[PATCH RTEMS 7/7] libtests/openfirmware: Added a testsuite for openfirmware
Niteesh G. S.
niteesh.gs at gmail.com
Sun Aug 2 09:14:57 UTC 2020
Hello,
I went through some of my previous conversations to summarize the various
directories
suggested by people. Maybe this will help to come up with a conclusion.
In my first porting commit, I placed the files under cpukit/libfreebsd this
caused issues like
accessing BSP dependent functions like bsp_fdt_get() therefore Christian
suggested moving
the files to bsps/shared.
https://lists.rtems.org/pipermail/devel/2020-May/059959.html
I then posted the patches on the mailing lists after moving the files to
bsps/shared. After this
Sebastian suggested moving these back to cpukit since they are BSP
independent. And add
an API to register FDTs since this would allow for unit testing. But later
instead of API we
started using linker wrappers.
https://lists.rtems.org/pipermail/devel/2020-May/059978.html
https://lists.rtems.org/pipermail/devel/2020-June/060025.html
Gedare also suggested having the files in cpukit since this would allow for
easier synchronization
with FreeBSD.
https://lists.rtems.org/pipermail/devel/2020-May/059807.html
Thanks,
Niteesh.
On Thu, Jul 30, 2020 at 1:03 AM Gedare Bloom <gedare at rtems.org> wrote:
> On Wed, Jul 29, 2020 at 12:33 PM Christian Mauderer <oss at c-mauderer.de>
> wrote:
> > On 29/07/2020 20:21, Gedare Bloom wrote:
> > > On Wed, Jul 29, 2020 at 12:10 PM Christian Mauderer <oss at c-mauderer.de>
> wrote:
> > >> On 29/07/2020 19:55, Gedare Bloom wrote:
> > >>> On Wed, Jul 29, 2020 at 10:44 AM Christian Mauderer <
> oss at c-mauderer.de> wrote:
> > >>>> On 29/07/2020 18:07, Gedare Bloom wrote:
> > >>>>> On Wed, Jul 15, 2020 at 12:32 AM G S Niteesh Babu <
> niteesh.gs at gmail.com> wrote:
> > >>>>>> spec/build/testsuites/libtests/grp.yml | 3 +
> > >>>>>> .../testsuites/libtests/openfirmware01.yml | 20 +++
> > >>>>>> testsuites/libtests/openfirmware01/init.c | 147
> > >>>>>> .../openfirmware01/openfirmware01.doc | 29 ++++
> > >>>>>> .../openfirmware01/openfirmware01.scn | 2 +
> > >>>>>> testsuites/libtests/openfirmware01/some.c | 52 +++++++
> > >>>>>> testsuites/libtests/openfirmware01/some.dts | 54 +++++++
> > >>>>>> testsuites/libtests/openfirmware01/some.h | 15 ++
> > >>>>>> 8 files changed, 322 insertions(+)
> > >>>>>> create mode 100644
> spec/build/testsuites/libtests/openfirmware01.yml
> > >>>>>> create mode 100644 testsuites/libtests/openfirmware01/init.c
> > >>>>>> create mode 100644
> testsuites/libtests/openfirmware01/openfirmware01.doc
> > >>>>>> create mode 100644
> testsuites/libtests/openfirmware01/openfirmware01.scn
> > >>>>>> create mode 100644 testsuites/libtests/openfirmware01/some.c
> > >>>>>> create mode 100644 testsuites/libtests/openfirmware01/some.dts
> > >>>>>> create mode 100644 testsuites/libtests/openfirmware01/some.h
> > >>>>>> diff --git a/spec/build/testsuites/libtests/grp.yml
> b/spec/build/testsuites/libtests/grp.yml
> > >>>>>> index f1de6cd75f..56e84d2c89 100644
> > >>>>>> --- a/spec/build/testsuites/libtests/grp.yml
> > >>>>>> +++ b/spec/build/testsuites/libtests/grp.yml
> > >>>>>> @@ -11,6 +11,7 @@ install: []
> > >>>>>> ldflags:
> > >>>>>> - -Wl,--wrap=printf
> > >>>>>> - -Wl,--wrap=puts
> > >>>>>> +- -Wl,--wrap=bsp_fdt_get
> > >>>>>> links:
> > >>>>>> - role: build-dependency
> > >>>>>> uid: optbin2c
> > >>>>>> @@ -312,6 +313,8 @@ links:
> > >>>>>> uid: write
> > >>>>>> uid: writev
> > >>>>>> +- role: build-dependency
> > >>>>>> + uid: openfirmware01
> > >>>>>> type: build
> > >>>>>> use-after:
> > >>>>>> - rtemstest
> > >>>>>> diff --git a/spec/build/testsuites/libtests/openfirmware01.yml
> b/spec/build/testsuites/libtests/openfirmware01.yml
> > >>>>>> new file mode 100644
> > >>>>>> index 0000000000..8feb69eb1e
> > >>>>>> --- /dev/null
> > >>>>>> +++ b/spec/build/testsuites/libtests/openfirmware01.yml
> > >>>>>> @@ -0,0 +1,20 @@
> > >>>>>> +SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
> > >>>>>> +build-type: test-program
> > >>>>>> +cflags: []
> > >>>>>> +copyrights:
> > >>>>>> +- Copyright (C) 2020 Niteesh G S
> > >>>>>> +cppflags: []
> > >>>>>> +cxxflags: []
> > >>>>>> +enabled-by: true
> > >>>>>> +features: c cprogram
> > >>>>>> +includes: []
> > >>>>>> +ldflags: []
> > >>>>>> +links: []
> > >>>>>> +source:
> > >>>>>> +- testsuites/libtests/openfirmware01/init.c
> > >>>>>> +- testsuites/libtests/openfirmware01/some.c
> > >>>>>> +stlib: []
> > >>>>>> +target: testsuites/libtests/openfirmware01.exe
> > >>>>>> +type: build
> > >>>>>> +use-after: []
> > >>>>>> +use-before: []
> > >>>>>> diff --git a/testsuites/libtests/openfirmware01/init.c
> b/testsuites/libtests/openfirmware01/init.c
> > >>>>>> index 0000000000..fc38e6c513
> > >>>>>> --- /dev/null
> > >>>>>> +++ b/testsuites/libtests/openfirmware01/init.c
> > >>>>>> @@ -0,0 +1,147 @@
> > >>>>>> +/* SPDX-License-Identifier: BSD-2-Clause */
> > >>>>>> + * Copyright (C) <2020> Niteesh G S <niteesh.gs at gmail.com>
> > >>>>>> + * Redistribution and use in source and binary forms, with or
> without
> > >>>>>> + * modification, are permitted provided that the following
> conditions
> > >>>>>> + * are met:
> > >>>>>> + * 1. Redistributions of source code must retain the above
> copyright
> > >>>>>> + * notice, this list of conditions and the following
> disclaimer.
> > >>>>>> + * 2. Redistributions in binary form must reproduce the above
> copyright
> disclaimer in the
> > >>>>>> + * documentation and/or other materials provided with the
> distribution.
> > >>>>>> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND
> CONTRIBUTORS "AS IS"
> > >>>>>> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
> LIMITED TO, THE
> > >>>>>> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
> PARTICULAR PURPOSE
> > >>>>>> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
> CONTRIBUTORS BE
> > >>>>>> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
> EXEMPLARY, OR
> > >>>>>> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
> PROCUREMENT OF
> > >>>>>> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
> OR BUSINESS
> > >>>>>> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
> WHETHER IN
> > >>>>>> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
> OTHERWISE)
> > >>>>>> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
> ADVISED OF THE
> > >>>>>> + * POSSIBILITY OF SUCH DAMAGE.
> > >>>>>> +#ifdef HAVE_CONFIG_H
> > >>>>>> +#include "config.h"
> > >>>>>> +#endif
> > >>>>>> +#include <tmacros.h>
> > >>>>>> +#include <stdio.h>
> > >>>>>> +#include <stdlib.h>
> > >>>>>> +#include <libfdt.h>
> > >>>>>> +#include <sys/endian.h>
> > >>>>>> +#include <dev/ofw/openfirm.h>
> > >>>>>> +#include "some.h"
> > >>>>>> +#define BUF_SIZE 100
> > >>>>>> +const char rtems_test_name[] = "OpenFirmWare 01";
> > >>>>>> +const void *__wrap_bsp_fdt_get(void);
> > >>>>>> +const void *__real_bsp_fdt_get(void);
> > >>>>>> + if (some_bin != NULL) {
> > >>>>>> + return &some_bin[0];
> > >>>>>> + return __real_bsp_fdt_get();
> > >>>>>> +static void Init(rtems_task_argument arg)
> > >>>>>> + int rv;
> > >>>>>> + phandle_t d;
> > >>>>>> + phandle_t l;
> > >>>>>> + phandle_t t;
> > >>>>>> + phandle_t root;
> > >>>>>> + phandle_t temp;
> > >>>>>> + uint32_t *arr;
> > >>>>>> + char buf[BUF_SIZE];
> > >>>>>> + char *bufp;
> > >>>>>> + ssize_t buf_len;
> > >>>>>> + TEST_BEGIN();
> > >>>>>> + buf_len = sizeof(buf);
> > >>>>>> + * Cannot use fdt_path_offset to compare because
> > >>>>>> + * the OF interface uses the offset from the ftdp
> > >>>>>> + * to the node as phandle.
> > >>>>>> + root = OF_finddevice("/");
> > >>>>>> + rtems_test_assert(root == 56);
> > >>>>>> + root = OF_peer(0);
> > >>>>>> + d = OF_child(root);
> > >>>>>> + temp = OF_finddevice("/d");
> > >>>>>> + rtems_test_assert(d == temp);
> > >>>>>> + temp = OF_parent(d);
> > >>>>>> + rtems_test_assert(root == temp);
> > >>>>>> + rv = OF_getprop(d, "e", buf, buf_len);
> > >>>>>> + rtems_test_assert(rv != -1);
> > >>>>>> + rtems_test_assert(strcmp(buf, "f") == 0);
> > >>>>>> + rv = OF_hasprop(d, "g");
> > >>>>>> + rtems_test_assert(rv == 1);
> > >>>>>> + rv = OF_getproplen(root, "model");
> > >>>>>> + rtems_test_assert(rv == 2);
> > >>>>>> + rv = OF_nextprop(d, "e", buf, buf_len);
> > >>>>>> + rtems_test_assert(strcmp(buf, "g") == 0);
> > >>>>>> + l = OF_finddevice("/m at 1248");
> > >>>>>> + rv = OF_searchprop(l, "model", buf, buf_len);
> > >>>>>> + rtems_test_assert(strcmp(buf, "c") == 0);
> > >>>>>> + rv = OF_getprop_alloc(root, "compatible", (void **)&bufp);
> > >>>>>> + rtems_test_assert(strcmp(bufp, "a,b") == 0);
> > >>>>>> + OF_prop_free(bufp);
> > >>>>>> + rv = OF_getprop_alloc_multi(l, "n", sizeof(*arr), (void
> **)&arr);
> > >>>>>> + rtems_test_assert(arr[0] == htobe32(0xdeadbeef));
> > >>>>>> + rtems_test_assert(arr[1] == htobe32(0x12345678));
> > >>>>>> + rv = OF_getencprop_alloc_multi(l, "n", sizeof(*arr), (void
> **)&arr);
> > >>>>>> + rtems_test_assert(arr[0] == 0xdeadbeef);
> > >>>>>> + rtems_test_assert(arr[1] == 0x12345678);
> > >>>>>> + t = OF_finddevice("/t");
> > >>>>>> + rv = OF_nextprop(t, "u", buf, buf_len);
> > >>>>>> + rtems_test_assert(rv == 0);
> > >>>>> ok, so these are intended to be application-visible. The interface
> is
> > >>>>> not standard though, as far as I know. So, I think we need to
> ensure
> > >>>>> we provide an RTEMS-friendly namespace for this OF API, and make
> sure
> > >>>>> the header files are properly arranged for visibility/layering.
> > >>>>> Everything else seems fine to me in a quick glance.
> > >>>> Hello Gedare,
> > >>>> the interface is ported from FreeBSD. It's an internal one in
> FreeBSD
> > >>>> but I think it is useful for application drivers too.
> > >>>> What would you suggest regarding the namespace. I'm not a big fan of
> > >>>> changing imported FreeBSD code.
> > >>> Background: The problem we have to avoid is polluting the user
> > >>> namespace. Software in kernel space, such as FreeBSD and other
> > >>> monolithic kernels, don't have that problem.
> > >>> I haven't studied the usage closely, I guess the pinmux is the main
> > >>> thing, but I'd like to understand if the FreeBSD symbols need to be
> > >>> exposed.
> > >>> Would it be feasible to introduce an rtems-branded API for this
> stuff,
> > >>> and provide a wrapper in libbsd for compatibility? Imagine something
> > >>> like....
> > >>> <rtems/dev/openfirmware.h>
> > >>> rtems_openfirmware_finddevice(char *s);
> > >>> freebsd-compat:
> > >>> #define OF_finddevice rtems_openfirmware_finddevice
> > >>> You could even then reuse other ofw interfaces, like:
> > >>> linux-compat:
> > >>> #define of_finddevice rtems_openfirmware_finddevice
> > >>> Just for example.
> > >>> This way, we only pollute the namespace if someone pulls in the bsd
> library.
> > >>> If the FreeBSD symbols have to be available inside RTEMS to support
> > >>> drivers without libbsd, then I would rather see the symbols converted
> > >>> to macros that link to namespace-friendly functions instead.
> > >>> Gedare
> > >> The main problem was that the openfirmware stuff is ported from
> FreeBSD
> > >> and someone (don't remember exactly who, possible that it was me)
> > >> suggestet that the ported files should be placed in cpukit rather than
> > >> in the BSP section. With that it's quite hard to use the interfaces
> in a
> > >> BSP driver without installing some headers.
> > > Let's step back for one minute and determine the requirements for the
> > > ofw support.
> > > Clearly it needs to be available for BSP code to use.
> > > Does it need to be available for user application (non-BSP) code?
> > Not really. Maybe could be usefull for closed BSPs with drivers that are
> > not put back to RTEMS. But as an open source project I don't think that
> > we have to take these into account as long as non of us needs the
> feature.
> Then we don't need a public API. That is a bit easier. Closed BSPs can
> poke under the hood if they need to, and we don't need to really care
> as you say.
> > > Does it need to be available for any driver frameworks in cpukit?
> > Not as far as I can tell. Of course it would be possible to say that it
> > _is_ a driver framework.
> Right, but if the code base itself does not need to be accessed from
> within cpukit, then it doesn't need to be in the cpukit.
> > > Does it need to be available for libbsd?
> > Can be usefull to reduce the duplication of code in libbsd and RTEMS.
> In this case though, libbsd could still provide the headers, if the
> code can be found/linked through the installed rtems. So, it seems to
> me that we don't need to have public headers at all. Then, this entire
> piece of code can reside in the bsps/ layer and can be namespaced like
> other bsp code if necessary.
> > > I think answers to those 3 questions will help to decide what
> > > direction to proceed.
> > >>>> Best regards
> > >>>> Christian
> > >>>>>> + TEST_END();
> > >>>>>> + rtems_test_exit(0);
> > >>>>>> +#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
> > >>>>>> +#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
> > >>>>>> +#define CONFIGURE_MAXIMUM_TASKS 1
> > >>>>>> +#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
> > >>>>>> +#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> > >>>>>> +#include <rtems/confdefs.h>
> > >>>>>> \ No newline at end of file
> > >>>>>> diff --git
> a/testsuites/libtests/openfirmware01/openfirmware01.doc
> b/testsuites/libtests/openfirmware01/openfirmware01.doc
> > >>>>>> index 0000000000..a9d2085798
> > >>>>>> --- /dev/null
> > >>>>>> +++ b/testsuites/libtests/openfirmware01/openfirmware01.doc
> > >>>>>> @@ -0,0 +1,29 @@
> > >>>>>> +This file describes the directives and concepts tested by this
> test set.
> > >>>>>> +test set name: openfirmware01
> > >>>>>> +directives:
> > >>>>>> + - OF_peer
> > >>>>>> + - OF_child
> > >>>>>> + - OF_parent
> > >>>>>> + - OF_getproplen
> > >>>>>> + - OF_getprop
> > >>>>>> + - OF_getencprop
> > >>>>>> + - OF_hasprop
> > >>>>>> + - OF_searchprop
> > >>>>>> + - OF_searchencprop
> > >>>>>> + - OF_getprop_alloc
> > >>>>>> + - OF_getprop_alloc_multi
> > >>>>>> + - OF_getencprop_alloc
> > >>>>>> + - OF_getencprop_alloc_multi
> > >>>>>> + - OF_prop_free
> > >>>>>> + - OF_nextprop
> > >>>>>> + - OF_setprop
> > >>>>>> + - OF_canon
> > >>>>>> + - OF_finddevice
> > >>>>>> + - OF_package_to_path
> > >>>>>> +concepts:
> > >>>>>> + - Ensure that some openfimware functions work as expected.
> > >>>>>> diff --git
> a/testsuites/libtests/openfirmware01/openfirmware01.scn
> b/testsuites/libtests/openfirmware01/openfirmware01.scn
> > >>>>>> index 0000000000..38abbdfc45
> > >>>>>> --- /dev/null
> > >>>>>> +++ b/testsuites/libtests/openfirmware01/openfirmware01.scn
> > >>>>>> @@ -0,0 +1,2 @@
> > >>>>>> +*** BEGIN OF TEST OPENFIRMWARE 1 ***
> > >>>>>> +*** END OF TEST OPENFIRMWARE 1 ***
> > >>>>>> diff --git a/testsuites/libtests/openfirmware01/some.c
> b/testsuites/libtests/openfirmware01/some.c
> > >>>>>> index 0000000000..5eed911204
> > >>>>>> --- /dev/null
> > >>>>>> +++ b/testsuites/libtests/openfirmware01/some.c
> > >>>>>> @@ -0,0 +1,52 @@
> > >>>>>> + * Declarations for C structure representing binary file
> some.bin
> > >>>>>> + * WARNING: Automatically generated -- do not edit!
> > >>>>>> +#include <sys/types.h>
> > >>>>>> +const unsigned char some_bin[] = {
> > >>>>>> + 0xd0, 0x0d, 0xfe, 0xed, 0x00, 0x00, 0x01, 0xd8, 0x00, 0x00,
> 0x00, 0x38,
> > >>>>>> + 0x00, 0x00, 0x01, 0x90, 0x00, 0x00, 0x00, 0x28, 0x00, 0x00,
> 0x00, 0x11,
> > >>>>>> + 0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
> 0x00, 0x48,
> > >>>>>> + 0x00, 0x00, 0x01, 0x58, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
> 0x00, 0x00,
> > >>>>>> + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
> 0x00, 0x01,
> > >>>>>> + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00,
> 0x00, 0x04,
> > >>>>>> + 0x00, 0x00, 0x00, 0x00, 0x61, 0x2c, 0x62, 0x00, 0x00, 0x00,
> 0x00, 0x03,
> > >>>>>> + 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x0b, 0x00, 0x00,
> 0x00, 0x01,
> > >>>>>> + 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00,
> 0x00, 0x1a,
> > >>>>>> + 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00,
> 0x00, 0x02,
> > >>>>>> + 0x00, 0x00, 0x00, 0x26, 0x63, 0x00, 0x00, 0x00, 0x00, 0x00,
> 0x00, 0x01,
> > >>>>>> + 0x64, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00,
> 0x00, 0x02,
> > >>>>>> + 0x00, 0x00, 0x00, 0x09, 0x66, 0x00, 0x00, 0x00, 0x00, 0x00,
> 0x00, 0x03,
> > >>>>>> + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x2c, 0x00, 0x00,
> 0x00, 0x01,
> > >>>>>> + 0x68, 0x40, 0x30, 0x00, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00,
> 0x00, 0x01,
> > >>>>>> + 0x68, 0x40, 0x31, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00,
> 0x00, 0x04,
> > >>>>>> + 0x00, 0x00, 0x00, 0x2e, 0x00, 0x00, 0x00, 0x7b, 0x00, 0x00,
> 0x00, 0x02,
> > >>>>>> + 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01, 0x61, 0x6c,
> 0x69, 0x61,
> > >>>>>> + 0x73, 0x65, 0x73, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00,
> 0x00, 0x08,
> > >>>>>> + 0x00, 0x00, 0x00, 0x30, 0x2f, 0x6d, 0x40, 0x31, 0x32, 0x34,
> 0x38, 0x00,
> > >>>>>> + 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01, 0x6d, 0x40,
> 0x31, 0x32,
> > >>>>>> + 0x34, 0x38, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00,
> 0x00, 0x08,
> > >>>>>> + 0x00, 0x00, 0x00, 0x32, 0xde, 0xad, 0xbe, 0xef, 0x12, 0x34,
> 0x56, 0x78,
> 0x00, 0x34,
> > >>>>>> + 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00,
> 0x00, 0x04,
> > >>>>>> + 0x00, 0x00, 0x00, 0x3a, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00,
> 0x00, 0x01,
> > >>>>>> + 0x6f, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00,
> 0x00, 0x00,
> > >>>>>> + 0x00, 0x00, 0x00, 0x42, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00,
> 0x00, 0x01,
> > >>>>>> + 0x71, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00,
> 0x00, 0x02,
> > >>>>>> + 0x00, 0x00, 0x00, 0x44, 0x73, 0x00, 0x00, 0x00, 0x00, 0x00,
> 0x00, 0x02,
> > >>>>>> + 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01, 0x74, 0x00,
> 0x00, 0x00,
> 0x00, 0x46,
> > >>>>>> + 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00,
> 0x00, 0x02,
> > >>>>>> + 0x00, 0x00, 0x00, 0x09, 0x63, 0x6f, 0x6d, 0x70, 0x61, 0x74,
> 0x69, 0x62,
> > >>>>>> + 0x6c, 0x65, 0x00, 0x23, 0x61, 0x64, 0x64, 0x72, 0x65, 0x73,
> 0x73, 0x2d,
> > >>>>>> + 0x63, 0x65, 0x6c, 0x6c, 0x73, 0x00, 0x23, 0x73, 0x69, 0x7a,
> 0x65, 0x2d,
> > >>>>>> + 0x63, 0x65, 0x6c, 0x6c, 0x73, 0x00, 0x6d, 0x6f, 0x64, 0x65,
> 0x6c, 0x00,
> > >>>>>> + 0x67, 0x00, 0x77, 0x00, 0x6b, 0x00, 0x6e, 0x00, 0x6c, 0x69,
> 0x6e, 0x75,
> > >>>>>> + 0x78, 0x2c, 0x70, 0x68, 0x61, 0x6e, 0x64, 0x6c, 0x65, 0x00,
> 0x70, 0x00,
> > >>>>>> + 0x72, 0x00, 0x75, 0x00,
> > >>>>>> +const size_t some_bin_size = sizeof(some_bin);
> > >>>>>> diff --git a/testsuites/libtests/openfirmware01/some.dts
> b/testsuites/libtests/openfirmware01/some.dts
> > >>>>>> index 0000000000..ac15825b17
> > >>>>>> --- /dev/null
> > >>>>>> +++ b/testsuites/libtests/openfirmware01/some.dts
> > >>>>>> @@ -0,0 +1,54 @@
> > >>>>>> + * Copyright (c) 2015 embedded brains GmbH. All rights reserved.
> > >>>>>> + * embedded brains GmbH
> > >>>>>> + * Dornierstr. 4
> > >>>>>> + * 82178 Puchheim
> > >>>>>> + * Germany
> > >>>>>> + * <rtems at embedded-brains.de>
> > >>>>>> + * The license and distribution terms for this file may be
> > >>>>>> + * found in the file LICENSE in this distribution or at
> > >>>>>> + * http://www.rtems.org/license/LICENSE.
> > >>>>>> +/dts-v1/;
> > >>>>>> + compatible = "a,b";
> > >>>>>> + #address-cells = <1>;
> > >>>>>> + #size-cells = <2>;
> > >>>>>> + model = "c";
> > >>>>>> + d {
> > >>>>>> + e = "f";
> > >>>>>> + g;
> > >>>>>> + h at 0 {
> > >>>>>> + h at 1 {
> > >>>>>> + w = <123>;
> > >>>>>> + aliases {
> > >>>>>> + k = "/m at 1248";
> > >>>>>> + l: m at 1248 {
> > >>>>>> + n = <0xdeadbeef 0x12345678>;
> > >>>>>> + o {
> > >>>>>> + p;
> > >>>>>> + q {
> > >>>>>> + r = "s";
> > >>>>>> + t {
> > >>>>>> + u = <&l>;
> > >>>>>> diff --git a/testsuites/libtests/openfirmware01/some.h
> b/testsuites/libtests/openfirmware01/some.h
> > >>>>>> index 0000000000..e2e0135e68
> > >>>>>> --- /dev/null
> > >>>>>> +++ b/testsuites/libtests/openfirmware01/some.h
> > >>>>>> @@ -0,0 +1,15 @@
> > >>>>>> + * Extern declarations for C structure representing binary file
> some.bin
> > >>>>>> +#ifndef __some_h
> > >>>>>> +#define __some_h
> > >>>>>> +extern const unsigned char some_bin[];
> > >>>>>> +extern const size_t some_bin_size;
> > >>>>>> +#endif
> > >>>>>> 2.17.1
> > >>>>> _______________________________________________
> > >>>>> devel mailing list
> > >>>>> devel at rtems.org
> > >>>>> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200802/c552eedb/attachment-0001.html>
