Build Error while setting up RTEMS ARM BSP xilinx_zynq for qemu
Mritunjay Sharma mritunjaysharma394 at gmail.com
Mon Apr 27 20:15:06 UTC 2020
Hello everyone,
This in reference to Ticket #3855 and my proposal for GSoC.
As I have already cross-compiled and built EPICS7
with RTEMS-5 for mvme6100, now I was trying to do the
same for qemu/xilinx_zynq.
However, while building with the below command:
'''../source-builder/sb-set-builder
--prefix=/home/mritunjay/development/rtems/5 \
--host=arm-rtems5 --with-rtems-bsp=xilinx_zynq_a9_qemu 5/rtems-arm'''
I encountered this error:
'''RTEMS Source Builder - Set Builder, 5 (96cdedce58e3)
Build Set: 5/rtems-arm
Build Set: 5/rtems-autotools.bset
Build Set: 5/rtems-autotools-internal.bset
config: tools/rtems-autoconf-2.69-1.cfg
package: autoconf-2.69-arm-rtems5-1
building: autoconf-2.69-arm-rtems5-1
sizes: autoconf-2.69-arm-rtems5-1: 7.501MB (installed: 0.000B)
cleaning: autoconf-2.69-arm-rtems5-1
config: tools/rtems-automake-1.12.6-1.cfg
package: automake-1.12.6-arm-rtems5-1
building: automake-1.12.6-arm-rtems5-1
sizes: automake-1.12.6-arm-rtems5-1: 8.085MB (installed: 0.000B)
cleaning: automake-1.12.6-arm-rtems5-1
Build Sizes: usage: 8.085MB total: 144.775MB (sources: 144.756MB, patches:
19.412KB, installed 0.000B)
Build Set: Time 0:00:10.271869
Build Set: 5/rtems-autotools-base.bset
sizes: autoconf-2.69-arm-rtems5-1: 10.532MB (installed: 3.034MB)
reporting: tools/rtems-autoconf-2.69-1.cfg -> autoconf-2.69-arm-rtems5-1.txt
reporting: tools/rtems-autoconf-2.69-1.cfg -> autoconf-2.69-arm-rtems5-1.xml
sizes: automake-1.12.6-arm-rtems5-1: 10.348MB (installed: 2.265MB)
reporting: tools/rtems-automake-1.12.6-1.cfg ->
automake-1.12.6-arm-rtems5-1.txt
automake-1.12.6-arm-rtems5-1.xml
staging: autoconf-2.69-arm-rtems5-1 ->
/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000-staging
staging: automake-1.12.6-arm-rtems5-1 ->
Build Sizes: usage: 15.830MB total: 150.073MB (sources: 144.756MB, patches:
19.412KB, installed 5.298MB)
Build Set: Time 0:00:13.777473
Build Set: Time 0:00:24.056142
config: devel/expat-2.1.0-1.cfg
package: expat-2.1.0-arm-rtems5-1
building: expat-2.1.0-arm-rtems5-1
error: building expat-2.1.0-arm-rtems5-1
Build FAILED
  See error report: rsb-report-expat-2.1.0-arm-rtems5-1.txt
Build Set: Time 0:00:24.851451
Build FAILED
Please help me if any configuration changes have to be made,
Thanks
Mritunjay
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200428/ee67f102/attachment-0001.html>
