtems_message_queue_send
> diff --git a/cpukit/rtems/src/partcreate.c b/cpukit/rtems/src/partcreate.c
> index 9378408e5b..2aefce8067 100644
> --- a/cpukit/rtems/src/partcreate.c
> +++ b/cpukit/rtems/src/partcreate.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief RTEMS Partition Create
> * @ingroup ClassicPart Partitions
> + * @brief RTEMS Partition Create
> diff --git a/cpukit/rtems/src/partmp.c b/cpukit/rtems/src/partmp.c
> index 3d7abc1e5d..ac2b48aba4 100644
> --- a/cpukit/rtems/src/partmp.c
> +++ b/cpukit/rtems/src/partmp.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Partition_MP_Send_process_packet
> * @ingroup ClassicPartMP Partition MP Support
> + * @brief Partition_MP_Send_process_packet
> diff --git a/cpukit/rtems/src/ratemoncreate.c
> b/cpukit/rtems/src/ratemoncreate.c
> index 440b093bfa..3eff5f0716 100644
> --- a/cpukit/rtems/src/ratemoncreate.c
> +++ b/cpukit/rtems/src/ratemoncreate.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Create a Period
> * @ingroup ClassicRateMon Rate Monotonic Scheduler
> + * @brief Create a Period
> diff --git a/cpukit/rtems/src/ratemonresetall.c
> b/cpukit/rtems/src/ratemonresetall.c
> index c9e9089528..978a33ace7 100644
> --- a/cpukit/rtems/src/ratemonresetall.c
> +++ b/cpukit/rtems/src/ratemonresetall.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief rtems_rate_monotonic_reset_all_statistics
> + * @brief rtems_rate_monotonic_reset_all_statistics
> diff --git a/cpukit/rtems/src/ratemonresetstatistics.c
> b/cpukit/rtems/src/ratemonresetstatistics.c
> index 3e133a478e..4567451a18 100644
> --- a/cpukit/rtems/src/ratemonresetstatistics.c
> +++ b/cpukit/rtems/src/ratemonresetstatistics.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief RTEMS Rate Monotonic Reset Statistics
> + * @brief RTEMS Rate Monotonic Reset Statistics
> diff --git a/cpukit/rtems/src/regioncreate.c
> b/cpukit/rtems/src/regioncreate.c
> index 5d3d8a60bc..de8f165fe7 100644
> --- a/cpukit/rtems/src/regioncreate.c
> +++ b/cpukit/rtems/src/regioncreate.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief rtems_region_create
> * @ingroup ClassicRegion Regions
> + * @brief rtems_region_create
> diff --git a/cpukit/rtems/src/rtemsbuildid.c
> b/cpukit/rtems/src/rtemsbuildid.c
> index 4e7bc51e54..b8a375a33c 100644
> --- a/cpukit/rtems/src/rtemsbuildid.c
> +++ b/cpukit/rtems/src/rtemsbuildid.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Build Object Id
> * @ingroup ClassicClassInfo Object Class Information
> + * @brief Build Object Id
> diff --git a/cpukit/rtems/src/rtemsobjectapiminimumclass.c
> b/cpukit/rtems/src/rtemsobjectapiminimumclass.c
> index 820892f303..1e3501c065 100644
> --- a/cpukit/rtems/src/rtemsobjectapiminimumclass.c
> +++ b/cpukit/rtems/src/rtemsobjectapiminimumclass.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Get Lowest Valid Class Value
> + * @brief Get Lowest Valid Class Value
> diff --git a/cpukit/rtems/src/rtemsobjectidgetapi.c
> b/cpukit/rtems/src/rtemsobjectidgetapi.c
> index 6c8eb153f7..2842a82615 100644
> --- a/cpukit/rtems/src/rtemsobjectidgetapi.c
> +++ b/cpukit/rtems/src/rtemsobjectidgetapi.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Get API Portion of Object Id
> + * @brief Get API Portion of Object Id
> diff --git a/cpukit/rtems/src/rtemsobjectsetname.c
> b/cpukit/rtems/src/rtemsobjectsetname.c
> index ccdda15737..9e1b3a4039 100644
> --- a/cpukit/rtems/src/rtemsobjectsetname.c
> +++ b/cpukit/rtems/src/rtemsobjectsetname.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Set Name of Object
> + * @brief Set Name of Object
> diff --git a/cpukit/rtems/src/semcreate.c b/cpukit/rtems/src/semcreate.c
> index 10f7b33f7c..6cdd877cce 100644
> --- a/cpukit/rtems/src/semcreate.c
> +++ b/cpukit/rtems/src/semcreate.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief rtems_semaphore_create
> * @ingroup ClassicSem Semaphores
> + * @brief rtems_semaphore_create
> diff --git a/cpukit/rtems/src/semrelease.c b/cpukit/rtems/src/semrelease.c
> index 4de2543a92..e5b0e4834d 100644
> --- a/cpukit/rtems/src/semrelease.c
> +++ b/cpukit/rtems/src/semrelease.c
> @@ -1,9 +1,10 @@
> * @file
> - * @brief RTEMS Semaphore Release
> + * @brief RTEMS Semaphore Release
> * This file contains the implementation of the Classic API directive
> * rtems_semaphore_release().
> diff --git a/cpukit/rtems/src/taskgetaffinity.c
> b/cpukit/rtems/src/taskgetaffinity.c
> index ebcdab9ee3..9f4b653d4c 100644
> --- a/cpukit/rtems/src/taskgetaffinity.c
> +++ b/cpukit/rtems/src/taskgetaffinity.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief RTEMS Task Get Affinity
> * @ingroup ClassicTasks Tasks
> + * @brief RTEMS Task Get Affinity
> diff --git a/cpukit/rtems/src/taskinitusers.c
> b/cpukit/rtems/src/taskinitusers.c
> index 104cb8b880..0b23d8bc86 100644
> --- a/cpukit/rtems/src/taskinitusers.c
> +++ b/cpukit/rtems/src/taskinitusers.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief _RTEMS_tasks_Initialize_user_tasks_body
> + * @brief _RTEMS_tasks_Initialize_user_tasks_body
> diff --git a/cpukit/rtems/src/taskissuspended.c
> b/cpukit/rtems/src/taskissuspended.c
> index 2706d76269..db9850ccb1 100644
> --- a/cpukit/rtems/src/taskissuspended.c
> +++ b/cpukit/rtems/src/taskissuspended.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief rtems_task_is_suspended
> + * @brief rtems_task_is_suspended
> diff --git a/cpukit/rtems/src/taskmp.c b/cpukit/rtems/src/taskmp.c
> index c5dcb89603..525c595ae3 100644
> --- a/cpukit/rtems/src/taskmp.c
> +++ b/cpukit/rtems/src/taskmp.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief RTEMS Tasks MP Send Process Packet
> * @ingroup ClassicTaskMP Task MP Support
> + * @brief RTEMS Tasks MP Send Process Packet
> diff --git a/cpukit/rtems/src/tasksetaffinity.c
> b/cpukit/rtems/src/tasksetaffinity.c
> index 1ba8343729..826c18dca3 100644
> --- a/cpukit/rtems/src/tasksetaffinity.c
> +++ b/cpukit/rtems/src/tasksetaffinity.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief RTEMS Task Set Affinity
> + * @brief RTEMS Task Set Affinity
> diff --git a/cpukit/rtems/src/taskstart.c b/cpukit/rtems/src/taskstart.c
> index e781734bdf..247756fcb1 100644
> --- a/cpukit/rtems/src/taskstart.c
> +++ b/cpukit/rtems/src/taskstart.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief RTEMS Start Task
> + * @brief RTEMS Start Task
> diff --git a/cpukit/rtems/src/timerreset.c b/cpukit/rtems/src/timerreset.c
> index 1465952c12..683264d839 100644
> --- a/cpukit/rtems/src/timerreset.c
> +++ b/cpukit/rtems/src/timerreset.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief RTEMS Timer Reset
> * @ingroup ClassicTimer Timers
> + * @brief RTEMS Timer Reset
> diff --git a/cpukit/rtems/src/timerserverfirewhen.c
> b/cpukit/rtems/src/timerserverfirewhen.c
> index 8d62c80c58..ca3961e1e5 100644
> --- a/cpukit/rtems/src/timerserverfirewhen.c
> +++ b/cpukit/rtems/src/timerserverfirewhen.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief RTEMS Timer Server Fire When Directive
> + * @brief RTEMS Timer Server Fire When Directive
> diff --git a/cpukit/sapi/src/rbtreefind.c b/cpukit/sapi/src/rbtreefind.c
> index f58799f19f..7c8fcb8952 100644
> --- a/cpukit/sapi/src/rbtreefind.c
> +++ b/cpukit/sapi/src/rbtreefind.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Find the control structure of the tree containing the given node
> * @ingroup RTEMSScorertems_rbtree
> + * @brief Find the control structure of the tree containing the given node
> diff --git a/cpukit/score/src/coremsginsert.c
> b/cpukit/score/src/coremsginsert.c
> index e377cff9cf..850e1cd457 100644
> --- a/cpukit/score/src/coremsginsert.c
> +++ b/cpukit/score/src/coremsginsert.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Insert a Message into the Message Queue
> * @ingroup RTEMSScoreMessageQueue
> + * @brief Insert a Message into the Message Queue
> diff --git a/cpukit/score/src/corerwlock.c b/cpukit/score/src/corerwlock.c
> index 933f6c1013..068a412861 100644
> --- a/cpukit/score/src/corerwlock.c
> +++ b/cpukit/score/src/corerwlock.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief
> * @ingroup RTEMSScoreRWLock
> + * @brief
> diff --git a/cpukit/score/src/corerwlockobtainread.c
> b/cpukit/score/src/corerwlockobtainread.c
> index 3f74da98ad..ee74c3dc6d 100644
> --- a/cpukit/score/src/corerwlockobtainread.c
> +++ b/cpukit/score/src/corerwlockobtainread.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Obtain RWLock for reading
> + * @brief Obtain RWLock for reading
> diff --git a/cpukit/score/src/corerwlockobtainwrite.c
> b/cpukit/score/src/corerwlockobtainwrite.c
> index 43ab8a74c0..ea0cdabcdc 100644
> --- a/cpukit/score/src/corerwlockobtainwrite.c
> +++ b/cpukit/score/src/corerwlockobtainwrite.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief RWLock Obtain for Writing
> + * @brief RWLock Obtain for Writing
> diff --git a/cpukit/score/src/coretodadjust.c
> b/cpukit/score/src/coretodadjust.c
> index f06515447e..e58d1e5d69 100644
> --- a/cpukit/score/src/coretodadjust.c
> +++ b/cpukit/score/src/coretodadjust.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Adjust the Time of Time
> * @ingroup RTEMSScoreTOD
> + * @brief Adjust the Time of Time
> diff --git a/cpukit/score/src/coretodtickspersec.c
> b/cpukit/score/src/coretodtickspersec.c
> index d319f6f74f..107614c730 100644
> --- a/cpukit/score/src/coretodtickspersec.c
> +++ b/cpukit/score/src/coretodtickspersec.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Convert Ticks To Seconds
> + * @brief Convert Ticks To Seconds
> /* COPYRIGHT (c) 1989-2014.
> diff --git a/cpukit/score/src/interr.c b/cpukit/score/src/interr.c
> index 5908381c67..f59f352ba2 100644
> --- a/cpukit/score/src/interr.c
> +++ b/cpukit/score/src/interr.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Initiates system termination
> * @ingroup RTEMSScoreIntErr
> + * @brief Initiates system termination
> diff --git a/cpukit/score/src/mpci.c b/cpukit/score/src/mpci.c
> index 8f1b218aca..dff2338ed6 100644
> --- a/cpukit/score/src/mpci.c
> +++ b/cpukit/score/src/mpci.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Multiprocessing Communications Interface (MPCI) Handler
> * @ingroup RTEMSScoreMPCI
> + * @brief Multiprocessing Communications Interface (MPCI) Handler
> diff --git a/cpukit/score/src/mpcidefault.c
> b/cpukit/score/src/mpcidefault.c
> index 101cbcd7b6..ea3e2eaf41 100644
> --- a/cpukit/score/src/mpcidefault.c
> +++ b/cpukit/score/src/mpcidefault.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Multiprocessing Communications Interface (MPCI) Default
> Configuration
> + * @brief Multiprocessing Communications Interface (MPCI) Default
> Configuration
> diff --git a/cpukit/score/src/objectextendinformation.c
> b/cpukit/score/src/objectextendinformation.c
> index a21257d1f5..f4c96462bf 100644
> --- a/cpukit/score/src/objectextendinformation.c
> +++ b/cpukit/score/src/objectextendinformation.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Extend Set of Objects
> * @ingroup RTEMSScoreObject
> + * @brief Extend Set of Objects
> diff --git a/cpukit/score/src/objectgetnext.c
> b/cpukit/score/src/objectgetnext.c
> index eb347e8ac0..841d5aa8e2 100644
> --- a/cpukit/score/src/objectgetnext.c
> +++ b/cpukit/score/src/objectgetnext.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Get Pointer to Next Object that is Active
> + * @brief Get Pointer to Next Object that is Active
> diff --git a/cpukit/score/src/objectinitializeinformation.c
> b/cpukit/score/src/objectinitializeinformation.c
> index 910112e223..b2cb85322f 100644
> --- a/cpukit/score/src/objectinitializeinformation.c
> +++ b/cpukit/score/src/objectinitializeinformation.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Initialize Object Information
> + * @brief Initialize Object Information
> diff --git a/cpukit/score/src/objectnametoidstring.c
> b/cpukit/score/src/objectnametoidstring.c
> index 3fd4141b03..38054bface 100644
> --- a/cpukit/score/src/objectnametoidstring.c
> +++ b/cpukit/score/src/objectnametoidstring.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Object ID to Name
> + * @brief Object ID to Name
> diff --git a/cpukit/score/src/objectsetname.c
> b/cpukit/score/src/objectsetname.c
> index 30b640ed52..0808ab87af 100644
> --- a/cpukit/score/src/objectsetname.c
> +++ b/cpukit/score/src/objectsetname.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Set Objects Name
> + * @brief Set Objects Name
> diff --git a/cpukit/score/src/percpu.c b/cpukit/score/src/percpu.c
> index 9d1620907b..6aebfc2637 100644
> --- a/cpukit/score/src/percpu.c
> +++ b/cpukit/score/src/percpu.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Allocate and Initialize Per CPU Structures
> * @ingroup PerCPU
> + * @brief Allocate and Initialize Per CPU Structures
> diff --git a/cpukit/score/src/scheduler.c b/cpukit/score/src/scheduler.c
> index a48f0e4783..45c0496838 100644
> --- a/cpukit/score/src/scheduler.c
> +++ b/cpukit/score/src/scheduler.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Scheduler Initialize
> * @ingroup RTEMSScoreScheduler
> + * @brief Scheduler Initialize
> diff --git a/cpukit/score/src/schedulercbs.c
> b/cpukit/score/src/schedulercbs.c
> index 94c4f49789..12a7a76251 100644
> --- a/cpukit/score/src/schedulercbs.c
> +++ b/cpukit/score/src/schedulercbs.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief CBS Scheduler Budget Handler
> + * @brief CBS Scheduler Budget Handler
> diff --git a/cpukit/score/src/schedulercbsgetparameters.c
> b/cpukit/score/src/schedulercbsgetparameters.c
> index de27c31370..65e4965176 100644
> --- a/cpukit/score/src/schedulercbsgetparameters.c
> +++ b/cpukit/score/src/schedulercbsgetparameters.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief _Scheduler_CBS_Get_parameters
> + * @brief _Scheduler_CBS_Get_parameters
> diff --git a/cpukit/score/src/scheduleredf.c
> b/cpukit/score/src/scheduleredf.c
> index 2ffdeb8040..3b0c62c0c3 100644
> --- a/cpukit/score/src/scheduleredf.c
> +++ b/cpukit/score/src/scheduleredf.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Scheduler EDF Initialize and Support
> + * @brief Scheduler EDF Initialize and Support
> diff --git a/cpukit/score/src/scheduleredfreleasejob.c
> b/cpukit/score/src/scheduleredfreleasejob.c
> index 1f01f9cfa5..0e3e527109 100644
> --- a/cpukit/score/src/scheduleredfreleasejob.c
> +++ b/cpukit/score/src/scheduleredfreleasejob.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Scheduler EDF Release Job
> + * @brief Scheduler EDF Release Job
> diff --git a/cpukit/score/src/scheduleredfunblock.c
> b/cpukit/score/src/scheduleredfunblock.c
> index 3302a478c0..a1c45af91c 100644
> --- a/cpukit/score/src/scheduleredfunblock.c
> +++ b/cpukit/score/src/scheduleredfunblock.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Scheduler EDF Unblock
> + * @brief Scheduler EDF Unblock
> diff --git a/cpukit/score/src/schedulerpriorityblock.c
> b/cpukit/score/src/schedulerpriorityblock.c
> index 50830f6176..ae44710ea6 100644
> --- a/cpukit/score/src/schedulerpriorityblock.c
> +++ b/cpukit/score/src/schedulerpriorityblock.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Scheduler Priority Block
> + * @brief Scheduler Priority Block
> diff --git a/cpukit/score/src/schedulerpriorityschedule.c
> b/cpukit/score/src/schedulerpriorityschedule.c
> index 3e1acb07c8..7861a5861e 100644
> --- a/cpukit/score/src/schedulerpriorityschedule.c
> +++ b/cpukit/score/src/schedulerpriorityschedule.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Priority Scheduler Schedule Method
> + * @brief Priority Scheduler Schedule Method
> diff --git a/cpukit/score/src/schedulersimpleschedule.c
> b/cpukit/score/src/schedulersimpleschedule.c
> index ee17219349..a48475828c 100644
> --- a/cpukit/score/src/schedulersimpleschedule.c
> +++ b/cpukit/score/src/schedulersimpleschedule.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Simple Schedule Determine Heir
> + * @brief Simple Schedule Determine Heir
> diff --git a/cpukit/score/src/schedulersimpleunblock.c
> b/cpukit/score/src/schedulersimpleunblock.c
> index 9bc1635b3d..516b5f2675 100644
> --- a/cpukit/score/src/schedulersimpleunblock.c
> +++ b/cpukit/score/src/schedulersimpleunblock.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Scheduler Simple Handler / Unblock
> + * @brief Scheduler Simple Handler / Unblock
> diff --git a/cpukit/score/src/schedulersimpleyield.c
> b/cpukit/score/src/schedulersimpleyield.c
> index 79b3f86c37..db78660719 100644
> --- a/cpukit/score/src/schedulersimpleyield.c
> +++ b/cpukit/score/src/schedulersimpleyield.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Simple Schedule Yield CPU
> + * @brief Simple Schedule Yield CPU
> diff --git a/cpukit/score/src/threaddispatch.c
> b/cpukit/score/src/threaddispatch.c
> index b2ac57b401..c57ddb01ae 100644
> --- a/cpukit/score/src/threaddispatch.c
> +++ b/cpukit/score/src/threaddispatch.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Dispatch Thread
> * @ingroup RTEMSScoreThread
> + * @brief Dispatch Thread
> diff --git a/cpukit/score/src/threadqenqueue.c
> b/cpukit/score/src/threadqenqueue.c
> index 44fabb24c7..972736f3f2 100644
> --- a/cpukit/score/src/threadqenqueue.c
> +++ b/cpukit/score/src/threadqenqueue.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Thread Queue Operations
> * @ingroup RTEMSScoreThreadQ
> + * @brief Thread Queue Operations
> diff --git a/cpukit/score/src/threadqflush.c
> b/cpukit/score/src/threadqflush.c
> index f9303f4eec..5666aaf22c 100644
> --- a/cpukit/score/src/threadqflush.c
> +++ b/cpukit/score/src/threadqflush.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Thread Queue Flush
> + * @brief Thread Queue Flush
> diff --git a/cpukit/score/src/threadrestart.c
> b/cpukit/score/src/threadrestart.c
> index 9ecf654f3b..fcae5b1e3c 100644
> --- a/cpukit/score/src/threadrestart.c
> +++ b/cpukit/score/src/threadrestart.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Restart Thread
> + * @brief Restart Thread
> diff --git a/cpukit/score/src/timespecdivide.c
> b/cpukit/score/src/timespecdivide.c
> index a163375c92..3c075fa75f 100644
> --- a/cpukit/score/src/timespecdivide.c
> +++ b/cpukit/score/src/timespecdivide.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Divide Timespec By Integer
> * @ingroup Timespec
> + * @brief Divide Timespec By Integer
> diff --git a/cpukit/score/src/watchdoginsert.c
> b/cpukit/score/src/watchdoginsert.c
> index 5a031d3a70..766b828368 100644
> --- a/cpukit/score/src/watchdoginsert.c
> +++ b/cpukit/score/src/watchdoginsert.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Watchdog Insert
> * @ingroup RTEMSScoreWatchdog
> + * @brief Watchdog Insert
> diff --git a/cpukit/score/src/watchdogremove.c
> b/cpukit/score/src/watchdogremove.c
> index def0ef5496..44a5ea26f3 100644
> --- a/cpukit/score/src/watchdogremove.c
> +++ b/cpukit/score/src/watchdogremove.c
> @@ -1,8 +1,9 @@
> * @file
> - * @brief Remove Watchdog
> + * @brief Remove Watchdog
> 2.16.4
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200427/da730f9f/attachment-0001.html>
