legacy stack or libbsd
Wed Aug 5 05:00:08 UTC 2020
On 5/8/20 2:13 pm, Gedare Bloom wrote:
> On Tue, Aug 4, 2020 at 6:41 PM Chris Johns <chrisj at rtems.org> wrote:
>> On 5/8/20 10:23 am, Chris Johns wrote:
>>> On 5/8/20 2:04 am, Heinz Junkes wrote:
>>>> Because the libbsd stack does not support some things yet (e.g. ntp)
>>> I have PTP running on libbsd. I currently have no time (ha) to clean up the work
> Is it precisely no time? ;)
About +/- 0, I am not sure which!
>>> and create a patch. It requires some extra support in the score.
> Is the hacked approach available, or you will get around to it eventually?
I will get back around to it. There are 2 sets of changes. In PTP itself a
change is to add kqueue support because select in libbsd does not support
signals. The PTP code runs a number of timers and they run of an alarm signal.
The other piece of support is to the score to bring in the FreeBSD kern_ntp
support to sit besides the timercounters.
There will be some unresolved issues like RTC driver support. I have this
commented out as I do not need it.
I would like to upstream the code however adding kqueue will trip that interface
on FreeBSD and may be others so I am not sure how much work that will create.
