[PATCH] psxhdrs/strncpy/stpncpy: Fix string turncation warning
Aschref Ben-Thabet
aschref.ben-thabet at embedded-brains.de
Wed Aug 5 11:54:33 UTC 2020
From: Aschref Ben Thabet <aschref.ben-thabet at embedded-brains.de>
Since we need to test the strncpy function, using a character array with
a fixed array size in this case in place of character pointer can avoid
the string turncation warning.
testsuites/psxtests/psxhdrs/string/stpncpy.c | 7 +++----
testsuites/psxtests/psxhdrs/string/strncpy.c | 7 +++----
2 files changed, 6 insertions(+), 8 deletions(-)
diff --git a/testsuites/psxtests/psxhdrs/string/stpncpy.c b/testsuites/psxtests/psxhdrs/string/stpncpy.c
index f81752de76..f7433a136f 100644
--- a/testsuites/psxtests/psxhdrs/string/stpncpy.c
+++ b/testsuites/psxtests/psxhdrs/string/stpncpy.c
@@ -40,12 +40,11 @@
int test( void )
- char *dest = "Hello world";
- char *src = "Dude";
- size_t num = 2;
+ char src[] = "Dude";
+ char dest[ sizeof( src ) ];
char *result;
- result = stpncpy( dest, src, num );
+ result = stpncpy( dest, src, sizeof( dest ) );
return ( result != NULL );
diff --git a/testsuites/psxtests/psxhdrs/string/strncpy.c b/testsuites/psxtests/psxhdrs/string/strncpy.c
index 50b64b3d57..e80d6f6e64 100644
--- a/testsuites/psxtests/psxhdrs/string/strncpy.c
+++ b/testsuites/psxtests/psxhdrs/string/strncpy.c
@@ -35,16 +35,15 @@
#endif
int test( void );
int test( void )
- char *dest = "Hello";
- char *src = "World";
+ char src[] = "World";
char *result;
- result = strncpy( dest, src, 3 );
+ result = strncpy( dest, src, sizeof( dest ) );
2.26.2
