legacy stack or libbsd
Wed Aug 5 04:13:54 UTC 2020
On Tue, Aug 4, 2020 at 6:41 PM Chris Johns <chrisj at rtems.org> wrote:
> On 5/8/20 10:23 am, Chris Johns wrote:
> > On 5/8/20 2:04 am, Heinz Junkes wrote:
> >> Because the libbsd stack does not support some things yet (e.g. ntp)
> > I have PTP running on libbsd. I currently have no time (ha) to clean up the work
Is it precisely no time? ;)
> > and create a patch. It requires some extra support in the score.
Is the hacked approach available, or you will get around to it eventually?
> >> I have to call different
> >> functions at rtems_init in EPICS. Therefore, when building EPICS for a target, I need
> >> to know which stack the target was built with.
> > The rtems_waf waf checks the header file. The compile check is:
> > https://git.rtems.org/rtems_waf/tree/rtems.py#n355
> I should also add rtems_waf detects libbsd with the following header check ...
> https://git.rtems.org/rtems_waf/tree/rtems_bsd.py#n88
> Chris
> devel mailing list
> devel at rtems.org
