rtems assembler
Hesham Almatary
heshamelmatary at gmail.com
Thu Apr 30 13:37:40 UTC 2020
On Thu, 30 Apr 2020 at 14:18, suyash singh <suyashsingh234 at gmail.com> wrote:
> I am using ubuntu 18.04 terminal
> Here's the python script I wrote to find all include files and run clang
> -fsanitize
> # run with python3 in terminal
> import subprocess
> import os
> relativedir="../bsps/sparc/erc32/btimer"
> directory=os.path.join(os.getcwd(),"../")
> file="btimer.c"
> root_dir="ubsan"
> arr=['clang','-target','sparc','-
target needs to be sparc-unknown-rtems5 to pick up the correct tools. Does
your clang support sparc backend? Can you try to compile and link some
simple C program with it?
fsanitize=undefined',"-I../../../../../../rtems/5/sparc-rtems5/erc32/lib/include","-I../../../../../../rtems/5/sparc-rtems5/include/"]
> for path, subdirs, files in os.walk(directory):
> for subdir in subdirs:
> if(subdir=="include"):
> includepath=os.path.join(path,subdir)
> idx=includepath.find("..")
> arr.append("-I../../../../"+includepath[idx+3:])
> arr.append(file)
> subprocess.run(arr,cwd=relativedir, stdout=subprocess.PIPE)
> #result=subprocess.run(['./a.out'],cwd=relativedir, stdout=subprocess.PIPE)
> On Thu, Apr 30, 2020 at 6:44 PM Hesham Almatary <heshamelmatary at gmail.com>
> wrote:
>> On Thu, 30 Apr 2020 at 13:51, Joel Sherrill <joel at rtems.org> wrote:
>>> On Thu, Apr 30, 2020 at 7:34 AM suyash singh <suyashsingh234 at gmail.com>
>>> wrote:
>>>> Hello,
>>>> I was running clang UBSan on
>>>> bsps/sparc/erc32/btimer/btimer.c
>>>> and got error
>>>> /usr/bin/as: unrecognized option '-Av8'
>>>> clang-11: error: assembler command failed with exit code 1
>>>> I am not sure but is it because clang is using wrong assembler?
>>> I haven't seen anyone run into this in a long time. :)
>>> In this case, it is likely one of two things:
>>> + Look at your $PATH. Make sure the RTEMS tools are first.
>>> + But in your case, I expect that it is because the clang didn't
>>> know (somehow) to put the target name in front of the as.
>>> Did you invoke it for sparc-rtems5? If so, then there is a
>>> path through clang where it isn't looking at the target name.
>> That’s likely to be the problem. I expect Suyash isn’t cross compiling
>> with clang.
>>> I also double checked the as manual to ensure -Av8 was in
>>> fact a sparc option.
>>> --joel
>>>> _______________________________________________
>>>> devel mailing list
>>>> devel at rtems.org
>>>> http://lists.rtems.org/mailman/listinfo/devel
>>> devel mailing list
>>> devel at rtems.org
>> Hesham
>> devel mailing list
>> devel at rtems.org
Hesham
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200430/d8b5a5b2/attachment.html>
