Error while building realview_pbx_a9 BSP with the new build system
Mon Aug 3 16:26:28 UTC 2020
On 03/08/2020 18:17, Utkarsh Rai wrote:
> When I use the above branch I get the following error on './waf
> install ' -
> Build failed
> Traceback (most recent call last):
>   File
> "/home/utkarsh/new_build/rtems/.waf-2.0.20-36f5354d605298f6a89c09e0c7ef6c1d/waflib/Task.py",
> line 180, in process
>     ret=self.run()
>   File
> "/home/utkarsh/new_build/rtems/.waf-2.0.20-36f5354d605298f6a89c09e0c7ef6c1d/waflib/Build.py",
> line 554, in run
>     x.parent.mkdir()
>   File
> "/home/utkarsh/new_build/rtems/.waf-2.0.20-36f5354d605298f6a89c09e0c7ef6c1d/waflib/Node.py",
> line 179, in mkdir
>     self.parent.mkdir()
>   File
> line 179, in mkdir
>     self.parent.mkdir()
>   File
> line 179, in mkdir
>     self.parent.mkdir()
>   File
> line 179, in mkdir
>     self.parent.mkdir()
>   File
> line 179, in mkdir
>     self.parent.mkdir()
>   File
> line 188, in mkdir
>     raise Errors.WafError('Could not create the directory %r'%self)
> WafError: Could not create the directory /opt/rtems
This is good, since it shows that you build as a normal user and not as
root.
Did you read the documentation of the new build system?
