rtems assembler
suyash singh
suyashsingh234 at gmail.com
Thu Apr 30 13:17:47 UTC 2020
I am using ubuntu 18.04 terminal
Here's the python script I wrote to find all include files and run clang
-fsanitize
# run with python3 in terminal
import subprocess
import os
relativedir="../bsps/sparc/erc32/btimer"
directory=os.path.join(os.getcwd(),"../")
file="btimer.c"
root_dir="ubsan"
arr=['clang','-target','sparc','-fsanitize=undefined',"-I../../../../../../rtems/5/sparc-rtems5/erc32/lib/include","-I../../../../../../rtems/5/sparc-rtems5/include/"]
for path, subdirs, files in os.walk(directory):
for subdir in subdirs:
if(subdir=="include"):
includepath=os.path.join(path,subdir)
idx=includepath.find("..")
arr.append("-I../../../../"+includepath[idx+3:])
arr.append(file)
subprocess.run(arr,cwd=relativedir, stdout=subprocess.PIPE)
#result=subprocess.run(['./a.out'],cwd=relativedir, stdout=subprocess.PIPE)
On Thu, Apr 30, 2020 at 6:44 PM Hesham Almatary <heshamelmatary at gmail.com>
wrote:
> On Thu, 30 Apr 2020 at 13:51, Joel Sherrill <joel at rtems.org> wrote:
>> On Thu, Apr 30, 2020 at 7:34 AM suyash singh <suyashsingh234 at gmail.com>
>> wrote:
>>> Hello,
>>> I was running clang UBSan on
>>> bsps/sparc/erc32/btimer/btimer.c
>>> and got error
>>> /usr/bin/as: unrecognized option '-Av8'
>>> clang-11: error: assembler command failed with exit code 1
>>> I am not sure but is it because clang is using wrong assembler?
>> I haven't seen anyone run into this in a long time. :)
>> In this case, it is likely one of two things:
>> + Look at your $PATH. Make sure the RTEMS tools are first.
>> + But in your case, I expect that it is because the clang didn't
>> know (somehow) to put the target name in front of the as.
>> Did you invoke it for sparc-rtems5? If so, then there is a
>> path through clang where it isn't looking at the target name.
> That’s likely to be the problem. I expect Suyash isn’t cross compiling
> with clang.
>> I also double checked the as manual to ensure -Av8 was in
>> fact a sparc option.
>> --joel
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
>> devel mailing list
>> devel at rtems.org
> Hesham
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200430/80629fcc/attachment-0001.html>
