Error while building realview_pbx_a9 BSP with the new build system
Utkarsh Rai utkarsh.rai60 at gmail.com
Mon Aug 3 16:28:24 UTC 2020
On Mon, Aug 3, 2020 at 9:56 PM Sebastian Huber <
> On 03/08/2020 18:17, Utkarsh Rai wrote:
> > When I use the above branch I get the following error on './waf
> > install ' -
> > Build failed
> > Traceback (most recent call last):
> >   File
> "/home/utkarsh/new_build/rtems/.waf-2.0.20-36f5354d605298f6a89c09e0c7ef6c1d/waflib/Task.py",
> > line 180, in process
> >     ret=self.run()
> >   File
> "/home/utkarsh/new_build/rtems/.waf-2.0.20-36f5354d605298f6a89c09e0c7ef6c1d/waflib/Build.py",
> > line 554, in run
> >     x.parent.mkdir()
> >   File
> "/home/utkarsh/new_build/rtems/.waf-2.0.20-36f5354d605298f6a89c09e0c7ef6c1d/waflib/Node.py",
> > line 179, in mkdir
> >     self.parent.mkdir()
> >   File
> > line 179, in mkdir
> >     self.parent.mkdir()
> >   File
> > line 179, in mkdir
> >     self.parent.mkdir()
> >   File
> > line 179, in mkdir
> >     self.parent.mkdir()
> >   File
> > line 179, in mkdir
> >     self.parent.mkdir()
> >   File
> > line 188, in mkdir
> >     raise Errors.WafError('Could not create the directory %r'%self)
> > WafError: Could not create the directory /opt/rtems
> This is good, since it shows that you build as a normal user and not as
> root.
> Did you read the documentation of the new build system?
Sorry, I forgot about that part. It builds now.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200803/f36cdd23/attachment-0001.html>
