[PATCH 0/3] Source Builder: Fixes for Python 3.8
Tue Apr 28 00:31:44 UTC 2020
On 28/4/20 5:15 am, Anders Montonen wrote:
> These patches fix some issues with Python 3.8 compatibility, which I
> encountered when trying out the new Ubuntu 20.04 release. There's also
> fixes for a number of syntax warnings which are flagged even with older
> Python versions.
Pushed. Thanks.
> The patches should not break compatibility with older Python versions,
> but I have not actually tested.
Tested on python 2.7.
> I'm not sure if the Linux distro check fix is the most elegant,
I do not know and it worked on Ubuntu LTS so I am OK with the change.
> but I
> think the whole thing should be changed to check if the required
> executables are found in the runtime path, instead of assuming some
> hard-coded locations.
I am not sure, you could be right. The original idea was to make sure
the exact binaries you want are used. Things have evolved a long way
from that place. What you suggest maybe a suitable path to follow.
Again, thanks.
