Release task request for help
Chris Johns
chrisj at rtems.org
Tue Apr 28 02:40:24 UTC 2020
On 28/4/20 11:51 am, Niteesh G. S. wrote:
> https://github.com/gs-niteesh/rtems-release/commit/8666bcd66066512f91194660817cd42cbb8c76e9
> If it is okay for you, then I will send the patch to the mailing list.
The repos list is now just the package names and the branch script as it
is expects the repo name, i.e. .git at the end.
Also the rtems-releases repo needs to be added to the list of repos (and
not packages).
I think it would be a good idea to be able to run this script which
means a way to switch the git clone from ssh to the git protocol. I
recently added command line support to rtems-release so I suggest you
borrow that code and add an option so you can switch the git protocol
and test. I would also add a switch to push, i.e. by default a push is
not done.
After we have the branch script the tag script needs to be updated.
