Release task request for help
Niteesh G. S. niteesh.gs at gmail.com
Thu Apr 30 06:11:28 UTC 2020
I have replied to the comment please have a look.
https://github.com/gs-niteesh/rtems-release/commit/58ed0cb3fc1f33f12de8e550979371a51e322754#r38841918
Thanks,
Niteesh
On Thu, Apr 30, 2020 at 5:58 AM Chris Johns <chrisj at rtems.org> wrote:
> It looks like there is something wrong with the rtems.org mail lists. I
> have pinged Amar to have a look.
> On 30/4/20 4:45 am, Niteesh G. S. wrote:
> > Please have a look at this if you missed it previously. :)
> > Thanks,
> > Niteesh.
> > On Tue, Apr 28, 2020 at 11:30 PM Niteesh G. S. <niteesh.gs at gmail.com
> > <mailto:niteesh.gs at gmail.com>> wrote:
> >     This is my first time writing shell scripts. If something seems like
> >     a hack or if there is a better of doing it. Please let me know.
> https://github.com/gs-niteesh/rtems-release/commit/70cbb5418ba68992a910844c3d6450ef4db17579
> >     On Tue, Apr 28, 2020 at 3:51 PM Chris Johns <chrisj at rtems.org
> >     <mailto:chrisj at rtems.org>> wrote:
> >         On 28/4/20 6:26 pm, Niteesh G. S. wrote:
> >          > On Tue, Apr 28, 2020 at 8:10 AM Chris Johns <chrisj at rtems.org
> >          > <mailto:chrisj at rtems.org <mailto:chrisj at rtems.org>>> wrote:
> >          >     On 28/4/20 11:51 am, Niteesh G. S. wrote:
> https://github.com/gs-niteesh/rtems-release/commit/8666bcd66066512f91194660817cd42cbb8c76e9
> >          >      > If it is okay for you, then I will send the patch to
> >         the mailing
> >          >     list.
> >          >     The repos list is now just the package names and the
> >         branch script
> >          >     as it
> >          >     is expects the repo name, i.e. .git at the end.
> >          > How should I do this? Shall I iterate over all the repos in
> >         rtems_repo
> >          > variable
> >          > and append '.git' to the end? This will happen right after the
> >          > declaration of the
> >          > variable.
> >         Yes this is fine.
> >          >     Also the rtems-releases repo needs to be added to the
> >         list of repos
> >          >     (and
> >          >     not packages).
> >          > Done.
> >          > We should avoid branching this repo, right?
> >         No lets branch it. We might as well be consistent in how we
> >         manage repos
> >         in the project. It makes procedures in the eng manual easier,
> >         i.e. just
> >         one procedure to cover them all.
> >          >     I think it would be a good idea to be able to run this
> >         script which
> >          >     means a way to switch the git clone from ssh to the git
> >         protocol. I
> >          >     recently added command line support to rtems-release so I
> >         suggest you
> >          >     borrow that code and add an option so you can switch the
> >         git protocol
> >          >     and test. I would also add a switch to push, i.e. by
> >         default a push is
> >          >     not done.
> >          > Should we take the URL from the user similar to how it is
> >         done in
> >          > rtems-release
> >          > or just ask if he wants to test? In this case, the user has
> >         to just pass
> >          > -t or something
> >          > to cmd line and it would download the sources from
> >         git://git.rtems.org/ <http://git.rtems.org/>
> >         Hmm lets start with an option to switch between the git and ssh
> >         protocols. I cannot see a use case where there is a completely
> >         different
> >         location for the repos. If that does arise it can be sorted out
> >         then.
> >         Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200430/533c9220/attachment-0001.html>
