Error while building realview_pbx_a9 BSP with the new build system
Utkarsh Rai utkarsh.rai60 at gmail.com
Mon Aug 3 17:20:58 UTC 2020
Yes.
https://ftp.rtems.org/pub/rtems/people/sebh/user.pdf - For steps on using
the build system( Chapter 7).
https://ftp.rtems.org/pub/rtems/people/sebh/eng.pdf- For the internals of
the build system ( Chapter 9.), Although I don't understand everything in
this perfectly well as of yet.
On Mon, Aug 3, 2020 at 10:47 PM Sebastian Huber <
> On 03/08/2020 18:32, Gedare Bloom wrote:
> > On Mon, Aug 3, 2020 at 10:27 AM Sebastian Huber
> > <sebastian.huber at embedded-brains.de>  wrote:
> >> On 03/08/2020 18:25, Gedare Bloom wrote:
> >>> On Mon, Aug 3, 2020 at 10:17 AM Utkarsh Rai<utkarsh.rai60 at gmail.com>
>  wrote:
> >>>> When I use the above branch I get the following error on './waf
> install ' -
> >>>> Build failed
> >>>> Traceback (most recent call last):
> >>>>     File
> "/home/utkarsh/new_build/rtems/.waf-2.0.20-36f5354d605298f6a89c09e0c7ef6c1d/waflib/Task.py",
> line 180, in process
> >>>>       ret=self.run()
> >>>>     File
> "/home/utkarsh/new_build/rtems/.waf-2.0.20-36f5354d605298f6a89c09e0c7ef6c1d/waflib/Build.py",
> line 554, in run
> >>>>       x.parent.mkdir()
> >>>>     File
> "/home/utkarsh/new_build/rtems/.waf-2.0.20-36f5354d605298f6a89c09e0c7ef6c1d/waflib/Node.py",
> line 179, in mkdir
> >>>>       self.parent.mkdir()
> >>>>     File
> line 179, in mkdir
> >>>>       self.parent.mkdir()
> >>>>     File
> line 179, in mkdir
> >>>>       self.parent.mkdir()
> >>>>     File
> line 179, in mkdir
> >>>>       self.parent.mkdir()
> >>>>     File
> line 179, in mkdir
> >>>>       self.parent.mkdir()
> >>>>     File
> line 188, in mkdir
> >>>>       raise Errors.WafError('Could not create the directory %r'%self)
> >>>> WafError: Could not create the directory /opt/rtems
> >>> Most likely you don't have a /opt/rtems directory, and that is being
> >>> used as a default prefix for install. Try to set the prefix/install
> >>> point yourself to a directory you 'own' already.
> >>> The other option is to create /opt/rtems, and chown to your user, e.g.,
> >>> sudo mkdir /opt/rtems
> >>> sudo chown utkarsh:utkarsh /opt/rtems
> >>> this works fine for single-user *nix development
> >> I think we should cover this somehow in the documentation. This looks
> >> like a common issue for someone using this for the first time.
> > We have something:
> > https://docs.rtems.org/branches/master/user/start/prefixes.html
> > But probably that will be skipped by a lot of people looking for a
> > "Quicker" start.
> Utkarsh, did look look at some documentation before you started to use
> the new build system?
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200803/0c76d23b/attachment.html>
