[PATCH] fix Wunused-function deleting unused static functions in dl_tests
Wed Aug 5 15:50:19 UTC 2020
On Wed, Aug 5, 2020 at 5:52 AM Aschref Ben-Thabet
<aschref.ben-thabet at embedded-brains.de> wrote:
> From: Aschref Ben Thabet <aschref.ben-thabet at embedded-brains.de>
> the functions dl_close and  dl_call are not needed for this test,
> deleting them will avoid the warning of Wunused-function.
>  testsuites/libtests/dl10/dl-load.c | 21 ---------------------
>  1 file changed, 21 deletions(-)
> diff --git a/testsuites/libtests/dl10/dl-load.c b/testsuites/libtests/dl10/dl-load.c
> index dee1d6e9cc..a9d60a7e5a 100644
> --- a/testsuites/libtests/dl10/dl-load.c
> +++ b/testsuites/libtests/dl10/dl-load.c
> @@ -96,27 +96,6 @@ static void* dl_load_obj(const char* name, bool has_unresolved)
>    return handle;
> -static void dl_close (void* handle)
> -  int r;
> -  printf ("handle: %p closing\n", handle);
> -  r = dlclose (handle);
> -  if (r != 0)
> -    printf("dlclose failed: %s\n", dlerror());
> -  rtems_test_assert (r == 0);
> -static int dl_call (void* handle, const char* func)
> -  call_sig call = dlsym (handle, func);
> -  if (call == NULL)
> -    printf("dlsym failed: symbol not found: %s\n", func);
> -    return 1;
> -  call ();
> -  return 0;
This looks like it will leave 2 blank lines in a row, after deletion.
Delete one of the blank lines also. send revision with -v2.
>  int dl_load_test(void)
> 2.26.2
> devel mailing list
> devel at rtems.org
