legacy stack or libbsd
Wed Aug 5 00:23:40 UTC 2020
On 5/8/20 2:04 am, Heinz Junkes wrote:
> Because the libbsd stack does not support some things yet (e.g. ntp)
I have PTP running on libbsd. I currently have no time (ha) to clean up the work
and create a patch. It requires some extra support in the score.
> I have to call different
> functions at rtems_init in EPICS. Therefore, when building EPICS for a target, I need
> to know which stack the target was built with.
The rtems_waf waf checks the header file. The compile check is:
https://git.rtems.org/rtems_waf/tree/rtems.py#n355
