writing .scn file
Eshan Dhawan
eshandhawan51 at gmail.com
Wed Apr 29 21:40:18 UTC 2020
Hello everyone,
As I changed the test framework in the
patch: https://lists.rtems.org/pipermail/devel/2020-April/059466.html
to the new T_TEST framework
and after running the test I got the output
*** BEGIN OF TEST PSXGETCPUCLOCKID 1 ***
*** TEST VERSION: 5.0.0.0c28e4e8f2768fd3cac0e7721d6f48776bbfd9e1-modified
*** TEST STATE: EXPECTED_PASS
*** TEST BUILD: RTEMS_POSIX_API
*** TEST TOOLS: 9.3.0 20200312 (RTEMS 5, RSB 5 (78c6e159d467), Newlib
7947581)
A:psxgetcpuclockid1
S:Platform:RTEMS
S:Compiler:9.3.0 20200312 (RTEMS 5, RSB 5 (78c6e159d467), Newlib 7947581)
S:Version:5.0.0.0c28e4e8f2768fd3cac0e7721d6f48776bbfd9e1-modified
S:BSP:rv32imac
S:RTEMS_DEBUG:0
S:RTEMS_MULTIPROCESSING:0
S:RTEMS_POSIX_API:1
S:RTEMS_PROFILING:0
S:RTEMS_SMP:0
B:pthread_getcpuclockid
F:*:0::init.c:124:-1 == 0, EINVAL
F:*:0::init.c:145:-1 == 0, EINVAL
F:*:0::init.c:157:1 == 0, EINVAL
F:*:0::init.c:172:3 == -1, EINVAL == ESRCH
E:pthread_getcpuclockid:N:0:F:4:D:0.502748
Z:psxgetcpuclockid1:C:1:N:0:F:4:D:0.503422
Y:ReportHash:SHA256:aa6c4c5af8748cd4750ecc7c1215deaf22cb97825ab5a61be353ca3a8e44260d
*** FATAL ***
fatal source: 5 (RTEMS_FATAL_SOURCE_EXIT)
fatal code: 0 (0x00000000)
RTEMS version: 5.0.0.0c28e4e8f2768fd3cac0e7721d6f48776bbfd9e1-modified
RTEMS tools: 9.3.0 20200312 (RTEMS 5, RSB 5 (78c6e159d467), Newlib 7947581)
executing thread ID: 0x08b010001
executing thread name:
Now what do I add in the .scn file?
Thanks
- Eshan
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200430/76c36c9c/attachment-0001.html>
