Build Error while setting up RTEMS ARM BSP xilinx_zynq for qemu
Mritunjay Sharma mritunjaysharma394 at gmail.com
Mon Apr 27 20:33:33 UTC 2020
Update: It is working now.
Thank you so much!
On Tue, Apr 28, 2020 at 1:54 AM Mritunjay Sharma <
mritunjaysharma394 at gmail.com> wrote:
> Thank you so much Vijay,
> I am attaching the txt file as well as looking into it to find the error
> and
> solution. Thanks for the help!
> Regards,
> Mritunjay
> On Tue, Apr 28, 2020 at 1:50 AM Vijay Kumar Banerjee <vijay at rtems.org>
> wrote:
>> On Tue, Apr 28, 2020, 1:45 AM Mritunjay Sharma <
>>> Hello everyone,
>>> This in reference to Ticket #3855 and my proposal for GSoC.
>>> As I have already cross-compiled and built EPICS7
>>> with RTEMS-5 for mvme6100, now I was trying to do the
>>> same for qemu/xilinx_zynq.
>>> However, while building with the below command:
>>> '''../source-builder/sb-set-builder
>>> --prefix=/home/mritunjay/development/rtems/5 \
>>> --host=arm-rtems5 --with-rtems-bsp=xilinx_zynq_a9_qemu 5/rtems-arm'''
>>> I encountered this error:
>>> '''RTEMS Source Builder - Set Builder, 5 (96cdedce58e3)
>>> Build Set: 5/rtems-arm
>>> Build Set: 5/rtems-autotools.bset
>>> Build Set: 5/rtems-autotools-internal.bset
>>> config: tools/rtems-autoconf-2.69-1.cfg
>>> package: autoconf-2.69-arm-rtems5-1
>>> building: autoconf-2.69-arm-rtems5-1
>>> sizes: autoconf-2.69-arm-rtems5-1: 7.501MB (installed: 0.000B)
>>> cleaning: autoconf-2.69-arm-rtems5-1
>>> config: tools/rtems-automake-1.12.6-1.cfg
>>> package: automake-1.12.6-arm-rtems5-1
>>> building: automake-1.12.6-arm-rtems5-1
>>> sizes: automake-1.12.6-arm-rtems5-1: 8.085MB (installed: 0.000B)
>>> cleaning: automake-1.12.6-arm-rtems5-1
>>> Build Sizes: usage: 8.085MB total: 144.775MB (sources: 144.756MB,
>>> patches: 19.412KB, installed 0.000B)
>>> Build Set: Time 0:00:10.271869
>>> Build Set: 5/rtems-autotools-base.bset
>>> sizes: autoconf-2.69-arm-rtems5-1: 10.532MB (installed: 3.034MB)
>>> reporting: tools/rtems-autoconf-2.69-1.cfg ->
>>> autoconf-2.69-arm-rtems5-1.txt
>>> autoconf-2.69-arm-rtems5-1.xml
>>> sizes: automake-1.12.6-arm-rtems5-1: 10.348MB (installed: 2.265MB)
>>> reporting: tools/rtems-automake-1.12.6-1.cfg ->
>>> automake-1.12.6-arm-rtems5-1.txt
>>> automake-1.12.6-arm-rtems5-1.xml
>>> staging: autoconf-2.69-arm-rtems5-1 ->
>>> /home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000-staging
>>> staging: automake-1.12.6-arm-rtems5-1 ->
>>> Build Sizes: usage: 15.830MB total: 150.073MB (sources: 144.756MB,
>>> patches: 19.412KB, installed 5.298MB)
>>> Build Set: Time 0:00:13.777473
>>> Build Set: Time 0:00:24.056142
>>> config: devel/expat-2.1.0-1.cfg
>>> package: expat-2.1.0-arm-rtems5-1
>>> building: expat-2.1.0-arm-rtems5-1
>>> error: building expat-2.1.0-arm-rtems5-1
>>> Build FAILED
>>>   See error report: rsb-report-expat-2.1.0-arm-rtems5-1.txt
>> Hi Mritunjay,
>> Please see in this txt file, the error is visible there. You can attach
>> this file in the mail and send so we can see it and try to figure out a
>> solution
>> Best regards,
>> Vijay
>>> Build Set: Time 0:00:24.851451
>>> Build FAILED
>>> Please help me if any configuration changes have to be made,
>>> Thanks
>>> Mritunjay
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200428/bd323cee/attachment.html>
