Build Error while setting up RTEMS ARM BSP xilinx_zynq for qemu
Vijay Kumar Banerjee
vijay at rtems.org
Mon Apr 27 20:40:58 UTC 2020
On Tue, Apr 28, 2020 at 2:03 AM Mritunjay Sharma <
mritunjaysharma394 at gmail.com> wrote:
> Update: It is working now.
Great! Looks like the error was a basic one ( C Compiler was absent.). Most
of the
time going to the log files give a good insight of the issue.
> Thank you so much!
> On Tue, Apr 28, 2020 at 1:54 AM Mritunjay Sharma <
>> Thank you so much Vijay,
>> I am attaching the txt file as well as looking into it to find the error
and
>> solution. Thanks for the help!
>> Regards,
>> Mritunjay
>> On Tue, Apr 28, 2020 at 1:50 AM Vijay Kumar Banerjee <vijay at rtems.org>
wrote:
>>> On Tue, Apr 28, 2020, 1:45 AM Mritunjay Sharma <
>>>> Hello everyone,
>>>> This in reference to Ticket #3855 and my proposal for GSoC.
>>>> As I have already cross-compiled and built EPICS7
>>>> with RTEMS-5 for mvme6100, now I was trying to do the
>>>> same for qemu/xilinx_zynq.
>>>> However, while building with the below command:
>>>> '''../source-builder/sb-set-builder
--prefix=/home/mritunjay/development/rtems/5 \
>>>> --host=arm-rtems5 --with-rtems-bsp=xilinx_zynq_a9_qemu 5/rtems-arm'''
>>>> I encountered this error:
>>>> '''RTEMS Source Builder - Set Builder, 5 (96cdedce58e3)
>>>> Build Set: 5/rtems-arm
>>>> Build Set: 5/rtems-autotools.bset
>>>> Build Set: 5/rtems-autotools-internal.bset
>>>> config: tools/rtems-autoconf-2.69-1.cfg
>>>> package: autoconf-2.69-arm-rtems5-1
>>>> building: autoconf-2.69-arm-rtems5-1
>>>> sizes: autoconf-2.69-arm-rtems5-1: 7.501MB (installed: 0.000B)
>>>> cleaning: autoconf-2.69-arm-rtems5-1
>>>> config: tools/rtems-automake-1.12.6-1.cfg
>>>> package: automake-1.12.6-arm-rtems5-1
>>>> building: automake-1.12.6-arm-rtems5-1
>>>> sizes: automake-1.12.6-arm-rtems5-1: 8.085MB (installed: 0.000B)
>>>> cleaning: automake-1.12.6-arm-rtems5-1
>>>> Build Sizes: usage: 8.085MB total: 144.775MB (sources: 144.756MB,
patches: 19.412KB, installed 0.000B)
>>>> Build Set: Time 0:00:10.271869
>>>> Build Set: 5/rtems-autotools-base.bset
>>>> sizes: autoconf-2.69-arm-rtems5-1: 10.532MB (installed: 3.034MB)
>>>> reporting: tools/rtems-autoconf-2.69-1.cfg ->
autoconf-2.69-arm-rtems5-1.txt
autoconf-2.69-arm-rtems5-1.xml
>>>> sizes: automake-1.12.6-arm-rtems5-1: 10.348MB (installed: 2.265MB)
>>>> reporting: tools/rtems-automake-1.12.6-1.cfg ->
automake-1.12.6-arm-rtems5-1.txt
automake-1.12.6-arm-rtems5-1.xml
>>>> staging: autoconf-2.69-arm-rtems5-1 ->
/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000-staging
>>>> staging: automake-1.12.6-arm-rtems5-1 ->
>>>> Build Sizes: usage: 15.830MB total: 150.073MB (sources: 144.756MB,
patches: 19.412KB, installed 5.298MB)
>>>> Build Set: Time 0:00:13.777473
>>>> Build Set: Time 0:00:24.056142
>>>> config: devel/expat-2.1.0-1.cfg
>>>> package: expat-2.1.0-arm-rtems5-1
>>>> building: expat-2.1.0-arm-rtems5-1
>>>> error: building expat-2.1.0-arm-rtems5-1
>>>> Build FAILED
>>>> See error report: rsb-report-expat-2.1.0-arm-rtems5-1.txt
>>> Hi Mritunjay,
>>> Please see in this txt file, the error is visible there. You can attach
this file in the mail and send so we can see it and try to figure out a
solution
>>> Best regards,
>>> Vijay
>>>> Build Set: Time 0:00:24.851451
>>>> Build FAILED
>>>> Please help me if any configuration changes have to be made,
>>>> Thanks
>>>> Mritunjay
>>>> _______________________________________________
>>>> devel mailing list
>>>> devel at rtems.org
>>>> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200428/1c90cd28/attachment.html>
