Name of the primary network interface, how to find in bsp header files?
Sat Aug 8 01:50:22 UTC 2020
On 8/8/20 5:12 am, Heinz Junkes wrote:
> it works great with the libbsd-stack.
I do not think it is a good idea rely on the RTEMS_BSP_NETWORK_DRIVER_NAME
setting in libbsd. I have not questioned it before now as it has been used
internally in the tests but exporting it as an interface is something else. It
works for a specific case of target but it does not for others, for example the
Xilinx Zynq has 2 MACs (cgem0, cgem1), a PC has a wide range of interfaces.
> That is then also definitely the way to go.
How would cgem1 on a Zynq be specified if RTEMS_BSP_NETWORK_DRIVER_NAME is
cgem0? Also there is nothing stopping me changing RTEMS_BSP_NETWORK_DRIVER_NAME
to cgem1 so how does that get handled?
After 25 years doing this I have learnt to be careful about what we export and
depend on.
> I just remembered in the legacy stack that the network driver name
> was set in some BSPs. But this was probably not continuous. And with the new ones, it is no longer possible.
As a default it may be OK however it would be nice or important to allow this to
be changed.
How does an EPICS build for Linux on a PC deal with this given there is a large
number of possible interface names?
