legacy stack or libbsd
Heinz Junkes junkes at fhi-berlin.mpg.de
Tue Aug 4 16:04:24 UTC 2020
Because the libbsd stack does not support some things yet (e.g. ntp) I have to call different
functions at rtems_init in EPICS. Therefore, when building EPICS for a target, I need
to know which stack the target was built with.
Viele Grüße
Heinz Junkes
Experience directly varies with equipment ruined.
> On 4. Aug 2020, at 15:44, Joel Sherrill <joel at rtems.org> wrote:
> On Tue, Aug 4, 2020 at 8:10 AM Heinz Junkes <junkes at fhi-berlin.mpg.de> wrote:
> I'm trying to figure out when compiling a third party software (EPICS),
> whether the RTEMS for a target bsp was created with the legacy stack or
> uses the libbsd stack.
> Unfortunately I have found some different definitions:
> in target.cfg : RTEMS_HAS_NETWORKING
> in bsp.cfg : HAS_NETWORKING
> in header files #if defined(RTEMS_NETWORKING)
> Which one should I take best?
> I tend to RTEMS_HAS_NETWORKING in target.cfg ;-)
> rtems/score/cpuopts.h defines it in the installed headers. but
> I think either bsp.cfg or target.cfg would be trustworthy. target.cfg
> has more info in it.
> This doesn't help you know before building which network stacks
> a BSP supports though.
> --joel
> Danke Heinz_______________________________________________
> devel mailing list
> devel at rtems.org
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200804/6cece71b/attachment-0001.bin>
